#215437
Télécharge OTM (OldTimer) sur ton Bureau :
:reg
[HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run]
"HP Software Update"=-
"LManager"=-
[HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoActiveDesktop"=DWORD:0
"NoActiveDesktopChanges"=DWORD:0
[HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Policies\Explorer]
[-HKLM\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfefire]
[-HKLM\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfefirek]
[-HKLM\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfefirek.sys]
[-HKLM\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfehidk]
[-HKLM\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfehidk.sys]
[-HKLM\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfevtp]
[-HKLM\Software\BrowserChoice]
[-HKLM\Software\WOW6432Node\{1146AC44-2F03-4431-B4FD-889BC837521F}]
[-HKLM\Software\WOW6432Node\{12DA0E6F-5543-440C-BAA2-28BF01070AFA}]
[-HKLM\Software\WOW6432Node\{6791A2F3-FC80-475C-A002-C014AF797E9C}]
:files
C:\Users\SYLVIE\Desktop\Onglet\iLivid.lnk
C:\Users\SYLVIE\Desktop\Photos\nouveau\nous\Desktop\McAfee Security Scan Plus.lnk
C:\Users\SYLVIE\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Mobogenie.lnk
C:\Users\SYLVIE\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Optimizer Pro.lnk
C:\Users\SYLVIE\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Microsoft Office\PlayerPlus.lnk
C:\Users\SYLVIE\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PlayerPlus\
C:\Users\SYLVIE\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Microsoft Office\FinalMediaPlayer.lnk
C:\Users\SYLVIE\Desktop\Onglet\Torch.lnk
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}
C:\7d6e5a23a9668388bf8f142cacdf
C:\d64d9fb9b217197134fefba77ea267
C:\Windows\Installer\8125afda.msi
C:\Users\All Users\2097c4ef87961bcfc29feb9d0c3c6c49_c
C:\Users\All Users\{41BBE7FA-FF2A-4F93-B788-95E2FF187CA4}
C:\Users\SYLVIE\AppData\Roaming\AnyProtectEx
C:\Users\SYLVIE\AppData\Roaming\appdataFr3.bin
C:\Users\SYLVIE\AppData\Local\CrashRpt
C:\Users\SYLVIE\AppData\Local\nslF6E2.tmp
C:\Users\SYLVIE\AppData\Local\PackageAware
C:\Program Files (x86)\QQueenCoupoonn
C:\Program Files (x86)\RROyaalCoupon
C:\Program Files (x86)\SSOftCoUUp
C:\Program Files\log
C:\Windows\Tasks\APSnotifierPP1.job
C:\Windows\Tasks\APSnotifierPP2.job
C:\Windows\Tasks\APSnotifierPP3.job
C:\Windows\System32\Tasks\APSnotifierPP1
C:\Windows\System32\Tasks\APSnotifierPP2
C:\Windows\System32\Tasks\APSnotifierPP3
C:\Windows\System32\Tasks\CreateChoiceProcessTask
C:\Windows\System32\Tasks\FGRun
C:\user.js
C:\Windows\Reimage.ini
@Alternate Data Stream - 119 bytes -> C:\ProgramData\Temp:373E1720
:commands
[emptytemp]
Accepte en cliquant sur YES.
#215439
All processes killed
Registry value HKEY_LOCAL_MACHINE\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\HP Software Update deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\LManager deleted successfully.
HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\\"NoActiveDesktop"|DWORD:0 /E : value set successfully!
HKLM\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\\"NoActiveDesktopChanges"|DWORD:0 /E : value set successfully!
HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Policies\Explorer\\"NoActiveDesktop"|DWORD:0 /E : value set successfully!
HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Policies\Explorer\\"NoActiveDesktopChanges"|DWORD:0 /E : value set successfully!
Registry key HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfefire\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfefirek\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfefirek.sys\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfehidk\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfehidk.sys\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\SafeBoot\Network\mfevtp\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\BrowserChoice\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\WOW6432Node\{1146AC44-2F03-4431-B4FD-889BC837521F}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{1146AC44-2F03-4431-B4FD-889BC837521F}\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\WOW6432Node\{12DA0E6F-5543-440C-BAA2-28BF01070AFA}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{12DA0E6F-5543-440C-BAA2-28BF01070AFA}\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\WOW6432Node\{6791A2F3-FC80-475C-A002-C014AF797E9C}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{6791A2F3-FC80-475C-A002-C014AF797E9C}\ not found.
