#213711
plus grand chose , tu vas passer ce script et me refaire un ZHPDiag ensuite ! (hébergé ce sera mieux !)
    M2 - MFEP: prefs.js [Martin - 2bf5vgze.default\jid1-U7omKQ6kQfxMaQ@jetpack] [] Booster Web v1.7.7 (..)    => PUP.BoosterWeb
    O4 - GS\Desktop [Martin]: µTorrent.lnk . (.BitTorrent Inc. - µTorrent.) -- C:\Users\Martin\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent
    OPT:O4 - HKLM\..\Wow6432Node\Run: [QuickTime Task] . (.Apple Inc. - QuickTime Task.) -- C:\Program Files (x86)\QuickTime\QTTask.exe
    O4 - HKLM\..\Wow6432Node\Run: [CitrixReceiver] C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Citrix\Receiver Updater.lnk (.not file.)    => Fichier absent
    [MD5.00000000000000000000000000000000] [APT] [YMJI] (...) -- C:\Users\Martin\AppData\Roaming\YMJI.exe (.not file.) [0]    => Infection FakeAlert (Possible)
    [MD5.00000000000000000000000000000000] [APT] [ZBDU] (...) -- C:\Users\Martin\AppData\Roaming\ZBDU.exe (.not file.) [0]    => Infection FakeAlert (Possible)
    O39 - APT: - (..) -- C:\Windows\System32\Tasks\FacebookUpdateTaskUserS-1-5-21-1233262645-512252785-536942539-1002Core [918]    => Facebook Update Task User
    O39 - APT: - (..) -- C:\Windows\System32\Tasks\FacebookUpdateTaskUserS-1-5-21-1233262645-512252785-536942539-1002UA [940]    => Facebook Update Task User
    [HKCU\Software\AI_RecycleBin]   =>Adware.Agent
    [HKLM\Software\Wow6432Node\Client]
    O43 - CFD: 29/07/2014 - 07:21:26 - [] ----D C:\Users\Martin\AppData\Local\Setup Integrity Check
    O45 - LFCP:[MD5.5F7B472BE173EDAC8BA1CECB40E0D99A] - 24/01/2015 - 16:30:10 ---A- - C:\Windows\Prefetch\UTORRENT.EXE-5884B64D.pf   =>P2P.µTorrent
    O87 - FAEL: "{1B4185EA-5BEB-435E-A082-D273A623BF0D}" | In - None - P6 - TRUE | .(.BitTorrent Inc. - µTorrent.) -- C:\Users\Martin\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent
    O87 - FAEL: "{3B3EAD52-F324-4D6F-AE16-96259B59E734}" | In - None - P17 - TRUE | .(.BitTorrent Inc. - µTorrent.) -- C:\Users\Martin\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent
    [HKCU\Software\AI_RecycleBin]   =>Adware.Agent^
    ProxyFix
    EmptyPrefetch
    SysRestore
    FirewallRAZ
    EmptyTemp
    exemple :
et donc un ZHPDiag pour vérification
#214022
:bravo1: pour moi c'est bon :
[img]https://upload.sosvirus.net/img/images/2015/02/08/Capturec1c21.jpg[/img]
Voici les canneds de fin et mes conseils , si tu as des questions .....
mes conseils :
fin de désinfection
Pour commencer , à lire , instructif :
Et aussi :
Pour terminer :
Beaucoup d'entre eux peuvent être dangereux et entrainer des dommages irréversibles sur ton système s'ils sont utilisés sans l'aide d'une personne qualifiée, de plus, fréquemment modifiés et mis à jour par leurs auteurs ils deviennent très rapidement obsolètes, en plus d'encombrer inutilement ton bureau.
Delfix
A - Télécharges DelFix sur votre bureau ICI
ps :Pour usage simple si rien n'est indiqué le passer comme il est programmé !
2/ Puis nettoyage
CCleaner
Instalation et fonctionnement de Ccleaner(N'installe pas la Yahoo Toolbar)
sauf l'antivirus !
puis à l'onglet recherche , supprimer , puis encore recherche et supprimer !plusieurs fois , jusqu'a ce qu'il n'y ai plus rien
4 - Clique sur Appliquer.
OU : Logiciel de Lady >>(très simple d'utilisation) :
D'autre liens TRàˆSutiles Pour les mises à jour :
- Java : https://www.sosvirus.net/telecharger/java/
- Adobe reader : https://www.sosvirus.net/telecharger/adobe-reader/
- Flash player : https://www.sosvirus.net/telecharger/flash-player/
- Update checker : https://www.sosvirus.net/telecharger/update-checker/
- Delfix : https://www.sosvirus.net/telecharger/delfix/
- Ccleaner : https://www.sosvirus.net/telecharger/ccleaner/
- Unchecky : https://www.sosvirus.net/telecharger/unchecky/
- Comodo : https://www.sosvirus.net/telecharger/co ... l-windows/
1/ - Conserve MBAM ICI
Il te servira à scanner les fichiers douteux en complément de l'antivirus et scanne le disque dur régulièrement. Mais n'oublie pas de faire la mise à jour avant de lancer le scan.
2/ -
Voici une extension à télécharger qui te permettra, en faisant tes recherches sur google, de savoir si le site proposé lors de tes recherches est un site de confiance ou un site à éviter car il pourrait infecter ton PC :
Pour Firefox :
Pour internet explorer:
4/ -
5/ -
6/ -
7/ -
8/ -
9/ -
10/ -
11/ -
- Sois plus vigilant(e) sur Internet à l'avenir !
Voilà pour moi c'est terminé.
