#221255
encore des trucs , nouveau script :
    [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Associations] Application: Modified   =>Hijacker.Application
    O42 - Logiciel: Google Update Helper - (.Google Inc..) [HKLM][64Bits] -- {A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}
    O42 - Logiciel: Java 6 Update 29 - (.Oracle.) [HKLM][64Bits] -- {26A24AE4-039D-4CA4-87B4-2F83216029FF}    => Oracle
    [HKCU\Software\AppDataLow\FDA]
    [HKCU\Software\Safer Networking Limited]    => Safer Networking Limited
    OPT:[HKLM\Software\BrowserChoice]    => Microsoft BrowserChoice
    [HKLM\Software\Safer Networking Limited]    => Safer Networking Limited
    [HKLM\Software\Wow6432Node\IncrediMail]    => Messaging.Incredimail
    [HKLM\Software\Wow6432Node\Safer Networking Limited]    => Safer Networking Limited
    [HKLM\Software\Wow6432Node\Software]
    O43 - CFD: 17/02/2014 - 13:43:26 - [] ----D C:\Program Files (x86)\GUM86FE.tmp    => Google Inc - Google Update Manager
    O43 - CFD: 15/02/2015 - 10:31:55 - [0] ----D C:\ProgramData\a68d9eea-b970-45e3-ba05-b4a5e2e396bc    => Empty Folder not necessary
    O43 - CFD: 29/11/2012 - 05:12:26 - [] ----D C:\ProgramData\Spybot - Search & Destroy    => Safer Networking Ltd - Spybot S&D
    O43 - CFD: 02/11/2014 - 14:39:40 - [0] ----D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Software    => Adware.Boxore
    O43 - CFD: 07/05/2014 - 11:11:50 - [] ----D C:\Users\Morgane\AppData\Roaming\pdfforge_GmbH
    O43 - CFD: 13/03/2014 - 18:53:31 - [] ----D C:\Users\Morgane\AppData\Roaming\Phon
    O43 - CFD: 23/10/2014 - 11:23:15 - [] ----D C:\Users\Morgane\AppData\Local\Apps
    O43 - CFD: 03/05/2015 - 19:29:13 - [0] ----D C:\Users\Morgane\AppData\Local\CRE    => Toolbar.Conduit
    O61 - LFC: 02/06/2015 - 15:18:31 ---A- . (.Bitdefender SRL.) -- C:\Users\Morgane\AppData\Roaming\Mozilla\Firefox\Profiles\8hbmruhc.default\extensions\{e001c731-5e37-4538-a5cb-8168736a2360}\plugins\npqscan.dll   [757896]    => Rogue.DefenderPro
    [HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{33BB0A4E-99AF-4226-BDF6-49120163DE86}]   =>PUP.V9Software
    [HKLM\Software\Microsoft\Internet Explorer\SearchScopes\{33BB0A4E-99AF-4226-BDF6-49120163DE86}]   =>PUP.V9Software
    [HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\SearchScopes\{33BB0A4E-99AF-4226-BDF6-49120163DE86}]   =>PUP.V9Software
    C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Software   =>Adware.Boxore
    [HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Associations] Application: Modified   =>Hijacker.Application^
    ProxyFix
    EmptyPrefetch
    SysRestore
    FirewallRAZ
    EmptyTemp
    exemple :
  • Ensuite faire un nouveau ZHPDiag , après un redémarrage
par kevin_quinta
#221261
Ok,
Je constate que Chrome est plus rapide, il ne se met plus intempestivement en mode 'ne réponds pas" et semble plus efficace.
Le démarrage est plus rapide aussi, et l'extinction aussi, malgré tout un programme semble bloquer l'extinction (écran qui s'affiche : Forcer l'arrêt et se coupe tout de suite)de l'ordinateur.
Peut être puis je voir les performance avec des logiciels dédiés?
#221264
oui pourquoi pas !
je ne pense pas que ce soit important ça !
parfois j'en ai aussi .....