========== FILES ==========
C:\Users\SYLVIE\Desktop\Onglet\iLivid.lnk moved successfully.
C:\Users\SYLVIE\Desktop\Photos\nouveau\nous\Desktop\McAfee Security Scan Plus.lnk moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Microsoft\Windows\Start MENU\Programs\Microsoft Office\Mobogenie.lnk moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Microsoft Office\Optimizer Pro.lnk moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Microsoft Office\PlayerPlus.lnk moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\PlayerPlus folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Microsoft Office\FinalMediaPlayer.lnk moved successfully.
C:\Users\SYLVIE\Desktop\Onglet\Torch.lnk moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\Plugins folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\modules folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\META-INF folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\lib folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\defaults\preferences folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\defaults folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\skin folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\sl folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\lib folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\core folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\WEATHER\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\WEATHER\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\WEATHER folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TWITTER\resources folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TWITTER\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TWITTER\img folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TWITTER folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TESTER_POPUP\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TESTER_POPUP folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TESTER_EMBEDDED\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TESTER_EMBEDDED folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TESTER_BCAPI\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TESTER_BCAPI\autoTest\spec folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TESTER_BCAPI\autoTest\lib\jasmine-1.1.0 folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TESTER_BCAPI\autoTest\lib folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TESTER_BCAPI\autoTest folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\TESTER_BCAPI folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\SEARCH_IN_NEW_TAB folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\SEARCH\view\style\rsx folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\SEARCH\view\style folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\SEARCH\view\script folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\SEARCH\view folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\SEARCH\resources folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\SEARCH\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\SEARCH\Css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\SEARCH\buildSettings folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\SEARCH folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\RADIO_PLAYER\js\resources folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\RADIO_PLAYER\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\RADIO_PLAYER\css\custom-theme folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\RADIO_PLAYER\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\RADIO_PLAYER folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\PRICE_GONG\menu_dlg folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\PRICE_GONG\images folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\PRICE_GONG\css\custom-theme folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\PRICE_GONG\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\PRICE_GONG\agreement folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\PRICE_GONG folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\Optimizer\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\Optimizer folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\NOTIFICATION\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\NOTIFICATION\images\light folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\NOTIFICATION\images\dark folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\NOTIFICATION\images folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\NOTIFICATION\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\NOTIFICATION folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\MULTI_RSS\js\resources folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\MULTI_RSS\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\MULTI_RSS\img folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\MULTI_RSS\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\MULTI_RSS folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\HIGHLIGHTER\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\HIGHLIGHTER\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\HIGHLIGHTER folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\EMAIL_NOTIFIER\js\plugins folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\EMAIL_NOTIFIER\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\EMAIL_NOTIFIER\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\EMAIL_NOTIFIER folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\APPLICATION_BUTTON\resources folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\APPLICATION_BUTTON\Js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\APPLICATION_BUTTON folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa\404 folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\wa folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\menu\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\menu\img folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\menu\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\menu folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\gf\img folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\gf\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\gf folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\gadgetFrame folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\dlg\ftd\images folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\dlg\ftd folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui\dlg folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ui folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\searchProtector\searchProtectorSettingsDialog\images folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\searchProtector\searchProtectorSettingsDialog folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\searchProtector\SearchProtectorBubbleDialog\images folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\searchProtector\SearchProtectorBubbleDialog folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\searchProtector\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\searchProtector folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\options\js\resources folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\options\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\options\images folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\options\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\options folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\myStuffDialogs folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\features\js\resources folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\features\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\features folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\api folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ac\res folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ac\img folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ac\css folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\ac folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\aboutBox\js folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\aboutBox\images folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al\aboutBox folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb\al folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content\tb folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785\content folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome\CT3198785 folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef}\chrome folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\Mozilla\Firefox\Profiles\495zl29s.default\Extensions\{cce665dd-f6dd-4808-968e-eaec971f70ef} folder moved successfully.
