#219059
ca parait bizarre le peu qu il y a dans le rapport ouais....
#219062
oui
par notinterested
#219063
Voici le résultat
All processes killed
Registry value HKEY_LOCAL_MACHINE\Software\WOW6432Node\Microsoft\Windows\CurrentVersion\Run\\iTunesHelper not found.
Registry value HKEY_USERS\S-1-5-21-2006616263-1337596404-1630953109-1001\Software\Microsoft\Windows\CurrentVersion\Run\\AdobeBridge not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Extensions\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Internet Explorer\Extensions\{898EA8C8-E7FF-479B-8935-AEC46303B9E5}\ not found.
========== FILES ==========
File/Folder C:\Users\admin\Desktop\Dossier\McAfee Security Scan Plus.lnk not found.
File/Folder C:\Users\admin\Desktop\Dossier\References\Nouveau dossier\Administrateur.lnk not found.
File/Folder C:\Users\admin\Desktop\Dossier\References\Nouveau dossier\Nouveau Dossier.lnk not found.
File/Folder C:\Users\admin\AppData\Local\Temprad1D344.tmp not found.
File/Folder C:\Users\admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\hkSFV not found.
File/Folder C:\Users\admin\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Astral.lnk not found.
File/Folder C:\Users\All Users\69B6DBD2-8E05-476F-B662-CF8D235FD499 not found.
[EMPTYTEMP]
User: admin
->Temp folder emptied: 30936 bytes
->Temporary Internet Files folder emptied: 1816 bytes
->Java cache emptied: 0 bytes
->Google Chrome cache emptied: 19615894 bytes
User: All Users
User: Default
User: Default User
User: Default.migrated
User: gourm_000
->Google Chrome cache emptied: 75644116 bytes
->Flash cache emptied: 57964 bytes
User: Public
Windows Temp folder emptied: 1581511978 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 1Â 599,00 mb
OTM by OldTimer - Version 3.1.21.0 log created on 05112015_010908
#219064
ok :)
des soucis persistent ?
par notinterested
#219065
A priori non, je n'ai plus le message d'erreur du script, Bahaty avait disparut depuis la dernière fois en fait, je ne le voyais plus dupliquer mon navigateur sur le bureau et en ouvrant le navigateur en question les onglets Bahaty ne s'ouvraient plus non plus, mais en lançant Adwcleaner je le voyait toujours dans les résultat du scan, je ne sais pas si il est toujours présent, y a t'il un moyen de vérifier ?
En tout cas, je tenais a te remercier pour ton aide, c'est vraiment sympas !
#219066
on peut voir comme ca :
Télécharge Seaf >> de C_XX
dans l'espace prévu à cet effet , tape ou colle : bahaty
coche "recherche également dans le registre"
puis lance la recheche.
heberge le rapport sur https://upload.sosvirus.net puis donne le lien obtenu pour aller le consulter
#219108
tu peux me poster ton rapport d'adwcleaner qui le detecte ? je verrai pour ta question ensuite ;)
