#214221
Oui, tu as bien fait pour la version 32 bit :super:
  • Clic sur OK
    start
    HKLM\...\Run: [] => [X]
    HKLM\...\Winlogon: [Userinit] C:\Windows\system32\ezShellStart.exe,
    CHR HKLM\SOFTWARE\Policies\Google: Policy restriction <======= ATTENTION
    BHO: buYfaset -> {a9f1c3ed-d9ed-4ade-a794-735091647bf4} -> C:\Program Files\buYfaset\glb7soUQ5lxXhA.dll ()
    Toolbar: HKU\S-1-5-21-2530834142-3848215751-2339319245-1000 -> No Name - {2318C2B1-4965-11D4-9B18-009027A5CD4F} -  No File
    FF Extension: saleepRizes - C:\Users\lekosz\AppData\Roaming\Mozilla\Firefox\Profiles\x3pbycux.default\Extensions\kzyDack0Ok@y.net [2015-02-11]
    FF Extension: brOwoseannddshop - C:\Users\lekosz\AppData\Roaming\Mozilla\Firefox\Profiles\x3pbycux.default\Extensions\n7lb@ZszhAf.edu [2015-02-11]
    S3 NwlnkFlt; system32\DRIVERS\nwlnkflt.sys [X]
    S3 NwlnkFwd; system32\DRIVERS\nwlnkfwd.sys [X]
    2015-02-10 17:26 - 2015-02-10 17:27 - 00000000 ____D () C:\Program Files\Facebook Colors
    2015-02-10 17:26 - 2015-02-10 17:26 - 00000000 ____D () C:\Program Files\fastSalier
    2015-02-10 17:25 - 2015-02-10 17:26 - 00000000 ____D () C:\Program Files\saleepRizes
    2015-02-10 17:25 - 2015-02-10 17:26 - 00000000 ____D () C:\Program Files\buYfaset
    2015-02-10 17:25 - 2015-02-10 17:26 - 00000000 ____D () C:\Program Files\brOwoseannddshop
    Task: {024D3720-E0E0-4AA6-ACC0-AA22D1998EB9} - \ProgramUpdateCheck No Task File <==== ATTENTION
    Task: {EC0CA43C-C827-42C3-8EC3-C4567F2A96A5} - \ProgramRefresh-ATFST No Task File <==== ATTENTION
    Task: {F5B94B60-5EE6-407E-9040-4AAC667D80EF} - System32\Tasks\InternetServiceOffers => C:\Program Files\Hewlett-Packard\HP TCS\RemEngine.exe [2008-10-01] ()
    end
  • Clic sur Fix
  • Clique sur GO
  • Copie le contenu du rapport SFTGC.txt sur , puis copie/colle le lien généré dans ta prochaine réponse.
