par freeanimal
#209999
ci joint mon rapport de scan :
############################## | UsbFix V 7.805 | [Recherche]
Utilisateur: Oliver (Administrateur) # OLIVER-PC
Mis à jour le 27/11/2014 par El Desaparecido - SosVirus
Lancé à 12:47:18 | 29/11/2014
Site Web :
Changelog :
Détection en Live :
Contact :
MB: ASUSTeK COMPUTER INC. (P8H77-M LE)
CPU: Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz
GC: NVIDIA GeForce GT 610
RAM -> [Total : 8074 Mo | Free : 6217 Mo]
OS: Microsoftâ„¢ Windows 7 Ultimate (6.1.7601 64-Bit) Service Pack 1
WB: Internet Explorer : 11.00.9600.16428
WB: Google Chrome : 39.0.2171.71
AV: avast! Antivirus [(!) Désactivé |A jour]
AS: avast! Antivirus [(!) Désactivé |A jour]
AS: Malwarebytes Anti-Malware : 2.0.3.1025
FW: Windows Firewall [Actif]
SC: Security Center [Actif]
WU: Windows Update [Actif]
C:\ (%SystemDrive%) -> Disque fixe # 150 Go (50 Go libre(s) - 33%) [] # NTFS
D:\ -> Disque fixe # 781 Go (464 Go libre(s) - 59%) [] # NTFS
F:\ -> Disque fixe # 100 Mo (32 Mo libre(s) - 32%) [System Reserved] # NTFS
G:\ -> Disque amovible # 7 Go (7 Go libre(s) - 100%) [Transcend] # FAT32
H:\ -> Disque amovible # 7 Go (7 Go libre(s) - 100%) [Transcend] # FAT32
F2 - HKLM\..\Winlogon : [Userinit] userinit.exe,
04 - HKCU\..\Run : [SkyDrive] "C:\Users\Oliver\AppData\Local\Microsoft\SkyDrive\SkyDrive.exe" /background
04 - HKCU\..\Run : [EPLTarget\P0000000000000000] C:\Windows\system32\spool\DRIVERS\x64\3\E_YATII2E.EXE /EPT "EPLTarget\P0000000000000000" /M "L210 Series"
04 - HKCU\..\Run : [CCleaner Monitoring] "C:\Program Files\CCleaner\CCleaner64.exe" /MONITOR
04 - HKCU\..\Run : [GoogleChromeAutoLaunch_30BB2D3B5F6B7A5646DD40BF478A2406] "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --no-startup-window
04 - HKLM\..\Run : [USB3MON] "C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe"
04 - HKLM\..\Run : [QuickTime Task] "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
04 - HKLM\..\Run : [EEventManager] "C:\Program Files (x86)\Epson Software\Event Manager\EEventManager.exe"
04 - HKLM\..\Run : [SunJavaUpdateSched] "C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe"
04 - [x64] HKLM\..\Run : [RTHDVCPL] C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe -s
04 - [x64] HKLM\..\Run : [IgfxTray] C:\Windows\system32\igfxtray.exe
04 - [x64] HKLM\..\Run : [HotKeysCmds] C:\Windows\system32\hkcmd.exe
04 - [x64] HKLM\..\Run : [Persistence] C:\Windows\system32\igfxpers.exe
04 - [x64] HKLM\..\Run : [NvBackend] "C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe"
04 - HKU\S-1-5-21-3443909541-3692748824-3244828282-1000\..\Run : [SkyDrive] "C:\Users\Oliver\AppData\Local\Microsoft\SkyDrive\SkyDrive.exe" /background
04 - HKU\S-1-5-21-3443909541-3692748824-3244828282-1000\..\Run : [EPLTarget\P0000000000000000] C:\Windows\system32\spool\DRIVERS\x64\3\E_YATII2E.EXE /EPT "EPLTarget\P0000000000000000" /M "L210 Series"
04 - HKU\S-1-5-21-3443909541-3692748824-3244828282-1000\..\Run : [CCleaner Monitoring] "C:\Program Files\CCleaner\CCleaner64.exe" /MONITOR
04 - HKU\S-1-5-21-3443909541-3692748824-3244828282-1000\..\Run : [GoogleChromeAutoLaunch_30BB2D3B5F6B7A5646DD40BF478A2406] "C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --no-startup-window
04 - HKU\S-1-5-21-3443909541-3692748824-3244828282-1001\..\Run : [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun
04 - HKU\S-1-5-21-3443909541-3692748824-3244828282-1001\..\RunOnce : [mctadmin] C:\Windows\System32\mctadmin.exe
Info :
Info :
Détection en Live :
################## | Hijack |
J'ai été infecté avec une clé USB et j'ai lancé USB Fix mais lors du nettoyage il me met un message :
Autoit Error
Line 40435 (File "C:\Usbfix\Usbfix.exe
Error: Subscript used ou non accessible variable
Que dois-je faire ?
Merci de vos réponse.
Freeanimal
#210001
Je m'appelle buckhulk... ^^
à savoir que je ne prend pas en charge les ordinateur encore sous XP
ZHPCleaner ICI
-Ensuite pour bien continuer il va falloir que tu fasses un ZHPDiag : ZHPDiag ICI
On va tout recommencer si tu veux bien ! ;)
par freeanimal
#210084
Bonjour Buckhulk
Merci pour ton aide ! Voilà j'ai fait comme tu me l'a demandé :
1\ télécharger ZHP Cleaner, puis scan + rapport et réparer+rapport.
2\ télécharger ZHP Diag, puis recherche complète+rapport
Je te joint les 3 rapports en deux messages car je ne peux mettre que 60000 caractères . J'espère avoir bien fait les choses car je suis novice en informatique.
ZHPCleaner v2014.11.29.240 by Nicolas Coolman (29/11/2014)
~ Run by Oliver (Administrator) (30/11/2014 12:47:01)
~ Forum : https://forum.nicolascoolman.fr
~ Facebook : https://www.facebook.com/nicolascoolman1
~ State version : Version OK
~ Type : Scanner
~ Report : C:\Users\Oliver\Desktop\ZHPCleaner.txt
~ Quarantine : C:\Users\Oliver\AppData\Roaming\ZHP\ZHPCleaner_Quarantine.txt
~ UAC : Activate
~ Windows 7, 64-bit Service Pack 1 (Build 7601)
---\\ Service. (0)
~ Aucun élément malicieux trouvé.
---\\ Navigateur internet. (2)
TROUVà‰ IE Params: Tabs ( res://ieframe.dll/tabswelcome.htm )
TROUVà‰ Chrome URL: "hxxps://www.yahoo.com?fr=hp-avast&type=avastbcl","www.google.com"]
---\\ Fichier hôte. (1)
~ Le fichier hôte est légitime. (21)
---\\ Tà¢che planifiée. (0)
---\\ Explorateur ( Dossiers, Fichiers ). (2)
TROUVà‰: C:\Users\Oliver\AppData\Roaming\inst.exe [ - ] (Adware.Pirrit)
TROUVà‰: C:\Users\Oliver\AppData\Roaming\inst.exe [ - ] (Adware.GenericTask)
---\\ Base de Registres ( Clés, Valeurs, Données ). (7)
TROUVà‰: HKCR\CLSID\{687F8E94-45D6-4685-A63D-1C7A140EF847} [DeltaSync Class] (Toolbar.DeltaSearch)
TROUVà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{100EB1FD-D03E-47FD-81F3-EE91287F9465} [ShopperReports.dll] (Adware.ShopperReports)
TROUVà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{258C9770-1713-4021-8D7E-1F184A2BD754} [ShoppingReport.dll] (Adware.ShoppingReport)
TROUVà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{2EECD738-5844-4A99-B4B6-146BF802613B} [BabylonToolbar.dll] (PUP.Babylon)
TROUVà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{97F2FF5B-260C-4CCF-834A-2DDA4E29E39E} [BabylonToolbar.dll] (PUP.Babylon)
TROUVà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{98889811-442D-49DD-99D7-DC866BE87DBC} [BabylonToolbarTlbr.dll] (PUP.Babylon)
TROUVà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{BDEA95CF-F0E6-41E0-BD3D-B00F39A4E939} [ShoppingReport.dll] (Adware.ShoppingReport)
---\\ Bilan de la réparation
~ Aucune réparation effectuée.
~ Ce navigateur est absent (Mozilla Firefox)
~ Ce navigateur est absent (Opera Software)
~ Réparation annulée par l'utilisateur (Internet Explorer)
End of clean at 12:49:40
~ ZHPCleaner v2014.11.29.240 by Nicolas Coolman (29/11/2014)
~ Run by Oliver (Administrator) (30/11/2014 12:50:18)
~ Type : Réparer
~ UAC : Activate
---\\ Service. (0)
REMPLACà‰ IE Params: Tabs ( res://ieframe.dll/tabswelcome.htm )
REMPLACà‰ Chrome URL: "hxxps://www.yahoo.com?fr=hp-avast&type=avastbcl","www.google.com"]
---\\ Explorateur ( Dossiers, Fichiers ). (1)
DEPLACà‰: C:\Users\Oliver\AppData\Roaming\inst.exe [ - ] (Adware.Pirrit)
SUPPRIMà‰: HKCR\CLSID\{687F8E94-45D6-4685-A63D-1C7A140EF847} [DeltaSync Class] (Toolbar.DeltaSearch)
SUPPRIMà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{100EB1FD-D03E-47FD-81F3-EE91287F9465} [ShopperReports.dll] (Adware.ShopperReports)
SUPPRIMà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{258C9770-1713-4021-8D7E-1F184A2BD754} [ShoppingReport.dll] (Adware.ShoppingReport)
SUPPRIMà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{2EECD738-5844-4A99-B4B6-146BF802613B} [BabylonToolbar.dll] (PUP.Babylon)
SUPPRIMà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{97F2FF5B-260C-4CCF-834A-2DDA4E29E39E} [BabylonToolbar.dll] (PUP.Babylon)
SUPPRIMà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{98889811-442D-49DD-99D7-DC866BE87DBC} [BabylonToolbarTlbr.dll] (PUP.Babylon)
SUPPRIMà‰: [X64] HKLM\SOFTWARE\Microsoft\Internet Explorer\Extension Compatibility\{BDEA95CF-F0E6-41E0-BD3D-B00F39A4E939} [ShoppingReport.dll] (Adware.ShoppingReport)
~ Réparation réalisée avec succès.
End of clean at 12:52:55
par freeanimal
#210088
Deuxième message et troisième rapport de ZHP Diag
~ Traduit par Nicolas Coolman
~ Etat de la version : Version à jour.
~ Liste blanche : Désactivée par l'utilisateur
---\\ Navigateurs Internet
MSIE: Internet Explorer v11.0.9600.17420
GCIE: Google Chrome v39.0.2171.71 (Defaut)
~ Langage: Français
Windows 7 Ultimate, 64-bit Service Pack 1 (Build 7601)
~ Windows Operating System - Windows(R) 7, OEM_COA_NSLP channel
Windows ID Activation : OK
~ Windows Partial Key : J9JQ4
Windows License : OK
~ Windows Remaining Initializations Number : 3
Avast Free Antivirus v10.0.2208
Malwarebytes Anti-Malware version 2.0.3.1025
ESET Online Scanner v3
Windows Defender W7 (Activate)
CCleaner v5.00
Adobe Flash Player 15 Plugin
Adobe Reader XI
~ Processor: Intel64 Family 6 Model 58 Stepping 9, GenuineIntel
~ Operating System: 64 Bits
Total RAM: 8074.1 MB (73% free)
System drive C: has 49 GB (32%) free of 150 GB
~ Computer Name: OLIVER-PC
~ User Name: Oliver
~ All Users Names: UpdatusUser, Oliver, HomeGroupUser$, Administrateur,
~ Unselected Option: None
Logged in as Administrator
~ System Unit : C:\
~ %AppZHP% : C:\Users\Oliver\AppData\Roaming\ZHP\
~ %AppData% : C:\Users\Oliver\AppData\Roaming\
~ %Desktop% : C:\Users\Oliver\Desktop\
~ %Favorites% : C:\Users\Oliver\Favorites\
~ %LocalAppData% : C:\Users\Oliver\AppData\Local\
~ %StartMenu% : C:\Users\Oliver\AppData\Roaming\Microsoft\Windows\Start Menu\
~ %Windir% : C:\Windows\
C: Hard drive, Flash drive, Thumb drive (Free 49 Go of 150 Go)
D: Hard drive, Flash drive, Thumb drive (Free 464 Go of 781 Go)
F: Hard drive, Flash drive, Thumb drive (Free 0 Go of 0 Go)
[HKLM\SOFTWARE\Microsoft\Security Center\Svc] AntiSpywareOverride: OK
[HKLM\SOFTWARE\Microsoft\Security Center\Svc] AntiVirusOverride: OK
[HKLM\SOFTWARE\Microsoft\Security Center\Svc] FirewallOverride: OK
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system] EnableLUA: OK
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\NOHIDDEN] CheckedValue: OK
[HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced] Start_ShowNetConn: Modified
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Folder\Hidden\SHOWALL] CheckedValue: OK
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Associations] Application: OK
[HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon] Shell: OK
[HKLM\SYSTEM\CurrentControlSet\Services\COMSysApp] Type: OK
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\Results\Install] LastSuccessTime : OK
~ Security Center: 41 Scanned in 00mn 00s
[MD5.332FEAB1435662FC6C672E25BEB37BE3] - (.Microsoft Corporation - Explorateur Windows.) (.25/02/2011 - 13:19:30.) -- C:\Windows\Explorer.exe [2871808]
[MD5.94355C28C1970635A31B3FE52EB7CEBA] - (.Microsoft Corporation - Application de démarrage de Windows.) (.14/07/2009 - 08:39:52.) -- C:\Windows\System32\Wininit.exe [129024]
[MD5.6FC2819A4F80AAB2DADEDFC1EFEE3C3F] - (.Microsoft Corporation - Extensions Internet pour Win32.) (.06/11/2014 - 09:17:24.) -- C:\Windows\System32\wininet.dll [2365440]
[MD5.8CEBD9D0A0A879CDE9F36F4383B7CAEA] - (.Microsoft Corporation - Application d‚ouverture de session Windows.) (.17/07/2014 - 09:07:24.) -- C:\Windows\System32\Winlogon.exe [455168]
[MD5.067FA52BFB59A56110A12312EF9AF243] - (.Microsoft Corporation - Bibliothèque de licences.) (.21/11/2010 - 10:24:16.) -- C:\Windows\System32\sppcomapi.dll [232448]
[MD5.FA886682CFC5D36718D3E436AACF10B9] - (.Microsoft Corporation - Ancillary Function Driver for WinSock.) (.30/05/2014 - 13:45:52.) -- C:\Windows\system32\Drivers\AFD.sys [497152]
[MD5.02062C0B390B7729EDC9E69C680A6F3C] - (.Microsoft Corporation - ATAPI IDE Miniport Driver.) (.14/07/2009 - 08:52:21.) -- C:\Windows\system32\Drivers\atapi.sys [24128]
[MD5.B8BD2BB284668C84865658C77574381A] - (.Microsoft Corporation - CD-ROM File System Driver.) (.14/07/2009 - 06:19:47.) -- C:\Windows\system32\Drivers\Cdfs.sys [92160]
[MD5.F036CE71586E93D94DAB220D7BDF4416] - (.Microsoft Corporation - SCSI CD-ROM Driver.) (.21/11/2010 - 10:23:47.) -- C:\Windows\system32\Drivers\Cdrom.sys [147456]
[MD5.9BB2EF44EAA163B29C4A4587887A0FE4] - (.Microsoft Corporation - DFS Namespace Client Driver.) (.21/11/2010 - 10:24:32.) -- C:\Windows\system32\Drivers\DfsC.sys [102400]
[MD5.97BFED39B6B79EB12CDDBFEED51F56BB] - (.Microsoft Corporation - High Definition Audio Bus Driver.) (.21/11/2010 - 10:23:47.) -- C:\Windows\system32\Drivers\HDAudBus.sys [122368]
[MD5.FA55C73D4AFFA7EE23AC4BE53B4592D3] - (.Microsoft Corporation - Pilote de port i8042.) (.14/07/2009 - 06:19:57.) -- C:\Windows\system32\Drivers\i8042prt.sys [105472]
[MD5.AF9B39A7E7B6CAA203B3862582E9F2D0] - (.Microsoft Corporation - IP Network Address Translator.) (.14/07/2009 - 07:10:03.) -- C:\Windows\system32\Drivers\IpNat.sys [116224]
[MD5.A5D9106A73DC88564C825D317CAC68AC] - (.Microsoft Corporation - Windows NT SMB Minirdr.) (.27/04/2011 - 09:40:40.) -- C:\Windows\system32\Drivers\MRxSmb.sys [158208]
[MD5.09594D1089C523423B32A4229263F068] - (.Microsoft Corporation - MBT Transport driver.) (.21/11/2010 - 10:23:51.) -- C:\Windows\system32\Drivers\netBT.sys [261632]
[MD5.1A29A59A4C5BA6F8C85062A613B7E2B2] - (.Microsoft Corporation - Pilote du système de fichiers NT.) (.24/01/2014 - 09:37:55.) -- C:\Windows\system32\Drivers\ntfs.sys [1684928]
[MD5.0086431C29C35BE1DBC43F52CC273887] - (.Microsoft Corporation - Pilote de port parallèle.) (.14/07/2009 - 07:00:41.) -- C:\Windows\system32\Drivers\Parport.sys [97280]
[MD5.471815800AE33E6F1C32FB1B97C490CA] - (.Microsoft Corporation - RAS L2TP mini-port/call-manager driver.) (.21/11/2010 - 10:24:33.) -- C:\Windows\system32\Drivers\Rasl2tp.sys [129536]
[MD5.1B6163C503398B23FF8B939C67747683] - (.Microsoft Corporation - Microsoft RDP Device redirector.) (.21/11/2010 - 10:25:07.) -- C:\Windows\system32\Drivers\rdpdr.sys [165888]
[MD5.548260A7B8654E024DC30BF8A7C5BAA4] - (.Microsoft Corporation - SMB Transport driver.) (.14/07/2009 - 07:09:09.) -- C:\Windows\system32\Drivers\smb.sys [93184]
[MD5.DDAD5A7AB24D8B65F8D724F5C20FD806] - (.Microsoft Corporation - TDI Translation Driver.) (.21/11/2010 - 10:24:32.) -- C:\Windows\system32\Drivers\tdx.sys [119296]
[MD5.DF8126BD41180351A093A3AD2FC8903B] - (.Microsoft Corporation - Pilote de cliché instantané du volume.) (.25/02/2011 - 13:25:38.) -- C:\Windows\system32\Drivers\volsnap.sys [296320]
Mes images (My Pictures) : 2/2 (Modified)
~ Mes Favoris (My Favorites) : 1/18
~ Mes Documents (My Documents) : 2/339
~ Mon Bureau (My Desktop) : 1/10
~ Menu demarrer (Programs) : 1/30
~ Hidden Files: Scanned in 00mn 00s
---\\ Processus lancés
[MD5.4F46EA70C7579052F764D0F9B81D23C2] - (.NVIDIA Corporation - NVIDIA Update Backend.) -- C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe [1797064] [PID.2096]
[MD5.0EC83E2DA29365048CBEB9A9A963BDFA] - (.Microsoft Corporation - Microsoft OneDrive.) -- C:\Users\Oliver\AppData\Local\Microsoft\SkyDrive\SkyDrive.exe [277672] [PID.2140]
