par Pitou019
#98248
========== PROCESSES ==========
Process pirritdesktop.exe killed successfully!
Process PirritService.exe killed successfully!
No active process named :Files was found!
No active process named C:\Program Files (x86)\Pirrit was found!
No active process named C:\Program Files\Pirrit was found!
No active process named %AppData%\Mozilla\Firefox\Profiles\*.default\Extensions\suggestor@suggestor.pirrit* was found!
No active process named %userprofile%\AppData\Local\Pirrit Suggestor was found!
No active process named %userprofile%\AppData\Roaming\Pirrit was found!
No active process named :Reg was found!
No active process named [-HKLM\Software\Pirrit] was found!
No active process named :Commands was found!
No active process named [RESETHOSTS] was found!
No active process named [REBOOT] was found!
OTM by OldTimer - Version 3.1.21.0 log created on 02282014_003054
par Pitou019
#98540
Hello!
J'ai refait la manip avec le nouveau script.
Cependant, OTM m'oblige à redémarrer immédiatement l'ordinateur. Du coup, je ne peux pas copier le résultat.
Mais de ce que j'ai pà» comprendre, il dit "Pirrit was successfuly killed".
Hélas il est toujours là .
Une chose a changé cependant, des fichiers cachés (à moi) sont apparus un peu partout: des pochettes d'albums, des fichiers desktop.ini
par Pitou019
#98559
Autant pour moi...
All processes killed
No active process named pirritdesktop.exe was found!
No active process named :files was found!
No active process named :reg was found!
No active process named :commands was found!
No active process named [emptytemp] was found!
No active process named [resethosts] was found!
No active process named [reboot] was found!
OTM by OldTimer - Version 3.1.21.0 log created on 02282014_171301
par H.A.W.X
#98565
Ok tente avec ce script :
:files
:reg
:commands
[emptytemp]
[resethosts]
[reboot]
A de suite :)
par Pitou019
#98578
Toujours là
========== FILES ==========
C:\Program Files (x86)\Pirrit\IEExtension folder moved successfully.
C:\Program Files (x86)\Pirrit folder moved successfully.
File/Folder C:\Program Files\Pirrit not found.
File/Folder C:\Users\Pitou\AppData\Roaming\Mozilla\Firefox\Profiles\*.default\Extensions\suggestor@suggestor.pirrit* not found.
File/Folder C:\Users\Pitou\AppData\Local\Pirrit Suggestor not found.
C:\Users\Pitou\AppData\Roaming\Pirrit folder moved successfully.
File/Folder :reg not found.
File/Folder [-HKLM\Software\Pirrit] not found.
File/Folder :commands not found.
File/Folder [emptytemp] not found.
File/Folder [resethosts] not found.
File/Folder [reboot] not found.
OTM by OldTimer - Version 3.1.21.0 log created on 02282014_182106
par Pitou019
#98588
Registry key HKEY_LOCAL_MACHINE\Software\Pirrit\ deleted successfully.
OTM by OldTimer - Version 3.1.21.0 log created on 02282014_184642
