#219565
:hello:
Tant pis pour eset :
  • Clic sur OK
    start
    CHR Extension: (No Name) - C:\Users\Laurene\AppData\Local\Google\Chrome\User Data\Default\Extensions\aapocclcgogkmnckokdopfmhonfmgoek [2015-05-16]
    CHR Extension: (No Name) - C:\Users\Laurene\AppData\Local\Google\Chrome\User Data\Default\Extensions\aohghmighlieiainnegkcijnfilokake [2015-05-16]
    CHR Extension: (No Name) - C:\Users\Laurene\AppData\Local\Google\Chrome\User Data\Default\Extensions\felcaaldnbdncclmgdcncolpebgiejap [2015-05-16]
    end
  • Clic sur Fix
Redémarre ensuite le PC et dis moi si tu as toujours des soucis stp
