#214210
    P2 - FPN: [HKCU] [@unity3d.com/UnityPlayer,version=1.0] - (...) -- C:\Users\killian\AppData\LocalLow\Unity\WebPlayer\loader\npUnity3D32.dll (.not file.)
    C:\Users\killian\AppData\Roaming\Mozilla\Firefox\Profiles\vcdfrmx2.default-1423143994229\prefs.js (.not file.)
    M2 - MFEP: Extension [killian - vcdfrmx2.default-1423143994229] {91A6D6AB-3E9A-4C00-A3CF-B08CBE803A2E}.xpi
    M2 - MFEP: Extension [killian - vcdfrmx2.default-1423143994229] {d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}.xpi  =>.Adblock Plus Extension Mozilla Firefox
    M2 - MFEP: Extension [killian - qlxj0imw.default-1423234886116] {91A6D6AB-3E9A-4C00-A3CF-B08CBE803A2E}.xpi
    O4 - HKLM\..\Run: [TosNC] C:\Program Files (x86)\Toshiba\BulletinBoard\TosNcCore.exe (.not file.)
    O4 - HKLM\..\Run: [TosReelTimeMonitor] C:\Program Files (x86)\TOSHIBA\ReelTime\TosReelTimeMonitor.exe (.not file.)
    O4 - HKLM\..\Run: [TPwrMain] C:\Program Files (x86)\TOSHIBA\Power Saver\TPwrMain.exe (.not file.)
    O4 - HKLM\..\Run: [SmoothView] C:\Program Files (x86)\Toshiba\SmoothView\SmoothView.exe (.not file.)
    O4 - HKLM\..\Run: [00TCrdMain] C:\Program Files (x86)\TOSHIBA\FlashCards\TCrdMain.exe (.not file.)
    O4 - HKLM\..\Run: [SynTPEnh] C:\Program Files (x86)\Synaptics\SynTP\SynTPEnh.exe (.not file.)
    O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - CLSID or File not found.
    [MD5.00000000000000000000000000000000] [APT] [{56C500B4-E9AE-454F-BDBE-A4A2568ADAA9}] (...) -- E:\NeroExpress\setup.exe (.not file.)   [0]
    O42 - Logiciel: Unity Web Player - (.Unity Technologies ApS.) [HKCU][64Bits] -- UnityWebPlayer
    O43 - CFD: 09/02/2015 - 09:17:10 - [0] ----D C:\Program Files (x86)\Avira
    O43 - CFD: 21/09/2012 - 16:25:46 - [0] --H-D C:\Users\killian\AppData\Roaming\{D94BA408-F110-488B-A65E-3AE7945F79E6}
    O43 - CFD: 09/02/2015 - 09:17:12 - [] ----D C:\ProgramData\Avira
    O53 - SMSR:HKLM\...\startupreg\SmartFaceVWatcher  [Key] . (...) -- C:\Program Files (x86)\Toshiba\SmartFaceV\SmartFaceVWatcher.exe (.not file.)
    O53 - SMSR:HKLM\...\startupreg\Adobe Reader Speed Launcher  [Key] . (...) -- C:\Program Files (x86)\Adobe\Reader 9.0\Reader\Reader_sl.exe (.not file.)
    O53 - SMSR:HKLM\...\startupreg\Google Update  [Key] . (...) -- C:\Users\killian\AppData\Local\Google\Update\GoogleUpdate.exe (.not file.)
    O61 - LFC: 04/02/2015 - 09:54:04 ---A- . (.Google Inc..) -- C:\Users\killian\AppData\Local\Google\Chrome\User Data\WidevineCDM\1.4.6.758\_platform_specific\win_x86\widevinecdmadapter.dll   [142152]
    O61 - LFC: 05/02/2015 - 09:54:25 ---A- . (.SurfRight B.V..) -- C:\Users\killian\Downloads\HitmanPro_x64.exe   [11225840]
    O61 - LFC: 06/02/2015 - 09:54:24 ---A- . (...) -- C:\Users\killian\Downloads\Firefox Setup Stub 35.0.1.exe   [243680]
    O61 - LFC: 06/02/2015 - 09:54:26 ---A- . (...) -- C:\Users\killian\ZHPCleaner.exe   [1466880]  =>.Nicolas Coolman
    O61 - LFC: 07/02/2015 - 09:54:05 ---A- . (...) -- C:\Users\killian\AppData\Local\Microsoft\Internet Explorer\UrlBlockManager\urlblocklist.bin   [0]
    O61 - LFC: 07/02/2015 - 09:54:24 ---A- . (.Google Inc..) -- C:\Users\killian\Downloads\ChromeSetup.exe   [880208]
    O61 - LFC: 08/02/2015 - 09:54:24 ---A- . (.AVAST Software.) -- C:\Users\killian\Downloads\avast_free_antivirus_setup_online.exe   [5002256]
    O61 - LFC: 08/02/2015 - 09:54:24 ---A- . (.Avira Operations GmbH & Co. KG.) -- C:\Users\killian\Downloads\avira_registry_cleaner_en.exe   [1087448]
    O61 - LFC: 10/02/2015 - 09:54:13 ---A- . (.SurfRight B.V..) -- C:\Users\killian\AppData\Local\Temp\HitmanPro.exe   [11227888]
    firewallraz
    emptyclsid
    emptyprefetch
    EmptyCLSID
    Emptytemp
  • Copie le contenu du rapport ZHPFixReport sur , puis copie/colle le lien généré dans ta prochaine réponse.
  • Lance AdsFix
  • Inscrit ton pays
Aide:
#214244
non rien de precisé aucun chemin rien
juste ca dans avast
hxtps://upload.sosvirus.net/download/x3v ... abtclxa0qn
la je viens de supprimer chrome du pc et tout les fichier de sauvegarde et autre
je l'ai réinstaller avec du mal mais j'ai enfin reussi
je redemarre le pc pour voir ce que ca donne
et pas de detection par avast
Modifié en dernier par chris14 le mer. 11 févr. 2015 18:33, modifié 3 fois.
#214333
bonjour , il ne fallait pas éditer mais ajouter , tu aurais pu attendre longtemps ^^ des soucis persistent ?