[MD5.F89773DFA9B8C95A3AC2AF1E7D99E483] - (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) -- C:\Program Files (x86)\Malwarebytes Anti-Malware\mbam.exe [7229752] [PID.2828]
[MD5.7515EC02E1F288107C95D5C195381235] - (.Intel Corporation - Intel(R) USB 3.0 Monitor.) -- C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe [292088] [PID.3772]
[MD5.46D3D19A4745B67DCA6692AFAB0E136D] - (.SEIKO EPSON CORPORATION - EEventManager Application.) -- C:\Program Files (x86)\Epson Software\Event Manager\EEventManager.exe [1058912] [PID.3808]
[MD5.FFB8CB731D62EC434A552680E0F8EC1A] - (.AVAST Software - avast! Antivirus.) -- C:\Program Files\AVAST Software\Avast\AvastUI.exe [5226600] [PID.3856]
[MD5.14D6542607ACD4B2D1DDB1A36E0D8813] - (.Oracle Corporation - Java(TM) Update Scheduler.) -- C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe [271744] [PID.3864]
[MD5.3CFB25DB09EB90FD2BD4C89D75611E6D] - (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe [856904] [PID.2076]
[MD5.17D0F31B84A09B648A662AD5C06B5600] - (.Nicolas Coolman - ZHPDiag.) -- C:\Program Files (x86)\ZHPDiag\ZHPDiag.exe [8132608] [PID.5044]
[MD5.CDA9313E34887A111B8309B55BCDCD82] - (.NVIDIA Corporation - Stereo Vision Control Panel API Server.) -- C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe [411936] [PID.944]
[MD5.E3F7EC811923F3F1A77B185F22638E5E] - (.AVAST Software - avast! Service.) -- C:\Program Files\AVAST Software\Avast\AvastSvc.exe [50344] [PID.1376]
[MD5.177FF6608B48638D4066726F3A3F8444] - (...) -- C:\Program Files (x86)\Adobe\Photoshop Elements 5.0\PhotoshopElementsFileAgent.exe [102400] [PID.1340]
[MD5.C5679E5186B2FC95BC76A8A9870D5456] - (.Adobe Systems Incorporated - Adobe Acrobat Update Service.) -- C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe [64704] [PID.1736]
[MD5.E536856E96A7605EBF580D62A868E5FE] - (...) -- C:\Windows\SysWOW64\ASGT.exe [55296] [PID.2040]
[MD5.3F56903E124E820AEECE6D471583C6C1] - (.Apple Inc. - Bonjour Service.) -- C:\Program Files (x86)\Bonjour\mDNSResponder.exe [238888] [PID.2384]
[MD5.C44B44E24B929631D9D7368F5B2B40CF] - (.Intel Corporation - Intel(R) Dynamic Application Loader Host In.) -- C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe [161560] [PID.2516]
[MD5.6D8A2EE4244630B290A837E79C0F37A1] - (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) -- C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe [1871160] [PID.2552]
[MD5.09D4503CBB6ADB3A54E7C7A75090B728] - (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) -- C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe [968504] [PID.2820]
[MD5.75F29D77B0540FCF47EE3BE000BBABDA] - (.Intel Corporation - Local Manageability Service.) -- C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe [277784] [PID.4684]
[MD5.193AD338F2A64D17300AD640ADFA5D0A] - (.Intel Corporation - User Notification Service.) -- C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe [363800] [PID.5052]
C:\Users\Oliver\AppData\Local\Google\Chrome\User Data\Default\Preferences
---\\ Liste des dossiers d'extension Google Chrome
~ Google Lines Browser: 0 Scanned in 00mn 00s
P2 - FPN: [HKLM] [@adobe.com/FlashPlayer] - (...) -- C:\Windows\system32\Macromed\Flash\NPSWF64_15_0_0_239.dll
P2 - FPN: [HKLM] [@Microsoft.com/NpCtrl,version=1.0] - (. Microsoft Corporation - 5.1.30514.0.) -- C:\Program Files\Microsoft Silverlight\5.1.30514.0\npctrl.dll
~ Firefox Browser: 2 Scanned in 00mn 00s
R0 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = https://www.google.com
R0 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = https://go.microsoft.com
R0 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = https://go.microsoft.com
R1 - HKCU\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = https://go.microsoft.com
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = https://go.microsoft.com
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = https://go.microsoft.com
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Extensions Off Page = about:noadd-ons
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Security Risk Page = about:securityrisk
R1 - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = https://go.microsoft.com
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\AboutURLs,Tabs = https://google.com
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page = https://go.microsoft.com
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL = https://go.microsoft.com
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL = https://go.microsoft.com
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Extensions Off Page = about:noadd-ons
R1 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\Main,Security Risk Page = about:securityrisk
R3 - URLSearchHook: Microsoft Url Search Hook [64Bits] - {CFBFAE00-17A6-11D0-99CB-00C04FD64497} . (.Microsoft Corporation - Navigateur Internet.) (11.00.9600.17239 (winblue_gdr.140724-2228)) -- C:\Windows\SysWOW64\ieframe.dll
R4 - HKLM\SOFTWARE\Microsoft\Internet Explorer\PhishingFilter,EnabledV8 = 1
R4 - HKLM\SOFTWARE\Wow6432Node\Microsoft\Internet Explorer\PhishingFilter,EnabledV8 = 1
~ IE Browser: 18 Scanned in 00mn 00s
~ Keys: Scanned in 00mn 00s
~ Le fichier hôte est sain (The hosts file is clean) (21)
---\\ Browser Helper Objects de navigateur (O2)
O2 - BHO: E-Web Print [64Bits] - {201CF130-E29C-4E5C-A73F-CD197DEFA6AE} . (.SEIKO EPSON CORPORATION - ewps_tb.) -- C:\Program Files (x86)\Epson Software\E-Web Print\ewps_tb.dll
O2 - BHO: Java(tm) Plug-In SSV Helper [64Bits] - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} . (.Oracle Corporation - Java(TM) Platform SE binary.) -- C:\Program Files (x86)\Java\jre7\bin\ssv.dll
O2 - BHO: avast! Online Security [64Bits] - {8E5E2654-AD2D-48bf-AC2D-D17F00898D06} . (.AVAST Software - IE Webrep plugin.) -- C:\Program Files\AVAST Software\Avast\aswWebRepIE.dll
O2 - BHO: Programme d‚aide de l‚Assistant de connexion au compte Microsoft [64Bits] - {9030D464-4C02-4ABF-8ECC-5164760863C6} . (.Microsoft Corp. - Microsoft® Windows Live ID Login Helper.) -- C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WindowsLiveLogin.dll
O2 - BHO: Google Toolbar Helper [64Bits] - {AA58ED58-01DD-4d91-8333-CF10577473F7} . (.Google Inc. - Google Toolbar.) -- C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
O2 - BHO: Java(tm) Plug-In 2 SSV Helper [64Bits] - {DBC80044-A445-435b-BC74-9C25C1C588A9} . (.Oracle Corporation - Java(TM) Platform SE binary.) -- C:\Program Files (x86)\Java\jre7\bin\jp2ssv.dll
~ BHO: 9 Scanned in 00mn 00s
---\\ Applications lancées au démarrage du système (O4)
O4 - HKLM\..\Run: [RTHDVCPL] . (.Realtek Semiconductor - Gestionnaire audio HD Realtek.) -- C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe =>.Realtek Semiconductor Corp
O4 - HKLM\..\Run: [IgfxTray] . (.Intel Corporation - igfxTray Module.) -- C:\Windows\system32\igfxtray.exe
O4 - HKLM\..\Run: [HotKeysCmds] . (.Intel Corporation - hkcmd Module.) -- C:\Windows\system32\hkcmd.exe
O4 - HKLM\..\Run: [Persistence] . (.Intel Corporation - persistence Module.) -- C:\Windows\system32\igfxpers.exe
O4 - HKLM\..\Run: [NvBackend] . (.NVIDIA Corporation - NVIDIA Update Backend.) -- C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe
O4 - HKCU\..\Run: [SkyDrive] . (.Microsoft Corporation - Microsoft OneDrive.) -- C:\Users\Oliver\AppData\Local\Microsoft\SkyDrive\SkyDrive.exe
O4 - HKCU\..\Run: [EPLTarget\P0000000000000000] . (.SEIKO EPSON CORPORATION - EPSON Status Monitor 3.) -- C:\Windows\system32\spool\DRIVERS\x64\3\E_YATII2E.exe =>.Epson Seiko Corporation
O4 - HKCU\..\Run: [CCleaner Monitoring] . (.Piriform Ltd - CCleaner.) -- C:\Program Files\CCleaner\CCleaner64.exe =>.Piriform Ltd
O4 - HKLM\..\Wow6432Node\Run: [USB3MON] . (.Intel Corporation - Intel(R) USB 3.0 Monitor.) -- C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe
O4 - HKLM\..\Wow6432Node\Run: [QuickTime Task] . (.Apple Inc. - QuickTime Task.) -- C:\Program Files (x86)\QuickTime\QTTask.exe
O4 - HKLM\..\Wow6432Node\Run: [EEventManager] . (.SEIKO EPSON CORPORATION - EEventManager Application.) -- C:\Program Files (x86)\Epson Software\Event Manager\EEventManager.exe
O4 - HKLM\..\Wow6432Node\Run: [AvastUI.exe] . (.AVAST Software - avast! Antivirus.) -- C:\Program Files\AVAST Software\Avast\AvastUI.exe
O4 - HKLM\..\Wow6432Node\Run: [SunJavaUpdateSched] . (.Oracle Corporation - Java(TM) Update Scheduler.) -- C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe =>.Oracle Corporation
O4 - HKUS\S-1-5-21-3443909541-3692748824-3244828282-1000\..\Run: [SkyDrive] . (.Microsoft Corporation - Microsoft OneDrive.) -- C:\Users\Oliver\AppData\Local\Microsoft\SkyDrive\SkyDrive.exe
O4 - HKUS\S-1-5-21-3443909541-3692748824-3244828282-1000\..\Run: [EPLTarget\P0000000000000000] . (.SEIKO EPSON CORPORATION - EPSON Status Monitor 3.) -- C:\Windows\system32\spool\DRIVERS\x64\3\E_YATII2E.exe =>.Epson Seiko Corporation
O4 - HKUS\S-1-5-21-3443909541-3692748824-3244828282-1000\..\Run: [CCleaner Monitoring] . (.Piriform Ltd - CCleaner.) -- C:\Program Files\CCleaner\CCleaner64.exe =>.Piriform Ltd
---\\ Invisibilité de l'icône d'options IE dans le panneau de Configuration (O5)
O5 - control.ini: [HKLM\..\Control Panel] inetcpl.cpl=no
~ IE Control Panel: 1 Scanned in 00mn 00s
---\\ Winsock hijacker (Layered Service Provider) (O10)
O10 - WLSP:\000000000001\Winsock LSP File . (.Microsoft Corporation - Network Location Awareness 2.) -- C:\Windows\system32\NLAapi.dll
O10 - WLSP:\000000000002\Winsock LSP File . (.Microsoft Corporation - Fournisseur Shim d‚affectation de noms de messagerie.) -- C:\Windows\system32\napinsp.dll
O10 - WLSP:\000000000003\Winsock LSP File . (.Microsoft Corporation - Fournisseur d‚espace de noms PNRP.) -- C:\Windows\system32\pnrpnsp.dll
O10 - WLSP:\000000000004\Winsock LSP File . (.Microsoft Corporation - Fournisseur d‚espace de noms PNRP.) -- C:\Windows\system32\pnrpnsp.dll
O10 - WLSP:\000000000005\Winsock LSP File . (.Microsoft Corporation - Fournisseur de service Sockets 2.0 de Microsoft Windows.) -- C:\Windows\system32\mswsock.dll =>.Microsoft Corporation
O10 - WLSP:\000000000006\Winsock LSP File . (.Microsoft Corporation - LDAP RnR Provider DLL.) -- C:\Windows\system32\winrnr.dll
O10 - WLSP:\000000000007\Winsock LSP File . (.Microsoft Corp. - Microsoft® Windows Live ID Namespace Provider.) -- C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.dll =>.Microsoft Corporation
O10 - WLSP:\000000000008\Winsock LSP File . (.Microsoft Corp. - Microsoft® Windows Live ID Namespace Provider.) -- C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.dll =>.Microsoft Corporation
O10 - WLSP:\000000000009\Winsock LSP File . (.Apple Inc. - Bonjour Namespace Provider.) -- C:\Program Files (x86)\Bonjour\mdnsNSP.dll
~ Winsock: 9 Scanned in 00mn 00s
O17 - HKLM\System\CCS\Services\Tcpip\..\{51F65F25-C863-47BD-B818-0F72B5F63AD1}: DhcpNameServer = 192.168.1.1
O17 - HKLM\System\CS1\Services\Tcpip\..\{51F65F25-C863-47BD-B818-0F72B5F63AD1}: DhcpNameServer = 192.168.1.1
O17 - HKLM\System\CS2\Services\Tcpip\..\{51F65F25-C863-47BD-B818-0F72B5F63AD1}: DhcpNameServer = 192.168.1.1
O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1
~ Domain: Scanned in 00mn 00s
O18 - Filter: text/xml [64Bits] - {807563E5-5146-11D5-A672-00B0D022E945} . (.Microsoft Corporation - Microsoft Office XML MIME Filter.) -- C:\Program Files\Common Files\Microsoft Shared\OFFICE12\MSOXMLMF.dll =>.Microsoft Corporation
O20 - Winlogon Notify: igfxcui . (.Intel Corporation - igfxdev Module.) -- C:\Windows\System32\igfxdev.dll
O20 - AppInit_DLLs: . (.NVIDIA Corporation - NVIDIA shim initialization dll, Version 335.) - C:\Windows\system32\nvinitx.dll
~ AppInit DLL: Scanned in 00mn 00s
---\\ Clé de Registre autorun ShellServiceObjectDelayLoad (SSO/SSODL) (O21)
O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - CLSID or File not found.
~ SSODL: 1 Scanned in 00mn 00s
O23 - Service: Adobe Active File Monitor V5 (AdobeActiveFileMonitor5.0) . (...) - C:\Program Files (x86)\Adobe\Photoshop Elements 5.0\PhotoshopElementsFileAgent.exe
O23 - Service: Adobe Acrobat Update Service (AdobeARMservice) . (.Adobe Systems Incorporated - Adobe Acrobat Update Service.) - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
O23 - Service: ASGT (ASGT) . (...) - C:\Windows\SysWOW64\ASGT.exe
O23 - Service: avast! Antivirus (avast! Antivirus) . (.AVAST Software - avast! Service.) - C:\Program Files\AVAST Software\Avast\AvastSvc.exe
O23 - Service: Service Bonjour (Bonjour Service) . (.Apple Inc. - Bonjour Service.) - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
O23 - Service: Epson Scanner Service (EpsonScanSvc) . (.Seiko Epson Corporation - Epson Scanner Service (64bit).) - C:\Windows\system32\EscSvc64.exe
O23 - Service: EPSON V3 Service4(05) (EPSON_PM_RPCV4_05) . (.SEIKO EPSON CORPORATION - EPSON Status Monitor 3.) - C:\Program Files\Common Files\EPSON\EPW!3 SSRP\E_WT50RP.exe =>.Epson Seiko Corporation
O23 - Service: Service Google Update (gupdate) (gupdate) . (.Google Inc. - Programme d'installation de Google.) - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe =>.Google Inc
O23 - Service: Intel(R) Capability Licensing Service Interface (Intel(R) Capability Licensing Service Interface) . (.Intel(R) Corporation - Intel(R) Capability Licensing Service Inter.) - C:\Program Files\Intel\iCLS Client\HeciServer.exe
O23 - Service: Intel(R) Dynamic Application Loader Host Interface Service (jhi_service) . (.Intel Corporation - Intel(R) Dynamic Application Loader Host In.) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
O23 - Service: Intel(R) Management and Security Application Local Manageme (LMS) . (.Intel Corporation - Local Manageability Service.) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
O23 - Service: (MBAMScheduler) . (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) - C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe
O23 - Service: (MBAMService) . (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) - C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) . (.NVIDIA Corporation - NVIDIA Driver Helper Service, Version 335.2.) - C:\Windows\system32\nvvsvc.exe
O23 - Service: NVIDIA Update Service Daemon (nvUpdatusService) . (.NVIDIA Corporation - NVIDIA Settings Update Manager.) - C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Update Core\daemonu.exe
O23 - Service: Skype Updater (SkypeUpdate) . (.Skype Technologies - Skype Updater Service.) - C:\Program Files (x86)\Skype\Updater\Updater.exe
O23 - Service: NVIDIA Stereoscopic 3D Driver Service (Stereo Service) . (.NVIDIA Corporation - Stereo Vision Control Panel API Server.) - C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe
O23 - Service: Intel(R) Management and Security Application User Notificat (UNS) . (.Intel Corporation - User Notification Service.) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe
~ Services: 18 Scanned in 00mn 07s
---\\ Enumération Active Desktop & MHTML Editor (O24)
O24 - Default MHTML Editor: Last - .(...) - (.not file.)
~ Desktop Component: 4 Scanned in 00mn 00s
---\\ Enumère les données de BootExecute (BEX) (O34)
O34 - HKLM BootExecute: (autocheck autochk *) - File not found
~ BEX: 1 Scanned in 00mn 00s
---\\ Tà¢ches planifiées en automatique (O39)
[MD5.F79623288F2A357AB20288B5DC4F452A] [APT] [Adobe Flash Player Updater] (.Adobe Systems Incorporated.) -- C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe [267440]
[MD5.4BB7714617D50D77FCDA6B0182FD8A9A] [APT] [avast! Emergency Update] (.AVAST Software.) -- C:\Program Files\AVAST Software\Avast\AvastEmUpdate.exe [857888]
[MD5.2E4EE47FBD9BB663A5220DBC38579986] [APT] [CCleanerSkipUAC] (.Piriform Ltd.) -- C:\Program Files\CCleaner\CCleaner.exe [5282584]
[MD5.506708142BC63DABA64F2D3AD1DCD5BF] [APT] [GoogleUpdateTaskMachineCore] (.Google Inc..) -- C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [116648]
[MD5.506708142BC63DABA64F2D3AD1DCD5BF] [APT] [GoogleUpdateTaskMachineUA] (.Google Inc..) -- C:\Program Files (x86)\Google\Update\GoogleUpdate.exe [116648]
[MD5.00000000000000000000000000000000] [APT] [{09FF2DE5-71DC-41F8-8029-849B9175DA86}] (...) -- C:\Users\Oliver\Downloads\mp3gain-win-full-1_2_5.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{34DE3D19-39D7-4FAD-8CC1-6F8E146529C8}] (...) -- C:\Users\Oliver\Downloads\MSReaderPPCFRASetup.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{510A8553-E6D2-4ADD-8B6A-E1B8966C8764}] (...) -- C:\Users\Oliver\Downloads\FR_fr_DP5_DL_20100602.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{6EE15E8D-CA58-4914-A1C2-B892F090AE37}] (...) -- E:\LaCie.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{8005AE53-865F-4A38-B74A-609EA26C8E4A}] (...) -- C:\Users\Oliver\Downloads\esetsmartinstaller_enu.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{98DF8ECB-29E9-47BC-8DD0-342CD4CA76E6}] (...) -- C:\Users\Oliver\Downloads\Rider_2_PC_jeu_gratuit.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{AE868D7F-E445-4C53-9286-FA0EF8687FEC}] (...) -- D:\Personnal DATA\Mon site DATA\setup hofmann france.exe (.not file.) [0]
[MD5.AA1FFCCE383A227144FD62A019CD27CE] [APT] [{F435C670-98E1-494C-B804-0B7598BBE25D}] (.ESET.) -- D:\Applications - Logiciels - Anti virus\Anti virus\esetsmartinstaller_enu.exe [2322184]
O39 - APT: Adobe Flash Player Updater - (.Adobe Systems Incorporated.) -- C:\Windows\Tasks\Adobe Flash Player Updater.job [1002]
O39 - APT: Adobe Flash Player Updater - (.Adobe Systems Incorporated.) -- C:\Windows\System32\Tasks\Adobe Flash Player Updater [1002]
O39 - APT: GoogleUpdateTaskMachineCore - (.Google Inc..) -- C:\Windows\Tasks\GoogleUpdateTaskMachineCore.job [1066]
O39 - APT: GoogleUpdateTaskMachineCore - (.Google Inc..) -- C:\Windows\System32\Tasks\GoogleUpdateTaskMachineCore [1066]
O39 - APT: GoogleUpdateTaskMachineUA - (.Google Inc..) -- C:\Windows\Tasks\GoogleUpdateTaskMachineUA.job [1070]
O39 - APT: GoogleUpdateTaskMachineUA - (.Google Inc..) -- C:\Windows\System32\Tasks\GoogleUpdateTaskMachineUA [1070]
~ Scheduled Task: 19 Scanned in 00mn 01s
---\\ Composants installés (ActiveSetup Installed Components) (O40)
O40 - ASIC: Microsoft Windows Media Player [64Bits] - >{22d6f312-b0f6-11d0-94ab-0080c74c7e95} . (.Microsoft Corporation - Ressources du Lecteur Windows Media.) -- C:\Windows\System32\wmploc.dll =>.Microsoft Corporation
O40 - ASIC: Microsoft Windows Media Player 12.0 [64Bits] - {22d6f312-b0f6-11d0-94ab-0080c74c7e95} . (.Microsoft Corporation - Windows Media Player Extension.) -- C:\Windows\SysWOW64\wmpdxm.dll =>.Microsoft Corporation
O40 - ASIC: Themes Setup [64Bits] - {2C7339CF-2B09-4501-B3F3-F3508C9228ED} . (.Microsoft Corporation - API Windows Theme.) -- C:\Windows\System32\themeui.dll
O40 - ASIC: Internet Explorer [64Bits] - {2D46B6DC-2207-486B-B523-A557E6D54B47} . (.Microsoft Corporation - Interpréteur de commandes Windows.) -- C:\Windows\system32\cmd.exe =>.Microsoft Corporation
O40 - ASIC: Microsoft Windows [64Bits] - {44BBA840-CC51-11CF-AAFA-00AA00B6015C} . (.Microsoft Corporation - Windows Mail.) -- C:\Program Files (x86)\Windows Mail\WinMail.exe =>.Microsoft Corporation
O40 - ASIC: Browsing Enhancements [64Bits] - {630b1da0-b465-11d1-9948-00c04f98bbc9} . (.Microsoft Corporation - Extension Shell dossier FTP Microsoft Internet Explorer..) -- C:\Windows\System32\msieftp.dll
O40 - ASIC: Microsoft Windows Media Player [64Bits] - {6BF52A52-394A-11d3-B153-00C04F79FAA6} . (.Microsoft Corporation - Ressources du Lecteur Windows Media.) -- C:\Windows\System32\wmploc.dll =>.Microsoft Corporation
O40 - ASIC: Windows Desktop Update [64Bits] - {89820200-ECBD-11cf-8B85-00AA005B4340} . (.Microsoft Corporation - DLL commune du shell Windows.) -- C:\Windows\System32\shell32.dll
O40 - ASIC: Web Platform Customizations [64Bits] - {89820200-ECBD-11cf-8B85-00AA005B4383} . (.Microsoft Corporation - Utilitaire d'initialisation d'Internet Explorer par utilisateur.) -- C:\Windows\System32\ie4uinit.exe
O40 - ASIC: (no name) [64Bits] - {89B4C1CD-B018-4511-B0A1-5476DBF70820} . (.Microsoft Corporation - Microsoft .NET IE SECURITY REGISTRATION.) -- C:\Windows\system32\mscories.dll
~ Active Setup: 10 Scanned in 00mn 00s
---\\ Pilotes lancés au démarrage du système (O41)
O41 - Driver: C:\Windows\System32\drivers\afd.sys (AFD) . (.Microsoft Corporation - Ancillary Function Driver for WinSock.) - C:\Windows\system32\drivers\afd.sys
O41 - Driver: (aswRdr) . (.AVAST Software - avast! WFP Redirect Driver.) - C:\Windows\system32\drivers\aswRdr2.sys
O41 - Driver: (aswSnx) . (.AVAST Software - avast! Virtualization Driver.) - C:\Windows\system32\drivers\aswSnx.sys
O41 - Driver: (aswSP) . (.AVAST Software - avast! self protection module.) - C:\Windows\system32\drivers\aswSP.sys
O41 - Driver: (blbdrive) . (.Microsoft Corporation - BLB Drive Driver.) - C:\Windows\System32\DRIVERS\blbdrive.sys
O41 - Driver: (cdrom) . (.Microsoft Corporation - SCSI CD-ROM Driver.) - C:\Windows\System32\DRIVERS\cdrom.sys
O41 - Driver: C:\Windows\System32\cscsvc.dll (CSC) . (.Microsoft Corporation - Windows Client Side Caching Driver.) - C:\Windows\System32\drivers\csc.sys
O41 - Driver: C:\Windows\System32\drivers\dfsc.sys (DfsC) . (.Microsoft Corporation - DFS Namespace Client Driver.) - C:\Windows\System32\Drivers\dfsc.sys
O41 - Driver: C:\Windows\System32\drivers\discache.sys (discache) . (.Microsoft Corporation - System Indexer/Cache Driver.) - C:\Windows\System32\drivers\discache.sys
O41 - Driver: (mssmbios) . (.Microsoft Corporation - System Management BIOS Driver.) - C:\Windows\System32\DRIVERS\mssmbios.sys
O41 - Driver: (NetBIOS) . (.Microsoft Corporation - NetBIOS interface driver.) - C:\Windows\System32\DRIVERS\netbios.sys
O41 - Driver: C:\Windows\System32\drivers\netbt.sys (NetBT) . (.Microsoft Corporation - MBT Transport driver.) - C:\Windows\System32\DRIVERS\netbt.sys
O41 - Driver: C:\Windows\System32\drivers\nsiproxy.sys (nsiproxy) . (.Microsoft Corporation - NSI Proxy.) - C:\Windows\System32\drivers\nsiproxy.sys
O41 - Driver: C:\Windows\System32\drivers\pacer.sys (Psched) . (.Microsoft Corporation - Planificateur de paquets QoS.) - C:\Windows\System32\DRIVERS\pacer.sys
O41 - Driver: C:\Windows\System32\wkssvc.dll (rdbss) . (.Microsoft Corporation - Pilote du sous-système de mise en mémoire t.) - C:\Windows\System32\DRIVERS\rdbss.sys
O41 - Driver: C:\Windows\System32\DRIVERS\RDPCDD.sys (RDPCDD) . (.Microsoft Corporation - RDP Miniport.) - C:\Windows\System32\DRIVERS\RDPCDD.sys
O41 - Driver: C:\Windows\System32\drivers\RDPENCDD.sys (RDPENCDD) . (.Microsoft Corporation - RDP Encoder Miniport.) - C:\Windows\System32\drivers\rdpencdd.sys
O41 - Driver: C:\Windows\System32\drivers\RdpRefMp.sys (RDPREFMP) . (.Microsoft Corporation - RDP Reflector Driver Miniport.) - C:\Windows\System32\drivers\rdprefmp.sys
O41 - Driver: C:\Windows\System32\tcpipcfg.dll (tdx) . (.Microsoft Corporation - TDI Translation Driver.) - C:\Windows\System32\DRIVERS\tdx.sys
O41 - Driver: (TermDD) . (.Microsoft Corporation - Remote Desktop Server Driver.) - C:\Windows\System32\DRIVERS\termdd.sys
O41 - Driver: (VgaSave) . (.Microsoft Corporation - VGA/Super VGA Video Driver.) - C:\Windows\system32\drivers\vga.sys
O41 - Driver: C:\Windows\System32\rascfg.dll (Wanarpv6) . (.Microsoft Corporation - MS Remote Access and Routing ARP Driver.) - C:\Windows\System32\DRIVERS\wanarp.sys
O41 - Driver: (WfpLwf) . (.Microsoft Corporation - WFP NDIS 6.20 Lightweight Filter Driver.) - C:\Windows\System32\DRIVERS\wfplwf.sys
~ Drivers: 69 Scanned in 00mn 00s
O42 - Logiciel: ASUS GPU Tweak - (.ASUSTek COMPUTER INC..) [HKLM][64Bits] -- InstallShield_{532F6E8A-AF97-41C3-915F-39F718EC07D1}
O42 - Logiciel: Adobe Flash Player 15 ActiveX - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- Adobe Flash Player ActiveX
O42 - Logiciel: Adobe Flash Player 15 Plugin - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- Adobe Flash Player Plugin
O42 - Logiciel: Adobe Help Center 2.1 - (.Adobe Systems.) [HKLM][64Bits] -- {25569723-DC5A-4467-A639-79535BF01B71}
O42 - Logiciel: Adobe Photoshop Elements 5.0 - (.Adobe Systems, Inc..) [HKLM][64Bits] -- Adobe Photoshop Elements 5 =>.Adobe Systems Incorporated
O42 - Logiciel: Adobe Reader XI (11.0.09) - Français - (.Adobe Systems Incorporated.) [HKLM][64Bits] -- {AC76BA86-7AD7-1036-7B44-AB0000000001}
O42 - Logiciel: AnglaisFacile.com - Planet English - (...) [HKLM][64Bits] -- afplanet
O42 - Logiciel: Avast Free Antivirus - (.AVAST Software.) [HKLM][64Bits] -- Avast
O42 - Logiciel: AxCrypt 1.7.3156.0 - (.Axantum Software AB.) [HKLM][64Bits] -- {8B49CDB9-824C-44D6-A5D3-D0235D3030B8}
O42 - Logiciel: Bonjour - (.Apple Inc..) [HKLM][64Bits] -- {07287123-B8AC-41CE-8346-3D777245C35B}
O42 - Logiciel: CCleaner - (.Piriform.) [HKLM][64Bits] -- CCleaner
O42 - Logiciel: D3DX10 - (.Microsoft.) [HKLM][64Bits] -- {E09C4DB7-630C-4F06-A631-8EA7239923AF}
O42 - Logiciel: Dictionnaire Freelang (liste de mots) - (.Freelang.) [HKLM][64Bits] -- {14B380D6-8205-4F9D-81D8-515235929F2A}_is1
O42 - Logiciel: Dictionnaire Freelang 3.74 beta - (.Freelang.) [HKLM][64Bits] -- {F53C4192-71DE-4B21-BE03-D6F8CBB5A238}_is1
O42 - Logiciel: EPSON L210 Series Printer Uninstall - (.SEIKO EPSON Corporation.) [HKLM][64Bits] -- EPSON L210 Series
O42 - Logiciel: EPSON Scan - (.Seiko Epson Corporation.) [HKLM][64Bits] -- EPSON Scanner
O42 - Logiciel: ESET Online Scanner v3 - (...) [HKLM][64Bits] -- ESET Online Scanner
O42 - Logiciel: Epson Connect Printer Setup - (.SEIKO EPSON CORPORATION.) [HKLM][64Bits] -- {D9B1D51B-EB56-410D-AEB5-1CCFAC4B6C8C}
O42 - Logiciel: Epson E-Web Print - (.SEIKO EPSON CORPORATION.) [HKLM][64Bits] -- {896667C8-53F8-47B8-B6B0-B113B10F05BC}
O42 - Logiciel: Epson Easy Photo Print 2 - (.SEIKO EPSON CORPORATION.) [HKLM][64Bits] -- {DEDB47A3-C988-4A43-A645-E2CEA571E680}
O42 - Logiciel: Epson Event Manager - (.Seiko Epson Corporation.) [HKLM][64Bits] -- {8F01524C-0676-4CC1-B4AE-64753C723391}
O42 - Logiciel: Epson User's Guide L210 Series - (...) [HKLM][64Bits] -- L210 Series Useg
O42 - Logiciel: FARO LS 1.1.406.58 - (.FARO Scanner Production.) [HKLM][64Bits] -- {951B0F30-9F1A-4BF6-B3DA-99EB0E917B1C}
O42 - Logiciel: FormatFactory 3.3.5.0 - (.Format Factory.) [HKLM][64Bits] -- FormatFactory
O42 - Logiciel: Galerie de photos - (.Microsoft Corporation.) [HKLM][64Bits] -- {F4D99A13-F63A-4FC1-8799-CFFDB78DDFB3}
O42 - Logiciel: Google Chrome - (.Google Inc..) [HKLM][64Bits] -- Google Chrome
O42 - Logiciel: Google Drive - (.Google, Inc..) [HKLM][64Bits] -- {C60F3836-333A-4AE2-B526-CFDBA143A9BA}
O42 - Logiciel: Google Toolbar for Internet Explorer - (.Google Inc..) [HKLM][64Bits] -- {18455581-E099-4BA8-BC6B-F34B2F06600C}
O42 - Logiciel: Google Toolbar for Internet Explorer - (.Google Inc..) [HKLM][64Bits] -- {2318C2B1-4965-11d4-9B18-009027A5CD4F}
O42 - Logiciel: Google Update Helper - (.Google Inc..) [HKLM][64Bits] -- {A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}
O42 - Logiciel: Google Earth - (.Google.) [HKLM][64Bits] -- {28E82311-8616-11E1-BEB0-B8AC6F97B88E}
O42 - Logiciel: HPDiagnosticAlert - (.Microsoft.) [HKLM][64Bits] -- {846B5DED-DC8C-4E1A-B5B4-9F5B39A0CACE}
O42 - Logiciel: IncrediMail - (.IncrediMail.) [HKLM][64Bits] -- {2CF22C94-1369-4C04-9A5F-A4BC6D91B508}
O42 - Logiciel: IncrediMail 2.0 - (.IncrediMail Ltd..) [HKLM][64Bits] -- IncrediMail
O42 - Logiciel: Inkscape 0.46 - (...) [HKLM][64Bits] -- Inkscape
O42 - Logiciel: Intel(R) Management Engine Components - (.Intel Corporation.) [HKLM][64Bits] -- {65153EA5-8B6E-43B6-857B-C6E4FC25798A}
O42 - Logiciel: Intel(R) OpenCL CPU Runtime - (.Intel Corporation.) [HKLM][64Bits] -- {FCB3772C-B7D0-4933-B1A9-3707EBACC573}
O42 - Logiciel: Intel(R) Processor Graphics - (.Intel Corporation.) [HKLM][64Bits] -- {F0E3AD40-2BBD-4360-9C76-B9AC9A5886EA}
O42 - Logiciel: Intel(R) USB 3.0 eXtensible Host Controller Driver - (.Intel Corporation.) [HKLM][64Bits] -- {240C3DDD-C5E9-4029-9DF7-95650D040CF2}
O42 - Logiciel: Intel® Trusted Connect Service Client - (.Intel Corporation.) [HKLM][64Bits] -- {09536BA1-E498-4CC3-B834-D884A67D7E34}
O42 - Logiciel: Java 7 Update 71 - (.Oracle.) [HKLM][64Bits] -- {26A24AE4-039D-4CA4-87B4-2F03217071FF}
O42 - Logiciel: Junk Mail filter update - (.Microsoft Corporation.) [HKLM][64Bits] -- {F6F30C28-38AA-4DBA-AE0B-7E30238E61BB}
O42 - Logiciel: MSVCRT - (.Microsoft.) [HKLM][64Bits] -- {8DD46C6A-0056-4FEC-B70A-28BB16A1F11F}
O42 - Logiciel: MSVCRT110 - (.Microsoft.) [HKLM][64Bits] -- {8E14DDC8-EA60-4E18-B3E3-1937104D5BDA}
O42 - Logiciel: MSVCRT110_amd64 - (.Microsoft.) [HKLM][64Bits] -- {E9FA781F-3E80-4399-825A-AD3E11C28C77}
O42 - Logiciel: MSVCRT_amd64 - (.Microsoft.) [HKLM][64Bits] -- {D0B44725-3666-492D-BEF6-587A14BD9BD9}
O42 - Logiciel: Malwarebytes Anti-Malware version 2.0.3.1025 - (.Malwarebytes Corporation.) [HKLM][64Bits] -- Malwarebytes Anti-Malware_is1
O42 - Logiciel: Microsoft OneDrive - (.Microsoft Corporation.) [HKCU][64Bits] -- OneDriveSetup.exe
O42 - Logiciel: Microsoft Silverlight - (.Microsoft Corporation.) [HKLM][64Bits] -- {89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}
O42 - Logiciel: Mises à jour NVIDIA 10.4.0 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Update
O42 - Logiciel: NVIDIA Logiciel système PhysX 9.12.1031 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX
O42 - Logiciel: NVIDIA PhysX - (.NVIDIA Corporation.) [HKLM][64Bits] -- {8B922CF8-8A6C-41CE-A858-F1755D7F5D29}
O42 - Logiciel: NVIDIA Pilote 3D Vision 335.23 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision
O42 - Logiciel: NVIDIA Pilote audio HD : 1.3.30.1 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver
O42 - Logiciel: NVIDIA Pilote du contrôleur 3D Vision 314.22 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB
O42 - Logiciel: NVIDIA Pilote graphique 335.23 - (.NVIDIA Corporation.) [HKLM][64Bits] -- {B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver
O42 - Logiciel: NVIDIA Stereoscopic 3D Driver - (.NVIDIA Corporation.) [HKLM][64Bits] -- NVIDIAStereo
O42 - Logiciel: PDFCreator - (.pdfforge.) [HKLM][64Bits] -- {0001B4FD-9EA3-4D90-A79E-FD14BA3AB01D}
O42 - Logiciel: PeaZip 5.1.1 - (.Giorgio Tani.) [HKLM][64Bits] -- {5A2BC38A-406C-4A5B-BF45-6991F9A05325}_is1
O42 - Logiciel: Photo Notifier and Animation Creator - (.IncrediMail Ltd..) [HKLM][64Bits] -- Photo Notifier and Animation Creator
O42 - Logiciel: Photo Notifier and Animation Creator - (.Nom de votre société.) [HKLM][64Bits] -- {6B7F28D4-160E-40C6-B7C8-5EC6B9734DA7}
O42 - Logiciel: QuickTime - (.Apple Inc..) [HKLM][64Bits] -- {8DC42D05-680B-41B0-8878-6C14D24602DB}
O42 - Logiciel: Realtek Ethernet Controller Driver - (.Realtek.) [HKLM][64Bits] -- {8833FFB6-5B0C-4764-81AA-06DFEED9A476}
O42 - Logiciel: Realtek High Definition Audio Driver - (.Realtek Semiconductor Corp..) [HKLM][64Bits] -- {F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}
O42 - Logiciel: Skype Web Plugin - (.Skype Technologies S.A..) [HKLM][64Bits] -- {B51DD93B-3CB5-4D9D-BFF2-FD19DBBBFD9A}
O42 - Logiciel: Skypeâ„¢ 6.21 - (.Skype Technologies S.A..) [HKLM][64Bits] -- {24991BA0-F0EE-44AD-9CC8-5EC50AECF6B7}
O42 - Logiciel: Software Updater - (.SEIKO EPSON CORPORATION.) [HKLM][64Bits] -- {B307472F-7BD9-4040-9255-CE6D6A1196A3}
O42 - Logiciel: VLC media player - (.VideoLAN.) [HKLM][64Bits] -- VLC media player =>.VideoLAN
O42 - Logiciel: Windows 7 Logon Background Changer - (.Julien MANICI.) [HKLM][64Bits] -- {2E6044C5-3495-485F-91BC-46D1B6430E51}
O42 - Logiciel: XAMPP - (.BitNami.) [HKLM][64Bits] -- xampp
O42 - Logiciel: jv16 PowerTools 1.3 - (...) [HKLM][64Bits] -- jv16 PowerTools_is1
~ Logic: 51 Scanned in 00mn 00s
[HKCU\Software\ASUS]
[HKCU\Software\AVAST Software]
[HKCU\Software\Adobe]
[HKCU\Software\AppDataLow\COMODO]
[HKCU\Software\AppDataLow\Software\JavaSoft]
[HKCU\Software\AppDataLow]
[HKCU\Software\Apple Computer, Inc.]
[HKCU\Software\Avery Dennison]
[HKCU\Software\Axantum]
[HKCU\Software\CallingID]
[HKCU\Software\Chromium]
[HKCU\Software\Classes]
[HKCU\Software\Clients]
[HKCU\Software\Digital River]
[HKCU\Software\EPSON Software Updater]
[HKCU\Software\EPSON]
[HKCU\Software\ESET]
[HKCU\Software\Earth Resource Mapping]
[HKCU\Software\Enterbrain]
[HKCU\Software\FreeTime]
[HKCU\Software\GFA]
[HKCU\Software\GNU]
[HKCU\Software\Gabest]
[HKCU\Software\Google]
[HKCU\Software\Haali]
[HKCU\Software\IM Providers]
[HKCU\Software\IncrediMail]
[HKCU\Software\Intel]
[HKCU\Software\JavaSoft]
[HKCU\Software\Licenses]
[HKCU\Software\Local AppWizard-Generated Applications]
[HKCU\Software\Macromedia]
[HKCU\Software\Malwarebytes' Anti-Malware]
[HKCU\Software\MozillaPlugins]
[HKCU\Software\NVIDIA Corporation]
[HKCU\Software\Netscape]
[HKCU\Software\Nico Mak Computing]
[HKCU\Software\ODBC]
[HKCU\Software\PDFCreator]
[HKCU\Software\Piriform]
[HKCU\Software\Policies]
[HKCU\Software\Realtek]
[HKCU\Software\Running Pillow]
[HKCU\Software\SEIKO EPSON CORPORATION]
[HKCU\Software\SEIKO EPSON]
[HKCU\Software\Skype]
[HKCU\Software\TeleCharger_v2]
[HKCU\Software\Transcend Elite]
[HKCU\Software\Transcend]
[HKCU\Software\Trolltech]
[HKCU\Software\UsbFix]
[HKCU\Software\VB and VBA Program Settings]
[HKCU\Software\VSO]
[HKCU\Software\Visan]
[HKCU\Software\WebApp]
[HKCU\Software\Wow6432Node]
[HKCU\Software\ZebHelpProcess Helper]
[HKLM\Software\AGEIA Technologies]
[HKLM\Software\ATI Technologies]
[HKLM\Software\Axantum]
[HKLM\Software\CBSTEST]
[HKLM\Software\Classes]
[HKLM\Software\Clients]
[HKLM\Software\DTS]
[HKLM\Software\Dolby]
[HKLM\Software\EPSON]
[HKLM\Software\Google]
[HKLM\Software\IM Providers]
[HKLM\Software\Intel]
[HKLM\Software\Khronos]
[HKLM\Software\Knowles]
[HKLM\Software\Macromedia]
[HKLM\Software\Macrovision]
[HKLM\Software\MozillaPlugins]
[HKLM\Software\NVIDIA Corporation]
[HKLM\Software\ODBC]
[HKLM\Software\Piriform]
[HKLM\Software\Policies]
[HKLM\Software\RTLSetup]
[HKLM\Software\Realtek]
[HKLM\Software\RegisteredApplications]
[HKLM\Software\SRS Labs]
[HKLM\Software\Skype]
[HKLM\Software\SonicFocus]
[HKLM\Software\Sonic]
[HKLM\Software\Synaptics]
[HKLM\Software\USB2800]
[HKLM\Software\Waves Audio]
[HKLM\Software\Wow6432Node\AGEIA Technologies]
[HKLM\Software\Wow6432Node\ASUS]
[HKLM\Software\Wow6432Node\AVAST Software]
[HKLM\Software\Wow6432Node\Adobe]
[HKLM\Software\Wow6432Node\AdwCleaner]
[HKLM\Software\Wow6432Node\Apple Computer, Inc.]
[HKLM\Software\Wow6432Node\Apple Inc.]
[HKLM\Software\Wow6432Node\AviSynth]
[HKLM\Software\Wow6432Node\Avira]
[HKLM\Software\Wow6432Node\Chromium]
[HKLM\Software\Wow6432Node\Classes]
[HKLM\Software\Wow6432Node\Clients]
[HKLM\Software\Wow6432Node\Comodo]
[HKLM\Software\Wow6432Node\EPSON]
[HKLM\Software\Wow6432Node\Eset]
[HKLM\Software\Wow6432Node\GNU]
[HKLM\Software\Wow6432Node\Google]
[HKLM\Software\Wow6432Node\HaaliMkx]
[HKLM\Software\Wow6432Node\Hewlett-Packard]
[HKLM\Software\Wow6432Node\IM Providers]
[HKLM\Software\Wow6432Node\InstallShield]
[HKLM\Software\Wow6432Node\Intel]
[HKLM\Software\Wow6432Node\JavaSoft]
[HKLM\Software\Wow6432Node\JreMetrics]
[HKLM\Software\Wow6432Node\Kaydara]
[HKLM\Software\Wow6432Node\Khronos]
[HKLM\Software\Wow6432Node\Licenses]
[HKLM\Software\Wow6432Node\Macromedia]
[HKLM\Software\Wow6432Node\Malwarebytes' Anti-Malware (Trial)]
[HKLM\Software\Wow6432Node\Malwarebytes' Anti-Malware]
[HKLM\Software\Wow6432Node\MozillaPlugins]
[HKLM\Software\Wow6432Node\Mozilla]
[HKLM\Software\Wow6432Node\NVIDIA Corporation]
[HKLM\Software\Wow6432Node\ODBC]
[HKLM\Software\Wow6432Node\PDF Architect]
[HKLM\Software\Wow6432Node\PDFCreator]
[HKLM\Software\Wow6432Node\PeaZip]
[HKLM\Software\Wow6432Node\PeaZip_additional]
[HKLM\Software\Wow6432Node\Policies]
[HKLM\Software\Wow6432Node\Protexis]
[HKLM\Software\Wow6432Node\Realtek Semiconductor Corp.]
[HKLM\Software\Wow6432Node\Realtek]
[HKLM\Software\Wow6432Node\RegisteredApplications]
[HKLM\Software\Wow6432Node\SOSVirus]
[HKLM\Software\Wow6432Node\SkypeWebPlugin]
[HKLM\Software\Wow6432Node\Skype]
[HKLM\Software\Wow6432Node\SoftVTU]
[HKLM\Software\Wow6432Node\Sonic]
[HKLM\Software\Wow6432Node\USB2800]
[HKLM\Software\Wow6432Node\VideoLAN]
[HKLM\Software\Wow6432Node\Volatile]
[HKLM\Software\Wow6432Node\mozilla.org]
[HKLM\Software\Wow6432Node]
~ Key Software: 269 Scanned in 00mn 00s
par freeanimal
#210089
Suite du rapport ZHP Diag
O43 - CFD: 12/12/2012 - 16:13:54 - [] ----D C:\Program Files (x86)\Adobe
O43 - CFD: 25/01/2014 - 14:30:22 - [] ----D C:\Program Files (x86)\AnglaisFacile.com
O43 - CFD: 12/12/2012 - 09:52:03 - [] ----D C:\Program Files (x86)\ASUS
O43 - CFD: 04/04/2014 - 17:03:08 - [] ----D C:\Program Files (x86)\Bonjour
O43 - CFD: 26/10/2014 - 13:40:52 - [] ----D C:\Program Files (x86)\Common Files
O43 - CFD: 19/04/2014 - 15:13:50 - [] ----D C:\Program Files (x86)\epson
O43 - CFD: 26/08/2014 - 10:17:52 - [] ----D C:\Program Files (x86)\Epson Software
O43 - CFD: 12/12/2012 - 13:21:30 - [] ----D C:\Program Files (x86)\ESET
O43 - CFD: 12/12/2012 - 13:21:02 - [] ----D C:\Program Files (x86)\FreeTime
O43 - CFD: 21/11/2013 - 08:46:16 - [] ----D C:\Program Files (x86)\Google
O43 - CFD: 30/07/2013 - 13:18:46 - [] ----D C:\Program Files (x86)\IncrediMail
O43 - CFD: 01/06/2014 - 15:37:36 - [] ----D C:\Program Files (x86)\Inkscape
O43 - CFD: 21/01/2014 - 17:23:53 - [] --H-D C:\Program Files (x86)\InstallShield Installation Information
O43 - CFD: 14/11/2013 - 17:51:07 - [] ----D C:\Program Files (x86)\Intel
O43 - CFD: 12/11/2014 - 12:21:31 - [] ----D C:\Program Files (x86)\Internet Explorer
O43 - CFD: 23/07/2014 - 07:37:34 - [] ----D C:\Program Files (x86)\Java
O43 - CFD: 10/01/2013 - 15:14:08 - [] ----D C:\Program Files (x86)\Julien MANICI
O43 - CFD: 10/09/2013 - 14:19:45 - [] ----D C:\Program Files (x86)\jv16 PowerTools
O43 - CFD: 25/10/2014 - 13:21:36 - [] ----D C:\Program Files (x86)\Malwarebytes Anti-Malware
O43 - CFD: 02/07/2014 - 13:28:13 - [0] ----D C:\Program Files (x86)\Microsoft
O43 - CFD: 16/12/2012 - 15:07:29 - [] ----D C:\Program Files (x86)\Microsoft Office
O43 - CFD: 25/07/2014 - 07:00:14 - [] ----D C:\Program Files (x86)\Microsoft Silverlight
O43 - CFD: 20/12/2012 - 20:34:04 - [] ----D C:\Program Files (x86)\Microsoft SkyDrive =>.Microsoft Corporation
O43 - CFD: 20/12/2012 - 20:37:26 - [] ----D C:\Program Files (x86)\Microsoft SQL Server Compact Edition
O43 - CFD: 12/12/2012 - 20:24:40 - [] ----D C:\Program Files (x86)\Microsoft Works
O43 - CFD: 18/12/2012 - 08:05:20 - [] ----D C:\Program Files (x86)\Microsoft.NET
O43 - CFD: 02/07/2014 - 10:21:32 - [] ----D C:\Program Files (x86)\MP3Gain
O43 - CFD: 14/07/2009 - 12:32:38 - [] ----D C:\Program Files (x86)\MSBuild
O43 - CFD: 13/06/2014 - 13:08:27 - [] ----D C:\Program Files (x86)\Notepad++
O43 - CFD: 02/07/2014 - 08:53:07 - [] ----D C:\Program Files (x86)\NVIDIA Corporation
O43 - CFD: 28/02/2014 - 10:27:36 - [] ----D C:\Program Files (x86)\PDFCreator
O43 - CFD: 31/08/2014 - 11:03:39 - [] ----D C:\Program Files (x86)\PeaZip
O43 - CFD: 12/12/2012 - 13:30:36 - [] ----D C:\Program Files (x86)\Photo Notifier and Animation Creator
O43 - CFD: 28/02/2013 - 18:14:13 - [] ----D C:\Program Files (x86)\QuickTime
O43 - CFD: 12/12/2012 - 09:35:03 - [] ----D C:\Program Files (x86)\Realtek
O43 - CFD: 14/07/2009 - 12:32:38 - [] ----D C:\Program Files (x86)\Reference Assemblies
O43 - CFD: 07/11/2014 - 11:51:05 - [] R---D C:\Program Files (x86)\Skype
O43 - CFD: 19/04/2014 - 14:23:25 - [] ----D C:\Program Files (x86)\SkypeWebPlugin
O43 - CFD: 12/12/2012 - 09:31:17 - [0] ----D C:\Program Files (x86)\Temp
O43 - CFD: 14/07/2009 - 11:57:06 - [0] --H-D C:\Program Files (x86)\Uninstall Information
O43 - CFD: 12/12/2012 - 13:23:41 - [] ----D C:\Program Files (x86)\VideoLAN
O43 - CFD: 22/02/2014 - 05:30:01 - [] ----D C:\Program Files (x86)\VSO
O43 - CFD: 11/07/2013 - 12:23:37 - [] ----D C:\Program Files (x86)\Windows Defender
O43 - CFD: 20/11/2013 - 09:29:06 - [] ----D C:\Program Files (x86)\Windows Live
O43 - CFD: 12/04/2011 - 16:16:36 - [] ----D C:\Program Files (x86)\Windows Mail =>.Microsoft Corporation
O43 - CFD: 16/10/2014 - 10:10:21 - [] ----D C:\Program Files (x86)\Windows Media Player =>.Microsoft Corporation
O43 - CFD: 14/07/2009 - 12:32:38 - [] ----D C:\Program Files (x86)\Windows NT
O43 - CFD: 12/04/2011 - 16:16:36 - [] ----D C:\Program Files (x86)\Windows Photo Viewer
O43 - CFD: 21/11/2010 - 10:31:38 - [] ----D C:\Program Files (x86)\Windows Portable Devices
O43 - CFD: 12/04/2011 - 16:16:36 - [] ----D C:\Program Files (x86)\Windows Sidebar
O43 - CFD: 30/11/2014 - 12:54:37 - [] ----D C:\Program Files (x86)\ZHPDiag =>.Nicolas Coolman
O43 - CFD: 12/12/2012 - 16:13:26 - [] ----D C:\Program Files (x86)\Common Files\Adobe
O43 - CFD: 28/02/2013 - 18:14:10 - [] ----D C:\Program Files (x86)\Common Files\Apple
O43 - CFD: 15/05/2014 - 03:01:06 - [] ----D C:\Program Files (x86)\Common Files\DESIGNER
O43 - CFD: 25/01/2014 - 14:41:38 - [] ----D C:\Program Files (x86)\Common Files\InstallShield
O43 - CFD: 12/12/2012 - 09:34:17 - [] ----D C:\Program Files (x86)\Common Files\Intel
O43 - CFD: 26/10/2014 - 13:40:52 - [] ----D C:\Program Files (x86)\Common Files\Java
O43 - CFD: 20/12/2012 - 20:35:49 - [] ----D C:\Program Files (x86)\Common Files\microsoft shared
O43 - CFD: 12/12/2012 - 09:36:16 - [] ----D C:\Program Files (x86)\Common Files\postureAgent
O43 - CFD: 14/07/2009 - 10:20:08 - [] ----D C:\Program Files (x86)\Common Files\Services
O43 - CFD: 20/09/2014 - 15:05:29 - [] ----D C:\Program Files (x86)\Common Files\Skype
O43 - CFD: 14/07/2009 - 10:20:08 - [] ----D C:\Program Files (x86)\Common Files\SpeechEngines
O43 - CFD: 12/12/2012 - 20:52:52 - [] ----D C:\Program Files (x86)\Common Files\System
O43 - CFD: 20/12/2012 - 18:15:49 - [] ----D C:\Program Files (x86)\Common Files\Windows Live
O43 - CFD: 14/04/2013 - 12:40:28 - [] ----D C:\ProgramData\Adobe
O43 - CFD: 04/04/2014 - 17:03:08 - [] ----D C:\ProgramData\Apple
O43 - CFD: 28/02/2013 - 18:14:10 - [] ----D C:\ProgramData\Apple Computer
O43 - CFD: 14/07/2009 - 12:08:56 - [] -SH-D C:\ProgramData\Application Data
O43 - CFD: 30/12/2012 - 09:43:10 - [] ----D C:\ProgramData\Arcade Lab
O43 - CFD: 02/07/2014 - 09:13:08 - [] ----D C:\ProgramData\AVAST Software
O43 - CFD: 02/01/2013 - 13:43:24 - [] ----D C:\ProgramData\AWEM
O43 - CFD: 11/12/2012 - 16:25:43 - [] -SH-D C:\ProgramData\Bureau
O43 - CFD: 14/07/2009 - 12:08:56 - [] -SH-D C:\ProgramData\Desktop
O43 - CFD: 14/07/2009 - 12:08:56 - [] -SH-D C:\ProgramData\Documents
O43 - CFD: 26/08/2014 - 10:16:37 - [] ----D C:\ProgramData\EPSON
O43 - CFD: 13/12/2013 - 11:37:03 - [] ----D C:\ProgramData\FaceOffMax
O43 - CFD: 11/12/2012 - 16:25:43 - [] -SH-D C:\ProgramData\Favoris
O43 - CFD: 14/07/2009 - 12:08:56 - [] -SH-D C:\ProgramData\Favorites
O43 - CFD: 15/09/2013 - 21:38:04 - [] ----D C:\ProgramData\FLEXnet
O43 - CFD: 21/11/2013 - 07:31:01 - [] ----D C:\ProgramData\Google
O43 - CFD: 12/12/2012 - 13:30:42 - [] ----D C:\ProgramData\IM
O43 - CFD: 12/12/2012 - 13:30:13 - [] ----D C:\ProgramData\IncrediMail
O43 - CFD: 12/12/2012 - 09:36:42 - [] ----D C:\ProgramData\Intel
O43 - CFD: 06/06/2014 - 04:34:18 - [] ----D C:\ProgramData\IsolatedStorage
O43 - CFD: 18/05/2014 - 07:53:17 - [] ----D C:\ProgramData\Malwarebytes
O43 - CFD: 11/12/2012 - 16:25:43 - [] -SH-D C:\ProgramData\Menu Démarrer
O43 - CFD: 02/07/2014 - 13:28:13 - [] -S--D C:\ProgramData\Microsoft
O43 - CFD: 12/11/2014 - 12:06:06 - [] ----D C:\ProgramData\Microsoft Help
O43 - CFD: 20/02/2014 - 12:48:41 - [] ----D C:\ProgramData\Microsoft OneDrive
O43 - CFD: 20/12/2012 - 20:33:58 - [] ----D C:\ProgramData\Microsoft SkyDrive =>.Microsoft Corporation
O43 - CFD: 11/12/2012 - 16:25:43 - [] -SH-D C:\ProgramData\Modèles
O43 - CFD: 30/11/2014 - 12:28:11 - [] ----D C:\ProgramData\NVIDIA
O43 - CFD: 02/07/2014 - 08:53:07 - [] ----D C:\ProgramData\NVIDIA Corporation
O43 - CFD: 26/10/2014 - 13:40:56 - [0] ----D C:\ProgramData\Oracle
O43 - CFD: 01/07/2014 - 14:57:41 - [0] ----D C:\ProgramData\Package Cache
O43 - CFD: 12/12/2012 - 13:30:36 - [] ----D C:\ProgramData\Photo Notifier and Animation Creator
O43 - CFD: 30/12/2012 - 10:23:43 - [] ----D C:\ProgramData\PlayPond
O43 - CFD: 07/11/2014 - 11:51:07 - [] ----D C:\ProgramData\Skype
O43 - CFD: 14/07/2009 - 12:08:56 - [] -SH-D C:\ProgramData\Start Menu
O43 - CFD: 24/02/2013 - 08:40:46 - [] ----D C:\ProgramData\Sun
O43 - CFD: 27/01/2013 - 22:32:54 - [0] ---AD C:\ProgramData\TEMP
O43 - CFD: 14/07/2009 - 12:08:56 - [] -SH-D C:\ProgramData\Templates
O43 - CFD: 12/12/2012 - 16:23:31 - [] ----D C:\ProgramData\UDL
O43 - CFD: 04/03/2013 - 17:56:33 - [] ----D C:\ProgramData\Ulead Systems
O43 - CFD: 24/08/2013 - 14:18:27 - [] ----D C:\ProgramData\Visan
O43 - CFD: 21/02/2014 - 17:24:02 - [] ----D C:\ProgramData\VSO
O43 - CFD: 24/02/2014 - 07:45:45 - [] R---D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Accessories
O43 - CFD: 11/12/2012 - 22:16:38 - [] R---D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools
O43 - CFD: 25/01/2014 - 14:30:22 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\AnglaisFacile.com
O43 - CFD: 12/12/2012 - 09:52:03 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ASUS
O43 - CFD: 27/08/2014 - 07:37:49 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Axantum AxCrypt
O43 - CFD: 04/04/2014 - 17:03:08 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Bonjour
O43 - CFD: 12/07/2014 - 09:00:18 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\CCleaner
O43 - CFD: 12/02/2014 - 10:35:52 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Dictionnaire Freelang
O43 - CFD: 26/08/2014 - 10:17:36 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\EPSON
O43 - CFD: 26/08/2014 - 10:15:09 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Epson Software
