par Ironer
#109507
J'ai étais infecté par Coupon server, j'ai donc suivi votre tutoriel http://www.sosvirus.net/viewtopic.php?t=5786&p=23240.
Vous demandez donc: Héberge le rapport Result.txt sur SosUpload, puis copie/colle le lien fourni dans ta prochaine réponse.
Voici le rapport:
MiniRegTool by Farbar Version:29-11-2012
Ran by Maxence (administrator) on 2014-03-16 at 02:41:24
Search Result For: "coupon server"
[HKEY_CLASSES_ROOT\TypeLib\{00B595DF-8592-45F8-A3A8-577D0497F0F6}\1.0\0\win32]
""="C:\Program Files\Coupon Server\FrameworkBHO.dll"
[HKEY_CLASSES_ROOT\TypeLib\{00B595DF-8592-45F8-A3A8-577D0497F0F6}\1.0\HELPDIR]
""="C:\Program Files\Coupon Server"
[HKEY_CLASSES_ROOT\TypeLib\{60405004-E845-421D-B5B1-2038E04A9313}\1.0\0\win32]
""="C:\Program Files\Coupon Server\FrameworkEngine.exe"
[HKEY_CLASSES_ROOT\TypeLib\{60405004-E845-421D-B5B1-2038E04A9313}\1.0\HELPDIR]
[HKEY_LOCAL_MACHINE\SOFTWARE]
"35852"="Coupon Server"
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{00B595DF-8592-45F8-A3A8-577D0497F0F6}\1.0\0\win32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{00B595DF-8592-45F8-A3A8-577D0497F0F6}\1.0\HELPDIR]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{60405004-E845-421D-B5B1-2038E04A9313}\1.0\0\win32]
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\TypeLib\{60405004-E845-421D-B5B1-2038E04A9313}\1.0\HELPDIR]
[HKEY_LOCAL_MACHINE\SOFTWARE\Coupon Server]
""="C:\Users\Maxence\AppData\Local\Coupon Server"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{60405004-E845-421D-B5B1-2038E04A9313}]
"AppPath"="C:\Program Files\Coupon Server\"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunOnce]
"Coupon Server-repairJob"="wscript.exe "C:\Users\Maxence\AppData\Local\Coupon Server\repair.js" "Coupon Server-repairJob""
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\35852_Coupon Server]
"DisplayName"="Coupon Server"
"DisplayIcon"="C:\Users\Maxence\AppData\Local\Coupon Server/icon.ico"
"InstallLocation"="C:\Users\Maxence\AppData\Local\Coupon Server"
"UninstallString"="C:\Users\Maxence\AppData\Local\Coupon Server\uninstall.exe "
par HelperBot
#109508
Bonjour ,
Bienvenue sur SosVirus :)
#109509
salut
  • Désactive ton antivirus
  • Lance Shortcut_Module,
  • Clic sur Nettoyer
par Ironer
#109542
¤¤¤¤¤¤¤¤¤¤ | Shortcut_Module | g3n-h@ckm@n | 16.03.2014.1
¤¤¤¤¤ XP | Vista | 7 | 8 - 32/64 bits ¤¤¤¤¤ - Start 04:32:18 - 16/03/2014
Mis à  jour le : 16/03/2014 | 03.10 par g3n-h@ckm@n
Contact : http://www.sosvirus.net" onclick="window.open(this.href);return false;
Boot : Normal
Système : Windows 7 Ultimate (32 bits) Ultimate
Mémoire RAM = Total (MB) : 3145 | Libre (MB) : 1078
Pagefile = Total (MB) : 6288 | Libre (MB) : 3649
Virtuelle = Total (MB) : 2097 | Libre (MB) : 1939
Registre sauvegardé , pour restaurer : C:\Shortcut_Module\Save\Clean\ERDNT.exe
¤¤¤¤¤¤¤¤¤¤ | Mises à  jour Windows
Dernière(s) détection(s) : 2014-03-15 12:55:51
Dernières Téléchargées : 2014-03-05 10:19:49
Dernières installées : 2014-03-06 01:28:52
Prochaine recherche : 2014-03-16 10:09:37
~ Service Pack 1 non installé !!!
¤¤¤¤¤¤¤¤¤¤ | Navigateurs
IE : 8.0.7601.17514 (© Microsoft Corporation. Tous droits réservés.)
¤¤¤¤¤¤¤¤¤¤ | Processus tués
476 | C:\Windows\system32\psxss.exe (.Microsoft Corporation - Serveur du sous-système SUA.) - (6.1.7601.17514) -> %SystemRoot%\system32\psxss.exe
860 | C:\Windows\system32\atiesrxx.exe (.AMD - AMD External Events Service Module.) - (6.14.11.1122) -> C:\Windows\system32\atiesrxx.exe
1432 | C:\Windows\system32\atieclxx.exe (.AMD - AMD External Events Client Module.) - (6.14.11.1122) -> atieclxx
1840 | C:\Windows\System32\spoolsv.exe (.Microsoft Corporation - Application sous-système spouleur.) - (6.1.7600.16962) -> C:\Windows\System32\spoolsv.exe
1032 | C:\Windows\system32\taskhost.exe (.Microsoft Corporation - Processus hôte pour Tà¢ches Windows.) - (6.1.7601.17514) -> "taskhost.exe"
1276 | C:\Windows\system32\taskeng.exe (.Microsoft Corporation - Moteur du Planificateur de tà¢ches.) - (6.1.7601.17514) -> taskeng.exe {D0D31C31-D0C3-47AF-8440-9FAE0A73E59E}
1808 | C:\Program Files\Common Files\Adobe\ARM\1.0\armsvc.exe (.Adobe Systems Incorporated - Adobe Acrobat Update Service.) - (1.701.3.3014) -> "C:\Program Files\Common Files\Adobe\ARM\1.0\armsvc.exe"
2064 | C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe (.Apple Inc. - YSLoader.exe.) - (17.327.4.24) -> "C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe"
2152 | C:\Program Files\Bonjour\mDNSResponder.exe (.Apple Inc. - Bonjour Service.) - (3.0.0.10) -> "C:\Program Files\Bonjour\mDNSResponder.exe"
2196 | C:\Windows\system32\CISVC.EXE (.Microsoft Corporation - Service d‚indexation du contenu.) - (6.1.7600.16385) -> C:\Windows\system32\CISVC.EXE
2216 | C:\Program Files\Google\Update\GoogleUpdate.exe (.Google Inc. - Programme d'installation de Google.) - (1.3.21.103) -> "C:\Program Files\Google\Update\GoogleUpdate.exe" /c
2372 | C:\ProgramData\Freemake\FreemakeUtilsService\FreemakeUtilsService.exe (.Freemake - FreemakeUtilsService.) - (1.0.0.0) -> "C:\ProgramData\Freemake\FreemakeUtilsService\FreemakeUtilsService.exe"
2480 | C:\Program Files\Freemake\CaptureLib\CaptureLibService.exe (.Ellora Assets Corp. - CaptureLibService.) - (1.0.0.0) -> "C:\Program Files\Freemake\CaptureLib\CaptureLibService.exe"
2584 | C:\Program Files\Kinoni\EpocCam_and_Barcode_drivers\KinoniSvc.exe (. - .) - (0.0.0.0) -> "C:\Program Files\Kinoni\EpocCam_and_Barcode_drivers\KinoniSvc.exe"
2624 | C:\Program Files\LogMeIn Hamachi\LMIGuardianSvc.exe (.LogMeIn, Inc. - LMIGuardianSvc.) - (10.1.0.1646) -> "C:\Program Files\LogMeIn Hamachi\LMIGuardianSvc.exe"
2648 | C:\Windows\system32\mqsvc.exe (.Microsoft Corporation - Message Queuing Service.) - (6.1.7600.16385) -> C:\Windows\system32\mqsvc.exe
2772 | C:\Windows\system32\PnkBstrA.exe (. - .) - (0.0.0.0) -> C:\Windows\system32\PnkBstrA.exe
2796 | C:\Windows\System32\tcpsvcs.exe (.Microsoft Corporation - TCP/IP Services Application.) - (6.1.7600.16385) -> C:\Windows\System32\tcpsvcs.exe
2860 | C:\Windows\System32\snmp.exe (.Microsoft Corporation - Service SNMP.) - (6.1.7601.17514) -> C:\Windows\System32\snmp.exe
3072 | C:\Program Files\LogMeIn Hamachi\hamachi-2.exe (.LogMeIn Inc. - Hamachi Client Tunneling Engine.) - (2.2.0.173) -> "C:\Program Files\LogMeIn Hamachi\hamachi-2.exe" -s
3412 | C:\Windows\system32\sppsvc.exe (.Microsoft Corporation - Service de la plateforme de protection logicielle Microsoft.) - (6.1.7601.17514) -> C:\Windows\system32\sppsvc.exe
3796 | C:\Windows\System32\rundll32.exe (.Microsoft Corporation - Processus hôte Windows (Rundll32).) - (6.1.7600.16385) -> C:\Windows\System32\rundll32.exe shell32.dll,SHCreateLocalServerRunDll {995C996E-D918-4a8c-A302-45719A6F4EA7} -Embedding
320 | C:\Windows\Explorer.EXE (.Microsoft Corporation - Explorateur Windows.) - (6.1.7600.16768) -> C:\Windows\Explorer.EXE
4100 | C:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe (.Microsoft Corporation - IPoint.exe.) - (2.0.162.0) -> "C:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe"
4108 | C:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe (.Microsoft Corporation - IType.exe.) - (2.0.162.0) -> "C:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe"
4228 | C:\Program Files\iTunes\iTunesHelper.exe (.Apple Inc. - iTunesHelper.) - (11.1.5.5) -> "C:\Program Files\iTunes\iTunesHelper.exe"
4460 | C:\Users\Maxence\AppData\Local\Akamai\netsession_win.exe (.Akamai Technologies, Inc. - Akamai NetSession Client.) - (1.8.9.2) -> "C:\Users\Maxence\AppData\Local\Akamai\netsession_win.exe"
4532 | C:\Program Files\iPod\bin\iPodService.exe (.Apple Inc. - iPodService Module (32-bit).) - (11.1.5.5) -> "C:\Program Files\iPod\bin\iPodService.exe"
4588 | C:\Users\Maxence\AppData\Local\Akamai\netsession_win.exe (.Akamai Technologies, Inc. - Akamai NetSession Client.) - (1.8.9.2) -> "C:/Users/Maxence/AppData/Local/Akamai/netsession_win.exe" --client
4660 | C:\Program Files\Skype\Phone\Skype.exe (.Skype Technologies S.A. - Skype .) - (6.11.0.102) -> "C:\Program Files\Skype\Phone\Skype.exe" /minimized /regrun
4768 | C:\Windows\system32\SearchIndexer.exe (.Microsoft Corporation - Indexeur Microsoft Windows Search.) - (7.0.7600.16385) -> C:\Windows\system32\SearchIndexer.exe /Embedding
4924 | C:\Program Files\Windows Media Player\wmpnetwk.exe (.Microsoft Corporation - Service Partage réseau du Lecteur Windows Media.) - (12.0.7601.17514) -> "C:\Program Files\Windows Media Player\wmpnetwk.exe"
4512 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe"
6072 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=gpu-process --channel="4512.0.1720126335\1977804988" --disable-d3d11 --supports-dual-gpus=false --gpu-driver-bug-workarounds=0,9,18,24,26 --gpu-vendor-id=0x1002 --gpu-device-id=0x9490 --gpu-driver-vendor="Advanced Micro Devices, Inc." --gpu-driver-version=8.970.100.7000 --ignored=" --type=renderer " /prefetch:822062411
3948 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --extension-process --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.2.717846690\956213121" /prefetch:673131151
3776 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --extension-process --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.3.2047116254\395226379" /prefetch:673131151
5836 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --extension-process --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.4.1255635540\766484610" /prefetch:673131151
3876 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.6.157740879\151903939" /prefetch:673131151
5684 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.8.1326220077\446573937" /prefetch:673131151
1056 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=ppapi --channel="4512.16.1330939480\1897605084" --ppapi-flash-args --lang=fr --ignored=" --type=renderer " /prefetch:-632637702
4652 | C:\Windows\system32\UI0Detect.exe (.Microsoft Corporation - Détection de services interactifs.) - (6.1.7600.16385) -> C:\Windows\system32\UI0Detect.exe
5312 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.17.275297875\576335535" /prefetch:673131151
5884 | C:\Program Files\Pando Networks\Media Booster\PMB.exe (. - Pando Media Booster.) - (2.6.0.8) -> "C:\Program Files\Pando Networks\Media Booster\PMB.exe"
4132 | C:\Riot Games\League of Legends\RADS\projects\lol_launcher\releases\0.0.0.202\deploy\LoLLauncher.exe (. - PVP.net Patcher.) - (2.5.0.422) -> "C:\Riot Games\League of Legends\RADS\projects\lol_launcher\releases\0.0.0.202\deploy\LoLLauncher.exe"
1076 | C:\Riot Games\League of Legends\RADS\projects\lol_air_client\releases\0.0.1.75\deploy\LolClient.exe (. - .) - (0.0.0.0) -> "C:/Riot Games/League of Legends/RADS/projects/lol_air_client/releases/0.0.1.75/deploy/LolClient.exe" -runtime .\ -nodebug META-INF\AIR\application.xml .\ -- 8393
3156 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials="AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/InstantExtended/Group1 pct:25 stable:r4 use_remote_ntp_on_startup:1 espv:210 suppress_on_srp:1/Prerender/PrerenderEnabled/PrerenderFromOmnibox/OmniboxPrerenderDisabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/" --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.21.1117456608\1958591112" /prefetch:673131151
3124 | C:\Windows\System32\WUDFHost.exe (.Microsoft Corporation - Windows Driver Foundation - Processus hôte de l‚infrastructure de pilotes en mode utilisateur.) - (6.2.9200.16384) -> "C:\Windows\System32\WUDFHost.exe" -HostGUID:{193a1820-d9ac-4997-8c55-be817523f6aa} -IoEventPortName:HostProcess-0b6ea65c-e6c7-4f9c-bc69-02e320f54e22 -SystemEventPortName:HostProcess-adc65287-07f9-462a-a15a-06fe37eea44a -IoCancelEventPortName:HostProcess-746a5813-21ba-4554-9bcb-5839acf0bcd1 -NonStateChangingEventPortName:HostProcess-a46e5625-c5f1-4b9b-a594-adcda0b3b162 -ServiceSID:S-1-5-80-2652678385-582572993-1835434367-1344795993-749280709 -LifetimeId:e8a50072-14bd-4984-a0db-427d10c0ce9d -DeviceGroupId:WpdFsGroup
3164 | C:\Windows\system32\SearchProtocolHost.exe (.Microsoft Corporation - Microsoft Windows Search Protocol Host.) - (7.0.7600.16385) -> "C:\Windows\system32\SearchProtocolHost.exe" Global\UsGthrFltPipeMssGthrPipe7_ Global\UsGthrCtrlFltPipeMssGthrPipe7 1 -2147483646 "Software\Microsoft\Windows Search" "Mozilla/4.0 (compatible; MSIE 6.0; Windows NT; MS Search 4.0 Robot)" "C:\ProgramData\Microsoft\Search\Data\Temp\usgthrsvc" "DownLevelDaemon"
2032 | C:\Windows\system32\SearchFilterHost.exe (.Microsoft Corporation - Microsoft Windows Search Filter Host.) - (7.0.7600.16385) -> "C:\Windows\system32\SearchFilterHost.exe" 0 504 508 516 65536 512
¤¤¤¤¤¤¤¤¤¤ | Processus démarrés
[10/04/2013 12:13:48] - 300 | C:\Windows\System32\smss.exe (.Microsoft Corporation - Gestionnaire de sessions Windows.) - (6.1.7600.17273) -> \SystemRoot\System32\smss.exe [69632 Ko]
[14/07/2009 00:11:09] - 388 | C:\Windows\system32\csrss.exe (.Microsoft Corporation - Processus d‚exécution client-serveur.) - (6.1.7600.16385) -> %SystemRoot%\system32\csrss.exe ObjectDirectory=\Windows SharedSection=1024,12288,512 Windows=On SubSystemType=Windows ServerDll=basesrv,1 ServerDll=winsrv:UserServerDllInitialization,3 ServerDll=winsrv:ConServerDllInitialization,2 ServerDll=sxssrv,4 ProfileControl=Off MaxRequestThreads=16 [6144 Ko]
[14/07/2009 00:11:09] - 488 | C:\Windows\system32\csrss.exe (.Microsoft Corporation - Processus d‚exécution client-serveur.) - (6.1.7600.16385) -> %SystemRoot%\system32\csrss.exe ObjectDirectory=\Windows SharedSection=1024,12288,512 Windows=On SubSystemType=Windows ServerDll=basesrv,1 ServerDll=winsrv:UserServerDllInitialization,3 ServerDll=winsrv:ConServerDllInitialization,2 ServerDll=sxssrv,4 ProfileControl=Off MaxRequestThreads=16 [6144 Ko]
[14/07/2009 00:36:49] - 500 | C:\Windows\system32\wininit.exe (.Microsoft Corporation - Application de démarrage de Windows.) - (6.1.7600.16385) -> wininit.exe [96256 Ko]
[14/07/2009 00:11:26] - 536 | C:\Windows\system32\services.exe (.Microsoft Corporation - Applications Services et Contrôleur.) - (6.1.7600.16385) -> C:\Windows\system32\services.exe [259072 Ko]
