#213602
Java à mettre à jour : Logiciel: Java 7 Update 71
Version 8 Update 31
tu connais ces logiciels :
Logiciel: ACB+
Logiciel: ArcelorMittal Beams Calculator
Logiciel: EQUER 3.4.6.0
Logiciel: MZ-Tools 3.0 pour VBA
Logiciel: PDF to Excel Converter
Logiciel: PTC Mathcad Prime 3.0
Logiciel: WD My Cloud
Logiciel: Windows 8 Development Essentials
Tu les as acheté ou tu les as eu gratuit , et ou ?
Merci !
ensuite tu vas passer ce script :
    [MD5.ADB838F9F78C33262EB263193E021980] - (.PC Utilities Software Limited - OptimizerPro – Clean up your PC.) -- C:\ProgramData\{8fdba9b6-6d68-028b-8fdb-ba9b66d6a6d9}\OptimizerProInstaller.exe   [5939704] [PID.4828]   =>PUP.OptimizerPro
    R5 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyHttp1.1 = 0    => Internet Explorer Proxy GET HTTP1.1 Disabled
    O2 - BHO: IETabPage Class [64Bits] - {3593C8B9-8E18-4B4B-B7D3-CB8BEB1AA42C} . (...) -- C:\Program Files (x86)\XTab\SupTab.dll (.not file.)   =>PUP.SupTab
    O2 - BHO: (no name) [64Bits] - {56e32636-e2b8-4b04-9a97-60581dd90f51} Clé orpheline    => Orphean Key not necessary
    O2 - BHO: Google Toolbar Helper [64Bits] - {AA58ED58-01DD-4d91-8333-CF10577473F7} . (.Google Inc. - Google Toolbar.) -- C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
    O3 - Toolbar: (no name) - [HKLM]{56e32636-e2b8-4b04-9a97-60581dd90f51} Clé orpheline    => Orphean Key not necessary
    O3 - Toolbar: Adobe Acrobat Create PDF Toolbar - [HKLM]{47833539-D0C5-4125-9FA8-0819E2EAAC93} . (.Adobe Systems Incorporated - Adobe PDF Toolbar for Internet Explorer.) -- C:\Program Files (x86)\Common Files\Adobe\Acrobat\WCIEActiveX\x64\AcroIEFavClient.dll
    O3 - Toolbar: Google Toolbar - [HKLM]{2318C2B1-4965-11d4-9B18-009027A5CD4F} . (.Google Inc. - Google Toolbar.) -- C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_64.dll
    O3 - Toolbar\WebBrowser: (no name) - [HKCU]{47833539-D0C5-4125-9FA8-0819E2EAAC93} Clé orpheline    => Adobe - Acrobat
    O3 - Toolbar\WebBrowser: (no name) - [HKCU]{2318C2B1-4965-11D4-9B18-009027A5CD4F} Clé orpheline    => Toolbar.Google
    O4 - GS\Program [Public]: Mozilla Firefox.lnk . (.Mozilla Corporation - Firefox.)  -- C:\Program Files (x86)\Mozilla Firefox\firefox.exe https://istart.webssearches.com   =>Hijacker.WebsSearches
    O4 - GS\Startup [José]: OptimizerProInstaller.lnk . (.PC Utilities Software Limited - OptimizerPro – Clean up your PC.)  -- C:\ProgramData\{8fdba9b6-6d68-028b-8fdb-ba9b66d6a6d9}\OptimizerProInstaller.exe   =>PUP.OptimizerPro
    O4 - HKLM\..\Run: [SBRegRebootCleaner] C:\Program Files (x86)\STOPzilla!\sbrc.exe (.not file.)    => Fichier absent
    OPT:O4 - HKLM\..\Wow6432Node\Run: [iTunesHelper] . (.Apple Inc. - iTunesHelper.) -- C:\Program Files (x86)\iTunes\iTunesHelper.exe
    OPT:O4 - HKLM\..\Wow6432Node\Run: [QuickTime Task] . (.Apple Inc. - QuickTime Task.) -- C:\Program Files (x86)\QuickTime\QTTask.exe
    OPT:O23 - Service: Service Bonjour (Bonjour Service) . (.Apple Inc. - Bonjour Service.) - C:\Program Files\Bonjour\mDNSResponder.exe
    [MD5.00000000000000000000000000000000] [APT] [zupa3002] (...) -- C:\Program Files (x86)\TabNav\zupa3002.exe (.not file.)   [0]    => Fichier absent
    O42 - Logiciel: Google Toolbar for Internet Explorer - (.Google Inc..) [HKLM][64Bits] -- {18455581-E099-4BA8-BC6B-F34B2F06600C}    => Toolbar.Google
    O42 - Logiciel: Google Toolbar for Internet Explorer - (.Google Inc..) [HKLM][64Bits] -- {2318C2B1-4965-11d4-9B18-009027A5CD4F}    => Toolbar.Google
    O42 - Logiciel: Java 7 Update 71 - (.Oracle.) [HKLM][64Bits] -- {26A24AE4-039D-4CA4-87B4-2F83217025FF}    => Oracle
    [HKCU\Software\AppDataLow\{1146AC44-2F03-4431-B4FD-889BC837521F}]    => PUP.OptimizerPro
    [HKCU\Software\Reg]
    [HKLM\Software\Wow6432Node\Reg]
    [HKLM\Software\Wow6432Node\WinPj]
