#214430
drivers32
%APPDATA%\*.
%APPDATA%\*.exe /s
%temp%\*.exe /s
%SYSTEMDRIVE%\*.exe
%systemroot%\*. /mp /s
services.exe
SAVEMBR:0
  • Clique sur Analyse
  • Copie le contenu des rapports OTL.txt et Extras.txt sur puis copie/colle le lien généré dans ta prochaine réponse.
Note : Au cas oà¹, tu peux les retrouver dans le dossier C:\OTL ou sur ton bureau en fonction des cas rencontrés[/list]
#214481
:hello:
  • Relance OTL.
    :OTL
    DRV:64bit: - [2014/10/22 09:29:01 | 000,155,912 | ---- | M] (BitDefender LLC) [File_System | Boot | Running] -- C:\Windows\SysNative\drivers\gzflt.sys -- (gzflt)
    DRV:64bit: - [2014/10/15 16:14:12 | 000,452,040 | ---- | M] (BitDefender S.R.L.) [File_System | Boot | Running] -- C:\Windows\SysNative\drivers\trufos.sys -- (trufos)
    FF - prefs.js..browser.search.param.yahoo-fr: "chrf-comodo"
    FF - prefs.js..browser.search.param.yahoo-fr-cjkt: "chrf-comodo"
    FF - prefs.js..extensions.enabledAddons: wrc%40avast.com:10.0.2502.149
    File not found (No name found) -- C:\PROGRAM FILES\AVAST SOFTWARE\AVAST\WEBREP\FF
    O3 - HKU\S-1-5-21-511495942-1315543408-433340416-1000\..\Toolbar\WebBrowser: (no name) - {1DAC0C53-7D23-4AB3-856A-B04D98CD982A} - No CLSID value found.
    MsConfig:64bit - StartUpReg: Report - hkey= - key= - C:\AdwCleaner\AdwCleaner[S2].txt ()
    SafeBootNet: 51412961.sys - Driver
    SafeBootNet:64bit: hitmanpro37 - C:\Windows\SysNative\drivers\hitmanpro37.sys ()
    SafeBootNet:64bit: hitmanpro37.sys - C:\Windows\SysNative\drivers\hitmanpro37.sys ()
    SafeBootNet:64bit: HitmanPro37Crusader - Reg Error: Value error.
    SafeBootNet:64bit: HitmanPro37CrusaderBoot - Reg Error: Value error.
    :files
    %Temp%\*.*
    C:\ProgramData\Bitdefender
    C:\Program Files\Bitdefender
    C:\Program Files\Common Files\Bitdefender
    C:\Program Files (x86)\Common Files\Bitdefender
    C:\ProgramData\Doctor Web
    C:\ProgramData\HitmanPro
    C:\ProgramData\panda_url_filtering
    C:\Users\godfroy\AppData\Roaming\Panda Security
    C:\ProgramData\Panda Security
    C:\Users\godfroy\Desktop\monalbumphoto
    C:\Users\godfroy\AppData\Roaming\AVG2015
    C:\$AVG
    C:\ProgramData\AVG2015
    C:\Users\godfroy\AppData\Local\Avg2015
    C:\ProgramData\Avira
    C:\OETemp
    C:\Users\godfroy\AppData\Roaming\BullGuard
    C:\ProgramData\BullGuard
    C:\Users\godfroy\AppData\Roaming\LavasoftStatistics
    C:\ProgramData\*.bin
    C:\bdr-cf01
    C:\bdr-bz01
    C:\bdr-ld01.mbr
    C:\bdr-im01.gz
    C:\bdr-ld01
    C:\Users\godfroy\AppData\Roaming\Software Informer
    :Commands
    [emptytemp]
    [emptyflash]
    [resethosts]
    [reboot]
  • Image
#214508
pour moi c'est du au fait que tu as des restes de AVG + Avast + BullGuard + McAfee + Hitman pro ...
Commence par faire le ménage dans les solutions de sécurité installées stp , désinstalle BullGuard et Hitman , regarde si tu vois avg et avast dans la liste des programmes installés, si présent tu désinstalles aussi.
par godlol54
#214529
bon ben je crois que c'est mort
je suis sur un autre ordi l'autre ne veut meme plus demarer il m'affiche la meme page que si j'avais eu une coupure de courant ( avec demande de mode sans echec ) mais en anglais et avec plusieur options je les ai toutes tentées mais l'ordinateur refuse de demarer il va falloir que je me debrouille pour faire un transfert de mes données presentes dans le disque dur
