par Marie Poppins
#23350
Et bé, j'ai l'impression qu'il y avait beaucoup de choses a nettoyer..
Voilà le rapport :
All processes killed
========== PROCESSES ==========
No active process named explorer.exe was found!
No active process named iexplore.exe was found!
No active process named firefox.exe was found!
No active process named msnmsgr.exe was found!
No active process named Teatimer.exe was found!
========== OTL ==========
HKU\S-1-5-21-291430848-2831316151-1618813105-1001\Software\Microsoft\Windows\CurrentVersion\Internet Settings\\ProxyOverride| /E : value set successfully!
Prefs.js: {34EFA911-B536-4C08-BECE-CD5E55C875B0}:1.0 removed from extensions.enabledItems
Prefs.js: {CAFEEFAC-0016-0000-0023-ABCDEFFEDCBA}:6.0.23 removed from extensions.enabledItems
Prefs.js: {CAFEEFAC-0016-0000-0024-ABCDEFFEDCBA}:6.0.24 removed from extensions.enabledItems
Prefs.js: {CAFEEFAC-0016-0000-0026-ABCDEFFEDCBA}:6.0.26 removed from extensions.enabledItems
C:\Users\Rémi\AppData\Roaming\mozilla\firefox\profiles\vzwjn1o4.default\extensions\jid0-GXjLLfbCoAx0LcltEdFrEkQdQPI@jetpack.xpi moved successfully.
Folder C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0035-ABCDEFFEDCBA}\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{e6ecc342-230c-4f2a-9555-17b076ad7dab}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{e6ecc342-230c-4f2a-9555-17b076ad7dab}\ deleted successfully.
Registry value HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\Toolbar\\Locked deleted successfully.
Registry value HKEY_USERS\S-1-5-21-291430848-2831316151-1618813105-1001\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{21FA44EF-376D-4D53-9B0F-8A89D3229068} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{21FA44EF-376D-4D53-9B0F-8A89D3229068}\ not found.
Registry value HKEY_USERS\S-1-5-21-291430848-2831316151-1618813105-1001\\Software\Microsoft\Windows\CurrentVersion\Run\\AdobeBridge deleted successfully.
Starting removal of ActiveX control {8AD9C840-044E-11D1-B3E9-00805F499D93}
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8AD9C840-044E-11D1-B3E9-00805F499D93}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{8AD9C840-044E-11D1-B3E9-00805F499D93}\ deleted successfully.
Registry key HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\{8AD9C840-044E-11D1-B3E9-00805F499D93}\ deleted successfully.
Registry key HKEY_USERS\.DEFAULT\SOFTWARE\Classes\CLSID\{8AD9C840-044E-11D1-B3E9-00805F499D93}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{8AD9C840-044E-11D1-B3E9-00805F499D93}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{8AD9C840-044E-11D1-B3E9-00805F499D93}\ not found.
Starting removal of ActiveX control {CAFEEFAC-0016-0000-0035-ABCDEFFEDCBA}
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0035-ABCDEFFEDCBA}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0035-ABCDEFFEDCBA}\ deleted successfully.
Registry key HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0035-ABCDEFFEDCBA}\ deleted successfully.
Registry key HKEY_USERS\.DEFAULT\SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0035-ABCDEFFEDCBA}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-0016-0000-0035-ABCDEFFEDCBA}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-0016-0000-0035-ABCDEFFEDCBA}\ not found.
Starting removal of ActiveX control {CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}\ deleted successfully.
Registry key HKEY_CURRENT_USER\SOFTWARE\Classes\CLSID\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}\ deleted successfully.
Registry key HKEY_USERS\.DEFAULT\SOFTWARE\Classes\CLSID\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PROTOCOLS\Handler\tmpx\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{0E526CB5-7446-41D1-A403-19BFE95E8C23}\ deleted successfully.
File {0E526CB5-7446-41D1-A403-19BFE95E8C23} - c:\Program Files\Trend Micro\Client Server Security Agent\bho\1009\TmIEPlg.dll File not found not found.
C:\ProgramData\Spybot - Search & Destroy\Recovery folder moved successfully.
C:\ProgramData\Spybot - Search & Destroy\Logs folder moved successfully.
C:\ProgramData\Spybot - Search & Destroy folder moved successfully.
C:\Program Files\Spybot - Search & Destroy\Help folder moved successfully.
C:\Program Files\Spybot - Search & Destroy folder moved successfully.
C:\Windows\System32\Tasks\CreateChoiceProcessTask moved successfully.
C:\Windows\System32\Tasks\RunAsStdUser Task for VeohWebPlayer moved successfully.
C:\Windows\System32\Tasks\Show-Password Update moved successfully.
Registry key HKEY_LOCAL_MACHINE\Software\BrowserChoice\ deleted successfully.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\DomainProfile\\"EnableFirewall"|DWORD:0 /E : value set successfully!
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\StandardProfile\\"EnableFirewall"|DWORD:0 /E : value set successfully!