O43 - CFD: 25/06/2014 - 08:28:33 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ffdshow
O43 - CFD: 30/07/2013 - 13:18:47 - [] R---D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Games
O43 - CFD: 21/11/2013 - 07:34:01 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Chrome
O43 - CFD: 07/11/2014 - 07:03:18 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Drive
O43 - CFD: 31/01/2013 - 13:44:58 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Google Earth =>.Google Inc
O43 - CFD: 30/07/2013 - 13:18:48 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IncrediMail
O43 - CFD: 26/10/2014 - 13:40:35 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Java
O43 - CFD: 10/09/2013 - 14:19:45 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\jv16 PowerTools
O43 - CFD: 14/07/2009 - 11:57:09 - [] R---D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Maintenance
O43 - CFD: 25/10/2014 - 13:21:36 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Malwarebytes Anti-Malware
O43 - CFD: 14/09/2013 - 01:35:22 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office
O43 - CFD: 24/07/2014 - 12:01:12 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Silverlight
O43 - CFD: 02/07/2014 - 10:21:32 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\MP3Gain
O43 - CFD: 12/12/2012 - 09:54:56 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
O43 - CFD: 27/02/2014 - 14:48:12 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PDFCreator
O43 - CFD: 03/11/2013 - 07:17:40 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\PeaZip
O43 - CFD: 28/02/2013 - 18:14:11 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\QuickTime
O43 - CFD: 20/09/2014 - 15:05:29 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Skype
O43 - CFD: 15/01/2014 - 15:12:19 - [] R---D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
O43 - CFD: 12/04/2011 - 16:27:56 - [0] R-H-D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Tablet PC
O43 - CFD: 02/12/2013 - 20:13:38 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VideoLAN
O43 - CFD: 07/08/2014 - 14:07:34 - [0] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\VSO
O43 - CFD: 21/11/2013 - 12:19:27 - [] R---D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Windows Live
O43 - CFD: 07/12/2013 - 15:40:12 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\XAMPP
O43 - CFD: 30/11/2014 - 12:54:37 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ZHP =>.Nicolas Coolman
O43 - CFD: 06/06/2014 - 15:05:43 - [] ----D C:\Users\Oliver\AppData\Roaming\Adobe
O43 - CFD: 02/07/2014 - 09:23:59 - [] ----D C:\Users\Oliver\AppData\Roaming\AVAST Software
O43 - CFD: 02/07/2014 - 09:25:02 - [] ----D C:\Users\Oliver\AppData\Roaming\Dropbox
O43 - CFD: 14/11/2014 - 09:29:12 - [] ----D C:\Users\Oliver\AppData\Roaming\dvdcss
O43 - CFD: 22/01/2014 - 10:12:40 - [] ----D C:\Users\Oliver\AppData\Roaming\EPSON
O43 - CFD: 13/12/2013 - 11:34:25 - [] ----D C:\Users\Oliver\AppData\Roaming\FaceOffMax
O43 - CFD: 03/07/2014 - 12:39:45 - [] ----D C:\Users\Oliver\AppData\Roaming\gtk-2.0
O43 - CFD: 11/09/2013 - 13:40:33 - [] ----D C:\Users\Oliver\AppData\Roaming\HpUpdate
O43 - CFD: 11/12/2012 - 16:26:00 - [] ----D C:\Users\Oliver\AppData\Roaming\Identities
O43 - CFD: 05/07/2014 - 14:01:32 - [] ----D C:\Users\Oliver\AppData\Roaming\Inkscape
O43 - CFD: 12/12/2012 - 09:36:01 - [] ----D C:\Users\Oliver\AppData\Roaming\InstallShield
O43 - CFD: 06/06/2014 - 04:34:18 - [] ----D C:\Users\Oliver\AppData\Roaming\IsolatedStorage
O43 - CFD: 31/10/2013 - 09:38:21 - [0] ----D C:\Users\Oliver\AppData\Roaming\Jsoft
O43 - CFD: 31/10/2013 - 09:38:21 - [] ----D C:\Users\Oliver\AppData\Roaming\jsoft.fr
O43 - CFD: 25/06/2014 - 12:22:31 - [] ----D C:\Users\Oliver\AppData\Roaming\Macromedia
O43 - CFD: 18/05/2014 - 07:53:19 - [0] ----D C:\Users\Oliver\AppData\Roaming\Malwarebytes
O43 - CFD: 12/04/2011 - 16:27:56 - [0] ----D C:\Users\Oliver\AppData\Roaming\Media Center Programs
O43 - CFD: 18/09/2014 - 10:25:19 - [] -S--D C:\Users\Oliver\AppData\Roaming\Microsoft
O43 - CFD: 13/06/2014 - 13:08:27 - [] ----D C:\Users\Oliver\AppData\Roaming\Notepad++
O43 - CFD: 12/12/2012 - 13:25:41 - [] ----D C:\Users\Oliver\AppData\Roaming\NVIDIA
O43 - CFD: 10/07/2014 - 11:55:52 - [0] ----D C:\Users\Oliver\AppData\Roaming\Opera
O43 - CFD: 31/08/2014 - 11:03:52 - [] ----D C:\Users\Oliver\AppData\Roaming\PeaZip
O43 - CFD: 07/11/2014 - 11:53:20 - [] ----D C:\Users\Oliver\AppData\Roaming\Skype
O43 - CFD: 07/07/2014 - 11:57:24 - [] ----D C:\Users\Oliver\AppData\Roaming\Transcend Elite
O43 - CFD: 24/08/2013 - 14:18:27 - [] ----D C:\Users\Oliver\AppData\Roaming\Visan
O43 - CFD: 28/11/2014 - 13:38:18 - [] ----D C:\Users\Oliver\AppData\Roaming\vlc
O43 - CFD: 22/02/2014 - 05:29:26 - [0] ----D C:\Users\Oliver\AppData\Roaming\Vso
O43 - CFD: 12/10/2013 - 10:57:51 - [] ----D C:\Users\Oliver\AppData\Roaming\WinZip
O43 - CFD: 30/11/2014 - 12:55:52 - [] ----D C:\Users\Oliver\AppData\Roaming\ZHP =>.Nicolas Coolman
O43 - CFD: 27/10/2014 - 13:30:37 - [] ----D C:\Users\Oliver\AppData\Local\Adobe
O43 - CFD: 11/12/2012 - 16:25:50 - [] -SH-D C:\Users\Oliver\AppData\Local\Application Data
O43 - CFD: 02/07/2014 - 07:56:38 - [] ----D C:\Users\Oliver\AppData\Local\Apps
O43 - CFD: 24/11/2014 - 12:38:35 - [] ----D C:\Users\Oliver\AppData\Local\Diagnostics
O43 - CFD: 12/02/2014 - 10:35:52 - [] ----D C:\Users\Oliver\AppData\Local\Dictionnaire Freelang
O43 - CFD: 15/02/2013 - 09:49:59 - [] ----D C:\Users\Oliver\AppData\Local\DoNotTrackPlus
O43 - CFD: 24/03/2014 - 06:36:55 - [0] ----D C:\Users\Oliver\AppData\Local\ElevatedDiagnostics
O43 - CFD: 13/11/2014 - 07:29:40 - [] -SH-D C:\Users\Oliver\AppData\Local\EmieBrowserModeList
O43 - CFD: 20/04/2014 - 07:27:42 - [] -SH-D C:\Users\Oliver\AppData\Local\EmieSiteList
O43 - CFD: 20/04/2014 - 07:27:42 - [] -SH-D C:\Users\Oliver\AppData\Local\EmieUserList
O43 - CFD: 06/06/2014 - 04:34:22 - [] ----D C:\Users\Oliver\AppData\Local\FileViewPro
O43 - CFD: 21/11/2013 - 08:46:17 - [] ----D C:\Users\Oliver\AppData\Local\Google
O43 - CFD: 11/12/2012 - 16:25:50 - [] -SH-D C:\Users\Oliver\AppData\Local\Historique
O43 - CFD: 10/01/2013 - 15:14:58 - [] ----D C:\Users\Oliver\AppData\Local\http___www.julien-manici
O43 - CFD: 28/01/2013 - 22:18:29 - [0] ----D C:\Users\Oliver\AppData\Local\IM
O43 - CFD: 12/12/2012 - 13:45:22 - [] ----D C:\Users\Oliver\AppData\Local\Macromedia
O43 - CFD: 18/09/2014 - 10:25:34 - [] ----D C:\Users\Oliver\AppData\Local\Microsoft
O43 - CFD: 21/12/2013 - 15:25:01 - [] ----D C:\Users\Oliver\AppData\Local\Microsoft Games
O43 - CFD: 05/07/2014 - 12:38:02 - [] ----D C:\Users\Oliver\AppData\Local\Microsoft Help
O43 - CFD: 02/07/2014 - 09:26:20 - [] ----D C:\Users\Oliver\AppData\Local\NVIDIA
O43 - CFD: 12/12/2012 - 13:24:00 - [] ----D C:\Users\Oliver\AppData\Local\Programs
O43 - CFD: 14/03/2014 - 11:34:59 - [] ----D C:\Users\Oliver\AppData\Local\Skype
O43 - CFD: 30/11/2014 - 12:54:38 - [] ----D C:\Users\Oliver\AppData\Local\Temp
O43 - CFD: 11/12/2012 - 16:25:50 - [] -SH-D C:\Users\Oliver\AppData\Local\Temporary Internet Files
O43 - CFD: 25/07/2014 - 10:29:17 - [] ----D C:\Users\Oliver\AppData\Local\VirtualStore
O43 - CFD: 20/11/2013 - 09:26:35 - [] ----D C:\Users\Oliver\AppData\Local\Windows Live
O43 - CFD: 14/07/2009 - 11:54:32 - [] R---D C:\Users\Oliver\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Accessories
O43 - CFD: 14/08/2014 - 07:07:45 - [] R---D C:\Users\Oliver\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Administrative Tools
O43 - CFD: 25/01/2014 - 14:30:22 - [0] ----D C:\Users\Oliver\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\AnglaisFacile.com
O43 - CFD: 19/06/2014 - 14:28:43 - [] ----D C:\Users\Oliver\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\FormatFactory
O43 - CFD: 30/12/2012 - 18:12:45 - [] ----D C:\Users\Oliver\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Games
O43 - CFD: 14/07/2009 - 11:49:38 - [] R---D C:\Users\Oliver\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Maintenance
O43 - CFD: 02/07/2014 - 10:21:32 - [0] ----D C:\Users\Oliver\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\MP3Gain
O43 - CFD: 14/08/2014 - 07:07:45 - [] R---D C:\Users\Oliver\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
~ Program Folder: 204 Scanned in 00mn 00s
O44 - LFC:[MD5.8A8CB073A4B9F9D97CFA8CA9C1C851CE] - 19/11/2014 - 08:48:38 ---A- . (.Microsoft Corporation - Package de sécurité Kerberos.) -- C:\Windows\System32\kerberos.dll [728064]
O44 - LFC:[MD5.1306E6A1BF4D506CD687DF9F947270F2] - 19/11/2014 - 08:48:38 ---A- . (.Microsoft Corporation - Pku2u Security Package.) -- C:\Windows\System32\pku2u.dll [241152]
O44 - LFC:[MD5.B59EF013D567E5746F1DEE2565F747ED] - 22/11/2014 - 08:17:05 ---A- . (.AVAST Software - avast! Screen Saver stub.) -- C:\Windows\avastSS.scr [43152]
O44 - LFC:[MD5.9BE9F2B83DE80E2752B1405CC427E2EC] - 22/11/2014 - 08:17:06 ---A- . (...) -- C:\Windows\System32\Drivers\aswHwid.sys [29208]
O44 - LFC:[MD5.1323269A92645705DEFA053F3596829D] - 22/11/2014 - 08:17:06 ---A- . (...) -- C:\Windows\System32\Drivers\aswRvrt.sys [65776]
O44 - LFC:[MD5.1A5BDDE65B648DC3AD48B6ECAA3AE9C8] - 22/11/2014 - 08:17:06 ---A- . (...) -- C:\Windows\System32\Drivers\aswVmm.sys [267632]
O44 - LFC:[MD5.7509F07BA6F84C1E3B2C0D78A1F6F782] - 22/11/2014 - 08:17:06 ---A- . (.AVAST Software - Stream Filter.) -- C:\Windows\System32\Drivers\aswstm.sys [116728]
O44 - LFC:[MD5.2DA1C1AEDF454F8E32A863A1AEACDD8C] - 22/11/2014 - 08:17:06 ---A- . (.AVAST Software - avast! File System Minifilter for Windows 2.) -- C:\Windows\System32\Drivers\aswMonFlt.sys [83280]
O44 - LFC:[MD5.4750016EF9CC1DEC6DA3FE5AF9A7F095] - 22/11/2014 - 08:17:06 ---A- . (.AVAST Software - avast! WFP Redirect Driver.) -- C:\Windows\System32\Drivers\aswRdr2.sys [93568]
O44 - LFC:[MD5.B1881A01E301990B671694CA1623F1B6] - 22/11/2014 - 08:17:06 ---A- . (.AVAST Software - avast! self protection module.) -- C:\Windows\System32\Drivers\aswsp.sys [436624]
O44 - LFC:[MD5.6663B30328C239D2AB10D2583054CF2E] - 22/11/2014 - 08:17:06 ---A- . (.AVAST Software - avast! start-up scanner.) -- C:\Windows\System32\aswBoot.exe [364512]
O44 - LFC:[MD5.E74FD717476B30E23F45354B8F3ACB30] - 22/11/2014 - 08:17:16 ---A- . (.AVAST Software - avast! Virtualization Driver.) -- C:\Windows\System32\Drivers\aswsnx.sys [1050432]
O44 - LFC:[MD5.26C43960C99EE861A5D0EDC4DCF3B1C3] - 28/11/2014 - 11:00:42 ---A- . (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) -- C:\Windows\System32\Drivers\246D0899.sys [129752]
O44 - LFC:[MD5.D74E3C688AA4F552EB9F55CB8EA67170] - 30/11/2014 - 12:28:11 ---A- . (...) -- C:\Windows\setupact.log [56]
O44 - LFC:[MD5.D41D8CD98F00B204E9800998ECF8427E] - 30/11/2014 - 12:28:11 ---A- . (...) -- C:\Windows\setuperr.log [0]
O44 - LFC:[MD5.B49BB14C6BFCBEAF87390130E0141529] - 30/11/2014 - 12:28:11 -S-A- . (...) -- C:\Windows\bootstat.dat [67584]
O44 - LFC:[MD5.26C43960C99EE861A5D0EDC4DCF3B1C3] - 30/11/2014 - 12:28:50 ---A- . (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) -- C:\Windows\System32\Drivers\MBAMSwissArmy.sys [129752]
O44 - LFC:[MD5.8D709EF9C96F1CF046AFE2956C29C6FF] - 30/11/2014 - 12:32:07 ---A- . (...) -- C:\Windows\WindowsUpdate.log [32204]
O44 - LFC:[MD5.B5C6732324426706BE02C0A7DB1938BD] - 30/11/2014 - 12:33:08 ---A- . (...) -- C:\Windows\System32\PerfStringBackup.INI [1669656]
O44 - LFC:[MD5.29BAA127146FC065F17D4B84D4A0166C] - 30/11/2014 - 12:33:08 ---A- . (...) -- C:\Windows\System32\perfc009.dat [122142]
O44 - LFC:[MD5.936D0814935961693F0C0A3552799989] - 30/11/2014 - 12:33:08 ---A- . (...) -- C:\Windows\System32\perfc00C.dat [150184]
O44 - LFC:[MD5.891EF4F9975A6410387B079535B19AE2] - 30/11/2014 - 12:33:08 ---A- . (...) -- C:\Windows\System32\perfh009.dat [654270]
O44 - LFC:[MD5.4982EFB3AE3355B0CF0A598DD3516527] - 30/11/2014 - 12:33:08 ---A- . (...) -- C:\Windows\System32\perfh00C.dat [747660]
~ Files: 23 Scanned in 00mn 00s
---\\ Déni du service (Local Security Authority) (O48)
O48 - LSA:Local Security Authority Authentication Packages . (.Microsoft Corporation - Microsoft Authentication Package v1.0.) -- C:\Windows\System32\msv1_0.dll
O48 - LSA:Local Security Authority Notification Packages . (.Microsoft Corporation - Moteur du client de l‚à‰diteur de configuration de sécurité Windows.) -- C:\Windows\System32\scecli.dll
O48 - LSA:Local Security Authority Security Packages . (.Microsoft Corporation - Package de sécurité Kerberos.) -- C:\Windows\System32\kerberos.dll
O48 - LSA:Local Security Authority Security Packages . (.Microsoft Corporation - Microsoft Authentication Package v1.0.) -- C:\Windows\System32\msv1_0.dll
O48 - LSA:Local Security Authority Security Packages . (.Microsoft Corporation - TLS / SSL Security Provider.) -- C:\Windows\System32\schannel.dll
O48 - LSA:Local Security Authority Security Packages . (.Microsoft Corporation - Microsoft Digest Access.) -- C:\Windows\System32\wdigest.dll
O48 - LSA:Local Security Authority Security Packages . (.Microsoft Corporation - Web Service Security Package.) -- C:\Windows\System32\tspkg.dll
O48 - LSA:Local Security Authority Security Packages . (.Microsoft Corporation - Pku2u Security Package.) -- C:\Windows\System32\pku2u.dll
O48 - LSA:Local Security Authority Security Packages . (.Microsoft Corp. - LiveSSP.) -- C:\Windows\System32\livessp.dll
~ LSA: 9 Scanned in 00mn 00s
---\\ Contrôle du Safe Boot (CSB) (O49)
O49 - CSB:Control Safe Boot HKLM\...\CCS\Minimal\sermouse.sys . (.Microsoft Corporation - Pilote de filtre souris série.) -- C:\Windows\System32\Drivers\sermouse.sys
O49 - CSB:Control Safe Boot HKLM\...\CCS\Minimal\vga.sys . (.Microsoft Corporation - VGA/Super VGA Video Driver.) -- C:\Windows\System32\Drivers\vga.sys
O49 - CSB:Control Safe Boot HKLM\...\CCS\Minimal\vgasave.sys . (...) -- C:\Windows\System32\Drivers\vgasave.sys (.not file.)
