rapport d'analyse Réparation PC
#220547
Passes-tu le script que je fais entiérement ?
car peu de changement !
Logiciels officiels ou crackés ? :
O42 - Logiciel: Kruidvat fotoservice - (...) [HKLM][64Bits] -- Kruidvat fotoservice
un dernier script :
    [MD5.432F4E8794A2EA8A64E4C75EA80B790E] - (.BitTorrent Inc. - µTorrent.) -- C:\Users\pc\AppData\Roaming\uTorrent\uTorrent.exe   [1694560] [PID.3716]   =>P2P.BitTorrent
    [MD5.E8B7FD67DA14A7BE57A5CB80E3139E60] - (.Google Inc. - Google Toolbar Broker.) -- C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbarUser_32.exe   [309704] [PID.3276]
    O3 - Toolbar: Google Toolbar - [HKLM]{2318C2B1-4965-11d4-9B18-009027A5CD4F} . (.Google Inc. - Google Toolbar.) -- C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_64.dll
    O3 - Toolbar\WebBrowser: (no name) - [HKCU]{2318C2B1-4965-11D4-9B18-009027A5CD4F} Clé orpheline    => Toolbar.Google
    O4 - GS\QuickLaunch [pc]: µTorrent.lnk . (.BitTorrent Inc. - µTorrent.)  -- C:\Users\pc\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent
    O4 - GS\TaskBar [pc]: µTorrent.lnk . (.BitTorrent Inc. - µTorrent.)  -- C:\Users\pc\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent
    O4 - GS\Desktop [pc]: µTorrent.lnk . (.BitTorrent Inc. - µTorrent.)  -- C:\Users\pc\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent
    O4 - HKCU\..\Run: [uTorrent] . (.BitTorrent Inc. - µTorrent.) -- C:\Users\pc\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent
    OPT:O4 - HKLM\..\Wow6432Node\Run: [LManager] . (.Dritek System Inc. - Launch Manager.) -- C:\Program Files (x86)\Launch Manager\LManager.exe
    O4 - HKUS\S-1-5-21-1111289623-3497696531-3005036286-1000\..\Run: [uTorrent] . (.BitTorrent Inc. - µTorrent.) -- C:\Users\pc\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent
    O39 - APT:  - (..) -- C:\Windows\System32\Tasks\FacebookUpdateTaskUserS-1-5-21-1111289623-3497696531-3005036286-1000Core   [894]    => Facebook Update Task User
    O39 - APT:  - (..) -- C:\Windows\System32\Tasks\FacebookUpdateTaskUserS-1-5-21-1111289623-3497696531-3005036286-1000UA   [916]    => Facebook Update Task User
    O51 - MPSK:{209f155d-f412-11e0-a242-00262da98c23}\AutoRun\command. (...) -- E:\setup_vmb_lite.exe (.not file.)    => Fichier absent
    O51 - MPSK:{209f157b-f412-11e0-a242-00262da98c23}\AutoRun\command. (...) -- E:\setup_vmb_lite.exe (.not file.)    => Fichier absent
    O87 - FAEL: "{B8AC121C-151B-419A-891A-A76CC407605D}" | In - None - P6 - TRUE | .(.BitTorrent Inc. - µTorrent.) -- C:\Users\pc\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent
    O87 - FAEL: "{288493D5-5500-4173-81A6-37ECBA2D1ECA}" | In - None - P17 - TRUE | .(.BitTorrent Inc. - µTorrent.) -- C:\Users\pc\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent
    SS - | Demand 9/04/2014 289256 |  (McComponentHostService) . (.McAfee, Inc..) - C:\Program Files\McAfee Security Scan\3.8.150\McCHSvc.exe    => McAfee, Inc
    [HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]:uTorrent   =>P2P.BitTorrent^
    C:\Users\pc\AppData\Roaming\uTorrent\uTorrent.exe   =>P2P.BitTorrent^
    ProxyFix
    EmptyPrefetch
    SysRestore
    FirewallRAZ
    EmptyTemp
    exemple :
  • Ensuite faire un nouveau ZHPDiag , après un redémarrage
après on passera surement à  la fin de désinfection ...
par fracha
#220803
Le logiciel : kruidvat fotoservice, c'est un programme j'ai téléchargé depuis le site du magasin pour pouvoir envoyer des photos. Je l'ai recherché dans la barre de recherche avant de lancer ZHPFIX mais il était introuvable...