[24/03/2013 11:49:25] - 552 | C:\Windows\system32\lsass.exe (.Microsoft Corporation - Local Security Authority Process.) - (6.1.7601.17725) -> C:\Windows\system32\lsass.exe [22528 Ko]
[01/05/2013 17:34:09] - 560 | C:\Windows\system32\lsm.exe (.Microsoft Corporation - Service du gestionnaire de session locale.) - (6.1.7601.17514) -> C:\Windows\system32\lsm.exe [267776 Ko]
[01/05/2013 17:34:13] - 696 | C:\Windows\system32\winlogon.exe (.Microsoft Corporation - Application d‚ouverture de session Windows.) - (6.1.7601.17514) -> winlogon.exe [286720 Ko]
[14/07/2009 00:19:28] - 704 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k DcomLaunch [20992 Ko]
[14/07/2009 00:19:28] - 812 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k RPCSS [20992 Ko]
[14/07/2009 00:19:28] - 916 | C:\Windows\System32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\System32\svchost.exe -k LocalServiceNetworkRestricted [20992 Ko]
[14/07/2009 00:19:28] - 948 | C:\Windows\System32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\System32\svchost.exe -k LocalSystemNetworkRestricted [20992 Ko]
[14/07/2009 00:19:28] - 988 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k netsvcs [20992 Ko]
[14/07/2009 00:19:28] - 1188 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k LocalService [20992 Ko]
[14/07/2009 00:19:28] - 1324 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k NetworkService [20992 Ko]
[16/11/2012 21:45:20] - 1432 | C:\Windows\system32\atieclxx.exe (.AMD - AMD External Events Client Module.) - (6.14.11.1122) -> atieclxx [453632 Ko]
[01/02/2014 15:15:23] - 1476 | C:\Program Files\AVAST Software\Avast\AvastSvc.exe (.AVAST Software - avast! Service.) - (9.0.2013.292) -> "C:\Program Files\AVAST Software\Avast\AvastSvc.exe" [50344 Ko]
[01/02/2014 15:14:37] - 1652 | C:\Program Files\AVAST Software\Avast\afwServ.exe (.AVAST Software - avast! firewall service.) - (9.0.2013.292) -> "C:\Program Files\AVAST Software\Avast\afwServ.exe" [113704 Ko]
[14/07/2009 00:19:28] - 1944 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k LocalServiceNoNetwork [20992 Ko]
[14/07/2009 00:19:28] - 624 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k apphost [20992 Ko]
[14/07/2009 00:19:28] - 2524 | C:\Windows\System32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\System32\svchost.exe -k ipripsvc [20992 Ko]
[01/05/2013 17:32:27] - 2860 | C:\Windows\System32\snmp.exe (.Microsoft Corporation - Service SNMP.) - (6.1.7601.17514) -> C:\Windows\System32\snmp.exe [47616 Ko]
[14/07/2009 00:19:28] - 2884 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k imgsvc [20992 Ko]
[14/07/2009 00:19:28] - 2932 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k iissvcs [20992 Ko]
[26/02/2014 19:57:30] - 3072 | C:\Program Files\LogMeIn Hamachi\hamachi-2.exe (.LogMeIn Inc. - Hamachi Client Tunneling Engine.) - (2.2.0.173) -> "C:\Program Files\LogMeIn Hamachi\hamachi-2.exe" -s [1678672 Ko]
[01/05/2013 17:33:20] - 3412 | C:\Windows\system32\sppsvc.exe (.Microsoft Corporation - Service de la plateforme de protection logicielle Microsoft.) - (6.1.7601.17514) -> C:\Windows\system32\sppsvc.exe [3179520 Ko]
[14/07/2009 00:19:28] - 3768 | C:\Windows\System32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\System32\svchost.exe -k secsvcs [20992 Ko]
[14/07/2009 00:19:28] - 3840 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k NetworkServiceNetworkRestricted [20992 Ko]
[14/07/2009 00:19:28] - 3936 | C:\Windows\system32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\system32\svchost.exe -k LocalServiceAndNoImpersonation [20992 Ko]
[14/07/2009 00:41:43] - 3796 | C:\Windows\System32\rundll32.exe (.Microsoft Corporation - Processus hôte Windows (Rundll32).) - (6.1.7600.16385) -> C:\Windows\System32\rundll32.exe shell32.dll,SHCreateLocalServerRunDll {995C996E-D918-4a8c-A302-45719A6F4EA7} -Embedding [44544 Ko]
[14/07/2009 00:24:23] - 1036 | C:\Windows\system32\Dwm.exe (.Microsoft Corporation - Gestionnaire de fenêtres du Bureau.) - (6.1.7600.16385) -> "C:\Windows\system32\Dwm.exe" [92672 Ko]
[24/03/2013 11:44:30] - 320 | C:\Windows\Explorer.EXE (.Microsoft Corporation - Explorateur Windows.) - (6.1.7600.16768) -> C:\Windows\Explorer.EXE [2614784 Ko]
[02/11/2012 15:37:08] - 4100 | C:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe (.Microsoft Corporation - IPoint.exe.) - (2.0.162.0) -> "C:\Program Files\Microsoft Mouse and Keyboard Center\ipoint.exe" [1668720 Ko]
[02/11/2012 15:37:08] - 4108 | C:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe (.Microsoft Corporation - IType.exe.) - (2.0.162.0) -> "C:\Program Files\Microsoft Mouse and Keyboard Center\itype.exe" [1093232 Ko]
[01/02/2014 15:15:23] - 4116 | C:\Program Files\AVAST Software\Avast\AvastUI.exe (.AVAST Software - avast! Antivirus.) - (9.0.2013.292) -> "C:\Program Files\AVAST Software\Avast\AvastUI.exe" /nogui [3767096 Ko]
[21/02/2014 03:54:40] - 4228 | C:\Program Files\iTunes\iTunesHelper.exe (.Apple Inc. - iTunesHelper.) - (11.1.5.5) -> "C:\Program Files\iTunes\iTunesHelper.exe" [152392 Ko]
[05/06/2013 01:02:10] - 4460 | C:\Users\Maxence\AppData\Local\Akamai\netsession_win.exe (.Akamai Technologies, Inc. - Akamai NetSession Client.) - (1.8.9.2) -> "C:\Users\Maxence\AppData\Local\Akamai\netsession_win.exe" [4489472 Ko]
[21/02/2014 03:54:26] - 4532 | C:\Program Files\iPod\bin\iPodService.exe (.Apple Inc. - iPodService Module (32-bit).) - (11.1.5.5) -> "C:\Program Files\iPod\bin\iPodService.exe" [553288 Ko]
[05/06/2013 01:02:10] - 4588 | C:\Users\Maxence\AppData\Local\Akamai\netsession_win.exe (.Akamai Technologies, Inc. - Akamai NetSession Client.) - (1.8.9.2) -> "C:/Users/Maxence/AppData/Local/Akamai/netsession_win.exe" --client [4489472 Ko]
[14/11/2013 16:42:42] - 4660 | C:\Program Files\Skype\Phone\Skype.exe (.Skype Technologies S.A. - Skype .) - (6.11.0.102) -> "C:\Program Files\Skype\Phone\Skype.exe" /minimized /regrun [20584608 Ko]
[14/07/2009 01:14:13] - 4768 | C:\Windows\system32\SearchIndexer.exe (.Microsoft Corporation - Indexeur Microsoft Windows Search.) - (7.0.7600.16385) -> C:\Windows\system32\SearchIndexer.exe /Embedding [428032 Ko]
[01/05/2013 17:34:18] - 4924 | C:\Program Files\Windows Media Player\wmpnetwk.exe (.Microsoft Corporation - Service Partage réseau du Lecteur Windows Media.) - (12.0.7601.17514) -> "C:\Program Files\Windows Media Player\wmpnetwk.exe" [1121792 Ko]
[15/11/2011 23:48:28] - 4512 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" [844752 Ko]
[15/11/2011 23:48:28] - 6072 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=gpu-process --channel="4512.0.1720126335\1977804988" --disable-d3d11 --supports-dual-gpus=false --gpu-driver-bug-workarounds=0,9,18,24,26 --gpu-vendor-id=0x1002 --gpu-device-id=0x9490 --gpu-driver-vendor="Advanced Micro Devices, Inc." --gpu-driver-version=8.970.100.7000 --ignored=" --type=renderer " /prefetch:822062411 [844752 Ko]
[15/11/2011 23:48:28] - 3948 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --extension-process --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.2.717846690\956213121" /prefetch:673131151 [844752 Ko]
[15/11/2011 23:48:28] - 3776 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --extension-process --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.3.2047116254\395226379" /prefetch:673131151 [844752 Ko]
[15/11/2011 23:48:28] - 5836 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --extension-process --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.4.1255635540\766484610" /prefetch:673131151 [844752 Ko]
[15/11/2011 23:48:28] - 3876 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.6.157740879\151903939" /prefetch:673131151 [844752 Ko]
[15/11/2011 23:48:28] - 5684 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.8.1326220077\446573937" /prefetch:673131151 [844752 Ko]
[14/07/2009 00:19:28] - 3240 | C:\Windows\System32\svchost.exe (.Microsoft Corporation - Processus hôte pour les services Windows.) - (6.1.7600.16385) -> C:\Windows\System32\svchost.exe -k LocalServicePeerNet [20992 Ko]
[15/11/2011 23:48:28] - 1056 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=ppapi --channel="4512.16.1330939480\1897605084" --ppapi-flash-args --lang=fr --ignored=" --type=renderer " /prefetch:-632637702 [844752 Ko]
[14/07/2009 00:36:55] - 4652 | C:\Windows\system32\UI0Detect.exe (.Microsoft Corporation - Détection de services interactifs.) - (6.1.7600.16385) -> C:\Windows\system32\UI0Detect.exe [35840 Ko]
[15/11/2011 23:48:28] - 5312 | C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe (.Google Inc. - Google Chrome.) - (30.0.1599.69) -> "C:\Users\Maxence\AppData\Local\Google\Chrome\Application\chrome.exe" --type=renderer --lang=fr --force-fieldtrials=AutocompleteDynamicTrial_2/DefaultControl_R2_Stable/ForceCompositingMode/thread/Prerender/PrerenderEnabled/PrerenderLocalPredictorSpec/LocalPredictor=Disabled/ShowAppLauncherPromo/ShowPromoUntilDismissed/Test0PercentDefault/group_01/UMA-Dynamic-Binary-Uniformity-Trial/default/UMA-Dynamic-Uniformity-Trial/Group6/UMA-Session-Randomized-Uniformity-Trial-5-Percent/group_03/UMA-Uniformity-Trial-1-Percent/group_62/UMA-Uniformity-Trial-10-Percent/group_01/UMA-Uniformity-Trial-100-Percent/group_01/UMA-Uniformity-Trial-20-Percent/group_02/UMA-Uniformity-Trial-5-Percent/group_16/UMA-Uniformity-Trial-50-Percent/group_01/ --renderer-print-preview --enable-threaded-compositing --disable-html-notifications --channel="4512.17.275297875\576335535" /prefetch:673131151 [844752 Ko]
[01/05/2013 17:34:09] - 5720 | C:\Windows\system32\wbem\wmiprvse.exe (.Microsoft Corporation - WMI Provider Host.) - (6.1.7601.17514) -> C:\Windows\system32\wbem\wmiprvse.exe [257536 Ko]
[16/03/2014 04:30:39] - 3908 | C:\Users\Maxence\Desktop\Shortcut_Module.exe (. - Shortcut_Module.) - (16.3.2014.1) -> "C:\Users\Maxence\Desktop\Shortcut_Module.exe" [2169344 Ko]
[01/05/2013 17:34:09] - 5396 | C:\Windows\system32\wbem\wmiprvse.exe (.Microsoft Corporation - WMI Provider Host.) - (6.1.7601.17514) -> C:\Windows\system32\wbem\wmiprvse.exe [257536 Ko]
¤¤¤¤¤¤¤¤¤¤ | Services
Service en fonctionnement : WINDEFEND
Service stoppé : WINDEFEND
Supprimé avec succès : HKLM\..\ControlSet001\Services\oUltraf : \??\C:\Users\Maxence\AppData\Local\Temp\oUltraf.sys
Supprimé avec succès : HKLM\..\ControlSet001\Enum\Root\LEGACY_oUltraf
Supprimé avec succès : HKLM\..\ControlSet002\Services\oUltraf : \??\C:\Users\Maxence\AppData\Local\Temp\oUltraf.sys
Supprimé avec succès : HKLM\..\ControlSet002\Enum\Root\LEGACY_oUltraf
Supprimé avec succès : HKLM\..\CurrentControlSet\Enum\Root\LEGACY_oUltraf
¤¤¤¤¤¤¤¤¤¤ | Hosts
C:\Windows\System32\Drivers\etc\hosts : Remis a zéro avec succès
¤¤¤¤¤¤¤¤¤¤ | Registre
Supprimé avec succès : HKLM\Software\Classes\AVSAudioEditor5.EditorChannels
Supprimé avec succès : HKLM\Software\Classes\AVSAudioEditor5.EditorChannels.1
Supprimé avec succès : HKLM\Software\Classes\Duuqu.OneClickCtrl.9
Supprimé avec succès : HKLM\Software\Classes\Duuqu.OneClickProcessLauncherMachine.1.0
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.CoCreateAsync
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.CoreClass
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.CoreClass.1
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.CoreMachineClass.1
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.CredentialDialogMachine.1.0
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.OnDemandCOMClassMachine.1.0
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.OnDemandCOMClassMachineFallback.1.0
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.OnDemandCOMClassSvc.1.0
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.ProcessLauncher.1.0
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.Update3COMClassService.1.0
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.Update3WebMachine.1.0
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.Update3WebMachineFallback.1.0
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.Update3WebSvc.1.0
Supprimé avec succès : HKLM\Software\Classes\Google.OneClickCtrl.9
Supprimé avec succès : HKLM\Software\Classes\Google.OneClickProcessLauncherMachine.1.0
Supprimé avec succès : HKLM\Software\Classes\LiveUpdate.MIDI.6
Supprimé avec succès : HKLM\Software\Classes\SBCONVERT.IEToolbar
Supprimé avec succès : HKLM\Software\Classes\SBCONVERT.IEToolbar.1
Supprimé avec succès : HKLM\Software\Classes\Toolbar3.SBCONVERT
Supprimé avec succès : HKLM\Software\Classes\Toolbar3.SBCONVERT.1
Supprimé avec succès : HKLM\Software\Classes\DuuquUpdate.CoCreateAsync.1.0
Supprimé avec succès : HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Classes\Google.OneClickCtrl.9
Supprimé avec succès : HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Classes\Google.OneClickProcessLauncherUser.1.0
Supprimé avec succès : HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Classes\LiveUpdate.MIDI.6
Supprimé avec succès : HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Microsoft\Internet Explorer\InternetRegistry\REGISTRY\USER\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Delta
Supprimé avec succès : HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Microsoft\Internet Explorer\InternetRegistry\REGISTRY\USER\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Softonic
Supprimé avec succès : HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Microsoft\Internet Explorer\InternetRegistry\REGISTRY\USER\S-1-5-21-686290786-2354244717-1715442158-1000\Software\SweetIM
Supprimé avec succès : [HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\CompatibilityAdapter\Signatures]|[DuuquUpdateTaskMachineCore.job] : "C:\Program Files\LibreOffice 4.0\program\swriter.exe" "%1"
Supprimé avec succès : [HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\CompatibilityAdapter\Signatures]|[DuuquUpdateTaskMachineUA.job] : "C:\Program Files\LibreOffice 4.0\program\swriter.exe" "%1"
Supprimé avec succès : [HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\CompatibilityAdapter\Signatures]|[PutLockerDownloader V6.0-chromeinstaller.job] : "C:\Program Files\LibreOffice 4.0\program\swriter.exe" "%1"
Supprimé avec succès : [HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\CompatibilityAdapter\Signatures]|[PutLockerDownloader V6.0-updater.job] : "C:\Program Files\LibreOffice 4.0\program\swriter.exe" "%1"
