par Paqui
#211523
Voilà :
J'ai mis les deux dans le même j'espère que c'est ok sinon je recommence sur 2 pastes pas de souci
#211524
  • Relance OTL.
    :OTL
    FF - prefs.js..browser.startup.homepage: ""
    [2014/12/11 21:30:47 | 000,000,000 | ---D | M] (Default) -- C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd}
    O15 - HKU\S-1-5-21-4277464422-782500475-2693772901-1000\..Trusted Domains: samsungsetup.com ([www] http in Sites de confiance)
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters: DhcpNameServer = 192.168.1.1 192.168.1.1
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{15F98FC0-85EB-4151-96B3-92B8DBB0C035}: NameServer = 127.0.0.1
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{173D8498-F4E7-4914-8F83-EA9614422F5F}: DhcpNameServer = 192.168.1.1 192.168.1.1
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{173D8498-F4E7-4914-8F83-EA9614422F5F}: NameServer = 127.0.0.1
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{5AEC0CFA-8D46-48DE-A373-570680F4EA99}: NameServer = 127.0.0.1
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{5C1051EE-0027-4341-83AF-C5C78360A1E6}: NameServer = 127.0.0.1
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{93B39732-02AA-4FF6-A73D-FE19EE56E502}: NameServer = 127.0.0.1
    O17 - HKLM\System\CCS\Services\Tcpip\Parameters\Interfaces\{9CBCB873-025D-48CC-BF60-95FD0223CAC5}: NameServer = 127.0.0.1
    :Commands
    [emptytemp]
    [emptyflash]
    [resethosts]
    [reboot]
  • Image
par Paqui
#211527
All processes killed
========== OTL ==========
Prefs.js: "" removed from browser.startup.homepage
C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{972ce4c6-7e08-4474-a285-3208198ce6fd} folder moved successfully.
Registry key HKEY_USERS\S-1-5-21-4277464422-782500475-2693772901-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ZoneMap\Domains\samsungsetup.com\www\ deleted successfully.
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters\\DhcpNameServer| /E : value set successfully!
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{15F98FC0-85EB-4151-96B3-92B8DBB0C035}\\NameServer| /E : value set successfully!
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{173D8498-F4E7-4914-8F83-EA9614422F5F}\\DhcpNameServer| /E : value set successfully!
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{173D8498-F4E7-4914-8F83-EA9614422F5F}\\NameServer| /E : value set successfully!
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{5AEC0CFA-8D46-48DE-A373-570680F4EA99}\\NameServer| /E : value set successfully!
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{5C1051EE-0027-4341-83AF-C5C78360A1E6}\\NameServer| /E : value set successfully!
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{93B39732-02AA-4FF6-A73D-FE19EE56E502}\\NameServer| /E : value set successfully!
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{9CBCB873-025D-48CC-BF60-95FD0223CAC5}\\NameServer| /E : value set successfully!
[EMPTYTEMP]
User: All Users
User: Caroline
->Temp folder emptied: 1448927984 bytes
->Temporary Internet Files folder emptied: 1465416 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 176503033 bytes
->Google Chrome cache emptied: 414179349 bytes
->Apple Safari cache emptied: 0 bytes
->Flash cache emptied: 3084 bytes
User: Default
User: Default User
User: Public
%systemroot% .tmp files removed: 4251555 bytes
Windows Temp folder emptied: 2813318 bytes
%systemroot%\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 39454 bytes
%systemroot%\system32\config\systemprofile\AppData\LocalLow\Sun\Java\Deployment folder emptied: 755 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 42293561 bytes
RecycleBin emptied: 30233052 bytes
Total Files Cleaned = 2Â 022,00 mb
[EMPTYFLASH]
User: All Users
User: Caroline
User: Default
User: Default User
User: Public
Total Flash Files Cleaned = 0,00 mb
C:\Windows\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
OTL by OldTimer - Version 3.2.69.0 log created on 12182014_104601
C:\Users\Caroline\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
C:\Windows\temp\CAROLINE-PC-20141218-0736.log moved successfully.
File\Folder C:\Windows\temp\officeclicktorun.exe_c2ruidll(20141218073619490).log not found!
File\Folder C:\Windows\temp\officeclicktorun.exe_streamserver(20141218073621490).log not found!
File move failed. C:\Windows\SysWow64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat scheduled to be moved on reboot.
File move failed. C:\Windows\SysNative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat scheduled to be moved on reboot.
#211587
  • Télécharge (de ESET) sur ton bureau.
  • Clic sur Démarrer
par Paqui
#211627
:\Users\Caroline\Downloads\PDFCreator-1_7_3_setup.exe Win32/InstallMonetizer.AQ application potentiellement indésirable supprimé - mis en quarantaine
Pas de changement a priori...
Est-ce que tu penses que le problème est lié à l'histoire de la DNS 127.0.0.1 comme je le pressens ?
Merci encore
#211637
Ouep, ça vient pas d'une infection mais d'un réglage que t'as du faire.
On va supprimer les outils d'analyse et de désinfection histoire de faire le ménage :)
par Paqui
#211638
Un réglage ? Mais quel réglage ?
En tout cas si j'ai changé quelque chose, c'est à l'insu de mon plein gré comme dirait l'autre...
Mais ça n'explique pas pourquoi je ne peux pas changer la config pour remettre "dns automatique", c'est quand même pas normal que ma modif s'annule, si ?
Bref, tu préconiserais quoi ? Tout remettre à zéro sur l'ordi ? (j'aimerais éviter mais s'il n'y a que ça je vais devoir m'y résoudre...)
#211640
hello juste une question , ca fait longtemps que tu as installé le VPN ?
les problemes ne dateraient pas de cela ? desisntalle-le pour voir à mon avis c'est lui qui bloque tout
par Paqui
#211643
Le VPN c'est quoi ? Le fait que nos ordis soient en réseau ? Non ça ça fait longtemps.
Sinon si c'est autre chose comment je le désinstalle ?
Bon alors je sais pas si ça va durer, mais j'ai tenté un truc un peu radical, j'ai désinstallé la carte réseau, redémarré l'ordi, et là c'est revenu à DNS automatique et ça ne bouge pas pour l'instant. Je ne veux pas crier victoire trop vite mais déjà c'est un changement qui me plait bien. Affaire à suivre...
Merci !
