#227207
salut r motobecane -
ceci stp
ou
  • Frst.txt
    Addition.txt
    Shortcut.txt
Mettre les 3 rapports
#227217
ceci stp
1/ ATTENTION: La Restauration système est désactivée
2/Lance Farbar
start::
CloseProcesses:
CreateRestorePoint:
2018-09-07 13:53 - 2018-09-07 13:53 - 000000000 ____D C:\Program Files\ZebHelpProcess
ContextMenuHandlers5: [igfxcui] -> {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => -> Pas de fichier
Task: {06CBE059-8117-4D22-8CC7-BBD0BE0864ED} - System32\Tasks\WBUpdateTask => C:\Program Files\WebBarMedia\5.5.6554.18569\winwb.exe <==== ATTENTION
DeleteValue: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\StartupApproved\Run|WebBar Toolbar
DeleteKey: HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0BCE8B0A-1E76-44E5-9909-3CF804D92E4D}_is1
DeleteKey: HKLM\SOFTWARE\WebBar
AlternateDataStreams: C:\Users\guerr\OneDrive:${3D0CE612-FDEE-43f7-8ACA-957BEC0CCBA0}.SyncRootIdentity [118]
AlternateDataStreams: C:\Users\guerr\OneDrive\Documents\desktop.ini:${3D0CE612-FDEE-43f7-8ACA-957BEC0CCBA0}.Metadata [194]
DeleteKey: HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{0BCE8B0A-1E76-44E5-9909-3CF804D92E4D}_is1
C:\Users\guerr\AppData\Local\Google\Chrome\User Data\Default\File System\000
C:\Users\guerr\AppData\Local\Google\Chrome\User Data\Default\File System\001
C:\Users\guerr\AppData\Local\Google\Chrome\User Data\Default\File System\002
C:\Users\guerr\AppData\Local\Google\Chrome\User Data\Default\File System\003
C:\Users\guerr\AppData\Local\Google\Chrome\User Data\Default\File System\004
C:\Users\guerr\AppData\Local\Google\Chrome\User Data\Default\File System\005
EmptyTemp:
end::
#227222
bonjour motobecane
ceci stp
Image Télécharge ZHPCleaner de Nicolas Coolman sur ton bureau
Scanner
puis cliques sur nettoyer
@+ didier
#227226
ceci maintenant
Image Télécharger Malwarebytes
ou
Paramétrer comme ceci
« Lancer le scan »
Rapport
  1. Compte rendus
  2. Compte rendu d'analyse
  3. Afficher le compte rendu
Exporter Fichier.txt
2 déposer
#227228
on continue
mettre sur le bureau KVRT.exe
désactiver l'antivirus
parametrer
lancer le scan
Scanner
Delete : Supprimer le fichier
Clique sur le bouton Continue
how to clean junk files
De rien Bon WE :)