Supprimé avec succès : [HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\CompatibilityAdapter\Signatures]|[bench-sys.job] : "C:\Program Files\LibreOffice 4.0\program\swriter.exe" "%1"
Supprimé avec succès : [HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\CompatibilityAdapter\Signatures]|[bench-S-1-5-21-686290786-2354244717-1715442158-1000.job] : "C:\Program Files\LibreOffice 4.0\program\swriter.exe" "%1"
Supprimé avec succès : HKLM\Software\Classes\AppID\{6A070EEA-E3F8-411E-9D3A-F3814ED6D1A8} : SoftwareUpdateApp
Supprimé avec succès : HKLM\Software\Classes\Interface\{1AD79784-C32D-46C7-8A35-6634C43316AC} : {41362495-8942-4D5A-BC98-8BDD17451100}
Supprimé avec succès : HKLM\Software\Classes\Interface\{3BAD286E-058C-4D50-BEBF-14A4FDEC82E1} : {60405004-E845-421D-B5B1-2038E04A9313}
Supprimé avec succès : HKLM\Software\Classes\Interface\{917CAAE9-DD47-4025-936E-1414F07DF5B8} : {968EDCE0-C10A-47BB-B3B6-FDF09F2A417D}
Supprimé avec succès : HKLM\Software\Classes\Interface\{CA201357-7C61-4A7F-B689-D044B70F3949} : {00B595DF-8592-45F8-A3A8-577D0497F0F6}
Supprimé avec succès : HKLM\Software\Classes\Interface\{F7E7D81D-4750-40CF-8498-4C2DE8F2EA02} : {00B595DF-8592-45F8-A3A8-577D0497F0F6}
Supprimé avec succès : HKLM\Software\Classes\Interface\{FF7C3CEF-4B15-11D1-ABED-709549C10000} : {FF7C3CE2-4B15-11D1-ABED-709549C10000}
Supprimé avec succès : HKLM\SYSTEM\CurrentControlSet\Services\Eventlog\Application\IePluginService : C:\ProgramData\IePluginS
Supprimé avec succès : HKLM\SYSTEM\CurrentControlSet\Services\Eventlog\Application\Microsoft-Windows-CertificateServicesClient : {73370bd6-85e5-430b-b60a-fea1285808a7}
Supprimé avec succès : HKLM\SYSTEM\CurrentControlSet\Services\Eventlog\Application\Wpm : C:\ProgramData\WPM\
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\01net_Hamachi_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\01net_LimeWire_Pirate_Edition_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\33374dd6-affb-4565-8e26-8e93db7cec5e_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\daemon-tools-lite_4-47-1-0337_fr_10729_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\DivXWebPlayerInstaller_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\LollipopInstaller_uni_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\Mysearchdial_suInstallerRemote_2_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\PutLockerDownloader V6_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\QwertyBox_Installer_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\Softonic_chr_1_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\SoftwareUpdate_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\SupTab_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\toolbarChecker_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\TornTV_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\wpm_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\wprotectmanager_RASAPI32
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\01net_Hamachi_RASMANCS
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\33374dd6-affb-4565-8e26-8e93db7cec5e_RASMANCS
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\daemon-tools-lite_4-47-1-0337_fr_10729_RASMANCS
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\DivXWebPlayerInstaller_RASMANCS
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\LollipopInstaller_uni_RASMANCS
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\Mysearchdial_suInstallerRemote_2_RASMANCS
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\PutLockerDownloader V6_RASMANCS
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\Softonic_chr_1_RASMANCS
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\SupTab_RASMANCS
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\toolbarChecker_RASMANCS
Supprimé avec succès : HKLM\Software\Microsoft\Tracing\wpm_RASMANCS
Supprimé avec succès : HKLM\Software\Google\Chrome\Extensions\pelmeidfhdlhlbjimpabfcbnnojbboma : : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Extensions\newtabv3.crx
Supprimé avec succès : HKLM\SOFTWARE\Google\Chrome\NativeMessagingHosts\com.bench.nmhost : : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Extensions\newtabv3.crx
Supprimé avec succès : HKLM\SOFTWARE\awesomehpSoftware
Supprimé avec succès : HKLM\SOFTWARE\Coupon Server
Supprimé avec succès : HKLM\SOFTWARE\PutLockerDownloader V6.0
Supprimé avec succès : HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\SpeedBit
Supprimé avec succès : HKU\S-1-5-18\Software\AskPartnerNetwork
Supprimé avec succès : HKU\S-1-5-18\Software\BabSolution
Supprimé avec succès : HKLM\Software\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{60405004-E845-421D-B5B1-2038E04A9313} : C:\Program Files\Coupon Server\
Supprimé avec succès : HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{603C4CC9-5DC6-4C44-873F-8281509DF953} : C:\Program Files\SpeedBit Video Downloader
Supprimé avec succès : HKU\S-1-5-21-686290786-2354244717-1715442158-1000\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{059A958F-2218-4D0F-9329-ABB86D86DB9A} : 01NET.com Main Customized Web Search
Supprimé avec succès : HKU\S-1-5-21-686290786-2354244717-1715442158-1000\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{BC8B7A62-A526-4409-8D59-0DEEB923AB21} : Search the web (Softonic)
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\047163973EAE2E1199118BCAF689CC3E : C:\Windows\Temp\._msigeplugin61\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\1AF74D8104403D847A0EAD9035F74F17 : C:\Users\Maxence\AppData\Local\Temp\IXP078.TMP\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\3e43b73803c7c394f8a6b2f0402e19c2 : C:\Users\Maxence\AppData\Local\Temp\IXP000.TMP\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\6531AF5077EED0943A67D5AB5DE3F02A : C:\Users\Maxence\AppData\Local\Temp\testnsis\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\8853563B0CA3D1A459F09D56138E3447 : C:\Users\Maxence\AppData\Local\Temp\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\9F2FDFE0D6387BE43AD230B83D1FBFA2 : C:\Windows\TEMP\IXP000.TMP\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\B17E077734D20084C93BB5C6AABEBEAE : C:\Users\Maxence\AppData\Local\Temp\~rnsetup\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\b25099274a207264182f8181add555d0 : C:\Users\Maxence\AppData\Local\Temp\IXP001.TMP\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\c1c4f01781cc94c4c8fb1542c0981a2a : C:\Users\Maxence\AppData\Local\Temp\IXP000.TMP\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\D2A425F47365A600677A7A857BC0A030 : C:\Program Files\AskPartnerNetwork\Toolbar\ORJ-V7\Source
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\E34D5CAAD618D2C4E81555FF3FB53E10 : C:\Users\Maxence\AppData\Local\Temp\IXP078.TMP\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\098CCE33084C42149BB5AB630E521B02 : C:\Program Files\Duuqu\Update\Install\{FCB9ECBC-EB3F-4589-BD9A-AACE58091F7F}\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\46B5A9879DD95AB419A50FCFA0B1B7EF : C:\Users\Maxence\AppData\Local\Temp\IXP844.TMP\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\B2F5519759897D9468219D52080EEDB5 : C:\Users\Maxence\AppData\Local\Temp\IXP844.TMP\
Supprimé avec succès : HKLM\Software\Classes\Installer\Products\D46512F250EDD6C42BE1809B3D31AF3B : C:\Users\Maxence\AppData\Local\Temp\IXP078.TMP\
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\158D6D9E3FE81fa428925F22ACB3A965] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\Updater\Shutdown\
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\15E6C514FEFC09f45BAFAAE1D7546ED4] : 02:\SOFTWARE\AskPartnerNetwork\PackageService\Register\ApnSetupV6\VersionCompareDigits
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\1DB42320A8525634AA089F0BEC86473B] : C:\Program Files\AskPartnerNetwork\Toolbar\apnmcp.exe
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\22468B0D6050b2e46B9C4B67A8F59577] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\PlatformVersion
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\2916E43B5BE8010448F91C6EE9188B68] : C:\Users\Maxence\AppData\Local\Temp\DirectX_Setup\
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\32DF3C84BE725644F83A492D57170E27] : 02:\Software\Duuqu\FrameFox\name
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\3CDF313E9B28c944FBC7579CF4949414] : 02:\SOFTWARE\AskPartnerNetwork\PackageService\
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\46D8F87ADB782284EAF9F8C8E9EAA947] : C:\Program Files\FrameFox\PRIVACY.txt
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\5DB40F0C798147F46B4C4210A29DCC03] : C:\Program Files\AskPartnerNetwork\Toolbar\
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\6C63F7979DCC2154CB9591969A5CB89D] : 02:\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SearchTheWebARP\UserSettings
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\71E54748EDD3dc1468548785DC856EDA] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\Updater\
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\754590DD06DE8d249B526503432F99D4] : C:\Program Files\AskPartnerNetwork\Toolbar\UpdateManager.exe
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\7C921921078A9E54E87804C143C5573C] : 02:\Software\Microsoft\Windows\CurrentVersion\Run\FrameFox Extensions
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\8036C72171EF4ba46856BF57969F6A36] : 01:\SOFTWARE\AskPartnerNetwork\Toolbar\Updater\
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\89BB7852687BDC34B9A81E01C7FF9173] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\shared\TotalTBEverLanded
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\8CBC85D72B148084ABE8C2F072F781F4] : 02:\SOFTWARE\AskPartnerNetwork\PackageService\Register\ApnSetupV6\CheckInterval
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\8DF9A1AC557F56c49B56F6B83E293C15] : 02:\SOFTWARE\AskPartnerNetwork\PackageService\Register\ApnSetupV6\LastCheckTimestamp
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\92BE82F4D303DB55D901F45A13BBBC98] : C:\Program Files\Common Files\Umbrella\Umbrella.exe
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\A97C590397DCC454AA8923563BAB10E4] : 01:\SOFTWARE\AskPartnerNetwork\Toolbar\shared\EnableSA
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\AF85C1F50EB3A0D42AAF49ED74C9A89E] : 02:\Software\Duuqu\Update\Clients\{AC14D5E8-02B7-4849-B31E-35E81F72D121}\name
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\CFA51B44D54927c4E9B7BC1D3FD1E49F] : C:\Program Files\AskPartnerNetwork\Toolbar\Updater\ask-search.xml
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D14A7F65792054F418578C78367D13F7] : 02:\SOFTWARE\AskPartnerNetwork\PackageService\Register\ApnSetupV6\UpdateAllSubPackageToVersion
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677A0850AB47487C] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\ORJ-V7\Info\timeinstalled_cr
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677A0850AB477508] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\ORJ-V7\Info\lastInstallOperation
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677A0850AB478757] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\ORJ-V7\Info\Reporting_URL
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677A0850AB47C77A] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\ORJ-V7\Info\productguid
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677A0850AB67CA07] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\ORJ-V7\Macro\
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677A7A8684D4677A] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\Updater\ORJ-V7\Macro\apnuguid
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677AA75C6CAD4777] : 02:\SOFTWARE\AskPartnerNetwork\PackageService\Register\ApnSetupV6\ORJ-V7\CmdArgs
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677AB8640F7CA77A] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\ORJ-V7\Info\sa_cr
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\DFE9F0BD163D827438CB6AD6B100EC48] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\shared\
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\F739A19A8327dc64C9A8B641A9E89646] : 02:\SOFTWARE\AskPartnerNetwork\PackageService\Register\ApnSetupV6\Version
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\FA1A1F8EF30E0364C9EEC550E8AB58B7] : 02:\Software\Duuqu\FrameFox\ExtensionChromeId
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\2251BF05A2F606d43BB064BD63CBD87E] : 02:\SOFTWARE\AskPartnerNetwork\PackageService\Register\ApnSetupV6\InvokePath
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\8CC5A38A64D6098468BC8395BA0EFF03] : C:\Program Files\AskPartnerNetwork\Toolbar\Updater\TBNotifier.exe
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677A0850AB4748E6] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\ORJ-V7\Info\timeinstalled
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677A0850AB47877E] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\ORJ-V7\Info\ProductVersion
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677A0CF64469657A] : C:\Program Files\AskPartnerNetwork\Toolbar\Updater\ORJ-V7\config.xml
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677A7B7987A75C7A] : 02:\SOFTWARE\AskPartnerNetwork\Toolbar\ORJ-V7\Info\Browsers
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D2A425F47365A600677AA75CE8770476] : 02:\SOFTWARE\AskPartnerNetwork\PackageService\Register\ApnSetupV6\ORJ-V7\Version
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\35852_Coupon Server : C:\Users\Maxence\AppData\Local\Coupon Server\uninstall.exe
Supprimé avec succès : HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\awesomehp uninstaller : C:\Users\Maxence\AppData\Roaming\awesomehp\UninstallManager.exe
Supprimé avec succès : [HKLM\Software\Microsoft\Windows\CurrentVersion\Run]|[BService] : C:\Program Files\Bench\BService\bservice.exe
Supprimé avec succès : [HKU\S-1-5-18\Software\Microsoft\Windows\CurrentVersion\Run]|[SearchProtect] : \SearchProtect\bin\cltmng.exe
