par conan
#211349
bonsoir voici les resultats du rapport:
All processes killed
========== FILES ==========
F:\sysusb folder moved successfully.
F:\Recycled folder moved successfully.
F:\snkb0pt folder moved successfully.
[EMPTYTEMP]
User: All Users
User: BILLY
->Temp folder emptied: 343491241 bytes
->Temporary Internet Files folder emptied: 47432093 bytes
->Java cache emptied: 47148809 bytes
->Google Chrome cache emptied: 368509473 bytes
->Flash cache emptied: 57503 bytes
User: Default
->Flash cache emptied: 57311 bytes
User: Default User
User: Public
Windows Temp folder emptied: 474233743 bytes
%systemroot%\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 3149863 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 56293113 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 1Â 278,00 mb
OTM by OldTimer - Version 3.1.21.0 log created on 12152014_182932
Files moved on Reboot...
C:\Users\BILLY\AppData\Local\Temp\FXSAPIDebugLogFile.txt moved successfully.
C:\Users\BILLY\AppData\Local\Temp\MMDUtl.log moved successfully.
C:\Users\BILLY\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
C:\Users\BILLY\AppData\Local\Google\Chrome\User Data\Default\Cache\data_0 moved successfully.
C:\Users\BILLY\AppData\Local\Google\Chrome\User Data\Default\Cache\data_1 moved successfully.
C:\Users\BILLY\AppData\Local\Google\Chrome\User Data\Default\Cache\data_2 moved successfully.
C:\Users\BILLY\AppData\Local\Google\Chrome\User Data\Default\Cache\data_3 moved successfully.
C:\Users\BILLY\AppData\Local\Google\Chrome\User Data\Default\Cache\index moved successfully.
File move failed. C:\Windows\temp\_avast_\AvastLock.txt scheduled to be moved on reboot.
File move failed. C:\Windows\temp\Low\SkypeClickToCall\Logs\AutoUpdateSvc.log scheduled to be moved on reboot.
File move failed. C:\Windows\temp\dsiwmis.log scheduled to be moved on reboot.
File move failed. C:\Windows\temp\LMutilps32.log scheduled to be moved on reboot.
#211365
:hello: ,
Avec le lecteur F connecté :
Ouvre la commande cmd (touche Windows + r) tape CMD et valide
Dans la fenetre noire qui apparaît écris ou copie colle ceci :
attrib -r -s -h -a "F:\*" /s /d
Valide par Entrée
Vérifie ensuite le contenu du lecteur F stp
par conan
#211384
après avoir exécuté ce que vous m'avez demandé il y a marqué accès refusé si je vois bien dans le lecteur F (je ne peux pas faire de copié collé pour plus de détail)
#211386
arff,
va dans menu démarrer -> acessoire -> clic droit sur invite de commande et choisis executer en tant qu'administrateur.
Ensuite fait la même manip :
Valide par Entrée
par conan
#211392
c'est génial tout mes fichiers sont apparus!!!!
merci bcp pour ton efficacité et ta disponibilité
je vous ferais de la pub! :hello: :bravo1:
merci encore!
#211393
:):content:
Bonne nouvelle :)
Bonne fin de semaine également :hello:
par conan
#211394
j'avais envoyé un message de remerciement je ne sais pas si il a été posté mais voilà encore un grand merci car ça à marché....bonne continuation :hello:
