#21180
Bonsoir à tous,
Depuis quelques jours, ma clé usb n'affiche plus que des raccourcis...
J'ai essayé usbfix mais ça se bloque à chaque fois à 19%. Il est mis "Firefox (ne réponds pas)"
Que faire...
Merci d'avance!
#21186
Hello :hello: ,
drivers32
%APPDATA%\*.
%APPDATA%\*.exe /s
%temp%\*.exe /s
%SYSTEMDRIVE%\*.exe
%systemroot%\*. /mp /s
services.exe
SAVEMBR:0
  • Clique sur Analyse
#21526
  • Relance OTL.
    :OTL
    O4 - HKU\S-1-5-21-3522616785-320077766-1110694346-1000..\Run: [APS] C:\Users\Public\conhost.exe (Hôte de la fenêtre de la console)
    O4 - Startup: C:\Users\Perso\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\conhost.exe (Hôte de la fenêtre de la console)
    O4 - Startup: C:\Users\Perso\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\SURVIVAL.vbe ()
    O4 - Startup: C:\Users\Perso\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\trz80D3.tmp (Isolution Graphique)
    O4 - HKU\S-1-5-21-3522616785-320077766-1110694346-1000..\Run: [SURVIVAL] wscript.exe //B "C:\Users\Perso\AppData\Local\Temp\SURVIVAL.vbe" File not found
    ActiveX: {89820200-ECBD-11cf-8B85-00AA005B4383} -
    :files
    C:\Users\Perso\AppData\Roaming\Public
    C:\Users\Perso\AppData\Roaming\Perso-wchelper.dll
    C:\Users\Perso\AppData\Roaming\56BB877C
    :Commands
    [emptytemp]
    [emptyflash]
    [reboot]
  • Image
#21625
Voici le rapport:
All processes killed
========== OTL ==========
Registry value HKEY_USERS\S-1-5-21-3522616785-320077766-1110694346-1000\Software\Microsoft\Windows\CurrentVersion\Run\\APS deleted successfully.
C:\Users\Public\conhost.exe moved successfully.
C:\Users\Perso\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\conhost.exe moved successfully.
C:\Users\Perso\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\SURVIVAL.vbe moved successfully.
C:\Users\Perso\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\trz80D3.tmp moved successfully.
Registry value HKEY_USERS\S-1-5-21-3522616785-320077766-1110694346-1000\Software\Microsoft\Windows\CurrentVersion\Run\\SURVIVAL deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{89820200-ECBD-11cf-8B85-00AA005B4383}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{89820200-ECBD-11cf-8B85-00AA005B4383}\ not found.
Registry key HKEY_CURRENT_USER\SOFTWARE\Microsoft\Active Setup\Installed Components\{89820200-ECBD-11cf-8B85-00AA005B4383}\ deleted successfully.
File ptytemp] not found.
File ptyflash] not found.
File boot] not found.
OTL by OldTimer - Version 3.2.69.0 log created on 12122013_094853
J'ai toujours des raccourcis dans ma clé usb. Quand OTL a démarré pour le premier scan, je l'ai mise quelques secondes après le démarrage. Je en sais pas si c'est une erreur et qu'il devait commencer avec pour être sur de la scanner...
Merci à vous
