#213793
  • Lance AdsFix
  • Inscrit ton pays
Aide:
#213947
:hello:
drivers32
%APPDATA%\*.
%APPDATA%\*.exe /s
%temp%\*.exe /s
%SYSTEMDRIVE%\*.exe
%systemroot%\*. /mp /s
services.exe
SAVEMBR:0
  • Clique sur Analyse
  • Copie le contenu des rapports OTL.txt et Extras.txt sur puis copie/colle le lien généré dans ta prochaine réponse.
Note : Au cas oà¹, tu peux les retrouver dans le dossier C:\OTL ou sur ton bureau en fonction des cas rencontrés[/list]
#214061
:hello:
  • Relance OTL.
    :OTL
    O3:64bit: - HKLM\..\Toolbar: (no name) - Locked - No CLSID value found.
    :files
    %Temp%\*.*
    C:\Program Files (x86)\Mozilla Firefox\extensions\toolbar@iadah.com
    C:\Users\j-jlekosz\AppData\Local\{9BA973B4-56B8-4F43-AFCA-C9D628438FA3}
    C:\Users\j-jlekosz\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\ZSoft
    C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ZSoft
    C:\Program Files (x86)\ZSoft
    :Commands
    [emptytemp]
    [emptyflash]
    [resethosts]
    [reboot]
  • Image
#214068
salut, content de te revoir :D
voici le rapport :
All processes killed
========== OTL ==========
64bit-Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\Locked deleted successfully.
========== FILES ==========
C:\Users\J-JLEK~1\AppData\Local\Temp\aipflib.log moved successfully.
File move failed. C:\Users\J-JLEK~1\AppData\Local\Temp\FXSAPIDebugLogFile.txt scheduled to be moved on reboot.
C:\Users\J-JLEK~1\AppData\Local\Temp\LManager.log moved successfully.
C:\Users\J-JLEK~1\AppData\Local\Temp\LMworker.log moved successfully.
C:\Program Files (x86)\Mozilla Firefox\extensions\toolbar@iadah.com\chrome folder moved successfully.
C:\Program Files (x86)\Mozilla Firefox\extensions\toolbar@iadah.com folder moved successfully.
C:\Users\j-jlekosz\AppData\Local\{9BA973B4-56B8-4F43-AFCA-C9D628438FA3} moved successfully.
C:\Users\j-jlekosz\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\ZSoft\Uninstaller folder moved successfully.
C:\Users\j-jlekosz\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\ZSoft folder moved successfully.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ZSoft\Uninstaller folder moved successfully.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\ZSoft folder moved successfully.
C:\Program Files (x86)\ZSoft\Uninstaller\PostUninstall folder moved successfully.
C:\Program Files (x86)\ZSoft\Uninstaller\logs folder moved successfully.
C:\Program Files (x86)\ZSoft\Uninstaller\LogBackups folder moved successfully.
C:\Program Files (x86)\ZSoft\Uninstaller\lang folder moved successfully.
C:\Program Files (x86)\ZSoft\Uninstaller folder moved successfully.
C:\Program Files (x86)\ZSoft folder moved successfully.
[EMPTYTEMP]
User: All Users
User: Default
->Temporary Internet Files folder emptied: 32902 bytes
User: Default User
User: j-jlekosz
->Temporary Internet Files folder emptied: 161 bytes
->Java cache emptied: 505734 bytes
->FireFox cache emptied: 44519486 bytes
->Flash cache emptied: 779 bytes
User: Public
Windows Temp folder emptied: 16706 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 58535929 bytes
RecycleBin emptied: 6010 bytes
Total Files Cleaned = 99,00 mb
[EMPTYFLASH]
User: All Users
User: Default
User: Default User
User: j-jlekosz
User: Public
Total Flash Files Cleaned = 0,00 mb
C:\Windows\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
OTL by OldTimer - Version 3.2.69.0 log created on 02092015_135007
C:\Users\J-JLEK~1\AppData\Local\Temp\FXSAPIDebugLogFile.txt moved successfully.
File\Folder C:\Users\j-jlekosz\AppData\Local\Temp\FXSAPIDebugLogFile.txt not found!
C:\Users\j-jlekosz\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
#214070
ca y 'est j 'arrive à ouvrir google :-):-)
Ouep, ça venait de ton fichier hosts , je pense que c'était cette toolbar la responsable : toolba[at]iadah.com
Bonne semaine :hello:
  • Télécharge CCleaner
  • Procède à l'installation de celui çi
  • Clic sur Oui
  • Clic sur Nettoyer
  • Clic sur OK
  • Clique sur Registre
  • Clique sur fermer