O49 - CSB:Control Safe Boot HKLM\...\CCS\Minimal\volmgr.sys . (.Microsoft Corporation - Volume Manager Driver.) -- C:\Windows\System32\Drivers\volmgr.sys
O49 - CSB:Control Safe Boot HKLM\...\CCS\Minimal\volmgrx.sys . (.Microsoft Corporation - Pilote d‚extension du gestionnaire de volumes.) -- C:\Windows\System32\Drivers\volmgrx.sys
O49 - CSB:Control Safe Boot HKLM\...\CCS\Network\ipnat.sys . (.Microsoft Corporation - IP Network Address Translator.) -- C:\Windows\System32\Drivers\ipnat.sys
O49 - CSB:Control Safe Boot HKLM\...\CCS\Network\nsiproxy.sys . (.Microsoft Corporation - NSI Proxy.) -- C:\Windows\System32\Drivers\nsiproxy.sys
O49 - CSB:Control Safe Boot HKLM\...\CCS\Network\rdpencdd.sys . (.Microsoft Corporation - RDP Encoder Miniport.) -- C:\Windows\System32\Drivers\rdpencdd.sys
O49 - CSB:Control Safe Boot HKLM\...\CCS\Network\sermouse.sys . (.Microsoft Corporation - Pilote de filtre souris série.) -- C:\Windows\System32\Drivers\sermouse.sys
O49 - CSB:Control Safe Boot HKLM\...\CCS\Network\vga.sys . (.Microsoft Corporation - VGA/Super VGA Video Driver.) -- C:\Windows\System32\Drivers\vga.sys
O49 - CSB:Control Safe Boot HKLM\...\CCS\Network\vgasave.sys . (...) -- C:\Windows\System32\Drivers\vgasave.sys (.not file.)
O49 - CSB:Control Safe Boot HKLM\...\CCS\Network\volmgr.sys . (.Microsoft Corporation - Volume Manager Driver.) -- C:\Windows\System32\Drivers\volmgr.sys
O49 - CSB:Control Safe Boot HKLM\...\CCS\Network\volmgrx.sys . (.Microsoft Corporation - Pilote d‚extension du gestionnaire de volumes.) -- C:\Windows\System32\Drivers\volmgrx.sys
~ CSB: 13 Scanned in 00mn 00s
---\\ Clé de registre Shell MountPoints2 (MPKS) (O51)
O51 - MPSK:{8171571d-56c9-11e2-8b1c-50465d4d3709}\AutoRun\command. (...) -- G:\WD SmartWare.exe (.not file.)
---\\ Recherche d'infection sur les pilotes (HKLM)(TDSD) (O52)
O52 - TDSD: \Drivers32\"msacm.l3acm"="C:\Windows\System32\l3codeca.acm" . (.Fraunhofer Institut Integrierte Schaltungen - MPEG Layer-3 Audio Codec for MSACM.) -- C:\Windows\System32\l3codeca.acm
O52 - TDSD: \drivers.desc\"C:\Windows\System32\l3codeca.acm"="Fraunhofer IIS MPEG Layer-3 Codec" . (.Fraunhofer Institut Integrierte Schaltungen - MPEG Layer-3 Audio Codec for MSACM.) -- C:\Windows\System32\l3codeca.acm
~ TDSD: 2 Scanned in 00mn 00s
---\\ Enumération des clés de registre StartupReg (SMSR) (O53)
O53 - SMSR:HKLM\...\startupreg\Adobe Photo Downloader [Key] . (.Adobe Systems Incorporated - Adobe Photo Downloader 3.0 component.) -- C:\Program Files (x86)\Adobe\Photoshop Elements 5.0\apdproxy.exe
O53 - SMSR:HKLM\...\startupreg\EPSON TX101 [Key] . (...) -- C:\Windows\system32\spool\DRIVERS\x64\3\E_IATIEDI.exe (.not file.)
O53 - SMSR:HKLM\...\startupreg\msnmsgr [Key] . (.Microsoft Corporation - Windows Live Messenger.) -- C:\Program Files (x86)\Windows Live\Messenger\msnmsgr.exe
~ SMSR Keys: 3 Scanned in 00mn 00s
---\\ Enumération des clés de registre SecurityProviders (MCSP) (O54)
O54 - MCSP:[HKLM\...\CurrentControlSet\Control] - (SecurityProviders) - (.Microsoft Corporation - Credential Delegation Security Package.) -- C:\Windows\System32\credssp.dll
O54 - MCSP:[HKLM\...\ControlSet001\Control] - (SecurityProviders) - (.Microsoft Corporation - Credential Delegation Security Package.) -- C:\Windows\System32\credssp.dll
~ MSCP: 2 Scanned in 00mn 00s
O55 - MWPS:[HKLM\...\Policies\System] - "ConsentPromptBehaviorAdmin"=5
O55 - MWPS:[HKLM\...\Policies\System] - "ConsentPromptBehaviorUser"=3
O55 - MWPS:[HKLM\...\Policies\System] - "EnableInstallerDetection"=1
O55 - MWPS:[HKLM\...\Policies\System] - "EnableLUA"=1
O55 - MWPS:[HKLM\...\Policies\System] - "EnableSecureUIAPaths"=1
O55 - MWPS:[HKLM\...\Policies\System] - "EnableVirtualization"=1
O55 - MWPS:[HKLM\...\Policies\System] - "PromptOnSecureDesktop"=1
O55 - MWPS:[HKLM\...\Policies\System] - "ValidateAdminCodeSignatures"=0
O55 - MWPS:[HKLM\...\Policies\System] - "dontdisplaylastusername"=0
O55 - MWPS:[HKLM\...\Policies\System] - "legalnoticecaption"=0
O55 - MWPS:[HKLM\...\Policies\System] - "legalnoticetext"=0
O55 - MWPS:[HKLM\...\Policies\System] - "scforceoption"=0
O55 - MWPS:[HKLM\...\Policies\System] - "shutdownwithoutlogon"=1
O55 - MWPS:[HKLM\...\Policies\System] - "undockwithoutlogon"=1
O55 - MWPS:[HKLM\...\Policies\System] - "SoftwareSASGeneration"=1
~ MWPS: 17 Scanned in 00mn 00s
O56 - MWPE:[HKLM\...\policies\Explorer] - "NoActiveDesktop"=1
O56 - MWPE:[HKLM\...\policies\Explorer] - "ForceActiveDesktopOn"=0
~ MWPE Keys: 3 Scanned in 00mn 00s
O58 - SDL:28/11/2014 - 11:00:42 ---A- . (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) -- C:\Windows\System32\Drivers\246D0899.sys [129752]
O58 - SDL:22/06/2014 - 11:25:54 ---A- . (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) -- C:\Windows\System32\Drivers\48230029.sys [122584]
O58 - SDL:14/07/2009 - 08:52:21 ---A- . (.Adaptec, Inc. - Adaptec Windows SAS/SATA Storport Driver.) -- C:\Windows\System32\Drivers\adp94xx.sys [491088]
O58 - SDL:14/07/2009 - 08:52:21 ---A- . (.Adaptec, Inc. - Adaptec Windows SATA Storport Driver.) -- C:\Windows\System32\Drivers\adpahci.sys [339536]
O58 - SDL:14/07/2009 - 08:52:21 ---A- . (.Adaptec, Inc. - Adaptec StorPort Ultra320 SCSI Driver (X64).) -- C:\Windows\System32\Drivers\adpu320.sys [182864]
O58 - SDL:14/07/2009 - 08:52:21 ---A- . (.Acer Laboratories Inc. - ALi mini IDE Driver.) -- C:\Windows\System32\Drivers\aliide.sys [15440]
O58 - SDL:11/03/2011 - 13:41:12 ---A- . (.Advanced Micro Devices - AHCI 1.2 Device Driver.) -- C:\Windows\System32\Drivers\amdsata.sys [107904]
O58 - SDL:14/07/2009 - 08:52:20 ---A- . (.AMD Technologies Inc. - AMD Technology AHCI Compatible Controller Driver for Windows -.) -- C:\Windows\System32\Drivers\amdsbs.sys [194128]
O58 - SDL:11/03/2011 - 13:41:12 ---A- . (.Advanced Micro Devices - Storage Filter Driver.) -- C:\Windows\System32\Drivers\amdxata.sys [27008]
O58 - SDL:14/07/2009 - 08:52:21 ---A- . (.Adaptec, Inc. - Adaptec RAID Storport Driver.) -- C:\Windows\System32\Drivers\arc.sys [87632]
O58 - SDL:14/07/2009 - 08:52:21 ---A- . (.Adaptec, Inc. - Adaptec SAS RAID WS03 Driver.) -- C:\Windows\System32\Drivers\arcsas.sys [97856]
O58 - SDL:22/11/2014 - 08:17:06 ---A- . (...) -- C:\Windows\System32\Drivers\aswHwid.sys [29208] =>.ALWIL Software
O58 - SDL:22/11/2014 - 08:17:06 ---A- . (.AVAST Software - avast! File System Minifilter for Windows 2003/Vista.) -- C:\Windows\System32\Drivers\aswMonFlt.sys [83280]
O58 - SDL:22/11/2014 - 08:17:06 ---A- . (.AVAST Software - avast! WFP Redirect Driver.) -- C:\Windows\System32\Drivers\aswRdr2.sys [93568]
O58 - SDL:22/11/2014 - 08:17:06 ---A- . (...) -- C:\Windows\System32\Drivers\aswRvrt.sys [65776] =>.ALWIL Software
O58 - SDL:22/11/2014 - 08:17:16 ---A- . (.AVAST Software - avast! Virtualization Driver.) -- C:\Windows\System32\Drivers\aswsnx.sys [1050432]
O58 - SDL:02/07/2014 - 09:13:34 ---A- . (.AVAST Software - avast! Virtualization Driver.) -- C:\Windows\System32\Drivers\aswsnx.sys.1404267811835 [1039096]
O58 - SDL:22/11/2014 - 08:17:06 ---A- . (.AVAST Software - avast! self protection module.) -- C:\Windows\System32\Drivers\aswsp.sys [436624]
O58 - SDL:02/07/2014 - 09:13:34 ---A- . (.AVAST Software - avast! self protection module.) -- C:\Windows\System32\Drivers\aswsp.sys.1404267811835 [423240]
O58 - SDL:22/11/2014 - 08:17:06 ---A- . (.AVAST Software - Stream Filter.) -- C:\Windows\System32\Drivers\aswstm.sys [116728]
O58 - SDL:22/11/2014 - 08:17:06 ---A- . (...) -- C:\Windows\System32\Drivers\aswVmm.sys [267632] =>.ALWIL Software
O58 - SDL:11/06/2009 - 03:34:23 ---A- . (.Broadcom Corporation - Broadcom NetXtreme Gigabit Ethernet NDIS6.x Unified Driver..) -- C:\Windows\System32\Drivers\b57nd60a.sys [270848]
O58 - SDL:11/06/2009 - 03:41:06 ---A- . (.Brother Industries, Ltd. - Windows ME USB Mass-Storage Bulk-Only Lower Filter Driver.) -- C:\Windows\System32\Drivers\BrFiltLo.sys [18432]
O58 - SDL:11/06/2009 - 03:41:06 ---A- . (.Brother Industries, Ltd. - Windows ME USB Mass-Storage Bulk-Only Upper Filter Driver.) -- C:\Windows\System32\Drivers\BrFiltUp.sys [8704]
O58 - SDL:14/07/2009 - 08:19:07 ---A- . (.Brother Industries Ltd. - Pilote Brother Série I/F (WDM).) -- C:\Windows\System32\Drivers\BrSerId.sys [286720]
O58 - SDL:11/06/2009 - 03:41:10 ---A- . (.Brother Industries Ltd. - Brother Serial driver (WDM version).) -- C:\Windows\System32\Drivers\BrSerWdm.sys [47104]
O58 - SDL:11/06/2009 - 03:41:10 ---A- . (.Brother Industries Ltd. - Brother USB MDM Driver.) -- C:\Windows\System32\Drivers\BrUsbMdm.sys [14976]
O58 - SDL:11/06/2009 - 03:41:10 ---A- . (.Brother Industries Ltd. - Brother USB Serial Driver.) -- C:\Windows\System32\Drivers\BrUsbSer.sys [14720]
O58 - SDL:11/06/2009 - 03:34:28 ---A- . (.Broadcom Corporation - Broadcom NetXtreme II GigE VBD.) -- C:\Windows\System32\Drivers\bxvbda.sys [468480]
O58 - SDL:14/07/2009 - 08:52:31 ---A- . (.CMD Technology, Inc. - CMD PCI IDE Bus Driver.) -- C:\Windows\System32\Drivers\cmdide.sys [17488]
O58 - SDL:14/07/2009 - 08:47:48 ---A- . (.Emulex - Storport Miniport Driver for LightPulse HBAs.) -- C:\Windows\System32\Drivers\elxstor.sys [530496]
O58 - SDL:23/07/2007 - 21:59:12 ---A- . (.eMPIA Technology, Inc. - USB 27xx WDM Driver.) -- C:\Windows\System32\Drivers\etDevice64.sys [527744]
O58 - SDL:14/06/2007 - 17:11:12 ---A- . (.eMPIA Technology Inc. - EM27xx / EM28xx Filter Driver.) -- C:\Windows\System32\Drivers\etFilter64.sys [281088]
O58 - SDL:23/07/2007 - 22:00:18 ---A- . (.eMPIA Technology, Inc. - USB 27xx WDM Upper Filter.) -- C:\Windows\System32\Drivers\etScan64.sys [9216]
O58 - SDL:11/06/2009 - 03:34:33 ---A- . (.Broadcom Corporation - Broadcom NetXtreme II 10 GigE VBD.) -- C:\Windows\System32\Drivers\evbda.sys [3286016]
O58 - SDL:18/04/2012 - 15:05:06 ---A- . (.GARMIN Corp. - Generic WDM Support Driver.) -- C:\Windows\System32\Drivers\grmngen.sys [30568]
O58 - SDL:18/04/2012 - 15:05:16 ---A- . (.GARMIN Corp. - grmnusb.sys.) -- C:\Windows\System32\Drivers\grmnusb.sys [19304]
O58 - SDL:11/06/2009 - 03:31:59 ---A- . (.Hauppauge Computer Works, Inc. - Hauppauge WinTV 885 Consumer IR Driver for eHome.) -- C:\Windows\System32\Drivers\hcw85cir.sys [31232]
O58 - SDL:17/07/2012 - 18:12:08 ---A- . (.Intel Corporation - Intel(R) Management Engine Interface.) -- C:\Windows\System32\Drivers\HECIx64.sys [62784]
O58 - SDL:21/11/2010 - 10:23:47 ---A- . (.Hewlett-Packard Company - Smart Array SAS/SATA Controller Media Driver.) -- C:\Windows\System32\Drivers\HpSAMD.sys [78720]
O58 - SDL:11/03/2011 - 13:41:26 ---A- . (.Intel Corporation - Intel Matrix Storage Manager driver - x64.) -- C:\Windows\System32\Drivers\iaStorV.sys [410496]
O58 - SDL:14/12/2012 - 02:42:22 ---A- . (.Intel Corporation - Intel Graphics Kernel Mode Driver.) -- C:\Windows\System32\Drivers\igdkmd64.sys [5353888]
O58 - SDL:14/07/2009 - 08:48:04 ---A- . (.Intel Corp./ICP vortex GmbH - Intel/ICP Raid Storport Driver.) -- C:\Windows\System32\Drivers\iirsp.sys [44112]
O58 - SDL:06/12/2011 - 02:23:08 ---A- . (.Intel(R) Corporation - Intel(R) Display Audio Driver.) -- C:\Windows\System32\Drivers\IntcDAud.sys [331264]
O58 - SDL:23/02/2010 - 07:46:36 ---A- . (.ASUSTeK Computer Inc. - ASUS Kernel Mode Driver for NT.) -- C:\Windows\System32\Drivers\IOMap64.sys [23680]
O58 - SDL:18/07/2013 - 23:43:39 ---A- . (.Intel Corporation - Intel(R) USB 3.0 Host Controller Switch Driver.) -- C:\Windows\System32\Drivers\iusb3hcs.sys [20464]
O58 - SDL:18/07/2013 - 23:43:39 ---A- . (.Intel Corporation - Intel(R) USB 3.0 Hub Driver.) -- C:\Windows\System32\Drivers\iusb3hub.sys [358896]
O58 - SDL:18/07/2013 - 23:43:39 ---A- . (.Intel Corporation - Intel(R) USB 3.0 eXtensible Host Controller Driver.) -- C:\Windows\System32\Drivers\iusb3xhc.sys [795632]
O58 - SDL:29/07/2010 - 00:25:10 ---A- . (.Initio Corporation - Initio Default Vendor Specific Device Driver.) -- C:\Windows\System32\Drivers\ivusb.sys [29720]
O58 - SDL:14/07/2009 - 08:48:04 ---A- . (.LSI Corporation - LSI Fusion-MPT FC Driver (StorPort).) -- C:\Windows\System32\Drivers\lsi_fc.sys [114752]
O58 - SDL:14/07/2009 - 08:48:04 ---A- . (.LSI Corporation - LSI Fusion-MPT SAS Driver (StorPort).) -- C:\Windows\System32\Drivers\lsi_sas.sys [106560]
O58 - SDL:14/07/2009 - 08:48:04 ---A- . (.LSI Corporation - LSI SAS Gen2 Driver (StorPort).) -- C:\Windows\System32\Drivers\lsi_sas2.sys [65600]
O58 - SDL:14/07/2009 - 08:48:04 ---A- . (.LSI Corporation - LSI Fusion-MPT SCSI Driver (StorPort).) -- C:\Windows\System32\Drivers\lsi_scsi.sys [115776]
O58 - SDL:01/10/2014 - 11:11:12 ---A- . (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) -- C:\Windows\System32\Drivers\mbam.sys [25816]
O58 - SDL:01/10/2014 - 11:11:16 ---A- . (.Malwarebytes Corporation - Malwarebytes Chameleon Protection Driver.) -- C:\Windows\System32\Drivers\mbamchameleon.sys [93400]
O58 - SDL:30/11/2014 - 12:28:50 ---A- . (.Malwarebytes Corporation - Malwarebytes Anti-Malware.) -- C:\Windows\System32\Drivers\MBAMSwissArmy.sys [129752]
O58 - SDL:14/07/2009 - 08:48:04 ---A- . (.LSI Corporation - MEGASAS RAID Controller Driver for Windows 7\Server 2008 R2 for.) -- C:\Windows\System32\Drivers\megasas.sys [35392]
O58 - SDL:14/07/2009 - 08:48:04 ---A- . (.LSI Corporation, Inc. - LSI MegaRAID Software RAID Driver.) -- C:\Windows\System32\Drivers\MegaSR.sys [284736]
O58 - SDL:01/10/2014 - 11:11:26 ---A- . (.Malwarebytes Corporation - Malwarebytes Web Access Control.) -- C:\Windows\System32\Drivers\mwac.sys [63704]
O58 - SDL:14/07/2009 - 08:48:26 ---A- . (.IBM Corporation - IBM ServeRAID Controller Driver.) -- C:\Windows\System32\Drivers\nfrd960.sys [51264]
O58 - SDL:10/03/2012 - 09:58:30 ---A- . (...) -- C:\Windows\System32\Drivers\nvflash.sys [15168]
O58 - SDL:20/03/2014 - 23:02:52 ---A- . (.NVIDIA Corporation - NVIDIA HDMI Audio Driver.) -- C:\Windows\System32\Drivers\nvhda64v.sys [197408]
O58 - SDL:20/03/2014 - 23:02:56 ---A- . (.NVIDIA Corporation - NVIDIA Windows Kernel Mode Driver, Version 335.23.) -- C:\Windows\System32\Drivers\nvlddmkm.sys [12708128]
O58 - SDL:11/03/2011 - 13:41:34 ---A- . (.NVIDIA Corporation - NVIDIA® nForce(TM) RAID Driver.) -- C:\Windows\System32\Drivers\nvraid.sys [148352]
O58 - SDL:11/03/2011 - 13:41:34 ---A- . (.NVIDIA Corporation - NVIDIA® nForce(TM) Sata Performance Driver.) -- C:\Windows\System32\Drivers\nvstor.sys [166272]
O58 - SDL:14/07/2009 - 08:45:46 ---A- . (.QLogic Corporation - QLogic Fibre Channel Stor Miniport Driver.) -- C:\Windows\System32\Drivers\ql2300.sys [1524816]
O58 - SDL:14/07/2009 - 08:45:45 ---A- . (.QLogic Corporation - QLogic iSCSI Storport Miniport Driver.) -- C:\Windows\System32\Drivers\ql40xx.sys [128592]
O58 - SDL:29/09/2011 - 16:30:34 ---A- . (.Realtek - Realtek 8136/8168/8169 NDIS 6.20 64-bit Driver.) -- C:\Windows\System32\Drivers\Rt64win7.sys [646248]
O58 - SDL:13/12/2011 - 17:27:30 ---A- . (.Realtek Semiconductor Corp. - Realtek(r) High Definition Audio Function Driver.) -- C:\Windows\System32\Drivers\RTKVHD64.sys [4718952]
O58 - SDL:11/06/2009 - 03:37:19 ---A- . (.Macrovision Corporation, Macrovision Europe - Macrovision SECURITY Driver.) -- C:\Windows\System32\Drivers\secdrv.sys [23040]
O58 - SDL:14/07/2009 - 07:00:40 ---A- . (.Brother Industries Ltd. - Pilote Brother Série I/F (WDM).) -- C:\Windows\System32\Drivers\serial.sys [94208]
O58 - SDL:14/07/2009 - 08:45:45 ---A- . (.Silicon Integrated Systems Corp. - SiS RAID Stor Miniport Driver.) -- C:\Windows\System32\Drivers\sisraid2.sys [43584]
O58 - SDL:14/07/2009 - 08:45:46 ---A- . (.Silicon Integrated Systems - SiS AHCI Stor-Miniport Driver.) -- C:\Windows\System32\Drivers\sisraid4.sys [80464]
O58 - SDL:19/12/2013 - 21:48:28 ---A- . (.Synaptics Incorporated - Synaptics SMBus Driver.) -- C:\Windows\System32\Drivers\Smb_driver_Intel.sys [31472]
O58 - SDL:14/07/2009 - 08:45:55 ---A- . (.Promise Technology - Promise SuperTrak EX Series Driver for Windows.) -- C:\Windows\System32\Drivers\stexstor.sys [24656]
O58 - SDL:11/06/2007 - 13:34:18 ---A- . (.Windows (R) Server 2003 DDK provider - Universal Serial Bus Camera Driver.) -- C:\Windows\System32\Drivers\TP6810.SYS [200832]
O58 - SDL:14/07/2009 - 08:45:55 ---A- . (.VIA Technologies, Inc. - VIA Generic PCI IDE Bus Driver.) -- C:\Windows\System32\Drivers\viaide.sys [17488]
O58 - SDL:14/07/2009 - 08:45:55 ---A- . (.VIA Technologies Inc.,Ltd - VIA RAID DRIVER FOR AMD-X86-64.) -- C:\Windows\System32\Drivers\vsmraid.sys [161872]
O58 - SDL:02/04/2009 - 19:30:14 ---A- . (...) -- C:\Windows\SysWOW64\drivers\ASUSHWIO.SYS [10296]
~ Drivers: 79 Scanned in 00mn 00s
O61 - LFC: 25/11/2014 - 12:55:57 ---A- . (...) -- C:\Users\Oliver\AppData\Local\Google\Chrome\User Data\WidevineCDM\1.4.6.703\_platform_specific\win_x86\widevinecdmadapter.dll [146760]
O61 - LFC: 29/11/2014 - 12:55:57 ---A- . (...) -- C:\Users\Oliver\AppData\Local\Adobe\Acrobat\11.0\UserCache.bin [98756]
O61 - LFC: 29/11/2014 - 12:55:59 ---A- . (...) -- C:\Users\Oliver\Downloads\Téléchargements Logiciels de dépanage\AppManagerSetup_1.44.exe [499976]
O61 - LFC: 29/11/2014 - 12:55:59 ---A- . (...) -- C:\Users\Oliver\Downloads\Téléchargements Logiciels de dépanage\bitdefender_isecurity.exe [7043336]
O61 - LFC: 29/11/2014 - 12:55:59 ---A- . (...) -- C:\Users\Oliver\Downloads\adwcleaner_4-102_fr_430277.exe [2148864]
O61 - LFC: 29/11/2014 - 12:55:59 ---A- . (.Bitdefender LLC.) -- C:\Users\Oliver\Downloads\Téléchargements Logiciels de dépanage\BDUSBImmunizerLauncher.exe [4071672]
O61 - LFC: 29/11/2014 - 12:55:59 ---A- . (.El Desaparecido - SosVirus.net - UsbFix.net.) -- C:\Users\Oliver\Downloads\Téléchargements Logiciels de dépanage\UsbFix_7.805.exe [3709699]
O61 - LFC: 29/11/2014 - 12:55:59 ---A- . (.Kaspersky Lab.) -- C:\Users\Oliver\Downloads\Téléchargements Logiciels de dépanage\pure13.0.2.558abcdFR_5556_trial.exe [195096656]
O61 - LFC: 29/11/2014 - 12:55:59 ---A- . (.Piriform Ltd.) -- C:\Users\Oliver\Downloads\ccsetup500.exe [5162080]
O61 - LFC: 30/11/2014 - 12:55:59 ---A- . (...) -- C:\Users\Oliver\AppData\Roaming\ZHP\ZHPCleaner.exe [1408000] =>.Nicolas Coolman
O61 - LFC: 30/11/2014 - 12:55:59 ---A- . (...) -- C:\Users\Oliver\Downloads\ZHPCleaner.exe [1408000] =>.Nicolas Coolman
O61 - LFC: 30/11/2014 - 12:55:59 ---A- . (.Nicolas Coolman.) -- C:\Users\Oliver\Downloads\ZHPDiag2.exe [6864042] =>.Nicolas Coolman
~ 34 Fichiers temporaires (Temporary files)
~ 2 Fichiers cookies (Cookies files)
~ Files: 12 Scanned in 00mn 02s
O63 - Logiciel: UsbFix - (.El Desaparecido - https://www.usbfix.net - https://www.sosvirus.net.) [HKLM] -- Usbfix
O63 - Logiciel: ZHPDiag 2014 - (.Nicolas Coolman.) [HKLM] -- ZHPDiag_is1 =>.Nicolas Coolman
~ ADS: Scanned in 00mn 00s
---\\ Liste les services legacy du registre (LALS) (O64)
O64 - Services: CurCS - 22/11/2014 - C:\Windows\system32\drivers\aswHwid.sys (aswHwid) .(...) - LEGACY_ASWHWID
O64 - Services: CurCS - 22/11/2014 - C:\Windows\system32\drivers\aswMonFlt.sys (aswMonFlt) .(.AVAST Software - avast! File System Minifilter for Windows 2.) - LEGACY_ASWMONFLT
O64 - Services: CurCS - 22/11/2014 - C:\Windows\system32\drivers\aswRdr2.sys (aswRdr) .(.AVAST Software - avast! WFP Redirect Driver.) - LEGACY_ASWRDR
O64 - Services: CurCS - 22/11/2014 - C:\Windows\System32\Drivers\aswRvrt.sys (aswRvrt) .(...) - LEGACY_ASWRVRT
O64 - Services: CurCS - 22/11/2014 - C:\Windows\system32\drivers\aswSnx.sys (aswSnx) .(.AVAST Software - avast! Virtualization Driver.) - LEGACY_ASWSNX
O64 - Services: CurCS - 22/11/2014 - C:\Windows\system32\drivers\aswSP.sys (aswSP) .(.AVAST Software - avast! self protection module.) - LEGACY_ASWSP
O64 - Services: CurCS - 22/11/2014 - C:\Windows\System32\Drivers\aswVmm.sys (aswVmm) .(...) - LEGACY_ASWVMM
O64 - Services: CurCS - 01/10/2014 - C:\Windows\system32\drivers\mbam.sys (MBAMProtector) .(.Malwarebytes Corporation - Malwarebytes Anti-Malware.) - LEGACY_MBAMPROTECTOR
O64 - Services: CurCS - 30/11/2014 - C:\Windows\system32\drivers\MBAMSwissArmy.sys (MBAMSwissArmy) .(.Malwarebytes Corporation - Malwarebytes Anti-Malware.) - LEGACY_MBAMSWISSARMY
O64 - Services: CurCS - 01/10/2014 - C:\Windows\system32\drivers\mwac.sys (MBAMWebAccessControl) .(.Malwarebytes Corporation - Malwarebytes Web Access Control.) - LEGACY_MBAMWEBACCESSCONTROL
O64 - Services: CurCS - 11/06/2009 - C:\Windows\System32\Drivers\secdrv.sys (secdrv) .(.Macrovision Corporation, Macrovision Europe - Macrovision SECURITY Driver.) - LEGACY_SECDRV
~ Legacy: 82 Scanned in 00mn 00s
O67 - Shell Spawning: <.bat> <batfile>[HKLM\..\open\Command] (...) -- "%1" %*
O67 - Shell Spawning: <.cpl> <cplfile>[HKLM\..\cplopen\Command] (.Microsoft Corporation - Windows Control Panel.) -- C:\Windows\System32\control.exe =>.Microsoft Corporation
O67 - Shell Spawning: <.cmd> <cmdfile>[HKLM\..\open\Command] (...) -- "%1" %*
O67 - Shell Spawning: <.com> <comfile>[HKLM\..\open\Command] (...) -- "%1" %*
O67 - Shell Spawning: <.evt> <evtfile>[HKLM\..\open\Command] (.Microsoft Corporation - Lanceur du composant logiciel enfichable Observateur d&#130;événements.) -- C:\Windows\System32\eventvwr.exe
O67 - Shell Spawning: <.exe> <exefile>[HKLM\..\open\Command] (...) -- "%1" %*
O67 - Shell Spawning: <.html> <ChromeHTML>[HKLM\..\open\Command] (.Google Inc. - Google Chrome.) -- C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
O67 - Shell Spawning: <.js> <JSFile>[HKLM\..\open\Command] (.Microsoft Corporation - Microsoft ® Windows Based Script Host.) -- C:\Windows\System32\WScript.exe
O67 - Shell Spawning: <.reg> <regfile>[HKLM\..\open\Command] (.Microsoft Corporation - à‰diteur du Registre.) -- C:\Windows\regedit.exe
O67 - Shell Spawning: <.scr> <scrfile>[HKLM\..\open\Command] (...) -- "%1" /S
~ FASS Keys: 11 Scanned in 00mn 00s
O68 - StartMenuInternet: <FIREFOX.EXE> <Mozilla Firefox>[HKLM\..\Shell\open\Command] (...) -- C:\Program Files (x86)\Mozilla Firefox\firefox.exe (.not file.)
