par V-X
#210893
  • Lance AdsFix
  • Inscrit ton pays
Aide: +
par V-X
#210910
  • Lance ZHPDiag,
  • Clic sur Complet
par V-X
#210913
    [HKLM\Software\Wow6432Node\SPPDCOM]
    O44 - LFC:[MD5.DD83F157345DB4C396840668647A8E68] - 06/12/2014 - 15:05:57 ---A- . (.Corsica - Web Instrumentation New Driver.) -- C:\Windows\System32\Drivers\webinstrNewH.sys   [106456]
    O44 - LFC:[MD5.99232093D4B7AAB12ADA85239932D8E6] - 23/11/2014 - 10:17:54 ---A- . (...) -- C:\Windows\Kommun.dll   [91136]
    O44 - LFC:[MD5.22E3B6DF2289566E9F41BC42FCD5D6FD] - 23/11/2014 - 10:17:54 ---A- . (.Pas de propriétaire - downloadManagement.) -- C:\Windows\LibDownloadManagement.dll   [6144]
    O51 - MPSK:{9c44bc49-3f41-11e1-9938-806e6f6e6963}\AutoRun\command. (...) -- E:\Bin\assetup.exe (.not file.)
    O58 - SDL:06/12/2014 - 15:05:57 ---A- . (.Corsica - Web Instrumentation New Driver.) -- C:\Windows\System32\Drivers\webinstrNewH.sys   [106456]
    O43 - CFD: 04/09/2012 - 20:29:34 - [] ----D C:\Program Files (x86)\Ad-Aware Antivirus
    O43 - CFD: 04/09/2012 - 03:26:46 - [] ----D C:\Users\Hassan\AppData\Roaming\Ad-Aware Antivirus
    O49 - CSB:Control Safe Boot HKLM\...\CCS\Minimal\CleanHlp.sys . (...) -- C:\Windows\System32\Drivers\CleanHlp.sys (.not file.)
    O49 - CSB:Control Safe Boot HKLM\...\CCS\Network\CleanHlp.sys . (...) -- C:\Windows\System32\Drivers\CleanHlp.sys (.not file.)
    O51 - MPSK:{87b5a607-6e0d-11e4-85ae-5404a6c4659f}\AutoRun\command. (...) -- E:\LGAutoRun.exe (.not file.)
    O41 - Driver: (SBRE) . (. - .) - C:\Windows\system32\drivers\SBREdrv.sys (.not file.)
    [MD5.00000000000000000000000000000000] [APT] [FacebookUpdateTaskUserS-1-5-21-1042510137-623599378-3774190377-1000Core] (...) -- C:\Users\Hassan\AppData\Local\Facebook\Update\FacebookUpdate.exe (.not file.)   [0]
    [MD5.00000000000000000000000000000000] [APT] [FacebookUpdateTaskUserS-1-5-21-1042510137-623599378-3774190377-1000UA] (...) -- C:\Users\Hassan\AppData\Local\Facebook\Update\FacebookUpdate.exe (.not file.)   [0]
    [MD5.00000000000000000000000000000000] [APT] [{636DD1FD-7E72-420F-A76F-F2EE5678E664}] (...) -- D:\Mes t‚l‚chargements\HTC_Desire_Unlock_v0.9.5\HTC_Desire_Unlock_v0.9.5\HTC_Desire_Unlock_v0.9.5.exe (.not file.)   [0]
    [MD5.00000000000000000000000000000000] [APT] [{C4969E62-0080-46CE-B30E-20C63A98956D}] (...) -- D:\Mes t‚l‚chargements\HTC_Desire_Unlock_v0.9.5\HTC_Desire_Unlock_v0.9.5\HTC_Desire_Unlock_v0.9.5.exe (.not file.)   [0]
    O68 - StartMenuInternet: <FIREFOX.EXE> <Mozilla Firefox>[HKLM\..\Shell\open\Command] (...) -- firefox.exe (.not file.)
    EmptyPrefetch
    FirewallRAZ
    EmptyTemp
  2. Colle les lignes helper données
  3. Puis Clic sur "GO"
  4. Confirmes les nettoyages des données en cliquant sur "Oui"
  5. Une fois le scan terminé rends toi sur le bureau, le fichier ZHPFixReport à été crée.
  6. Héberge le rapport ZHPFixReport sur SosUpload, puis copie/colle le lien fourni dans ta prochaine réponse.
Aide : ++
par V-X
#210936
OK, pour finir :
  • Clique sur GO
  • Héberge le rapport SFTGC.txt sur SosUpload, puis copie/colle le lien fourni dans ta prochaine réponse sur le forum.
  • Lance Delfix,
  • Coche la case suivantes :
    • Réactiver l'UAC