#221309
bonjour,
non mais de toute façon il ne faut pas espérer faire d'une 2 ch une Ferrari !
les performances sont lié au processeur, à  la carte mère et à  la Ram que tu as ....
et surtout à  ta connexion !!
après les ralentissement sont du aux virus (tu n'en a plus ) aux nombre de téléchargements en même temps etc.....
par kevin_quinta
#221312
Bonjour et merci pour ta réponse,
Non je ne voulais pas "upgrader" les performances de mon ordi, juste le passer dans un logiciel qui aurait pu dire si il y'avait des tasks ou des processus bizarres qui grapillaient de la ressource mémoire.
Je ne crois pas les trucs du style "BoosterPc" ou j'sais pas quoi. C'est bon à  te coller des logiciels malveillants ça.
Dans tous les cas, je reste à  disposition. Du nouveaux sur les éventuels faux positifs? Ou je peux rendre l'ordinateur à  ma soeur?
Encore merci,
Kévin :D
#221315
oui alors c'est rien du tout pas de soucis , tu peux rendre le PC à  ta soeur !
Je n'en connais pas qui soit vraiment utile !
les canneds de fin et mes conseils :
Mes conseils :
fin de désinfection
Pour commencer , à  lire , instructif :
Concernant les P2P
Et aussi :
Guide des menaces informatiques PDF
Et :
Adware prévention: lien direct
Pour terminer :
Beaucoup d'entre eux peuvent être dangereux et entrainer des dommages irréversibles sur ton système s'ils sont utilisés sans l'aide d'une personne qualifiée, de plus, fréquemment modifiés et mis à  jour par leurs auteurs ils deviennent très rapidement obsolètes, en plus d'encombrer inutilement ton bureau.
Delfix
Delfix à  changé et est devenu plus performant !
A - Télécharges DelFix sur votre bureau ICI
ps : Pour usage simple si rien n'est indiqué le passer comme il est programmé !
2/ Puis nettoyage
CCleaner
Instalation et fonctionnement de Ccleaner (N'installe pas la Yahoo Toolbar)
sauf l'antivirus !
(les programmes seront toujours là  quand tu en auras besoin mais ne "tourneront" plus continuellement !)
puis à  l'onglet recherche , supprimer , puis encore recherche et supprimer !plusieurs fois , jusqu'a ce qu'il n'y ai plus rien
4 - Clique sur Appliquer.
OU : Logiciel de Lady >>(très simple d'utilisation) : oneclick-2-restore-point
SXCU de Igor 51, Logiciel intéressant pour les mises à  jour java, adobe , etc..
Tutoriel
D'autre liens TRàˆS utiles Pour les mises à  jour :
- Java : https://www.sosvirus.net/telecharger/java/
- Adobe reader : https://www.sosvirus.net/telecharger/adobe-reader/
- Flash player : https://www.sosvirus.net/telecharger/flash-player/
- Update checker : https://www.sosvirus.net/telecharger/update-checker/
- Delfix : https://www.sosvirus.net/telecharger/delfix/
- Ccleaner : https://www.sosvirus.net/telecharger/ccleaner/
- Unchecky : https://www.sosvirus.net/telecharger/unchecky/
- Comodo : https://www.sosvirus.net/telecharger/co ... l-windows/
1/ - Conserve MBAM ICI
Il te servira à  scanner les fichiers douteux en complément de l'antivirus et scanne le disque dur régulièrement. Mais n'oublie pas de faire la mise à  jour avant de lancer le scan.
2/ - Installe l'extension de sécurité adblock plus pour bloquer les publicités
Voici une extension à  télécharger qui te permettra, en faisant tes recherches sur google, de savoir si le site proposé lors de tes recherches est un site de confiance ou un site à  éviter car il pourrait infecter ton PC :
Pour Firefox : WOT Firefox
Pour internet explorer: WOT IE
4/ - Tutoriel pour t'aider à  installer WOT
5/ - Tu peux lire ce sujet sur les logiciels recommandés
6/ - Quels sont les logiciels à  éviter ?
7/ - Si tu utilises FireFox, vérifie que tes plugins sont à  jour
8/ - Comment reconnaitre les PUPS ?
9/ - Les Toolbars ce n'est pas obligatoire !
10/ - La sécurité de son PC c'est quoi ?
11/ - Maintenir ses programmes à  jour : Sécunia
- Sois plus vigilant(e) sur Internet à  l'avenir !
Voilà  pour moi c'est terminé.
:bye:
