par Brely
#226926
Re Voici le bon rapport SearchReg:
Farbar Recovery Scan Tool (x64) Version: 20.06.2018
Exécuté par filyann bureau (05-07-2018 19:11:15)
Exécuté depuis C:\Users\filyann bureau\Desktop
Mode d'amorçage: Normal
================== Chercher Registre: "discord" ===========
[HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore\1836a071_0]
""="{0.0.0.00000000}.{dea06f30-8cd1-4f6c-bf0a-3379d3d36ece}|\Device\HarddiskVolume2\Users\filyann bureau\AppData\Local\Discord\app-0.0.298\Discord.exe%b{00000000-0000-0000-0000-000000000000}"
[HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore\3481aa20_0]
""="{0.0.0.00000000}.{6dd5e698-95d3-4bb0-a757-d0025d7cc914}|\Device\HarddiskVolume2\Users\filyann bureau\AppData\Local\Discord\app-0.0.301\Discord.exe%b{00000000-0000-0000-0000-000000000000}"
[HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore\779704e9_0]
""="{0.0.0.00000000}.{b8a084dc-d20f-4a4e-b668-387ae42e278c}|\Device\HarddiskVolume2\Users\filyann bureau\AppData\Local\Discord\app-0.0.297\Discord.exe%b{00000000-0000-0000-0000-000000000000}"
[HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore\a0ecca02_0]
""="{0.0.0.00000000}.{dea06f30-8cd1-4f6c-bf0a-3379d3d36ece}|\Device\HarddiskVolume2\Users\filyann bureau\AppData\Local\Discord\app-0.0.301\Discord.exe%b{00000000-0000-0000-0000-000000000000}"
[HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore\cd53ebe4_0]
""="{0.0.0.00000000}.{878fc6f3-eb06-47f1-8ce8-c4c220fcc4c9}|\Device\HarddiskVolume2\Users\filyann bureau\AppData\Local\Discord\app-0.0.297\Discord.exe%b{00000000-0000-0000-0000-000000000000}"
[HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore\eb96d95a_0]
""="{0.0.0.00000000}.{cf2e7884-ca26-43d7-8679-9b14083b5e53}|\Device\HarddiskVolume2\Users\filyann bureau\AppData\Local\Discord\app-0.0.297\Discord.exe%b{00000000-0000-0000-0000-000000000000}"
[HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted]
"C:\Users\filyann bureau\AppData\Local\Discord\Update.exe"="1"
[HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Classes\Discord]
""="URL:Discord Protocol"
[HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Classes\Discord\DefaultIcon]
""=""C:\Users\filyann bureau\AppData\Local\Discord\app-0.0.301\Discord.exe",-1"
[HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Classes\Discord\shell\open\command]
""=""C:\Users\filyann bureau\AppData\Local\Discord\app-0.0.301\Discord.exe" --url -- "%1""
====== Fin de Chercher ======
A+
par did80
#226927
salut brely
tu as supprime les clés infectées avec malwarebytes le temps que je regarde tout çà
par did80
#226929
salut brely
ceci stp
Télécharge OTM
OTM ici
• Enregistre le fichier sur votre bureau.
• AVAST reconnait ce logiciel comme un intrus, donc le désactiver le temps des manipulations.
• Double-cliquez sur OTM.exe pour l'exécuter. (Si vous êtes sous Vista, seven, cliquez-droit sur le fichier OTM.exe et exécutez-le en tant qu'administrateur.)
Copies les lignes suivantes du lien dans le cadre de gauche sous
paste instructions for items to be moved
:Reg
[-HKEY_USERS\S-1-5-21-4286018159-260783739-1479431557-1000\Software\Classes\Discord]
:Commands
[purity]
[emptytemp]
Cliquez sur MOVE IT ! pour lancer la suppression.
Attendre la fin du travail de l'outil puis fermer OTM
Le résultat apparaitra dans le cadre Results.
Clique sur Exit pour fermer.
copie colle le rapport situé dans C:\_OTM\MovedFiles\06092009_130526.log "Exemple"
NB: Il te sera peut-être demandé de redémarrer le pc pour achever la suppression.
si c'est le cas accepte par Oui/Yes.
par Brely
#226930
Bonjour Did80
J'ai un problème avec OTM il ne répond plus au bout de une minutes je l'ai téléchargé une nouvelle fois, mais pas mieux je le laisse tourné mais rien ne ce passe ça va bien faire une heure oO .
Petite question je ne peut pas aller directement les supprimé dans regedit?
par did80
#226931
si tu sais oui
fais une sauvegarde bdr avant
par Brely
#226932
Re
C'est bon, tout est supprimé sans problème apparemment :) , par contre j'ai toujours le logo de discord et quelque fichiers dans l'emplacement du raccourci je suppose que je peut les supprimé directement mais je préfère demandé pour ne pas faire de bêtise.
par did80
#226933
oui
tu peux aussi faire une suppression des clés conduit
Fichier crypté [COMJ File]
bonne chance