Supprimé avec succès : [HKLM\Software\Microsoft\Windows\CurrentVersion\RunOnce]|[Coupon Server-repairJob] : wscript.exe "C:\Users\Maxence\AppData\Local\Coupon Server\repair.js" "Coupon Server-repairJob"
¤¤¤¤¤¤¤¤¤¤ | IFEO
par Ironer
#109543
¤¤¤¤¤¤¤¤¤¤ | Dossiers
Supprimé avec succès : C:\Windows\Tasks\bench-S-1-5-21-686290786-2354244717-1715442158-1000.job
Supprimé avec succès : C:\Windows\Tasks\GoogleUpdateTaskMachineCore.job
Supprimé avec succès : C:\Windows\Tasks\GoogleUpdateTaskMachineUA.job
Supprimé avec succès : C:\Windows\Tasks\GoogleUpdateTaskUserS-1-5-21-686290786-2354244717-1715442158-1000Core.job
Supprimé avec succès : C:\Windows\Tasks\GoogleUpdateTaskUserS-1-5-21-686290786-2354244717-1715442158-1000UA.job
Supprimé avec succès : C:\Windows\Tasks\PutLockerDownloader V6.0-chromeinstaller.job
Supprimé avec succès : C:\Windows\System32\Tasks\bench-S-1-5-21-686290786-2354244717-1715442158-1000
Supprimé avec succès : C:\Windows\System32\Tasks\GoogleUpdateTaskMachineCore
Supprimé avec succès : C:\Windows\System32\Tasks\GoogleUpdateTaskMachineUA
Supprimé avec succès : C:\Windows\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-686290786-2354244717-1715442158-1000Core
Supprimé avec succès : C:\Windows\System32\Tasks\GoogleUpdateTaskUserS-1-5-21-686290786-2354244717-1715442158-1000UA
Supprimé avec succès : C:\Windows\System32\Tasks\PutLockerDownloader V6.0-chromeinstaller
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\DVDVideoSoft
Supprimé avec succès : C:\Program Files\Common Files\SpeedBit
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Coupon Server
Supprimé avec succès : C:\Users\All Users\InstallMate
Supprimé avec succès : C:\Users\All Users\SpeedBit
Supprimé avec succès : C:\Users\All Users\Blizzard Entertainment\Battle.net\Cache\21\b2\21b205fba0c40dd2d09ce8e61a91f337a9c77dab10d7b6b211bcee3564863362.wows
Supprimé avec succès : C:\Users\All Users\Freemake\FreemakeUtilsService\Statistics\CallStacks\9bd1f408-914f-46ee-bd2b-7337255ca922
Supprimé avec succès : C:\Users\All Users\Freemake\FreemakeUtilsService\Statistics\TemporaryLogs\9bd1f408-914f-46ee-bd2b-7337255ca922
Supprimé avec succès : C:\Users\All Users\PMB Files\3EAD3233747E.tok
Supprimé avec succès : C:\Users\All Users\PMB Files\EE34A2337C82.tok
Supprimé avec succès : C:\Users\All Users\TrackMania\Cache\15EE1A337626A5CB3FFBB04BE4DCD99B_Skins%5cAny%5cAdvertisement%5cdanger_.bik
Supprimé avec succès : C:\Users\All Users\TrackMania\Cache\15EE1A337626A5CB3FFBB04BE4DCD99B_Skins%5cAny%5cAdvertisement%5cdanger_.bik.loc
Supprimé avec succès : C:\Users\DefaultAppPool\AppData\Local\Microsoft\Windows\UsrClass.dat{67bff781-b7c8-11e2-a545-002421282337}.TM.blf
Supprimé avec succès : C:\Users\DefaultAppPool\AppData\Local\Microsoft\Windows\UsrClass.dat{67bff781-b7c8-11e2-a545-002421282337}.TMContainer00000000000000000001.regtrans-ms
Supprimé avec succès : C:\Users\DefaultAppPool\AppData\Local\Microsoft\Windows\UsrClass.dat{67bff781-b7c8-11e2-a545-002421282337}.TMContainer00000000000000000002.regtrans-ms
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Battle.net\Cache\37\14\3714660733773ed5d24cfc63f3e88474
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Focus Home Interactive\Cities XL 2012\live\bench.xml
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Extensions\gebbadcnkcgcfgpbmcdleckpejgopimf\1.19_0\cacaoweb.js
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_mcedit.softonic.fr_0.localstorage-journal
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_search.softonic.com_0.localstorage-journal
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_wlan-optimizer.softonic.fr_0.localstorage-journal
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.01net.com_0.localstorage-journal
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Local Storage\http_www.softonic.fr_0.localstorage-journal
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects\7X724A5V\cdn.zopim.com\p0R0uqTScvznF6W#\icok4NIrF0n7lv9XWSession_SO.sol
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects\7X724A5V\cdn.zopim.com\p0R0uqTScvznF6Wi#\cok4NIrF0n7lv9XWVolatile_SO.sol
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Microsoft\Windows\UsrClass.dat{5f13fdb4-b62d-11e0-9117-002421282337}.TM.blf
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Microsoft\Windows\UsrClass.dat{5f13fdb4-b62d-11e0-9117-002421282337}.TMContainer00000000000000000001.regtrans-ms
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Microsoft\Windows\UsrClass.dat{5f13fdb4-b62d-11e0-9117-002421282337}.TMContainer00000000000000000002.regtrans-ms
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Microsoft\Windows\UsrClass.dat{a17a126c-b60e-11e0-950e-002421282337}.TM.blf
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Microsoft\Windows\UsrClass.dat{a17a126c-b60e-11e0-950e-002421282337}.TMContainer00000000000000000001.regtrans-ms
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Microsoft\Windows\UsrClass.dat{a17a126c-b60e-11e0-950e-002421282337}.TMContainer00000000000000000002.regtrans-ms
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Origin\Web Cache\data7\5\1b5e5v9e.d
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Temp\5b9f7932-f3ac-48f1-a7bd-6c3f13a298c7\bin\Awesomehp
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Temp\5b9f7932-f3ac-48f1-a7bd-6c3f13a298c7\software\Coupon Server.exe
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Temp\5b9f7932-f3ac-48f1-a7bd-6c3f13a298c7\software\LollipopInstaller_uni.exe
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Temp\5b9f7932-f3ac-48f1-a7bd-6c3f13a298c7\software\OptimizerPro.exe
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Temp\5b9f7932-f3ac-48f1-a7bd-6c3f13a298c7\software\tugs_awesomehp.exe
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Temp\5b9f7932-f3ac-48f1-a7bd-6c3f13a298c7\temp\Awesomehpinfo.dfe
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Temp\fullpackage_temp1394818288\log\QQBrowser.LOG
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Temp\fullpackage_temp1394818288\tmp\SupTab.exe
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Temp\fullpackage_temp1394818288\tmp\wpm.exe
Supprimé avec succès : C:\Users\Maxence\AppData\Local\Turbine\DeltaPatch.log
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\.minecraft\assets\objects\4d\4d03069c0e14794b463f563044da46433776da60
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\.minecraft\assets\objects\af\afb01196e2179e3b15b48f3373cea4c155d56b84
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\.minecraft\assets\objects\b9\b9eef13c2337a6335c4523858619ca560dff4496
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\.minecraft\assets\objects\e3\e37d3ab28ec7acc17337da3d4a4fe4dd0642aac5
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\StartMenu\cacaoweb.lnk
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Microsoft\Windows\Cookies\V9HO8K72.txt
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\chrome\CT3285358\content\ConduitAbstractionLayer.js
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\chrome\CT3285358\content\ConduitAbstractionLayerBack.js
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\chrome\CT3285358\content\ConduitAbstractionLayerFront.js
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\chrome\CT3285358\content\toolbarOverlay.js
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\chrome\CT3285358\content\toolbarOverlay.xul
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\chrome\CT3285358\content\tb\al\api\toolbarapi.js
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\chrome\CT3285358\content\tb\al\sp\js\searchProtectorManager.js
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\chrome\CT3285358\content\tb\al\ui\dlg\ftd\ToolbarFirstTimeDialog.js
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\chrome\CT3285358\content\tb\al\wa\Optimizer
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\chrome\CT3285358\content\tb\al\wa\NOTIFICATION\js\ToolbarAndAppsSettings.js
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\lib\log4conduit.jsm
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\extensions\{f531b93a-b50b-4ff1-8288-404c881ac4da}\Plugins\npConduitFirefoxPlugin.dll
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Origin\Widget Updates\dc08c76c1c700cdea8833b5d85fcfd65bedcbe94\837b337204423292b54ba566c95c619d52cc2122
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\Origin\Widget Updates\dc08c76c1c700cdea8833b5d85fcfd65bedcbe94\e9113b764b0e3375eb06db7e94e34ff4fb8dd0ea
Supprimé avec succès : C:\Users\Maxence\AppData\Roaming\TERA\launcher\live\5195e95eb3fc85617c119245505746667a337ecb.settings
Supprimé avec succès : C:\Users\Maxence\Desktop\LOLPBE\RADS\projects\lol_air_client\releases\0.0.1.218\deploy\lib\ClientLibNewPlayerLandingPage.dat
Supprimé avec succès : C:\Users\Maxence\Desktop\LOLPBE\RADS\projects\lol_air_client\releases\0.0.1.218\deploy\logs\LolClient.20110920.174337.log
Supprimé avec succès : C:\Users\Maxence\Desktop\LOLPBE\RADS\projects\lol_air_client\releases\0.0.1.218\deploy\mod\lp\themes\parchment\newPlayerLandingPageAssets.swf
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\items\materials\apexshipsupport.matitem
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\monsters\ground\quadruped\organic\chest\gator\gatorchest.monsterpart
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\monsters\ground\quadrupednight\organic\chest\gator\gatorchest.monsterpart
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\avian\avianbench1
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\avian\avianbench2
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\avian\crystaltorch
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\floran\floranbench
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\floran\huntingbench
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\floran\huntinggroundtorch
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\floran\planttorch
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\generic\torch
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\glitch\medievaltorch
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\human\prisonbench
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\objects\minibiome\sandstone\sandstonetorch
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\recipes\biomes\sandstone\sandstonetorch.recipe
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\recipes\starter\plain\torch.recipe
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\sfx\objects\torch.wav
Supprimé avec succès : C:\Users\Maxence\Documents\Starbound\Starbound\assets\tiles\materials\apexshipsupport.material
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_assistant_intermediate.ba
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_assistant_intermediate.bae
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_assistant_intermediate.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_assistant_intermediate.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_assistant_intermediate.bs
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_assistant_intermediate.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_assistant_intermediate_1.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_assistant_intermediate_2.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_assistant_intermediate_shd.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_assistant_intermediate_sword.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_drillmaster_intermediate.ba
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_drillmaster_intermediate.bae
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_drillmaster_intermediate.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_drillmaster_intermediate.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_drillmaster_intermediate.bs
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_drillmaster_intermediate.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_drillmaster_intermediate_1.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_drillmaster_intermediate_2.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_drillmaster_intermediate_shd.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_drillmaster_intermediate_sword.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guarddog_intermediate.ba
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guarddog_intermediate.bae
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guarddog_intermediate.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guarddog_intermediate.bs
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guarddog_intermediate.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guarddog_intermediate_bu.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guarddog_intermediate_head.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guard_intermediate.ba
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guard_intermediate.bae
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guard_intermediate.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guard_intermediate.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guard_intermediate.bs
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guard_intermediate.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_guard_intermediate_sword.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate.bae
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate.bs
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate_1.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate_2.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate_3.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate_4.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate_shd.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_intermediate_sword.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_instructor_lintermediate.ba
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_trainee_intermediate.ba
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_trainee_intermediate.bae
