par simo_sezif
#227985
############################## | UsbFix V 7.138 | [Recherche]
Utilisateur: dell (Administrateur) # DELL-PC
Mis à jour le 20/09/2013 par El Desaparecido - Team SosVirus
Lancé à 19:21:56 | 16/05/2019
Site Web: http://www.usbfix.net/
Forum : http://www.sosvirus.net/
Upload Malware: http://www.sosvirus.net/upload_malware.php
Contact: http://www.usbfix.net/contact/
PC: Dell Inc. (Latitude E6320) (x64-based PC)
CPU: Intel(R) Core(TM) i5-2520M CPU @ 2.50GHz (2501)
RAM -> [Total : 3977 | Free : 919]
BIOS: Default System BIOS
BOOT: Normal boot
OS: Microsoft Windows 7 Édition Intégrale (6.1.7601 64-Bit) # Service Pack 1
WB: Windows Internet Explorer 8.0.7601.17514
AV: Avast Antivirus [Enabled | Updated]
C:\ (%systemdrive%) -> Disque fixe # 298 Go (242 Go libre(s) - 81%) [] # NTFS
D:\ -> CD-ROM
E:\ -> Disque amovible # 29 Go (29 Go libre(s) - 100%) [KINGSTON] # FAT32
C:\Windows\system32\csrss.exe (424)
C:\Windows\system32\wininit.exe (512)
C:\Windows\system32\csrss.exe (536)
C:\Windows\system32\services.exe (576)
C:\Windows\system32\lsass.exe (596)
C:\Windows\system32\lsm.exe (604)
C:\Windows\system32\svchost.exe (712)
C:\Windows\system32\svchost.exe (808)
C:\Windows\System32\svchost.exe (872)
C:\Windows\system32\winlogon.exe (908)
C:\Windows\System32\svchost.exe (924)
C:\Windows\system32\svchost.exe (964)
C:\Program Files\IDT\WDM\STacSV64.exe (124)
C:\Windows\system32\svchost.exe (1056)
C:\Windows\system32\WUDFHost.exe (1140)
C:\Windows\system32\svchost.exe (1224)
C:\Program Files\AVAST Software\Avast\AvastSvc.exe (1320)
C:\Windows\system32\Dwm.exe (1408)
C:\Windows\Explorer.EXE (1432)
C:\Windows\System32\spoolsv.exe (1556)
C:\Windows\system32\taskhost.exe (1564)
C:\Windows\system32\svchost.exe (1596)
C:\Windows\system32\svchost.exe (1648)
C:\Program Files\IDT\WDM\AESTSr64.exe (1788)
C:\Windows\system32\WUDFHost.exe (1776)
C:\Program Files\IDT\WDM\sttray64.exe (2128)
C:\Windows\System32\igfxtray.exe (2136)
C:\Windows\System32\hkcmd.exe (2144)
C:\Windows\System32\igfxpers.exe (2152)
C:\Program Files\AVAST Software\Avast\avastui.exe (2360)
C:\Windows\system32\SearchIndexer.exe (2120)
C:\Windows\system32\wbem\unsecapp.exe (2252)
C:\Windows\system32\wbem\wmiprvse.exe (2548)
C:\Windows\system32\DRIVERS\o2flash.exe (3104)
C:\Windows\system32\sppsvc.exe (3308)
C:\UsbFix\Go.exe (2100)
C:\Windows\system32\SearchProtocolHost.exe (4008)
C:\Windows\servicing\TrustedInstaller.exe (3076)
C:\Windows\system32\wbem\wmiprvse.exe (256)
C:\Windows\system32\SearchFilterHost.exe (3312)
C:\UsbFix\Go.exe (3748)
C:\Windows\system32\SearchProtocolHost.exe (1608)
HKLM\SOFTWARE | Run : [AvastUI.exe] - "C:\Program Files\AVAST Software\Avast\AvastUI.exe" /nogui
HKLM\SOFTWARE\wow6432Node | Run : [AvastUI.exe] - "C:\Program Files\AVAST Software\Avast\AvastUI.exe" /nogui
HKU\S-1-5-21-2663653995-24086885-403962637-1000\SOFTWARE | Run : [SysinfY2X] - C:\WINDOWS\system32\cmd.exe /c start wscript /e:VBScript.Encode %temp%\SysinfY2X.db
################## | Éléments infectieux |
################## | E.O.F | http://www.usbfix.net - http://www.sosvirus.net |
par did80
#227986
Salut
quel est ton pb ?
