par Evasion60
#20391
:hello: Re
/!\ Les versions Starter de Seven, sur des machines premier prix :(
Applique ce correctif =>
Ouvre le bloc-notes
Séléctionne et copie dedans le script ci dessous =>
[MD5.00000000000000000000000000000000] [APT] [{EBE206DD-560A-49D7-8AB7-8156D44C0DDF}] (...) -- c:\users\Utilisateur\appdata\local\lollipop\lollipop.bat (.not file.) [0] => Adware.Lollipop*
[HKLM\Software\iWin] => Adware.iWinArcade
[HKLM\Software\supWPM]
O43 - CFD: 02/12/2013 - 15:10:59 - [0] ----D C:\ProgramData\WPM => Empty Folder not necessary
O45 - LFCP:[MD5.0D86F15C90F0A8B0E0B18D9D5B747C43] - 02/12/2013 - 13:36:39 ---A- - C:\Windows\Prefetch\WAJAMC.EXE-DFDFA7D5.pf => PUP.Wajam*
O45 - LFCP:[MD5.86161F65FEFB657A3734F2F07BE30E27] - 02/12/2013 - 13:37:07 ---A- - C:\Windows\Prefetch\BOXOREINSTALLER.EXE-EF59D9E7.pf => Adware.Boxore*
O45 - LFCP:[MD5.C6FEE6EF279E96DA6198A10A5D7482E8] - 15/11/2013 - 10:29:34 ---A- - C:\Windows\Prefetch\IMINENT.EXE-75DD804E.pf => Adware.IMBooster*
[MD5.2F08D91BFE7D5B863F7DDE4826B1955F] [SPRF][05/11/2013] (.The Software Group - Software Update Setup.) -- C:\Users\Utilisateur\AppData\Local\Temp\BoxoreInstaller.exe [621168] => Adware.Boxore*
[MD5.37F2F6D556EE5C6C3EE3779CE4C13EA6] [SPRF][02/12/2013] (...) -- C:\Users\Utilisateur\AppData\Local\Temp\SHSetup.exe [45663824] => Crapware.SpyHunter
[MD5.EEFAC0A5E3D9EAC7FE34F5D969FCD35D] [SPRF][05/11/2013] (...) -- C:\Users\Utilisateur\AppData\Local\Temp\wajam_download.exe [61624] => PUP.Wajam*
[MD5.5A45A7E3E12BE51844B741945FB8E85E] [SPRF][18/03/2012] (.Iminent - IMinent bootstrapper.) -- C:\Users\Utilisateur\Desktop\IminentSetup_2-KFRPtAWP-1_.exe [825312] => Adware.IMBooster*
O87 - FAEL: "{BC12CA59-B7DD-409B-9F92-0E34691C2DA8}" |In - None - P17 - TRUE | .(...) -- C:\Program Files\Iminent\Iminent.exe (.not file.) => Adware.IMBooster*
O87 - FAEL: "{3226F1BB-817B-4C8D-908C-FC02542FE4E8}" |In - None - P17 - TRUE | .(...) -- C:\Program Files\Iminent\Iminent.Messengers.exe (.not file.) => Adware.IMBooster*
O87 - FAEL: "{BC629C0A-8B58-462B-9566-582C3007A83E}" |In - Private - P6 - TRUE | .(...) -- C:\Program Files\SweetIM\Communicator\SweetPacksUpdateManager.exe (.not file.) => PUP.SweetIM*
O87 - FAEL: "{BA00D535-4718-43D8-8062-48950818D02D}" |In - Private - P17 - TRUE | .(...) -- C:\Program Files\SweetIM\Communicator\SweetPacksUpdateManager.exe (.not file.) => PUP.SweetIM*
O90 - PUC: "BA172DB42E6685D4FA8808EFB370074C" . (.Fissa.) -- C:\Windows\Installer\{4BD271AB-66E2-4D58-AF88-80FE3B0770C4}\ARPPRODUCTICON.exe => Infection PUP (PUP.OfferBox)
[MD5.EBAB99411769E8924D9BF17717ECB07E] [WIS][18/07/2012] (.SweetIM Technologies Ltd. - SweetIM for Messenger 3.6.) -- C:\Windows\Installer\194585d.msi [3553792] => PUP.SweetIM*
[MD5.0C8AC497AFCA75C05EB08C89863A97B3] [WIS][18/07/2012] (.SweetIM Technologies Ltd. - SweetPacks Toolbar for Internet Explorer 4.0.) -- C:\Windows\Installer\1945862.msi [3070464] => PUP.SweetIM*
[MD5.85C5DEF2B079CA6E8CA7FCBD45793BEF] [WIS][18/07/2012] (.SweetIM Technologies Ltd. - Sweetpacks Communicator 1.0.) -- C:\Windows\Installer\1945867.msi [2243584] => PUP.SweetIM*
[MD5.FEEB576634F1F961F5649D4D09F02363] [WIS][18/03/2012] (.Iminent - Iminent.) -- C:\Windows\Installer\ab4b5.msi [9420800] => Adware.IMBooster*
[MD5.A672E4C77ED7CCC851575B10B46CC8AD] [WIS][18/03/2012] (.IMinent - IMinent Toolbar.) -- C:\Windows\Installer\ab4ba.msi [1019392] => Adware.IMBooster*
[HKLM\Software\Classes\Installer\Features\BA172DB42E6685D4FA8808EFB370074C] => Infection PUP (PUP.OfferBox)
[HKLM\Software\Classes\Installer\Products\BA172DB42E6685D4FA8808EFB370074C] => Infection PUP (PUP.OfferBox)
[HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\BA172DB42E6685D4FA8808EFB370074C] => Infection PUP (PUP.OfferBox)
[HKLM\Software\iwin] => Adware.iWinArcade
[HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0FF2AEFF45EEA0A48A4B33C1973B6094] => Macromedia/Dreamweaver or PUP.SweetIM
[HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\305B09CE8C53A214DB58887F62F25536] => Macromedia/Dreamweaver or PUP.SweetIM
C:\Users\Utilisateur\AppData\Local\Software => Infection PUP (Adware.Boxore)
C:\Users\Utilisateur\AppData\Local\Temp\BoxoreInstaller.exe => Adware.Boxore*
C:\Users\Utilisateur\AppData\Local\Temp\SHSetup.exe => Crapware.SpyHunter
C:\Users\Utilisateur\AppData\Local\Temp\wajam_download.exe => PUP.Wajam*
C:\Users\Utilisateur\Desktop\IminentSetup_2-KFRPtAWP-1_.exe => Adware.IMBooster*
EmptyCLSID
Emptytemp
Un avertissement s'affiche
Si le script est conforme
Mises à jour à effectuer (impératif) =>
Adobe Flash Player 11 ActiveX => Adobe Systems // en 11.9.900.152
Adobe Reader X => Adobe Systems // en 11.0.4
Liens =>
Adobe Flash Player
V11.9.900.152
Décocher avant le téléchargement => Mc Afee Security Scan Plus et/ou Google Chrome
Nota => Pour Windows 8, c'est une KB, qui fait la mise à jour
Adobe Reader 11.0.4
Décocher Google Chrome , avant le téléchargement
Quand tout est complété, reviens avec le rapport de ZHPFix
