#23321
Bonsoir @natus , ouvre-toi un nouveau sujet pour une prise en charge merci
@lolita
désinstalle adobe reader si ce n'est fait
ATTENTION !!! : Script personnalisé pour cette machine uniquement , ne pas reproduire !!!
si tu as XP => double clique
si tu as Vista ou windows 7 => clic droit "executer en tant que...."
sur OTL.exe pour le lancer.
Copie la liste qui se trouve en gras ci-dessous,
colle-la dans la zone sous "Personnalisation" :
:processes
iexplore.exe
firefox.exe
msnmsgr.exe
Teatimer.exe
:OTL
IE - HKU\S-1-5-21-2636585911-1586567364-1655311612-1000\..\SearchScopes\{14a03cec-1b4f-49fc-bba5-b7dda53dc0e6}: "URL" = {searchTerms}
FF - HKLM\Software\MozillaPlugins\Adobe Reader: C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AIR\nppdf32.dll (Adobe Systems Inc.)
CHR - default_search_provider: Muzeen (Enabled)
CHR - default_search_provider: search_url = {searchTerms}
CHR - default_search_provider: suggest_url =
CHR - homepage:
O3 - HKLM\..\Toolbar: (Muzeen Toolbar) - {61B10F46-9307-4daf-A741-657CC3284AA2} - C:\Program Files (x86)\Muzeen\Toolbar\Muzeen.dll (Muse Media)
O3 - HKU\.DEFAULT\..\Toolbar\WebBrowser: (no name) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - No CLSID value found.
O3 - HKU\S-1-5-18\..\Toolbar\WebBrowser: (no name) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - No CLSID value found.
O3 - HKU\S-1-5-21-2636585911-1586567364-1655311612-1000\..\Toolbar\WebBrowser: (no name) - {21FA44EF-376D-4D53-9B0F-8A89D3229068} - No CLSID value found.
O3 - HKU\S-1-5-21-2636585911-1586567364-1655311612-1000\..\Toolbar\WebBrowser: (no name) - {D3028143-6145-4318-99D3-3EDCE54A95A9} - No CLSID value found.
O4 - HKU\S-1-5-18\..\Run: [SpywareTerminatorUpdate] "C:\Program Files (x86)\Spyware Terminator\SpywareTerminatorUpdate.exe" File not found
O4 - HKU\S-1-5-21-2636585911-1586567364-1655311612-1000\..\Run: [orangeinside] C:\Users\Lalita\AppData\Roaming\Orange\OrangeInside\one\OrangeInside.exe File not found
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktop = 1
O6 - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer: NoActiveDesktopChanges = 1
O16 - DPF: {87AF076E-D86D-4E87-ADDD-F05804E1F150} (Reg Error: Key error.)
MsConfig:64bit - StartUpFolder: C:^ProgramData^Microsoft^Windows^Start Menu^Programs^Startup^tmchlang.lnk - - File not found
MsConfig:64bit - StartUpReg: SpywareTerminator - hkey= - key= - File not found
MsConfig:64bit - StartUpReg: SpywareTerminatorUpdate - hkey= - key= - File not found
MsConfig:64bit - StartUpReg: UfSeAgnt.exe - hkey= - key= - File not found
[1 C:\Windows\*.tmp files -> C:\Windows\*.tmp -> ]
[1 C:\Users\Lalita\Documents\*.tmp files -> C:\Users\Lalita\Documents\*.tmp -> ]
[2013/12/21 16:59:13 | 000,045,056 | ---- | M] () -- C:\Windows\SysNative\acovcnt.exe
[2011/02/21 19:08:30 | 000,000,000 | ---D | M] -- C:\0b589f9424f2ab0fdb7c3f29
[2012/12/28 09:29:11 | 000,000,000 | ---D | M] -- C:\Users\Lalita\AppData\Local\CRE
[2013/07/30 15:10:50 | 000,000,000 | ---D | M] -- C:\Program Files (x86)\Muzeen
:reg
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]
"EnableFirewall"=DWORD:0
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\PublicProfile]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules]
"TCP Query User{22382CA4-591F-4283-8859-5C12DAB2FF46}C:\program files (x86)\spyware terminator\spywareterminatorupdate.exe"=-
"UDP Query User{2997B662-F097-4895-AF4D-CFE85C9C9011}C:\program files (x86)\spyware terminator\spywareterminatorupdate.exe"=-
[HKEY_USERS\S-1-5-21-2636585911-1586567364-1655311612-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MuzeenToolbar]
:Files
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\*
:commands
[emptytemp]
Clique sur "Correction" pour lancer la suppression.
Poste le rapport qui logiquement s'ouvrira tout seul en fin de travail appres le redemarrage.
par Lalita18
#23331
tataaaa :D
All processes killed
========== PROCESSES ==========
No active process named explorer.exe was found!
Process iexplore.exe killed successfully!
No active process named firefox.exe was found!
No active process named msnmsgr.exe was found!
No active process named Teatimer.exe was found!
========== OTL ==========
Registry key HKEY_USERS\S-1-5-21-2636585911-1586567364-1655311612-1000\Software\Microsoft\Internet Explorer\SearchScopes\{14a03cec-1b4f-49fc-bba5-b7dda53dc0e6}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{14a03cec-1b4f-49fc-bba5-b7dda53dc0e6}\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\MozillaPlugins\Adobe Reader\ not found.
File C:\Program Files (x86)\Adobe\Reader 9.0\Reader\AIR\nppdf32.dll not found.
Use Chrome's Settings page to remove the default_search_provider items.
Use Chrome's Settings page to change the HomePage.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\Locked deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\{61B10F46-9307-4daf-A741-657CC3284AA2} not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{61B10F46-9307-4daf-A741-657CC3284AA2}\ not found.
File C:\Program Files (x86)\Muzeen\Toolbar\Muzeen.dll not found.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\Locked not found.
Registry value HKEY_USERS\.DEFAULT\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{21FA44EF-376D-4D53-9B0F-8A89D3229068} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{21FA44EF-376D-4D53-9B0F-8A89D3229068}\ not found.
Registry value HKEY_USERS\S-1-5-18\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{21FA44EF-376D-4D53-9B0F-8A89D3229068} not found.
Registry value HKEY_USERS\S-1-5-21-2636585911-1586567364-1655311612-1000\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{21FA44EF-376D-4D53-9B0F-8A89D3229068} deleted successfully.
Registry value HKEY_USERS\S-1-5-21-2636585911-1586567364-1655311612-1000\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{D3028143-6145-4318-99D3-3EDCE54A95A9} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D3028143-6145-4318-99D3-3EDCE54A95A9}\ not found.
Registry value HKEY_USERS\S-1-5-18\\Software\Microsoft\Windows\CurrentVersion\Run\\SpywareTerminatorUpdate deleted successfully.
Registry value HKEY_USERS\S-1-5-21-2636585911-1586567364-1655311612-1000\\Software\Microsoft\Windows\CurrentVersion\Run\\orangeinside deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\NoActiveDesktop deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer\\NoActiveDesktopChanges deleted successfully.
Starting removal of ActiveX control {87AF076E-D86D-4E87-ADDD-F05804E1F150}
C:\Windows\Downloaded Program Files\setup.inf moved successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{87AF076E-D86D-4E87-ADDD-F05804E1F150}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{87AF076E-D86D-4E87-ADDD-F05804E1F150}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{87AF076E-D86D-4E87-ADDD-F05804E1F150}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\StartUpReg\SpywareTerminator\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\StartUpReg\SpywareTerminatorUpdate\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Shared Tools\MSConfig\StartUpReg\UfSeAgnt.exe\ not found.
C:\Windows\msdownld.tmp folder deleted successfully.
C:\Users\Lalita\Documents\~WRL0005.tmp deleted successfully.
C:\Windows\SysNative\acovcnt.exe moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\Graphics folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\Client folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\3082 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\3076 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\2070 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\2052 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1055 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1053 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1049 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1046 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1045 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1044 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1043 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1042 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1041 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1040 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1038 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1037 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1036 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1035 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1033 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1032 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1031 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1030 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1029 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1028 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29\1025 folder moved successfully.
C:\0b589f9424f2ab0fdb7c3f29 folder moved successfully.
C:\Users\Lalita\AppData\Local\CRE folder moved successfully.
Folder C:\Program Files (x86)\Muzeen\ not found.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\\"EnableFirewall"|DWORD:0 /E : value set successfully!
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\\"EnableFirewall"|DWORD:0 /E : value set successfully!
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\PublicProfile\\"EnableFirewall"|DWORD:0 /E : value set successfully!
Registry value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\TCP Query User{22382CA4-591F-4283-8859-5C12DAB2FF46}C:\program files (x86)\spyware terminator\spywareterminatorupdate.exe deleted successfully.
Registry value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\UDP Query User{2997B662-F097-4895-AF4D-CFE85C9C9011}C:\program files (x86)\spyware terminator\spywareterminatorupdate.exe deleted successfully.
========== FILES ==========
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\FXSSVCDebugLogFile.txt moved successfully.
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\FXSTIFFDebugLogFile.txt moved successfully.
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\mpam-4af1589b.exe moved successfully.
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\mpam-7403748f.exe moved successfully.
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\mpam-b8b5a10a.exe moved successfully.
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\mpam-f58ffb4c.exe moved successfully.
File move failed. C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\MpCmdRun.log scheduled to be moved on reboot.
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\MpSigStub.log moved successfully.
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\T30DebugLogFile.txt moved successfully.
[EMPTYTEMP]
User: All Users
User: Default
->Temporary Internet Files folder emptied: 33170 bytes
->Flash cache emptied: 41695 bytes
User: Default User
User: Hudson
User: Lalita
->Temp folder emptied: 67627272 bytes
->Temporary Internet Files folder emptied: 196171781 bytes
->Google Chrome cache emptied: 394626611 bytes
->Flash cache emptied: 52341 bytes
User: Public
Windows Temp folder emptied: 2962213 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 50540 bytes
RecycleBin emptied: 820 bytes
Total Files Cleaned = 631.00 mb
OTL by OldTimer - Version 3.2.69.0 log created on 12212013_225927
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\MpCmdRun.log moved successfully.
C:\Users\Lalita\AppData\Local\Temp\FXSAPIDebugLogFile.txt moved successfully.
#23332
j'ai raté une clé :(
refais-en un avec jsute ca dedans :
:reg
[-HKEY_USERS\S-1-5-21-2636585911-1586567364-1655311612-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MuzeenToolbar]
puis correction
par Lalita18
#23388
Registry key HKEY_USERS\S-1-5-21-2636585911-1586567364-1655311612-1000\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MuzeenToolbar\ not found.
OTL by OldTimer - Version 3.2.69.0 log created on 12222013_174937
:D
Je vrois que ça te dit not found parce que je me suis rendu compte que mon père l'avais et je l'ai supprimé un peu avant de faire marcher OTL
#23390
dac' :)
encore de soucis ?
par Lalita18
#24530
Apparemment c'est bon juste à ré installer adobe reader d'ailleur petite question pourquoi tu m'a dit de le désinstallé ? C'est lui qui posé problème ?
#24536
coucou la réponse est dans ce qui suit :)
  • Clique sur GO
  • Télécharge sur ton Bureau.
    • Réactiver l'UAC
No Internet Explorer :
Internet Explorer :