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_trainee_intermediate.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_trainee_intermediate.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_trainee_intermediate.bs
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_trainee_intermediate.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_trainee_intermediate_1.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\heresy_trainee_intermediate_sword.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Monster\Heresy\_TEG_T_CENTER_heresy_guarddog_intermediate.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\Sounds\Monster\MondShine\HERESY_INSTRUCTOR_lintermediate_ATT02.wav
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Ascadia-MondShine(CappellaDungeon)\Ska\torchlight_01.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Ascadia-MondShine(CappellaDungeon)\Ska\torchlight_01.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Ascadia-MondShine(CappellaDungeon)\Ska\torchlight_01.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Ascadia-MondShine(CappellaDungeon)\Ska\torchlight_01.tbn
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Ascadia-MondShine(CappellaDungeon)\Ska\Texture\torchlight_01.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_01.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_01.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_01.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_01.tbn
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_02.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_02.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_02.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_02.tbn
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_03.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_03.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_03.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_03.tbn
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_04.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_04.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_04.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\torchlight_04.tbn
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\Texter\A_torchlight_01.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\Texter\torchlight_01.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\Texter\torchlight_02.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\Texter\torchlight_03-1.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\Texter\torchlight_03-2.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\Texter\torchlight_03-3.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\Texter\torchlight_04-1.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_10F_Top\Ska\Texter\torchlight_04-2.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_01.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_01.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_01.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_01.tbn
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_02.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_02.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_02.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_02.tbn
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_03.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_03.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_03.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_03.tbn
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_04.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_04.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_04.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\torchlight_04.tbn
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\Texter\A_torchlight_01.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\Texter\torchlight_01.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\Texter\torchlight_02.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\Texter\torchlight_03-1.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\Texter\torchlight_03-2.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\Texter\torchlight_03-3.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\Texter\torchlight_04-1.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_1F_7F\Ska\Texter\torchlight_04-2.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_01.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_01.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_01.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_02.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_02.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_02.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_03.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_03.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_03.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_04.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_04.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\torchlight_04.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\Texter\A_torchlight_01.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\Texter\torchlight_01.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\Texter\torchlight_02.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\Texter\torchlight_03-1.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\Texter\torchlight_03-2.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\Texter\torchlight_03-3.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\Texter\torchlight_04-1.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_8F\Ska\Texter\torchlight_04-2.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\torchlight_01.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\torchlight_01.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\torchlight_02.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\torchlight_02.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\torchlight_03.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\torchlight_03.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\torchlight_04.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\torchlight_04.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\Texter\A_torchlight_01.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\Texter\torchlight_01.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\Texter\torchlight_02.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\Texter\torchlight_03-1.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\Texter\torchlight_03-2.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\Texter\torchlight_03-3.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\Texter\torchlight_04-1.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Egeha_dungeon_9F\Ska\Texter\torchlight_04-2.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Guild\Ska\torch_G.aml
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Guild\Ska\torch_G.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Guild\Ska\torch_G.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Guild\Ska\torch_G.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Guild\Ska\Texture\torch_G.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\ox_Event\Ska\torch_G.aml
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\ox_Event\Ska\torch_G.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\ox_Event\Ska\torch_G.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\ox_Event\Ska\torch_G.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\ox_Event\Ska\Texture\torch_G.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\StartZone\Ska\st_bench_01.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\StartZone\Ska\st_bench_01.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\StartZone\Ska\st_bench_01.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\StartZone\Ska\st_bench_01.tbn
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\StartZone\Ska\Texture\st_bench_01_01.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\StartZone\Ska\Texture\st_bench_01_02.tex
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Tarian_dungeon\Ska\td_torch_01.bm
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Tarian_dungeon\Ska\td_torch_01.bmc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Tarian_dungeon\Ska\td_torch_01.smc
Supprimé avec succès : C:\Users\Maxence\Downloads\destinylc\Data\World\Tarian_dungeon\Ska\Texture\torch.tex
Supprimé avec succès : C:\Users\Maxence\minecraft\assets\objects\4d\4d03069c0e14794b463f563044da46433776da60
Supprimé avec succès : C:\Users\Maxence\minecraft\assets\objects\af\afb01196e2179e3b15b48f3373cea4c155d56b84
Supprimé avec succès : C:\Users\Maxence\minecraft\assets\objects\b9\b9eef13c2337a6335c4523858619ca560dff4496
Supprimé avec succès : C:\Windows\Installer\{4F524A2D-5637-006A-76A7-A758B70C0A03}\ToolbarIcon.exe
¤¤¤¤¤¤¤¤¤¤ | Détournements de raccourcis
¤¤¤¤¤¤¤¤¤¤ | Proxy
Réparé : [HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Microsoft\Windows\CurrentVersion\Internet settings]|[ProxyOverride] : *.local;<local> -> *.local
Réparé : [HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Microsoft\Windows\CurrentVersion\Internet settings]|[WarnonZoneCrossing] : 0 -> 1
¤¤¤¤¤¤¤¤¤¤ | Détournement internet Explorer
Réparé : [HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Microsoft\Internet Explorer\Main]|[Start Page] : http://www.google.com" onclick="window.open(this.href);return false; -> http://www.google.com/" onclick="window.open(this.href);return false;
Réparé : [HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Microsoft\Internet Explorer\Main]|[Search Page] : http://go.microsoft.com/fwlink/?LinkId=54896" onclick="window.open(this.href);return false; -> http://www.microsoft.com/isapi/redir.dl ... r=iesearch" onclick="window.open(this.href);return false;
Réparé : [HKU\S-1-5-21-686290786-2354244717-1715442158-1000\Software\Microsoft\Internet Explorer\Main]|[Default_Page_URL] : http://www.google.com" onclick="window.open(this.href);return false; -> http://go.microsoft.com/fwlink/?LinkId=69157" onclick="window.open(this.href);return false;
Réparé : [HKLM\Software\Microsoft\Internet Explorer\Main]|[Start Page] : http://www.google.com" onclick="window.open(this.href);return false; -> http://go.microsoft.com/fwlink/?LinkId=69157" onclick="window.open(this.href);return false;
Réparé : [HKLM\Software\Microsoft\Internet Explorer\Main]|[Default_Search_URL] : http://www.google.com" onclick="window.open(this.href);return false; -> http://go.microsoft.com/fwlink/?LinkId=54896" onclick="window.open(this.href);return false;
Réparé : [HKLM\Software\Microsoft\Internet Explorer\Main]|[Default_Page_URL] : http://www.google.com" onclick="window.open(this.href);return false; -> http://go.microsoft.com/fwlink/?LinkId=69157" onclick="window.open(this.href);return false;
Réparé : [HKLM\Software\Microsoft\Internet Explorer\Main]|[Search Page] : http://www.google.com" onclick="window.open(this.href);return false; -> http://go.microsoft.com/fwlink/?LinkId=54896" onclick="window.open(this.href);return false;
Réparé : [HKLM\Software\Microsoft\Internet Explorer\AboutURLs]|[Tabs] : http://www.google.com" onclick="window.open(this.href);return false; -> res://ieframe.dll/tabswelcome.htm" onclick="window.open(this.href);return false;
¤¤¤¤¤¤¤¤¤¤ | Détournement Google Chrome
[Maxence] Remis a zéro avec succès : SearchURL
[Maxence] Remis a zéro avec succès : Preferences
¤¤¤¤¤¤¤¤¤¤ | Détournement Firefox
¤¤¤¤¤¤¤¤¤¤ | Détournement des clés StartMenuInternet
Réparé : [HKLM\Software\Clients\StartMenuInternet\IExplore.exe\shell\open\command] : C:\Program Files\Internet Explorer\iexplore.exe -> "C:\Program Files\Internet Explorer\iexplore.exe"
¤¤¤¤¤¤¤¤¤¤ | AppInit_DLLs
[HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows]|[LoadAppInit_DLLs] : 1
¤¤¤¤¤¤¤¤¤¤ | Détournement Javascript
¤¤¤¤¤¤¤¤¤¤ | Firewall
Réparé : [HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\DomainProfile]|[EnableFirewall] : 1 -> 0
Réparé : [HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\StandardProfile]|[EnableFirewall] : 1 -> 0
Réparé : [HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\PublicProfile]|[EnableFirewall] : 1 -> 0
Supprimé avec succès : [HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules]|[TCP Query User{187A97FD-F74E-428F-AE5F-B626677DB4EB}C:\users\maxence\appdata\roaming\cacaoweb\cacaoweb.exe] : v2.10|Action=Allow|Active=TRUE|Dir=In|Protocol=6|Profile=Private|App=C:\users\maxence\appdata\roaming\cacaoweb\cacaoweb.exe|Name=cacaoweb.exe|Desc=cacaoweb.exe|Defer=User|
Supprimé avec succès : [HKLM\SYSTEM\CurrentControlSet\services\SharedAccess\Parameters\FirewallPolicy\FirewallRules]|[{3A0CED28-78DA-481F-B0D4-CE51DA474837}] : v2.10|Action=Block|Active=TRUE|Dir=In|Protocol=17|Profile=Public|App=C:\users\maxence\appdata\roaming\cacaoweb\cacaoweb.exe|Name=cacaoweb.exe|Desc=cacaoweb.exe|
¤¤¤¤¤¤¤¤¤¤ | Fichiers temporaires
[All Users] Fichiers temporaires Supprimés : 0 Ko
[Default User] Fichiers temporaires Supprimés : 0 Ko
[Default] Fichiers temporaires Supprimés : 0 Ko
[DefaultAppPool] Fichiers temporaires Supprimés : 0 Ko
[Public] Fichiers temporaires Supprimés : 0 Ko
[hedev] Fichiers temporaires Supprimés : 43164 Ko
[Maxence] Fichiers temporaires Supprimés : 80904 Ko
Autre rapport
¤¤¤¤¤¤¤¤¤¤ |EOF| ¤¤¤¤¤¤¤¤¤¤ | 05:08:45
#109604
on a pas fini ^^
    1. Choisis l'option Scanner
    2. Choisis l'option Nettoyer
par Ironer
#109628
# AdwCleaner v3.022 - Rapport créé le 16/03/2014 à  03:10:01
# Mis à  jour le 13/03/2014 par Xplode
# Système d'exploitation : Windows 7 Ultimate (32 bits)
# Nom d'utilisateur : Maxence - MAXENCE-PC
# Exécuté depuis : C:\Users\Maxence\Downloads\adwcleaner.exe
# Option : Nettoyer
***** [ Services ] *****
Service Supprimé : APNMCP
[#] Service Supprimé : dqupdate
[#] Service Supprimé : dqupdatem
Service Supprimé : IePluginService
Service Supprimé : Wpm
Dossier Supprimé : C:\ProgramData\apn
Dossier Supprimé : C:\ProgramData\Ask
Dossier Supprimé : C:\ProgramData\AskPartnerNetwork
Dossier Supprimé : C:\ProgramData\IePluginService
Dossier Supprimé : C:\ProgramData\Iminent
Dossier Supprimé : C:\ProgramData\StarApp
