par Antoine971
#214053
############################## | UsbFix V 7.812 | [Nettoyage]
Utilisateur: Antoine (Administrateur) # ANTOINE-PC
Mis à jour le 03/02/2015 par El Desaparecido - SosVirus
Lancé à 00:27:36 | 09/02/2015
Site Web :
Changelog :
Détection en Live :
Contact :
MB: Acer (Roxy)
CPU: Intel(R) Celeron(R) CPU N2840 @ 2.16GHz
RAM -> [Total : 1933 Mo | Free : 1160 Mo]
Bios: Insyde Corp.
OS: Microsoftâ„¢ Windows 7 Professional (6.1.7600 64-Bit)
WB: Internet Explorer : 8.00.7600.16385
WB: Google Chrome : 40.0.2214.111
AV: avast! Antivirus [(!) Désactivé |A jour]
AS: avast! Antivirus [(!) Désactivé |A jour]
FW: Windows Firewall [(!) Désactivé]
SC: Security Center [Actif]
WU: Windows Update [Actif]
C:\ (%SystemDrive%) -> Disque fixe # 298 Go (251 Go libre(s) - 84%) [] # NTFS
D:\ -> Disque amovible # 15 Go (15 Go libre(s) - 100%) [PETITJEAN] # FAT32
(!) Fichiers temporaires supprimés. (0.644923210144043 MB)
F2 - HKLM\..\Winlogon : [Userinit] C:\Windows\Syswow64\userinit.exe,
04 - HKLM\..\Run : [USB3MON] "C:\Program Files (x86)\Intel\Intel(R) USB 3.0 eXtensible Host Controller Driver\Application\iusb3mon.exe"
04 - [x64] HKLM\..\Run : [RTHDVCPL] "C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe" -s
04 - [x64] HKLM\..\Run : [UMonit64] C:\Windows\SysWOW64\UMonit64.exe
04GS - Bluetooth.lnk : C:\Program Files (x86)\WIDCOMM\Bluetooth Software\BTTray.exe
Info :
Info :
Détection en Live :
################## | Hijack |
[09/02/2015 - 00:00:17 | RA | 13 Ko] - C:\Pre_Scan_09_02_2015_00_00_17.txt
[09/02/2015 - 00:24:22 | ASH | 1484820 Ko] - C:\hiberfil.sys
[09/02/2015 - 00:24:26 | ASH | 1979764 Ko] - C:\pagefile.sys
[06/02/2015 - 09:06:00 | D] - C:\Config.Msi
[09/02/2015 - 00:02:34 | SHD] - C:\$Recycle.Bin
[13/07/2009 - 22:20:08 | D] - C:\PerfLogs
[14/07/2009 - 00:08:56 | SD] - C:\Documents and Settings
[27/01/2015 - 18:17:46 | SHD] - C:\Recovery
[27/01/2015 - 18:17:59 | RD] - C:\Users
[27/01/2015 - 19:21:54 | D] - C:\Intel
[27/01/2015 - 19:33:51 | D] - C:\Temp
[28/01/2015 - 06:21:04 | RHD] - C:\MSOCache
[05/02/2015 - 23:35:28 | RD] - C:\Program Files (x86)
[08/02/2015 - 01:04:09 | HD] - C:\ProgramData
[08/02/2015 - 01:05:11 | RD] - C:\Program Files
[08/02/2015 - 01:10:24 | D] - C:\Windows
[08/02/2015 - 14:45:39 | D] - C:\UsbFix
[09/02/2015 - 00:00:29 | D] - C:\Pre_Scan
################## | D:\ - Disque USB (FAT32) |
#214060
bonjour pour avancer :
rends-toi sur puis fais analyser ce fichier :
une fois l'analyse des antivirus terminée , récupère le lien de la page en haut puis colle-le ici que je puisse m'y rendre pour consulter
#214118
:hello:
  • Coche la case Addition.txt
  • Clique sur Scan
