par niconico10
#211776
All processes killed
Registry value HKEY_USERS\S-1-5-21-265772704-413240918-312726416-1000\Software\Microsoft\Windows\CurrentVersion\Run\\cacaoweb deleted successfully.
HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\\"EnableFirewall"|DWORD:0 /E : value set successfully!
HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\\"EnableFirewall"|DWORD:0 /E : value set successfully!
HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\PublicProfile\\"EnableFirewall"|DWORD:0 /E : value set successfully!
HKU\S-1-5-21-265772704-413240918-312726416-1000\SOFTWARE\Microsoft\Internet Explorer\Toolbar\\"Locked"|DWORD:0 /E : value set successfully!
Registry key HKEY_LOCAL_MACHINE\Software\BrowserChoice\ deleted successfully.
Registry key HKEY_USERS\S-1-5-18\Software\5c6db8cbd6eed17\ deleted successfully.
Registry key HKEY_CLASSES_ROOT\Installer\Products\5C9F59CB830AEE547A93698B6A7DF9D7\ deleted successfully.
========== FILES ==========
C:\Windows.old\Documents and Settings\Administrateur\Application Data\SecuROM\UserData folder moved successfully.
C:\Windows.old\Documents and Settings\Administrateur\Application Data\SecuROM folder moved successfully.
C:\Windows.old\Documents and Settings\Administrateur\Application Data folder moved successfully.
C:\Windows.old\Documents and Settings\Administrateur folder moved successfully.
C:\Windows.old\Documents and Settings folder moved successfully.
C:\Windows.old folder moved successfully.
C:\Windows.old.000\Users\nico et steph\Desktop folder moved successfully.
C:\Windows.old.000\Users\nico et steph folder moved successfully.
C:\Windows.old.000\Users folder moved successfully.
C:\Windows.old.000 folder moved successfully.
C:\Users\nicoetsteph\tmp1.36 moved successfully.
C:\Users\nicoetsteph\tmp1.37 moved successfully.
C:\Users\nicoetsteph\tmp1.38 moved successfully.
C:\Windows\System32\Tasks\CreateChoiceProcessTask moved successfully.
[EMPTYTEMP]
User: All Users
User: Default
User: Default User
User: nicoetsteph
->Temp folder emptied: 8646 bytes
->Temporary Internet Files folder emptied: 87378337 bytes
->Java cache emptied: 2946643 bytes
->Flash cache emptied: 966 bytes
User: Public
%systemroot%\System32 .tmp files removed: 2347008 bytes
Windows Temp folder emptied: 730835 bytes
%systemroot%\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 22157056 bytes
RecycleBin emptied: 504112 bytes
Total Files Cleaned = 111,00 mb
OTM by OldTimer - Version 3.1.21.0 log created on 12212014_212535
Files moved on Reboot...
File move failed. C:\Windows\temp\_avast_\AvastLock.txt scheduled to be moved on reboot.
#211802
ok bonsoir tu peux citer les soucis restants ?
par niconico10
#211804
bonsoir
mon seul souci était boxore...
j'ai ensuite suivi tes directives... à toi de me dire s'il reste des bêbêtes ou si tout est en règle.. (désolé mais je suis une bille en informatique alors j'ai déjà pas compris la moitié de ce que tu m"as fait faire.. je te fais confiance....)
par contre, je dois supprimer les adsfix, zhpdiag,...????
#211805
la réponse à toutes tes questions se trouvent dans la suite , par contre attention à qui tu fais confiance sur internet , quand quelqu'un te propose son aide renseigne-toi sur google sur son pseudo ( surnom , comme moi ici , g3n-h@ckm@n ) , tu tapes le pseudo sur google et tu lis un peu son palmarès , histoire de voir s'il va pas t'amener à la catastrophe avec ta machine.
sur ce , :
    configure-le comme ceci :
    les options :
    • Télécharge sur ton Bureau.
      • Réactiver l'UAC
No Internet Explorer :
Internet Explorer :
par niconico10
#211808
ok. j'ai fait tout ça.
merci beaucoup pour l'aide et le temps passé, G3n (j'avoue avoir cherché sur google des infos sur sos virus avant de poster...)
bonnes fêtes de fin d'année à toi et bonne continuation.