Dossier Supprimé : C:\ProgramData\Tarma Installer
Dossier Supprimé : C:\ProgramData\WPM
Dossier Supprimé : C:\ProgramData\coNtinuuetosave
Dossier Supprimé : C:\ProgramData\Searchh-NewwTab
[/!\] Non Supprimé ( Junction ) : C:\ProgramData\Searchh-NewwTab
Dossier Supprimé : C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Iminent
Dossier Supprimé : C:\Program Files\AskPartnerNetwork
Dossier Supprimé : C:\Program Files\Bench
Dossier Supprimé : C:\Program Files\Iminent
Dossier Supprimé : C:\Program Files\Optimizer Pro
Dossier Supprimé : C:\Program Files\SearchProtect
Dossier Supprimé : C:\Program Files\Softonic
Dossier Supprimé : C:\Program Files\SoftwareUpdater
Dossier Supprimé : C:\Program Files\SupTab
Dossier Supprimé : C:\Program Files\Common Files\Umbrella
Dossier Supprimé : C:\Windows\system32\AI_RecycleBin
Dossier Supprimé : C:\Windows\system32\SearchProtect
Dossier Supprimé : C:\Users\Maxence\AppData\Local\apn
Dossier Supprimé : C:\Users\Maxence\AppData\Local\BenchUpdater
Dossier Supprimé : C:\Users\Maxence\AppData\Local\Bundled software uninstaller
Dossier Supprimé : C:\Users\Maxence\AppData\Local\Conduit
Dossier Supprimé : C:\Users\Maxence\AppData\Local\cool_mirage
Dossier Supprimé : C:\Users\Maxence\AppData\Local\Duuqu
Dossier Supprimé : C:\Users\Maxence\AppData\Local\lollipop
Dossier Supprimé : C:\Users\Maxence\AppData\Local\SearchProtect
Dossier Supprimé : C:\Users\Maxence\AppData\LocalLow\boost_interprocess
Dossier Supprimé : C:\Users\Maxence\AppData\LocalLow\Conduit
Dossier Supprimé : C:\Users\Maxence\AppData\LocalLow\Delta
Dossier Supprimé : C:\Users\Maxence\AppData\LocalLow\Softonic
Dossier Supprimé : C:\Users\Maxence\AppData\LocalLow\Toolbar4
Dossier Supprimé : C:\Users\Maxence\AppData\LocalLow\coNtinuuetosave
Dossier Supprimé : C:\Users\Maxence\AppData\LocalLow\Searchh-NewwTab
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\awesomehp
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\BabSolution
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\cacaoweb
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\Delta
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\dvdvideosoftiehelpers
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\file scout
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\Iminent
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\Mysearchdial
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\OpenCandy
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\Softonic
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\SupTab
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\Yontoo
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\BitGuard
Dossier Supprimé : C:\Users\Maxence\Documents\Optimizer Pro
Dossier Supprimé : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\Profiles\[ofr2][opt]rs0\Extensions\cacaoweb@cacaoweb.org
Dossier Supprimé : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Extensions\dmcecclamecbinmplcolhaljlclhbgah
Fichier Supprimé : C:\Users\Maxence\AppData\Roaming\BabMaint.exe
Fichier Supprimé : C:\Users\Maxence\Desktop\cacaoweb.exe
Fichier Supprimé : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\Profiles\[ofr2][opt]rs0\searchplugins\WebSearch.xml
Fichier Supprimé : C:\Program Files\Mozilla Firefox\user.js
Fichier Supprimé : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\bProtector Web Data
Fichier Supprimé : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Local Storage\chrome-extension_eooncjejnppfjjklapaamhcdmjbilmde_0.localstorage
Fichier Supprimé : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Local Storage\hxxp_search.babylon.com_0.localstorage-journal
Fichier Supprimé : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Local Storage\hxxp_www.delta-search.com_0.localstorage-journal
Fichier Supprimé : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Local Storage\hxxp_www.wajam.com_0.localstorage-journal
Fichier Supprimé : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\Local Storage\hxxp_www1.delta-search.com_0.localstorage-journal
Fichier Supprimé : C:\Windows\Tasks\bench-sys.job
Fichier Supprimé : C:\Windows\System32\Tasks\bench-sys
Fichier Supprimé : C:\Windows\System32\Tasks\BitGuard
Fichier Supprimé : C:\Windows\System32\Tasks\Dealply
Fichier Supprimé : C:\Windows\System32\Tasks\DealPlyUpdate
Fichier Supprimé : C:\Windows\Tasks\DuuquUpdateTaskMachineCore.job
Fichier Supprimé : C:\Windows\System32\Tasks\DuuquUpdateTaskMachineCore
Fichier Supprimé : C:\Windows\Tasks\DuuquUpdateTaskMachineUA.job
Fichier Supprimé : C:\Windows\System32\Tasks\DuuquUpdateTaskMachineUA
Fichier Supprimé : C:\Windows\System32\Tasks\EPUpdater
Fichier Supprimé : C:\Windows\Tasks\PutLockerDownloader V6.0-updater.job
Fichier Supprimé : C:\Windows\System32\Tasks\PutLockerDownloader V6.0-updater
***** [ Raccourcis ] *****
Raccourci Désinfecté : C:\Users\Maxence\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Internet Explorer.lnk
Raccourci Désinfecté : C:\Users\Maxence\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Google Chrome\Google Chrome.lnk
Raccourci Désinfecté : C:\Users\Maxence\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Accessories\System Tools\Internet Explorer (No Add-ons).lnk
Raccourci Désinfecté : C:\Users\Maxence\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Launch Internet Explorer Browser.lnk
Raccourci Désinfecté : C:\Users\Maxence\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar\Google Chrome.lnk
***** [ Registre ] *****
Valeur Supprimée : HKCU\Software\Mozilla\Firefox\Extensions [{0F827075-B026-42F3-885D-98981EE7B1AE}]
Valeur Supprimée : HKCU\Software\Mozilla\Firefox\Extensions [{5a95a9e0-59dd-4314-bd84-4d18ca83a0e2}]
Valeur Supprimée : HKCU\Software\Mozilla\Firefox\Extensions [autolyrics@man-soft.net]
Valeur Supprimée : HKLM\SOFTWARE\Mozilla\Firefox\Extensions [searchpredict@speedbit.com]
Clé Supprimée : HKLM\SOFTWARE\Google\Chrome\Extensions\elchiiiejkobdbblfejjkbphbddgmljf
Clé Supprimée : HKLM\SOFTWARE\Google\Chrome\Extensions\eooncjejnppfjjklapaamhcdmjbilmde
Clé Supprimée : HKCU\Software\Google\Chrome\Extensions\gaiilaahiahdejapggenmdmafpmbipje
Clé Supprimée : HKCU\Software\Google\Chrome\Extensions\hakpajgggjjcjmidfbnnncnbaihjneaj
Clé Supprimée : HKLM\SOFTWARE\Google\Chrome\Extensions\hakpajgggjjcjmidfbnnncnbaihjneaj
Clé Supprimée : HKCU\Software\Google\Chrome\Extensions\leahdjjpjmnamomgpojikeapflgbmjab
Clé Supprimée : HKLM\SOFTWARE\Google\Chrome\Extensions\nbmafkdmkkckhggblphicnnhlgljnoje
Clé Supprimée : HKLM\SOFTWARE\Google\Chrome\Extensions\niapdbllcanepiiimjjndipklodoedlc
Clé Supprimée : HKCU\Software\Google\Chrome\Extensions\paoponfhfdfnjgddpnpjkambkcgdaaib
Clé Supprimée : HKLM\SOFTWARE\Google\Chrome\Extensions\paoponfhfdfnjgddpnpjkambkcgdaaib
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{92BF3C28-5CB4-4B78-B4C4-CB28D398D44F}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{92BF3C28-5CB4-4B78-B4C4-CB28D398D44F}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{6667EEF7-AC31-4547-9BD3-0FE2847FB344}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{6667EEF7-AC31-4547-9BD3-0FE2847FB344}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon\{C7A16EE1-7B44-4B84-8EE3-C0D90327595C}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{C7A16EE1-7B44-4B84-8EE3-C0D90327595C}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{EF55C836-B1CF-43C1-A8A9-9515682BD6F6}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{EF55C836-B1CF-43C1-A8A9-9515682BD6F6}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Plain\{8826BB30-C2EE-48AA-83A0-85894CFCCDA5}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{8826BB30-C2EE-48AA-83A0-85894CFCCDA5}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Logon\{1386DF86-8C24-4465-8D46-C3F6C3EB786E}
[#] Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\{1386DF86-8C24-4465-8D46-C3F6C3EB786E}
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes [bProtectorDefaultScope]
Valeur Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Run [cacaoweb]
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\escort.DLL
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\escortApp.DLL
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\escortEng.DLL
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\escorTlbr.DLL
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\esrv.EXE
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\TbCommonUtils.DLL
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\TbHelper.EXE
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\YontooIEClient.DLL
Clé Supprimée : HKLM\SOFTWARE\Classes\ComObject.DeskbarEnabler
Clé Supprimée : HKLM\SOFTWARE\Classes\ComObject.DeskbarEnabler.1
Clé Supprimée : HKLM\SOFTWARE\Classes\d
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltaappCore
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltaappCore.1
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltadskBnd
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltadskBnd.1
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltaHlpr
Clé Supprimée : HKLM\SOFTWARE\Classes\delta.deltaHlpr.1
Clé Supprimée : HKLM\SOFTWARE\Classes\escort.escortIEPane
Clé Supprimée : HKLM\SOFTWARE\Classes\escort.escortIEPane.1
Clé Supprimée : HKLM\SOFTWARE\Classes\esrv.deltaESrvc
Clé Supprimée : HKLM\SOFTWARE\Classes\esrv.deltaESrvc.1
Clé Supprimée : HKLM\SOFTWARE\Classes\Iminent
Clé Supprimée : HKLM\SOFTWARE\Classes\S
Clé Supprimée : HKLM\SOFTWARE\Classes\SBConvert.SBConvert
Clé Supprimée : HKLM\SOFTWARE\Classes\SBConvert.SBConvert.3
Clé Supprimée : HKLM\SOFTWARE\Classes\Softonic.dskBnd
Clé Supprimée : HKLM\SOFTWARE\Classes\Softonic.dskBnd.1
Clé Supprimée : HKLM\SOFTWARE\Classes\Softonic.SoftonicHlpr
Clé Supprimée : HKLM\SOFTWARE\Classes\Softonic.SoftonicHlpr.1
Clé Supprimée : HKLM\SOFTWARE\Classes\SoftonicApp.appCore
Clé Supprimée : HKLM\SOFTWARE\Classes\SoftonicApp.appCore.1
Clé Supprimée : HKLM\SOFTWARE\Classes\speedupmypc
Clé Supprimée : HKLM\SOFTWARE\Classes\srv.SoftonicSrvc
Clé Supprimée : HKLM\SOFTWARE\Classes\srv.SoftonicSrvc.1
Clé Supprimée : HKLM\SOFTWARE\Classes\TbCommonUtils.CommonUtils
Clé Supprimée : HKLM\SOFTWARE\Classes\TbCommonUtils.CommonUtils.1
Clé Supprimée : HKLM\SOFTWARE\Classes\TbHelper.TbDownloadManager
Clé Supprimée : HKLM\SOFTWARE\Classes\TbHelper.TbDownloadManager.1
Clé Supprimée : HKLM\SOFTWARE\Classes\TbHelper.TbPropertyManager
Clé Supprimée : HKLM\SOFTWARE\Classes\TbHelper.TbPropertyManager.1
Clé Supprimée : HKLM\SOFTWARE\Classes\TbHelper.TbRequest
Clé Supprimée : HKLM\SOFTWARE\Classes\TbHelper.TbRequest.1
Clé Supprimée : HKLM\SOFTWARE\Classes\TbHelper.TbTask
Clé Supprimée : HKLM\SOFTWARE\Classes\TbHelper.TbTask.1
Clé Supprimée : HKLM\SOFTWARE\Classes\TbHelper.ToolbarHelper
Clé Supprimée : HKLM\SOFTWARE\Classes\TbHelper.ToolbarHelper.1
Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar3.ContextMenuNotifier
Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar3.ContextMenuNotifier.1
Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar3.CustomInternetSecurityImpl
Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar3.CustomInternetSecurityImpl.1
Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar3.SearchProviderManager
Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar3.SearchProviderManager.1
Clé Supprimée : HKLM\SOFTWARE\Classes\URLSearchHook.ToolbarURLSearchHook
Clé Supprimée : HKLM\SOFTWARE\Classes\URLSearchHook.ToolbarURLSearchHook.1
Clé Supprimée : HKLM\SOFTWARE\Classes\YontooIEClient.Api
Clé Supprimée : HKLM\SOFTWARE\Classes\YontooIEClient.Api.1
Clé Supprimée : HKLM\SOFTWARE\Classes\YontooIEClient.Layers
Clé Supprimée : HKLM\SOFTWARE\Classes\YontooIEClient.Layers.1
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\AboutURLs [bProtectTabs]
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\ApnSetup_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\ApnSetup_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\apntoolbarinstaller_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\apntoolbarinstaller_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\askpartnercobrandingtool_rasapi32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\askpartnercobrandingtool_rasmancs
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\boxore_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\boxore_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\IminentSetup_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\IminentSetup_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\optprostart_rasapi32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\optprostart_rasmancs
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\PutlockerDownloader_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\PutlockerDownloader_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\wajam_download_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\wajam_download_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\wajam_install_rasapi32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\wajam_install_rasmancs
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\wajamupdater_rasapi32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\wajamupdater_rasmancs
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [ApnTbMon]
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run [IminentMessenger]
Clé Supprimée : HKLM\SOFTWARE\MozillaPlugins\@www.duuqu.com/omaha/tools//Duuqu Update;version=3
Clé Supprimée : HKLM\SOFTWARE\MozillaPlugins\@www.duuqu.com/omaha/tools//Duuqu Update;version=9
Clé Supprimée : HKCU\Software\590da8db135ec43
Clé Supprimée : HKLM\SOFTWARE\590da8db135ec43
Clé Supprimée : HKLM\SOFTWARE\Classes\Toolbar.CT3285358
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\SoftonicDownloader_for_rail-simulator_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\SoftonicDownloader_for_rail-simulator_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\SoftonicDownloader_pour_osu_RASAPI32
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Tracing\SoftonicDownloader_pour_osu_RASMANCS