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\PublicProfile\\"EnableFirewall"|DWORD:0 /E : value set successfully!
Registry value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{0826AFAD-9C68-483F-A303-62321E45E17D} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{0826AFAD-9C68-483F-A303-62321E45E17D}\ not found.
Registry value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{75A15906-2944-47B7-8693-9CA7542B03CB} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{75A15906-2944-47B7-8693-9CA7542B03CB}\ not found.
Registry value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{B845A985-07A7-4EE6-9EE0-FF3C41DE5CBE} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{B845A985-07A7-4EE6-9EE0-FF3C41DE5CBE}\ not found.
Registry value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{E4F636BC-3991-4496-BB63-3DE42968A668} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{E4F636BC-3991-4496-BB63-3DE42968A668}\ not found.
Registry value HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SharedAccess\Parameters\FirewallPolicy\FirewallRules\\{F7DFE3FA-2D08-4FA2-AD63-D83B2267D2D2} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{F7DFE3FA-2D08-4FA2-AD63-D83B2267D2D2}\ not found.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\44a5ce38-8adb-43c9-8a5e-ee8ed8f3982a\ deleted successfully.
========== FILES ==========
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\shaders folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\res\flightsim\planet folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\res\flightsim\keyboard folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\res\flightsim\hud folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\res\flightsim\controller folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\res\flightsim\aircraft folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\res\flightsim folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\res folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\lang folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\imageformats folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\alchemy\optimizations folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\alchemy\ogles20 folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\alchemy\ogl folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin\alchemy folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\plugin folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\shaders folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\res\flightsim\planet folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\res\flightsim\keyboard folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\res\flightsim\hud folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\res\flightsim\controller folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\res\flightsim\aircraft folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\res\flightsim folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\res folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\Plugins folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\lang folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\imageformats folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\alchemy\optimizations folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\alchemy\ogles20 folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\alchemy\ogl folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client\alchemy folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth\client folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google\Google Earth folder moved successfully.
C:\Windows\Temp\._msige61\program files\Google folder moved successfully.
C:\Windows\Temp\._msige61\program files folder moved successfully.
C:\Windows\Temp\._msige61\LocalAppData\Google\Custom Buttons folder moved successfully.
C:\Windows\Temp\._msige61\LocalAppData\Google folder moved successfully.
C:\Windows\Temp\._msige61\LocalAppData folder moved successfully.
C:\Windows\Temp\._msige61 folder moved successfully.
C:\Windows\Temp\830cac40660416_78_53e88fac3a1394 moved successfully.
C:\Windows\Temp\AdobeARM.log moved successfully.
C:\Windows\Temp\AVSETUP_529a46d1 folder moved successfully.
C:\Windows\Temp\BootClean.log moved successfully.
C:\Windows\Temp\Cookies folder moved successfully.
C:\Windows\Temp\dd_clwireg.txt moved successfully.
C:\Windows\Temp\dmiwu\{307A1C6A-7D06-420D-9A14-811104335BF6}\i386 folder moved successfully.
C:\Windows\Temp\dmiwu\{307A1C6A-7D06-420D-9A14-811104335BF6} folder moved successfully.
C:\Windows\Temp\dmiwu folder moved successfully.
C:\Windows\Temp\E_S14E7.tmp moved successfully.
C:\Windows\Temp\Fichiers Internet temporaires\Content.IE5\Y4OTP042 folder moved successfully.
C:\Windows\Temp\Fichiers Internet temporaires\Content.IE5\VZHMFSEJ folder moved successfully.
C:\Windows\Temp\Fichiers Internet temporaires\Content.IE5\S7LWALB4 folder moved successfully.
C:\Windows\Temp\Fichiers Internet temporaires\Content.IE5\CU3NLX4Q folder moved successfully.
C:\Windows\Temp\Fichiers Internet temporaires\Content.IE5 folder moved successfully.
C:\Windows\Temp\Fichiers Internet temporaires folder moved successfully.
C:\Windows\Temp\fwtsqmfile00.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile01.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile02.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile03.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile04.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile05.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile06.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile07.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile08.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile09.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile10.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile11.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile12.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile13.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile14.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile15.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile16.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile17.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile18.sqm moved successfully.
C:\Windows\Temp\fwtsqmfile19.sqm moved successfully.
C:\Windows\Temp\History\History.IE5 folder moved successfully.
C:\Windows\Temp\History folder moved successfully.
C:\Windows\Temp\is2126.tmp moved successfully.
C:\Windows\Temp\is602F.tmp moved successfully.
C:\Windows\Temp\isA589.tmp moved successfully.
C:\Windows\Temp\isAE81.tmp moved successfully.
C:\Windows\Temp\isD66C.tmp moved successfully.
C:\Windows\Temp\isE638.tmp moved successfully.