    O45 - LFCP:[MD5.184590C07211CE9C1B4FF3849F8216AA] - 03.02.2015 - 21:50:13 ---A- - C:\Windows\Prefetch\OPTIMIZERPROINSTALLER.EXE-97F33F17.pf   =>PUP.OptimizerPro
    O62 - ADS:Alternate Data Stream File - C:\Windows\System32\install.bat:Zone.Identifier
    O62 - ADS:Alternate Data Stream File - C:\Windows\System32\readme.txt:Zone.Identifier
    O62 - ADS:Alternate Data Stream File - C:\Windows\System32\uninstall.bat:Zone.Identifier
    OPT:SR - | Auto 30.08.2011 462184 |  (Bonjour Service) . (.Apple Inc..) - C:\Program Files\Bonjour\mDNSResponder.exe
    [HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3593C8B9-8E18-4B4B-B7D3-CB8BEB1AA42C}]   =>PUP.SupTab^
    [HKCU\Software\AppDataLow\{1146AC44-2F03-4431-B4FD-889BC837521F}]   =>PUP.OptimizerPro
    C:\Users\José\AppData\Local\Installer   =>Adware.InstallPedia
    C:\ProgramData\{8fdba9b6-6d68-028b-8fdb-ba9b66d6a6d9}\OptimizerProInstaller.exe   =>PUP.OptimizerPro^
    ProxyFix
    EmptyPrefetch
    SysRestore
    FirewallRAZ
    EmptyTemp
    exemple :
ensuite tu me dis comment ça va
OK ??
par REGUEIRO
#213604
MERCI
en Réponse à tes questions :
Logiciel: ACB+
Logiciel Gratuit sur le Site de ArcelorMittals pour le dimensionnement statique
IZUBA énergies développe et diffuse des outils d'analyse énergétique, Gratuit
Pour Programmation en VBA sur Excel très pratique, Gratuit.
Sur un site je ne sais plus lequel ?
Logiciel achetée pour mon Serveur NAS Western Digital
Je ne sais ??
Je fais le nécessaire pour le reste.
Bonne soirée
#213681
Bonjour José
ok plus d'infections , pas mal de logiciels que je ne connais pas , qui sont en non traité mais plus d'infections :
[img]https://upload.sosvirus.net/img/images/2015/02/05/Capture08620.jpg[/img]
voici donc les canneds de fin et mes conseils ...
mes conseils :
fin de désinfection
Pour commencer , à lire , instructif :
Et aussi :
Pour terminer :
Beaucoup d'entre eux peuvent être dangereux et entrainer des dommages irréversibles sur ton système s'ils sont utilisés sans l'aide d'une personne qualifiée, de plus, fréquemment modifiés et mis à jour par leurs auteurs ils deviennent très rapidement obsolètes, en plus d'encombrer inutilement ton bureau.
Delfix
A - Télécharges DelFix sur votre bureau ICI
ps :Pour usage simple si rien n'est indiqué le passer comme il est programmé !
2/ Puis nettoyage
CCleaner
Instalation et fonctionnement de Ccleaner(N'installe pas la Yahoo Toolbar)
sauf l'antivirus !
puis à l'onglet recherche , supprimer , puis encore recherche et supprimer !plusieurs fois , jusqu'a ce qu'il n'y ai plus rien
4 - Clique sur Appliquer.
OU : Logiciel de Lady >>(très simple d'utilisation) :
D'autre liens TRàˆSutiles Pour les mises à jour :
- Java : https://www.sosvirus.net/telecharger/java/
- Adobe reader : https://www.sosvirus.net/telecharger/adobe-reader/
- Flash player : https://www.sosvirus.net/telecharger/flash-player/
- Update checker : https://www.sosvirus.net/telecharger/update-checker/
- Delfix : https://www.sosvirus.net/telecharger/delfix/
- Ccleaner : https://www.sosvirus.net/telecharger/ccleaner/
- Unchecky : https://www.sosvirus.net/telecharger/unchecky/
- Comodo : https://www.sosvirus.net/telecharger/co ... l-windows/
1/ - Conserve MBAM ICI
Il te servira à scanner les fichiers douteux en complément de l'antivirus et scanne le disque dur régulièrement. Mais n'oublie pas de faire la mise à jour avant de lancer le scan.
2/ -
Voici une extension à télécharger qui te permettra, en faisant tes recherches sur google, de savoir si le site proposé lors de tes recherches est un site de confiance ou un site à éviter car il pourrait infecter ton PC :
Pour Firefox :
Pour internet explorer:
4/ -
5/ -
6/ -
7/ -
8/ -
9/ -
10/ -
11/ -
- Sois plus vigilant(e) sur Internet à l'avenir !
Voilà pour moi c'est terminé.
par REGUEIRO
#213713
BONSOIR
Merci beaucoup pour votre Aide. :bravo1:
ça a l'air de très bien marcher.
A Bientôt
Longue Vie à votre Site
Bonne Soirée