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{09C554C3-109B-483C-A06B-F14172F1A947}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{39CB8175-E224-4446-8746-00566302DF8D}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{4CE516A7-F7AC-4628-B411-8F886DC5733E}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{4E1E9D45-8BF9-4139-915C-9F83CC3D5921}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{628F3201-34D0-49C0-BB9A-82A26AEFB291}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{7ABBFE1C-E485-44AA-8F36-353751B4124D}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{B12E99ED-69BD-437C-86BE-C862B9E5444D}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{B15F118E-AF21-45E8-A809-29FDD7362565}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{CA5CAA63-B27C-4963-9BEC-CB16A36D56F8}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{CFDAFE39-20CE-451D-BD45-A37452F39CF0}
Clé Supprimée : HKLM\SOFTWARE\Classes\AppID\{D7EE8177-D51E-4F89-92B6-83EA2EC40800}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{3593C8B9-8E18-4B4B-B7D3-CB8BEB1AA42C}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{44B50C01-4993-48E2-ADEE-D812BAE2E9A2}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{5018CFD2-804D-4C99-9F81-25EAEA2769DE}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{80922EE0-8A76-46AE-95D5-BD3C3FE0708D}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{99066096-8989-4612-841F-621A01D54AD7}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{A3E2F089-DDBB-4CBF-B06C-5D44DA316ED3}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{A5679AB0-C59E-49E7-83C4-5289F844A6E0}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{CA0167C2-6295-41B8-9BDA-704B2F5E4CD9}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{E87806B5-E908-45FD-AF5E-957D83E58E68}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{FE9271F2-6EFD-44B0-A826-84C829536E93}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{3C66E288-CA4A-D1DC-60AD-AD14D47BE24B}
Clé Supprimée : HKLM\SOFTWARE\Classes\CLSID\{DF63C4EC-CF5D-D784-8E6F-D09BD51DE298}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{01221FCC-4BFB-461C-B08C-F6D2DF309921}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{087CDC12-0A11-4D1D-8DCF-44185D7C3496}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{088BF3A9-6AE8-47B9-A3FB-26262F236C79}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{0FA32667-9A8A-4E9C-902F-CA3323180003}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{10DE7085-6A1E-4D41-A7BF-9AF93E351401}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{1231839B-064E-4788-B865-465A1B5266FD}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{1AD27395-1659-4DFF-A319-2CFA243861A5}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{2A42D13C-D427-4787-821B-CF6973855778}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{2AC7B9EB-3881-4EB9-8DEE-0A731A309FDE}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{2DAC2231-CC35-482B-97C5-CED1D4185080}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{31E3BC75-2A09-4CFF-9C92-8D0ED8D1DC0F}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{349C0469-ACDD-49DF-9B3E-0D82E7C7DC4D}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{3D8478AA-7B88-48A9-8BCB-B85D594411EC}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{3F1CD84C-04A3-4EA0-9EA1-7D134FD66C82}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{3F83A9CA-B5F0-44EC-9357-35BB3E84B07F}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{41226591-6F7A-4082-B63A-67FE4A0CF7A6}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{452AE416-9A97-44CA-93DA-D0F15C36254F}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{45CDA4F7-594C-49A0-AAD1-8224517FE979}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{47E520EA-CAD2-4F51-8F30-613B3A1C33EB}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{4897BBA6-48D9-468C-8EFA-846275D7701B}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{4D8ED2B3-DC62-43EC-ABA3-5B74F046B1BE}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{55D69CD1-6715-4C40-BF05-9519AC4DC6E6}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{57C91446-8D81-4156-A70E-624551442DE9}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{66C8FD57-54C4-4D4F-BC95-DCCC763B410A}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{6B458F62-592F-4B25-8967-E6A350A59328}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{70AFB7B2-9FB5-4A70-905B-0E9576142E1D}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{717BAE33-7061-4279-8AE5-6C13BC8AF3F9}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{7AD65FD1-79E0-406D-B03C-DD7C14726D69}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{81E852CC-1FD5-4004-8761-79A48B975E29}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{84F06F7A-F811-48D7-8B34-3F4145183D8F}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{88F6D55F-AA3F-4003-BE69-4AC1998D6492}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{8DBCDED5-08AD-41A2-9BBC-235D84F4FE06}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{95B6A271-FEB4-4160-B0FF-44394C21C8DC}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{97DD820D-2E20-40AD-B01E-6730B2FCE630}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{A0F66203-1A86-4812-9603-A57E09A4D7A3}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{B177446D-54A4-4869-BABC-8566110B4BE0}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{B2CA345D-ADB8-4F5D-AC64-4AB34322F659}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{B9F43021-60D4-42A6-A065-9BA37F38AC47}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{BC39D1B3-4471-41C1-AACA-E097FAF4B7AA}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{BF921DD3-732A-4A11-933B-A5EA49F2FD2C}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{C66F0B7A-BD67-4982-AF71-C6CA6E7F016F}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{D83B296A-2FA6-425B-8AE8-A1F33D99FBD6}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{D9D1DFC5-502D-43E4-B1BB-4D0B7841489A}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{DEB85542-1311-4EC6-8A32-5372EB27FC94}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{E0B07188-A528-4F9E-B2F7-C7FDE8680AE4}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{E67D5BC7-7129-493E-9281-F47BDAFACE4F}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{F05B12E1-ADE8-4485-B45B-898748B53C37}
Clé Supprimée : HKLM\SOFTWARE\Classes\Interface\{FCC9CDD3-EFFF-11D1-A9F0-00A0244AC403}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{11D9E165-B8C1-4734-A56C-BC4FCACA966B}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{39CB8175-E224-4446-8746-00566302DF8D}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{3BCF582D-CA87-4C6F-AF3D-B3548A976AB3}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{4509D3CC-B642-4745-B030-645B79522C6D}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{4599D05A-D545-4069-BB42-5895B4EAE05B}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{4E1E9D45-8BF9-4139-915C-9F83CC3D5921}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{B15F118E-AF21-45E8-A809-29FDD7362565}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{B87F8B63-7274-43FD-87FA-09D3B7496148}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{C4BAE205-5E02-4E32-876E-F34B4E2D000C}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{D372567D-67C1-4B29-B3F0-159B52B3E967}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{D7EE8177-D51E-4F89-92B6-83EA2EC40800}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{E2343056-CC08-46AC-B898-BFC7ACF4E755}
Clé Supprimée : HKLM\SOFTWARE\Classes\TypeLib\{EC4085F2-8DB3-45A6-AD0B-CA289F3C5D7E}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3593C8B9-8E18-4B4B-B7D3-CB8BEB1AA42C}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{E87806B5-E908-45FD-AF5E-957D83E58E68}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{3C66E288-CA4A-D1DC-60AD-AD14D47BE24B}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DF63C4EC-CF5D-D784-8E6F-D09BD51DE298}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{0329E7D6-6F54-462D-93F6-F5C3118BADF2}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{2EECD738-5844-4A99-B4B6-146BF802613B}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{3593C8B9-8E18-4B4B-B7D3-CB8BEB1AA42C}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{389943B0-C3A2-4E69-82CB-8596A84CB3DC}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{5018CFD2-804D-4C99-9F81-25EAEA2769DE}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{82E1477C-B154-48D3-9891-33D83C26BCD3}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{92A9ACF4-9333-43AE-9698-DB283326F87F}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{98889811-442D-49DD-99D7-DC866BE87DBC}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{A6174F27-1FFF-E1D6-A93F-BA48AD5DD448}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{A7A6995D-6EE1-4FD1-A258-49395D5BF99C}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{C1AF5FA5-852C-4C90-812E-A7F75E011D87}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{D4027C7F-154A-4066-A1AD-4243D8127440}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{DAEB9E85-4694-4F9B-85CB-2F28987872D7}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{DF7770F7-832F-4BDF-B144-100EDDD0C3AE}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{E87806B5-E908-45FD-AF5E-957D83E58E68}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{FD6D90C0-E6EE-4BC6-B9F7-9ED319698007}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{FD72061E-9FDE-484D-A58A-0BAB4151CAD8}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{FF7C3CF0-4B15-11D1-ABED-709549C10000}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{3C66E288-CA4A-D1DC-60AD-AD14D47BE24B}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{DF63C4EC-CF5D-D784-8E6F-D09BD51DE298}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{0329E7D6-6F54-462D-93F6-F5C3118BADF2}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{2EECD738-5844-4A99-B4B6-146BF802613B}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{389943B0-C3A2-4E69-82CB-8596A84CB3DC}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{5018CFD2-804D-4C99-9F81-25EAEA2769DE}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{82E1477C-B154-48D3-9891-33D83C26BCD3}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{92A9ACF4-9333-43AE-9698-DB283326F87F}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{98889811-442D-49DD-99D7-DC866BE87DBC}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{A6174F27-1FFF-E1D6-A93F-BA48AD5DD448}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{A7A6995D-6EE1-4FD1-A258-49395D5BF99C}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{C1AF5FA5-852C-4C90-812E-A7F75E011D87}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{D4027C7F-154A-4066-A1AD-4243D8127440}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{DAEB9E85-4694-4F9B-85CB-2F28987872D7}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{E87806B5-E908-45FD-AF5E-957D83E58E68}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{FD72061E-9FDE-484D-A58A-0BAB4151CAD8}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{FF7C3CF0-4B15-11D1-ABED-709549C10000}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{3C66E288-CA4A-D1DC-60AD-AD14D47BE24B}
Clé Supprimée : HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{DF63C4EC-CF5D-D784-8E6F-D09BD51DE298}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{02C5B62D-AC28-4C96-AED9-1B1CBC5E73F5}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{B47AD5D8-9D04-4F7B-8776-35EA5892F138}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{DF7770F7-832F-4BDF-B144-100EDDD0C3AE}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{02C5B62D-AC28-4C96-AED9-1B1CBC5E73F5}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{219046AE-358F-4CF1-B1FD-2B4DE83642A8}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{348C2DF3-1191-4C3E-92A6-B3A89A9D9C85}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{603C4CC9-5DC6-4C44-873F-8281509DF953}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{628F3201-34D0-49C0-BB9A-82A26AEFB291}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{68B81CCD-A80C-4060-8947-5AE69ED01199}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{9CF034EA-7B46-48D3-8895-8A14B32AE445}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{B47AD5D8-9D04-4F7B-8776-35EA5892F138}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{E6B969FB-6D33-48D2-9061-8BBD4899EB08}
Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{014DB5FA-EAFB-4592-A95B-F44D3EE87FA9}
Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{33BB0A4E-99AF-4226-BDF6-49120163DE86}
Clé Supprimée : HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{BB74DE59-BC4C-4172-9AC4-73315F71CFFE}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{33BB0A4E-99AF-4226-BDF6-49120163DE86}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\SearchScopes\{BB74DE59-BC4C-4172-9AC4-73315F71CFFE}
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{5018CFD2-804D-4C99-9F81-25EAEA2769DE}]
Valeur Supprimée : HKLM\SOFTWARE\Microsoft\Internet Explorer\Toolbar [{82E1477C-B154-48D3-9891-33D83C26BCD3}]
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{0329E7D6-6F54-462D-93F6-F5C3118BADF2}]
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser [{D4027C7F-154A-4066-A1AD-4243D8127440}]
Valeur Supprimée : HKCU\Software\Microsoft\Internet Explorer\URLSearchHooks [{84FF7BD6-B47F-46F8-9130-01B2696B36CB}]
Donnée Restaurée : HKEY_LOCAL_MACHINE\SOFTWARE\Clients\StartMenuInternet\IEXPLORE.EXE\shell\open\command
Donnée Restaurée : HKEY_LOCAL_MACHINE\SOFTWARE\Clients\StartMenuInternet\Google Chrome\shell\open\command
Valeur Supprimée : HKLM\SOFTWARE\Policies\Google\Chrome\ExtensionInstallForcelist [1]
Clé Supprimée : HKCU\Software\1ClickDownload
Clé Supprimée : HKCU\Software\APN PIP
Clé Supprimée : HKCU\Software\AskPartnerNetwork
Clé Supprimée : HKCU\Software\BI
Clé Supprimée : HKCU\Software\cacaoweb
Clé Supprimée : HKCU\Software\DealPly
Clé Supprimée : HKCU\Software\Duuqu
Clé Supprimée : HKCU\Software\filescout
Clé Supprimée : HKCU\Software\Iminent
Clé Supprimée : HKCU\Software\installedbrowserextensions