Voici le lien du rapport ZHP FIX :
dvw ... su7s03i4jz
Maintenant je redémarre mon ordinateur et je relancerai le ZHP DIAG alors,
Un tout grand merci de votre aide!! :merci2:
par fracha
#220804
Je recommence le ZHP FIX parce que j'avais oublié de brancher mon disque dur externe...
JE vous remets le liens ensuite
#220843
:bravo1: oui c'est bon , reste ton logiciel de P2P bit torrent ! :(
plus d'inferction (pour le moment !)
regarde :
[img]https://upload.sosvirus.net/images/2015/06/03/Capture5d53e.jpg[/img]
Les canneds de fin et mes qlq conseils :
mes conseils :
fin de désinfection
Pour commencer , à  lire , instructif :
Concernant les P2P
Et aussi :
Guide des menaces informatiques PDF
Et :
Adware prévention: lien direct
Pour terminer :
Beaucoup d'entre eux peuvent être dangereux et entrainer des dommages irréversibles sur ton système s'ils sont utilisés sans l'aide d'une personne qualifiée, de plus, fréquemment modifiés et mis à  jour par leurs auteurs ils deviennent très rapidement obsolètes, en plus d'encombrer inutilement ton bureau.
Delfix
Delfix à  changé et est devenu plus performant !
A - Télécharges DelFix sur votre bureau ICI
ps : Pour usage simple si rien n'est indiqué le passer comme il est programmé !
2/ Puis nettoyage
CCleaner
Instalation et fonctionnement de Ccleaner (N'installe pas la Yahoo Toolbar)
sauf l'antivirus !
(les programmes seront toujours là  quand tu en auras besoin mais ne "tourneront" plus continuellement !)
puis à  l'onglet recherche , supprimer , puis encore recherche et supprimer !plusieurs fois , jusqu'a ce qu'il n'y ai plus rien
1 - Dans la barre des tàches de Windows, clique sur Démarrer.
4 - Clique sur Appliquer.
OU : Logiciel de Lady >>(très simple d'utilisation) : oneclick-2-restore-point
SXCU de Igor 51, Logiciel intéressant pour les mises à  jour java, adobe , etc..
Tutoriel
D'autre liens TRàˆS utiles Pour les mises à  jour :
- Java : https://www.sosvirus.net/telecharger/java/
- Adobe reader : https://www.sosvirus.net/telecharger/adobe-reader/
- Flash player : https://www.sosvirus.net/telecharger/flash-player/
- Update checker : https://www.sosvirus.net/telecharger/update-checker/
- Delfix : https://www.sosvirus.net/telecharger/delfix/
- Ccleaner : https://www.sosvirus.net/telecharger/ccleaner/
- Unchecky : https://www.sosvirus.net/telecharger/unchecky/
- Comodo : https://www.sosvirus.net/telecharger/co ... l-windows/
1/ - Conserve MBAM ICI
Il te servira à  scanner les fichiers douteux en complément de l'antivirus et scanne le disque dur régulièrement. Mais n'oublie pas de faire la mise à  jour avant de lancer le scan.
2/ - Installe l'extension de sécurité adblock plus pour bloquer les publicités
Voici une extension à  télécharger qui te permettra, en faisant tes recherches sur google, de savoir si le site proposé lors de tes recherches est un site de confiance ou un site à  éviter car il pourrait infecter ton PC :
Pour Firefox : WOT Firefox
Pour internet explorer: WOT IE
4/ - Tutoriel pour t'aider à  installer WOT
5/ - Tu peux lire ce sujet sur les logiciels recommandés
6/ - Quels sont les logiciels à  éviter ?
7/ - Si tu utilises FireFox, vérifie que tes plugins sont à  jour
8/ - Comment reconnaitre les PUPS ?
9/ - Les Toolbars ce n'est pas obligatoire !
10/ - La sécurité de son PC c'est quoi ?
11/ - Maintenir ses programmes à  jour : Sécunia
- Sois plus vigilant(e) sur Internet à  l'avenir !
Voilà  pour moi c'est terminé.
par fracha
#220878
:merci2: :merci2: :merci2:
Je pense que j'ai de la lecture à  faire ;)
Bonne continuation dans votre travail, c'est très bien expliqué et très utile!! :)