~ Keys: Scanned in 00mn 00s
O69 - SBI: SearchScopes [HKCU] {0633EE93-D776-472f-A0FF-E1416B8B2E3A} - (Bing) - https://www.bing.com
---\\ Enumère les service demarrés par Svchost (SSS) (O83)
O83 - Search Svchost Services: AeLookupSvc (AeLookupSvc) . (.Microsoft Corporation - Service Expérience d&#130;application.) -- C:\Windows\System32\aelupsvc.dll [72192]
O83 - Search Svchost Services: CertPropSvc (CertPropSvc) . (.Microsoft Corporation - Service de propagation de certificats de cartes à puce Microsoft.) -- C:\Windows\System32\certprop.dll [80384]
O83 - Search Svchost Services: SCPolicySvc (SCPolicySvc) . (.Microsoft Corporation - Service de propagation de certificats de cartes à puce Microsoft.) -- C:\Windows\System32\certprop.dll [80384]
O83 - Search Svchost Services: lanmanserver (lanmanserver) . (.Microsoft Corporation - DLL du service Serveur.) -- C:\Windows\System32\srvsvc.dll [236032]
O83 - Search Svchost Services: gpsvc (gpsvc) . (.Microsoft Corporation - Client de stratégie de groupe.) -- C:\Windows\System32\gpsvc.dll [777728]
O83 - Search Svchost Services: IKEEXT (IKEEXT) . (.Microsoft Corporation - Extension IKE.) -- C:\Windows\System32\ikeext.dll [859648]
O83 - Search Svchost Services: AudioSrv (AudioSrv) . (.Microsoft Corporation - Service Audio Windows.) -- C:\Windows\System32\Audiosrv.dll [680960]
O83 - Search Svchost Services: Rasauto (Rasauto) . (.Microsoft Corporation - Gestionnaire de numérotation automatique d&#130;accès distant.) -- C:\Windows\System32\rasauto.dll [99328]
O83 - Search Svchost Services: Rasman (Rasman) . (.Microsoft Corporation - Gestionnaire de connexions d&#130;accès distant.) -- C:\Windows\System32\rasmans.dll [344064]
O83 - Search Svchost Services: Remoteaccess (Remoteaccess) . (.Microsoft Corporation - Gestionnaire d&#130;interface dynamique.) -- C:\Windows\System32\mprdim.dll [97792]
O83 - Search Svchost Services: SENS (SENS) . (.Microsoft Corporation - Service de notification d&#130;événements système (SENS).) -- C:\Windows\System32\sens.dll [64512]
O83 - Search Svchost Services: Sharedaccess (Sharedaccess) . (.Microsoft Corporation - Composants de l&#130;application d&#130;assistance à Microsoft NAT.) -- C:\Windows\System32\ipnathlp.dll [359424]
O83 - Search Svchost Services: Tapisrv (Tapisrv) . (.Microsoft Corporation - Serveur de téléphonie Microsoft® Windows(TM).) -- C:\Windows\System32\tapisrv.dll [316928]
O83 - Search Svchost Services: TermService (TermService) . (.Microsoft Corporation - Gestionnaire des connexions distantes du serveur hôte de session Burea.) -- C:\Windows\System32\termsrv.dll [683520]
O83 - Search Svchost Services: wuauserv (wuauserv) . (.Microsoft Corporation - Agent de mise à jour automatique Windows Update.) -- C:\Windows\System32\wuaueng.dll [2477536]
O83 - Search Svchost Services: BITS (BITS) . (.Microsoft Corporation - Service de transfert intelligent en arrière-plan.) -- C:\Windows\System32\qmgr.dll [849920]
O83 - Search Svchost Services: ShellHWDetection (ShellHWDetection) . (.Microsoft Corporation - Dll des services Windows Shell.) -- C:\Windows\System32\shsvcs.dll [370688]
O83 - Search Svchost Services: iphlpsvc (iphlpsvc) . (.Microsoft Corporation - Service offrant une connectivité IPv6 sur un réseau IPv4..) -- C:\Windows\System32\iphlpsvc.dll [569344]
O83 - Search Svchost Services: seclogon (seclogon) . (.Microsoft Corporation - DLL de service d&#130;ouverture de session secondaire.) -- C:\Windows\system32\seclogon.dll [30720]
O83 - Search Svchost Services: AppInfo (AppInfo) . (.Microsoft Corporation - Service Informations d&#130;application.) -- C:\Windows\System32\appinfo.dll [70144]
O83 - Search Svchost Services: msiscsi (msiscsi) . (.Microsoft Corporation - Service de découverte iSCSI.) -- C:\Windows\System32\iscsiexe.dll [156672]
O83 - Search Svchost Services: MMCSS (MMCSS) . (.Microsoft Corporation - Service Planificateur de classes multimédias.) -- C:\Windows\System32\mmcss.dll [67584]
O83 - Search Svchost Services: winmgmt (winmgmt) . (.Microsoft Corporation - WMI.) -- C:\Windows\System32\wbem\WMIsvc.dll [242688]
O83 - Search Svchost Services: SessionEnv (SessionEnv) . (.Microsoft Corporation - Service Configuration des services Bureau à distance.) -- C:\Windows\System32\sessenv.dll [121856]
O83 - Search Svchost Services: browser (browser) . (.Microsoft Corporation - DLL du service Explorateur d&#130;ordinateurs.) -- C:\Windows\System32\browser.dll [136704]
O83 - Search Svchost Services: EapHost (EapHost) . (.Microsoft Corporation - Service EAPHost Microsoft.) -- C:\Windows\System32\eapsvc.dll [111104]
O83 - Search Svchost Services: schedule (schedule) . (.Microsoft Corporation - Service du Planificateur de tà¢ches.) -- C:\Windows\System32\schedsvc.dll [1110016]
O83 - Search Svchost Services: hkmsvc (hkmsvc) . (.Microsoft Corporation - Service Gestion des clés.) -- C:\Windows\System32\kmsvc.dll [90624]
O83 - Search Svchost Services: wercplsupport (wercplsupport) . (.Microsoft Corporation - Rapports et solutions aux problèmes.) -- C:\Windows\System32\wercplsupport.dll [84480]
O83 - Search Svchost Services: ProfSvc (ProfSvc) . (.Microsoft Corporation - ProfSvc.) -- C:\Windows\System32\profsvc.dll [209920]
O83 - Search Svchost Services: Themes (Themes) . (.Microsoft Corporation - DLL du service des thèmes Windows Shell.) -- C:\Windows\System32\themeservice.dll [44544]
O83 - Search Svchost Services: BDESVC (BDESVC) . (.Microsoft Corporation - Service BDE.) -- C:\Windows\System32\bdesvc.dll [100864]
O83 - Search Svchost Services: AppMgmt (AppMgmt) . (.Microsoft Corporation - Service Installation de logiciels.) -- C:\Windows\System32\appmgmts.dll [193536]
~ Services: 33 Scanned in 00mn 00s
[MD5.B8026EBDE7FDC4C7A379D09251C2EA79] [SPRF][02/03/2013] (...) -- C:\ProgramData\6DCCC2EADD.sys [88]
[MD5.264C2B7550E294C35691DDA369D716C3] [SPRF][02/03/2013] (...) -- C:\ProgramData\KGyGaAvL.sys [2516]
[MD5.AF7CE12C4F3DC8CB2B07685C916BBCFE] [SPRF][22/02/2014] (.VSO Software - low level access layer for CD/DVD/BD devices.) -- C:\Users\Oliver\AppData\Roaming\pcouffin.sys [82816]
[MD5.1558D0623A648DCCFF4A1ABAA71FA69F] [SPRF][07/12/2013] (.BitNami - Pas de description.) -- C:\Users\Oliver\Desktop\xampp-win32-1.8.2-3-VC9-installer.exe [106500008]
~ Files: 4 Scanned in 00mn 00s
SS - | Demand 26/11/2014 267440 | (AdobeFlashPlayerUpdateSvc) . (.Adobe Systems Incorporated.) - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
SS - | Demand 14/12/2012 277616 | (cphs) . (.Intel Corporation.) - C:\Windows\SysWow64\IntelCpHeciSvc.exe
SS - | Demand 12/12/2012 1436424 | (FLEXnet Licensing Service 64) . (.Acresso Software Inc..) - C:\Program Files\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService64.exe
SS - | Auto 21/11/2013 116648 | (gupdate) . (.Google Inc..) - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
SS - | Demand 21/11/2013 116648 | (gupdatem) . (.Google Inc..) - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
SS - | Demand 21/11/2013 194032 | (gusvc) . (.Google.) - C:\Program Files (x86)\Google\Common\Google Updater\GoogleUpdaterService.exe
SS - | Auto 15/03/2013 1266464 | (nvUpdatusService) . (.NVIDIA Corporation.) - C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Update Core\daemonu.exe
SS - | Auto 03/04/2014 315008 | (SkypeUpdate) . (.Skype Technologies.) - C:\Program Files (x86)\Skype\Updater\Updater.exe
SR - | Auto 14/09/2006 102400 | (AdobeActiveFileMonitor5.0) . (...) - C:\Program Files (x86)\Adobe\Photoshop Elements 5.0\PhotoshopElementsFileAgent.exe
SR - | Auto 12/09/2014 64704 | (AdobeARMservice) . (.Adobe Systems Incorporated.) - C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
SR - | Auto 17/01/2012 55296 | (ASGT) . (...) - C:\Windows\SysWOW64\ASGT.exe
SR - | Auto 22/11/2014 50344 | (avast! Antivirus) . (.AVAST Software.) - C:\Program Files\AVAST Software\Avast\AvastSvc.exe
SR - | Auto 12/12/2008 238888 | (Bonjour Service) . (.Apple Inc..) - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
SR - | Auto 12/12/2011 135824 | (EpsonScanSvc) . (.Seiko Epson Corporation.) - C:\Windows\system32\EscSvc64.exe
SR - | Auto 27/02/2012 151648 | (EPSON_PM_RPCV4_05) . (.SEIKO EPSON CORPORATION.) - C:\Program Files\Common Files\EPSON\EPW!3 SSRP\E_WT50RP.exe
SR - | Auto 02/02/2012 628448 | (Intel(R) Capability Licensing Service Interface) . (.Intel(R) Corporation.) - C:\Program Files\Intel\iCLS Client\HeciServer.exe
SR - | Auto 07/02/2012 161560 | (jhi_service) . (.Intel Corporation.) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL\jhi_service.exe
SR - | Auto 07/02/2012 277784 | (LMS) . (.Intel Corporation.) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
SR - | Auto 01/10/2014 1871160 | (MBAMScheduler) . (.Malwarebytes Corporation.) - C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamscheduler.exe
SR - | Auto 01/10/2014 968504 | (MBAMService) . (.Malwarebytes Corporation.) - C:\Program Files (x86)\Malwarebytes Anti-Malware\mbamservice.exe
SR - | Auto 04/03/2014 922968 | (nvsvc) . (.NVIDIA Corporation.) - C:\Windows\system32\nvvsvc.exe
SR - | Auto 04/03/2014 411936 | (Stereo Service) . (.NVIDIA Corporation.) - C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe
SR - | Auto 07/02/2012 363800 | (UNS) . (.Intel Corporation.) - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe
SR - | Auto 14/07/2009 27136 | C:\Program Files (x86)\Windows Defender\mpsvc.dll (WinDefend) . (.Microsoft Corporation.) - C:\Windows\System32\svchost.exe
SR - | Auto 11/07/1658 0 | (WMPNetworkSvc) . (...) - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe =>.Microsoft Corporation
~ Services: Scanned in 00mn 05s
Run by Oliver at 30/11/2014 12:56:45
~ MBR: 0 Scanned in 00mn 00s
Run by Oliver at 30/11/2014 12:56:47
C:\PhysicalDisk0_MBR.bin
~ MBR: Scanned in 00mn 02s
---\\ Scan Additionnel (O88)
Database Version : 13026 - (26/11/2014)
Clés trouvées (Keys found) : 2
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{D6533F74-218B-41BE-9D91-5BD471FECFFD}] =>Toolbar.Conduit
[HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{D6533F74-218B-41BE-9D91-5BD471FECFFD}] =>Toolbar.Conduit
~ Additionnel Scan: 251979 Items scanned in 00mn 11s
---\\ Informations complémentaires sur les modules
~ https://nicolascoolman.fr/r5-internet-explorer-proxy-management-iepm/ =>.Internet Explorer, Proxy Management (R5)
~ https://nicolascoolman.fr/o2-browser-helper-objects-de-navigateur/ =>.Browser Helper Objects de navigateur (O2)
~ https://nicolascoolman.fr/o4-applications-demarrees-par-le-registre/ =>.Applications lancées au démarrage du système (O4)
~ https://nicolascoolman.fr/o51-mountpoints2-shell-key-mpsk/ =>.Clé de registre Shell MountPoints2 (MPKS) (O51)
~ AMI: 4 Scanned in 00mn 00s
https://nicolascoolman.fr/toolbar-conduit =>Toolbar.Conduit
~ MSI: 1 link(s) detected in 00mn 00s
End of the scan (1239 lines in 01mn 23s)(0)
Merci pour ton aide
Freeanimal
#210102
Plus grand chose Pour les deux premiers rapport , c'est OK ,
recommence ZHPDiag :
[center]ZHPDiag[/center]
suis bien les instructions
1) * Télécharge ZHPDiag (de Nicolas coolman) sur ton bureau !!
OU :miroir : ftp://zebulon.fr/ZHPDiag2.exe (Lien direct)
- Cliquer sur le Bouton Bleu + Nicolas Coolman :
Si ton système d'exploitation est Vista ou Win7/8, lance les logiciels par simple clic droit et choisis "exécuter en tant qu'administrateur"
a) * Une fois le téléchargement achevé,
b) * double clique (ou clic droit pour seven , vista et 8 exécuter en tant qu'administrateur) sur ZHPDiag2.exe et suis les instructions.
c) * L'outil va créer 2 icônes de racourcis : ZHPDiag >> ZHPFix
d) * Clique droit sur le parchemin
e) *A l'ouverture le programme te proposes "Rechercher" , "Configurer" , Complet -
Clique sur "Complet" le scan démarre.......le rapport s'affiche
Si tu cliques sur Configurer :
* Clique sur le tournevis en bas à droite et choisis "Tous" puis "OK"
2)* Maintenant clique sur "Rechercher".
* Important >> Pendant l analyse de ton PC par ZHPDIag ne touche à plus rien !!!!!
3) * Le rapport s'affiche sur ton Bureau une fois terminé !
Il suffit de cliquer sur :
Tu peux fermer ZHPDiag
IMPORTANT
[les rapports étant trop long, les héberger :
Rappel des dépôts
1sosvirus>>Utilisation
2
3
pour le rapport ZHPDiag il faut l'héberger :
[center]Hébergement[/center]
Les rapports de diagnostique sont trop long, ils dépassent la taille autorisée par les éditeurs des forums , il faut donc héberger le rapport :
A/ - Héberge le rapport ZHPDiag.txt sur : SoSVirus Upload et"les captures d'écran aussi"
ou sur
B/ - Cliques sur >> Parcourir (ou choisissez un fichier)
C/ - Cherche le rapport de ZHPDiag que tu viens de faire qui est sur ton bureau
D/ - Cliques sur >> envoyer le fichier (ou créer le lien)
E/ - Un lien sera généré, Un lien de cette forme:
F/ - Il te suffit de le poster ici
par freeanimal
#210194
Pas mal d'infos intéressantes. Donc je t'envoie le dernier rapport de ZHP Diag ici :
Merci pour ton aide, c'est un peu "Hard" car je ne maîtrise pas encore le langage informatique mais ça va le faire !
freeanimal
#210225
à‰videment que ça va le faire :p
si tu ne comprend pas quelque chose , demande j'essayerais de te l'expliquer..... :p:
Déjà tu as utilisé Pjjoint qui est plus difficile que les autres alors....
Pas grand chose , je te conseille de désinstaller incrédimail et ESET Online Scanner v3 => ESET
Ensuite tu vas passer ce script et après me refaire un ZHPDiag en me disant comment ton ordi fonctionne ?
    [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer] NoActiveDesktopChanges: Modified    => SYSTEM : Active Desktop désactivé et configuration refusée
    [HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced] Start_ShowNetConn: Modified    => PUA.StartShow
    OPT:O4 - HKLM\..\Wow6432Node\Run: [QuickTime Task] . (.Apple Inc. - QuickTime Task.) -- C:\Program Files (x86)\QuickTime\QTTask.exe
    [MD5.00000000000000000000000000000000] [APT] [{09FF2DE5-71DC-41F8-8029-849B9175DA86}] (...) -- C:\Users\Oliver\Downloads\mp3gain-win-full-1_2_5.exe (.not file.)   [0]    => Fichier absent
    [MD5.00000000000000000000000000000000] [APT] [{34DE3D19-39D7-4FAD-8CC1-6F8E146529C8}] (...) -- C:\Users\Oliver\Downloads\MSReaderPPCFRASetup.exe (.not file.)   [0]    => Fichier absent
    [MD5.00000000000000000000000000000000] [APT] [{510A8553-E6D2-4ADD-8B6A-E1B8966C8764}] (...) -- C:\Users\Oliver\Downloads\FR_fr_DP5_DL_20100602.exe (.not file.)   [0]    => Fichier absent
    [MD5.00000000000000000000000000000000] [APT] [{6EE15E8D-CA58-4914-A1C2-B892F090AE37}] (...) -- E:\LaCie.exe (.not file.)   [0]    => Fichier absent
    [MD5.00000000000000000000000000000000] [APT] [{8005AE53-865F-4A38-B74A-609EA26C8E4A}] (...) -- C:\Users\Oliver\Downloads\esetsmartinstaller_enu.exe (.not file.)   [0]    => Fichier absent
    [MD5.00000000000000000000000000000000] [APT] [{98DF8ECB-29E9-47BC-8DD0-342CD4CA76E6}] (...) -- C:\Users\Oliver\Downloads\Rider_2_PC_jeu_gratuit.exe (.not file.)   [0]    => Fichier absent
    [MD5.00000000000000000000000000000000] [APT] [{AE868D7F-E445-4C53-9286-FA0EF8687FEC}] (...) -- D:\Personnal DATA\Mon site DATA\setup hofmann france.exe (.not file.)   [0]    => Fichier absent
    O42 - Logiciel: IncrediMail - (.IncrediMail.) [HKLM][64Bits] -- {2CF22C94-1369-4C04-9A5F-A4BC6D91B508}    => Messaging.Incredimail
    O42 - Logiciel: IncrediMail 2.0 - (.IncrediMail Ltd..) [HKLM][64Bits] -- IncrediMail    => Messaging.Incredimail
    [HKCU\Software\IncrediMail]    => Messaging.Incredimail
    O43 - CFD: 30/07/2013 - 13:18:46 - [] ----D C:\Program Files (x86)\IncrediMail    => Messaging.Incredimail
    O43 - CFD: 12/12/2012 - 13:30:42 - [] ----D C:\ProgramData\IM    => Messaging.IncrediMail
    O43 - CFD: 12/12/2012 - 13:30:13 - [] ----D C:\ProgramData\IncrediMail    => Messaging.Incredimail
    O43 - CFD: 30/07/2013 - 13:18:48 - [] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\IncrediMail    => Messaging.Incredimail
    O43 - CFD: 28/01/2013 - 22:18:29 - [0] ----D C:\Users\Oliver\AppData\Local\IM    => Messaging.IncrediMail
    OPT:SR - | Auto 12/12/2008 238888 |  (Bonjour Service) . (.Apple Inc..) - C:\Program Files (x86)\Bonjour\mDNSResponder.exe
    ProxyFix
    EmptyPrefetch
    SysRestore
    FirewallRAZ
    EmptyTemp
    exemple :
#210312
:super: impeccable maintenant tu peux me faire un nouveau ZHPDiag s'il te plait pour vérification :
IMPORTANT
Les rapports de diagnostique sont trop long, ils dépassent la taille autorisée par les éditeurs des forums , il faut donc héberger les rapports :
ou sur