Clé Supprimée : HKCU\Software\lollipop
Clé Supprimée : HKCU\Software\mysearchdial
Clé Supprimée : HKCU\Software\PIP
Clé Supprimée : HKCU\Software\AppDataLow\{1146AC44-2F03-4431-B4FD-889BC837521F}
Clé Supprimée : HKCU\Software\AppDataLow\SProtector
Clé Supprimée : HKCU\Software\AppDataLow\Software\AutoLyrics
Clé Supprimée : HKCU\Software\AppDataLow\Software\ConduitSearchScopes
Clé Supprimée : HKCU\Software\AppDataLow\Software\SmartBar
Clé Supprimée : HKLM\Software\{3A7D3E19-1B79-4E4E-BD96-5467DA2C4EF0}
Clé Supprimée : HKLM\Software\{6791A2F3-FC80-475C-A002-C014AF797E9C}
Clé Supprimée : HKLM\Software\AskPartnerNetwork
Clé Supprimée : HKLM\Software\Bench
Clé Supprimée : HKLM\Software\Boxore
Clé Supprimée : HKLM\Software\Duuqu
Clé Supprimée : HKLM\Software\Iminent
Clé Supprimée : HKLM\Software\InstallCore
Clé Supprimée : HKLM\Software\PIP
Clé Supprimée : HKLM\Software\SearchProtect
Clé Supprimée : HKLM\Software\Softonic
Clé Supprimée : HKLM\Software\SP Global
Clé Supprimée : HKLM\Software\SProtector
Clé Supprimée : HKLM\Software\supTab
Clé Supprimée : HKLM\Software\supWPM
Clé Supprimée : HKLM\Software\Tarma Installer
Clé Supprimée : HKLM\Software\Uniblue
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0C3DD791-1026-4B03-8085-34EFB8CE1BBF}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{33ECC890-C480-4124-B95B-BA36E025B120}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{889DF117-14D1-44EE-9F31-C5FB5D47F68B}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C670DCAE-E392-AA32-6F42-143C7FC4BDFD}
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\bi_uninstaller
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Delta Chrome Toolbar
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IePlugins
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\IMBoosterARP
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Iminent
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SearchProtect
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SearchTheWebARP
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Softonic
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\supTab
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Wpm
Clé Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{C1C6816E-CBB3-A748-85F9-A8B47B68985B}
Donnée Supprimée : HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows [AppInit_DLLs] - c:\progra~2\bitguard\271832~1.68\{c16c1~1\bitguard.dll
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0238BBE24EA3A70408B81E4BB89C15E5
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\04D01B4BB24CCD043B69431CCABB1A34
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0702826FCAC36EE52AC0441EEEEE2170
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\1198E28F40C3E185E9958608554D4253
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\14C66209FCA938858B9729645C666684
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\15A073601B9AEC3549BE4A9314794615
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\1F7C80F9CE5CDF44E9AADDC99402534C
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\206AF45B775E3A445B3B2273827DA85F
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\225C3CBCEB850204D860A6C7CC7724AF
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\2310FC151CD4F185798FA0996B3524D7
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\26707ED04B511954795390209ACE9875
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\28572D2E2DE533256AC6B560EA573C22
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\29799DE249E7DBC459FC6C8F07EB8375
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\29C79786B109AC443B0DC7BFD61B1896
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\2ABB56EABB920EB59B04BDDD26A62083
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\2DABA02DFED47E352A2FA2EBDD6F6187
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\311567B4A9A002050BB9423FD73FB880
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\373FCED70D7F84E5FB5F3F7B76BEE024
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\3BE992C130B235E53A2937391FDCA35B
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\3DA5F64B3483DE549947A9164ACBAD21
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\3ED93605BB9B6635E9D0D86615AF31F1
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\43C098337DB065A49B665D4EA7F16D1C
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\4759B017032BA185F9BA6F7DBC95A2D4
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\4A78ABCBB54E46E5482A3EE0AD66C39E
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\4F9E947B6B895EB5A86757FC5D3DB862
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\4FEEA83BF72B97E43A2DF0EE4BE4F261
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\509EC7EFB89B7D942997574AB14037A4
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\50A730A9A3A61BF5BA70CA8A3B7C133B
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\51A95A1D4CDE4F958A9451FBB39BF54A
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\536133807DE80465BA6CD0A9742B7DE5
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\5E25036E68895D45B95E72D1C3C58C74
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\60ECC80C54085B141A40437A96CA2618
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\60FD8CD5BE007315CA3B5C7E41F24017
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\618E7D05458C4F257909ED9C8CDC0D66
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\621C21014D3C152529E2460FA6304EE3
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\6241FF6F317CABD4EBBEE0DE9076BD94
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\636B9C23C79154B57AB561F39A139BFD
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\65AAF0F0CB7F0B45F900FDF19CEAAF2B
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\6879A5E348601C45986308CA84958E94
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\6A6F3B7A9805E1F5492A1020EEDF2341
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\6B1F5D204E4EEB342A5AD1D7E60D61BF
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\7005A2A4DCF9DD7548137AB17E3A3AF3
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\712EAF07EE73CC65C822CC3BAE3B2483
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\75FF6D97AF9FC004A9521D4B83FA6321
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\7947B301B2446E752A3FE06EAD7D26B5
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\7987CE52D13E16258B0E1E3DB1BB0974
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\7BEED197C514FDA53901AE8DD8EF0891
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\7DFDCF03D46C34159BDE29FBDBF1ACF5
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\87EC9ACEAFE8ECD52A529663CD35213F
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\890F436B85B790A55A582B7307DA12CE
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\8C13DA6755F685B529615C8E92B3CA39
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\8D07CD9CB3E6BE652872BF06A1CCA782
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\90841B1FC98200349925C88999866F17
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\94194FDD4DF523E53A888D65722A135D
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\95266D07D008D2E4E9B6F8E0DD15432A
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\A4223BBC9438CAD49BBE10B4E344B1DD
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\A71991503412AEB42838B02C5ED9F9CD
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\A72F23B1D745C27508518132197BC982
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\A89E2B6FB14D8275DA63D075171DA184
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\A9C43CD4001E9E4518B274AF9A0EFDA9
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\AABA081CF7F19915FBB80B3BAF47CE63
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\AC2A0FFD0A1686D53A4E24D6E96949E4
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\AE5BDB2750259915D8442D4591A7717B
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\B1A79C71D5DC1C150B76B6ED11195DFC
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\B6D497DB33974935488761F7C4C3D755
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\B752EF3300008394886C402CC27B474F
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\B8C8BCC1206978D51A8B9EECBF806C53
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\BAD3576CEA646895B962F94754612791
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\BB4091512C8F4295E99CE2D061ED2020
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\BBCD189EC41EB4E4AB05DC8A9EB51C45
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\BEE6BBC9A31531F598794A62120B51C7
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\C19162788CA4D235E829F88E2F771567
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\C71F07DA356B66B5484A8E7F2ADEB7DC
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\C96AD15EE8E887B56BAF2136A9088503
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\C9E6B66ECC49D155888399C51D05C49E
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\CA0054A5AB3EFFE4CB5660E44A1E7DCC
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\CA360F24F0B214744BE40657FDA0B727
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\CB13D869D7D092348847B7481BB59E27
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\CE85F265816AE2D4E9B73C3E207E679C
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D5389AEEA4A1E20428D045E86BCF643B
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\D5B62BB7BC607FB539585E2B7B6AFD16
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\DB027F01D4D53765C8E4FBE7DB77E07E
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\DC2EB492393411F5ABE8ED13C59FBF20
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\DDA2534BD056D1F44B6EC96AAA7F1F6E
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\DDCA763D4C48A105086B4CCCEE78043F
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\DEF7558C7CD27EF46AF802AFBE402675
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\E05B987540A9E2849AAF9E5B06C27DA8
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\E09F4A6B9D2A08B599AE9E38BFC93CD6
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\E27B6535D0D94A24E91047C7D86F27BC
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\E45D171E075A5425CBACF6631A45FA39
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\E513C2076D90AD04F888BD762143F191
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\E8F4C985459564F5B8DCFF2B3C7EBD27
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\E96E33222BAC06B57A1FA9D72951C945
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\EAA46CE9007F70A5CAFA5F26E5DDEBE5
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\EE43FF091A8714A599F33EF2533FB59A
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\EE790015CF30DAA569960905FF1651A0
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\EEB44C47185BD304D80FDF5A4BBE8F54
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\F214EB834D2EC474CA76C1CDE306CF3A
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\F25491036D0FA5D5FA6742F5742F151A
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\F2E0D3DD9E5E4B74CA43BCE77815E287
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\F4D1BA8B482D9734E943EE260A7ADEF2
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\F6704141BAAF6884785EC6843143D6A7
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\F7507D4D4C310125E9A22BD909A41FB6
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\F7652513C62FF63448CFF05163719DB7
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\F79C21D785419125595AC59458A6142D
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\FA15C90F092A60F53A4E0F88CED02968
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\FA1CF130B3D58B553833ACB6BE8AFAD4
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\FB0F1A18E4F0DBD509A42F4D4C05C02A
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\FD17ED194F1C2B457B4F6EF4AE8DEAF3
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\197DD3C0620130B4085843FE8BECB1FB
Clé Supprimée : HKLM\Software\Classes\Installer\Features\197DD3C0620130B4085843FE8BECB1FB
Clé Supprimée : HKLM\Software\Classes\Installer\Products\197DD3C0620130B4085843FE8BECB1FB
Clé Supprimée : HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\F1057DD419AED0B468AD8888429E139A
***** [ Navigateurs ] *****
-\\ Internet Explorer v8.0.7601.17514
Paramètre Restauré : HKCU\Software\Microsoft\Internet Explorer\Main [Default_Page_URL]
Paramètre Restauré : HKLM\SOFTWARE\Microsoft\Internet Explorer\Main [Default_Page_URL]
Paramètre Restauré : HKLM\SOFTWARE\Microsoft\Internet Explorer\Main [Start Page]
Paramètre Restauré : HKLM\SOFTWARE\Microsoft\Internet Explorer\AboutURls [Tabs]
Paramètre Restauré : HKLM\SOFTWARE\Microsoft\Internet Explorer\AboutURls [bProtectTabs]
-\\ Mozilla Firefox v
[ Fichier : C:\Users\Maxence\AppData\Roaming\Mozilla\Firefox\Profiles\[ofr2][opt]rs0\prefs.js ]
Ligne Supprimée : user_pref("browser.startup.homepage", "hxxp://websearch.pu-results.info/?pid=724&r=2013/05/17&hid=804395808&lg=EN&cc=FR");
Ligne Supprimée : user_pref("browser.search.order.1", "WebSearch");
Ligne Supprimée : user_pref("browser.search.defaultenginename", "WebSearch");
Ligne Supprimée : user_pref("browser.search.selectedEngine", "WebSearch");
Ligne Supprimée : user_pref("browser.search.defaulturl", "hxxp://websearch.pu-results.info/?pid=724&r=2013/05/17&hid=804395808&lg=EN&cc=FR&l=1&q=");
Ligne Supprimée : user_pref("browser.search.order.1,S", "WebSearch");
Ligne Supprimée : user_pref("browser.search.defaultenginename,S", "WebSearch");
Ligne Supprimée : user_pref("browser.search.selectedEngine,S", "WebSearch");
Ligne Supprimée : user_pref("keyword.URL", "hxxp://websearch.pu-results.info/?pid=724&r=2013/05/17&hid=804395808&lg=EN&cc=FR&l=1&q=");
-\\ Google Chrome v
[ Fichier : C:\Users\Maxence\AppData\Local\Google\Chrome\User Data\Default\preferences ]
AdwCleaner[R0].txt - [54863 octets] - [16/03/2014 02:52:40]
AdwCleaner[S0].txt - [52598 octets] - [16/03/2014 03:10:01]
########## EOF - C:\AdwCleaner\AdwCleaner[S0].txt - [52659 octets] ##########
#109675
comment ca se fait que ce rapport date de 3h10 du matin ?
