#21774
y'a des trucs que j'avais pas fait gaffe :(
desinstalle adobe reader 9
colle ca dans la partie d'OTL en bas sous personnalisation :
:OTL
IE - HKU\S-1-5-21-3441707194-849277393-838960651-1000\..\SearchScopes\{B538EED8-DEAC-4027-A729-8785628D85B5}: "URL" = {searchTerms}&locale=&apn_ptnrs=U3&apn_dtid=OSJ000YYBE&apn_uid=FDB6EA3E-D00D-4A82-93E2-F80ADDB48CE8&apn_sauid=8DA89CB1-1FCD-490D-8F09-C6FCC284FD57
FF - user.js - File not found
[2013/12/04 19:30:22 | 000,000,000 | ---D | M] (No name found) -- C:\Users\Hélène\AppData\Roaming\Mozilla\Firefox\Profiles7x2ho4fw.default\extensions\staged
CHR - homepage:
CHR - Extension: WebSite Recommendation = C:\Users\Hélène\AppData\Local\Google\Chrome\User Data\Default\Extensions\jopdpbolklklaiookikgmdinfbooiipj\4.0_0\
O3 - HKU\S-1-5-21-3441707194-849277393-838960651-1000\..\Toolbar\WebBrowser: (no name) - {2318C2B1-4965-11D4-9B18-009027A5CD4F} - No CLSID value found.
O4 - Startup: C:\Users\Hélène\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\OpenOffice.org 3.3.lnk
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktopChanges = 1
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Plug-in 1.6.0_22)
O16 - DPF: {CAFEEFAC-0016-0000-0022-ABCDEFFEDCBA} (Java Plug-in 1.6.0_22)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} (Java Plug-in 1.6.0_22)
O16 - DPF: {8AD9C840-044E-11D1-B3E9-00805F499D93} (Java Plug-in 10.45.2)
O16 - DPF: {CAFEEFAC-0016-0000-0031-ABCDEFFEDCBA} (Java Plug-in 1.6.0_31)
O16 - DPF: {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA} (Java Plug-in 10.45.2)
[2013/11/29 07:14:26 | 000,000,000 | ---D | C] -- C:\ProgramData\banyk
[2013/11/28 17:32:33 | 000,000,000 | ---D | C] -- C:\ProgramData\yvkg
[2013/11/28 17:32:33 | 000,000,000 | ---D | C] -- C:\ProgramData\dqo
[2013/11/28 17:32:31 | 000,000,000 | ---D | C] -- C:\ProgramData\wsyovl
[2013/11/27 09:06:18 | 000,000,000 | ---D | C] -- C:\ProgramData\ivra
[2013/11/27 09:02:06 | 000,000,000 | ---D | C] -- C:\ProgramData\ntmrs
[2013/11/27 09:02:06 | 000,000,000 | ---D | C] -- C:\ProgramData\exvh
[2013/11/27 09:02:00 | 000,000,000 | ---D | C] -- C:\ProgramData\dvdh
[2013/11/25 16:38:21 | 000,000,000 | ---D | C] -- C:\ProgramData\rofnxut
[2013/11/25 16:38:19 | 000,000,000 | ---D | C] -- C:\ProgramData\vdb
[2013/11/25 16:38:17 | 000,000,000 | ---D | C] -- C:\ProgramData\rxlqjiv
[2013/11/25 16:38:02 | 000,000,000 | ---D | C] -- C:\ProgramData\rxk
[2013/11/25 16:38:00 | 000,000,000 | ---D | C] -- C:\ProgramData\rqw
[2013/11/25 16:38:00 | 000,000,000 | ---D | C] -- C:\ProgramData\ocj
[2013/11/25 16:37:59 | 000,000,000 | ---D | C] -- C:\ProgramData\yrp
[2013/11/25 16:37:59 | 000,000,000 | ---D | C] -- C:\ProgramData\jktuit
[2013/11/25 16:37:57 | 000,000,000 | ---D | C] -- C:\ProgramData\rickoyu
[2013/11/25 16:37:57 | 000,000,000 | ---D | C] -- C:\ProgramData\fbw
[2013/11/25 16:37:57 | 000,000,000 | ---D | C] -- C:\ProgramData\amhu
[2013/11/25 16:37:55 | 000,000,000 | ---D | C] -- C:\ProgramData\jijxp
[2013/11/25 16:37:49 | 000,000,000 | ---D | C] -- C:\ProgramData\yeqacd
[2013/11/25 16:37:49 | 000,000,000 | ---D | C] -- C:\ProgramData\ybey
[2013/11/25 16:37:49 | 000,000,000 | ---D | C] -- C:\ProgramData\gvrg
[2013/11/25 16:37:48 | 000,000,000 | ---D | C] -- C:\ProgramData\hoy
[2013/11/25 16:37:47 | 000,000,000 | ---D | C] -- C:\ProgramData\uvrmyvl
[2013/11/25 16:37:47 | 000,000,000 | ---D | C] -- C:\ProgramData\mum
[2013/11/25 16:37:47 | 000,000,000 | ---D | C] -- C:\ProgramData\hvfsa
[2013/11/25 16:37:46 | 000,000,000 | ---D | C] -- C:\ProgramData\edef
[2013/11/25 16:35:43 | 000,000,000 | ---D | C] -- C:\ProgramData\gesjkh
[4 C:\Windows\SysWow64\*.tmp files -> C:\Windows\SysWow64\*.tmp -> ]
[1 C:\Windows\*.tmp files -> C:\Windows\*.tmp -> ]
[1 C:\Program Files (x86)\*.tmp files -> C:\Program Files (x86)\*.tmp -> ]
[2012/07/02 19:13:29 | 000,000,000 | ---D | M] -- C:\Users\Hélène\AppData\Local\CRE
:reg
[-HKEY_CURRENT_USER\Software\2014]
:Files
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\*
:commands
[emptytemp]
puis clique sur correction
colle le contenu du rapport qui s'ouvrira au redemarrage
s'il ne s ouvre pas il est là :
C:\OTL\Moved Files\date_et_heure.log
#21842
hello il y a differentes écoles de formation qui permettent d'apprendre cela , néanmoins il faut avoir au minimum la connaissance du fonctionnement de windows un tant soit peu.
quels soucis persistent ?
par Qude
#21845
"regarde juste dans les extensions de chrome tu dois avoir nation zoom supprime-la"
Toujours d'actualité ca ? :p
J'imagine que non il ne s'y trouve toujours pas.
j'ai l'impression que tout fonctionne :)
Je peux retélécharger Adobe reader ?
#21867
laisse tomber adobe reader pour lire les PDF j'ai mieux et plus sà»r ^^
donc on finit avec ca :
  • Clique sur GO
  • Télécharges sur ton Bureau.
  • Coche la case suivantes :
    • Réactiver l'UAC
No Internet Explorer :
Internet Explorer :
pense à l‚installation , à cocher la case qui correspond à utiliser SumatraPDF comme lecteur par defaut » et installer les plugins pour les navigateurs.
#21870
j'ouvre le sujet pour le pc3 ou tu le fais ? ^^