C:\7d6e5a23a9668388bf8f142cacdf folder moved successfully.
C:\d64d9fb9b217197134fefba77ea267 folder moved successfully.
C:\Windows\INSTALLER\8125afda.msi moved successfully.
C:\Users\All Users\2097c4ef87961bcfc29feb9d0c3c6c49_c moved successfully.
C:\Users\All Users\{41BBE7FA-FF2A-4F93-B788-95E2FF187CA4}\OFFLINE\mMSI.dll folder moved successfully.
C:\Users\All Users\{41BBE7FA-FF2A-4F93-B788-95E2FF187CA4}\OFFLINE\mIDEFunc.dll folder moved successfully.
C:\Users\All Users\{41BBE7FA-FF2A-4F93-B788-95E2FF187CA4}\OFFLINE\mDown.dll folder moved successfully.
C:\Users\All Users\{41BBE7FA-FF2A-4F93-B788-95E2FF187CA4}\OFFLINE folder moved successfully.
C:\Users\All Users\{41BBE7FA-FF2A-4F93-B788-95E2FF187CA4} folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\AnyProtectEx\swf folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\AnyProtectEx\scan_results folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\AnyProtectEx\logs folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\AnyProtectEx\language folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\AnyProtectEx\installer folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\AnyProtectEx folder moved successfully.
C:\Users\SYLVIE\AppData\Roaming\appdataFr3.bin moved successfully.
C:\Users\SYLVIE\AppData\Local\CrashRpt\UnsentCrashReports\Softonic for Windows_1.5.11 folder moved successfully.
C:\Users\SYLVIE\AppData\Local\CrashRpt\UnsentCrashReports folder moved successfully.
C:\Users\SYLVIE\AppData\Local\CrashRpt folder moved successfully.
C:\Users\SYLVIE\AppData\Local\nslF6E2.tmp moved successfully.
C:\Users\SYLVIE\AppData\Local\PackageAware folder moved successfully.
C:\Program Files (x86)\QQueenCoupoonn folder moved successfully.
C:\Program Files (x86)\RROyaalCoupon folder moved successfully.
C:\Program Files (x86)\SSOftCoUUp folder moved successfully.
C:\Program Files\log folder moved successfully.
C:\Windows\Tasks\APSnotifierPP1.job moved successfully.
C:\Windows\Tasks\APSnotifierPP2.job moved successfully.
C:\Windows\Tasks\APSnotifierPP3.job moved successfully.
File/Folder C:\Windows\System32\Tasks\APSnotifierPP1 not found.
File/Folder C:\Windows\System32\Tasks\APSnotifierPP2 not found.
File/Folder C:\Windows\System32\Tasks\APSnotifierPP3 not found.
File/Folder C:\Windows\System32\Tasks\CreateChoiceProcessTask not found.
File/Folder C:\Windows\System32\Tasks\FGRun not found.
Unable to delete ADS Alternate Data Stream - 119 bytes -> C:\ProgramData\Temp:373E1720 .
[EMPTYTEMP]
User: All Users
User: Default
->Flash cache emptied: 56466 bytes
User: Default User
User: Public
User: SYLVIE
->Temp folder emptied: 34956677 bytes
->Temporary Internet Files folder emptied: 214129418 bytes
->Java cache emptied: 11424719 bytes
->FireFox cache emptied: 43178714 bytes
->Google Chrome cache emptied: 401613131 bytes
->Flash cache emptied: 58768 bytes
Windows Temp folder emptied: 5771965 bytes
%systemroot%\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 1007355 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 42304153 bytes
RecycleBin emptied: 1935 bytes
Total Files Cleaned = 720,00 mb
OTM by OldTimer - Version 3.1.21.0 log created on 03022015_153402
Files moved on Reboot...
C:\Users\SYLVIE\AppData\Local\Temp\FXSAPIDebugLogFile.txt moved successfully.
C:\Users\SYLVIE\AppData\Local\Temp\MMDUtl.log moved successfully.
C:\Users\SYLVIE\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
File move failed. C:\Windows\temp\dsiwmis.log scheduled to be moved on reboot.
File move failed. C:\Windows\temp\LMutilps32.log scheduled to be moved on reboot.