C:\Windows\Temp\KB2446708_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2468871v2_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2478663_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2518870_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2533523_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2539636_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2572078_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2600217_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2604121_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2604121_20120510_064709480-Microsoft .NET Framework 4 Client Profile-MSP0.txt moved successfully.
C:\Windows\Temp\KB2604121_20120510_064709480.html moved successfully.
C:\Windows\Temp\KB2633870_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2656351_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2656368v2_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2656368v2_20120613_194017139-Microsoft .NET Framework 4 Client Profile-MSP0.txt moved successfully.
C:\Windows\Temp\KB2656368v2_20120613_194017139.html moved successfully.
C:\Windows\Temp\KB2656368_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2656368_20120411_030319841-Microsoft .NET Framework 4 Client Profile-MSP0.txt moved successfully.
C:\Windows\Temp\KB2656368_20120411_030319841.html moved successfully.
C:\Windows\Temp\KB2656405_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2656405_20120510_064921347-Microsoft .NET Framework 4 Client Profile-MSP0.txt moved successfully.
C:\Windows\Temp\KB2656405_20120510_064921347.html moved successfully.
C:\Windows\Temp\KB2686827_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2686827_20120613_194308474-Microsoft .NET Framework 4 Client Profile-MSP0.txt moved successfully.
C:\Windows\Temp\KB2686827_20120613_194308474.html moved successfully.
C:\Windows\Temp\KB2729449_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2729449_20121116_030409920-Microsoft .NET Framework 4 Client Profile-MSP0.txt moved successfully.
C:\Windows\Temp\KB2729449_20121116_030409920.html moved successfully.
C:\Windows\Temp\KB2737019_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2737019_20121116_030636295-Microsoft .NET Framework 4 Client Profile-MSP0.txt moved successfully.
C:\Windows\Temp\KB2737019_20121116_030636295.html moved successfully.
C:\Windows\Temp\KB2742595_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2742595_20130110_030423992-Microsoft .NET Framework 4 Client Profile-MSP0.txt moved successfully.
C:\Windows\Temp\KB2742595_20130110_030423992.html moved successfully.
C:\Windows\Temp\KB2789642_10.0.30319 folder moved successfully.
C:\Windows\Temp\KB2789642_20130213_163407912-Microsoft .NET Framework 4 Client Profile-MSP0.txt moved successfully.
C:\Windows\Temp\KB2789642_20130213_163407912.html moved successfully.
C:\Windows\Temp\Microsoft .NET Framework 4 Client Profile Setup_4.0.30319 folder moved successfully.
C:\Windows\Temp\Microsoft .NET Framework Client Profile Language Pack Setup_4.0.30319 folder moved successfully.
C:\Windows\Temp\Microsoft Visual C++ 2010 x86 Redistributable Setup_10.0.40219 folder moved successfully.
C:\Windows\Temp\Microsoft Visual C++ 2010 x86 Redistributable Setup_20121218_030040505-Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219-MSP0.txt moved successfully.
C:\Windows\Temp\Microsoft Visual C++ 2010 x86 Redistributable Setup_20121218_030040505.html moved successfully.
C:\Windows\Temp\MpCmdRun.log moved successfully.
C:\Windows\Temp\MpSigStub.log moved successfully.
C:\Windows\Temp\MPTelemetrySubmit folder moved successfully.
C:\Windows\Temp\MSI4eb67.LOG moved successfully.
C:\Windows\Temp\MSId1267.LOG moved successfully.
C:\Windows\Temp\OutofProcReport101521661.txt moved successfully.
C:\Windows\Temp\RES4FB5.tmp folder moved successfully.
C:\Windows\Temp\Silverlight0.log moved successfully.
C:\Windows\Temp\SilverlightMSI.log moved successfully.
C:\Windows\Temp\TMP00000002E4C3F10961426300 moved successfully.
C:\Windows\Temp\TMP0000001BDC1A14C3F4300276 moved successfully.
C:\Windows\Temp\TMP00000024B34F7209C397E9C2 moved successfully.
C:\Windows\Temp\TMP00000025C45AD9BFD3AE8A7B moved successfully.
C:\Windows\Temp\TMP00000029149EC9867DB496CC moved successfully.
C:\Windows\Temp\TMP000000393CF86C9F616121A9 moved successfully.
C:\Windows\Temp\TMP0000005911ED6F60FF3F8FD5 moved successfully.
C:\Windows\Temp\TMP0000014BFD44CB674CAEFC79 moved successfully.
C:\Windows\Temp\WER5B4F.tmp.appcompat.txt moved successfully.
C:\Windows\Temp\{1C6F5407-D865-4B9B-A5BB-1B1BEA919FE4} folder moved successfully.
C:\Windows\Temp\{32842E3C-5DBA-4ACF-AF2F-0F33091F5B5D} folder moved successfully.
C:\Windows\Temp\{337B10AC-B1E6-452D-860B-0302619C0BB9} folder moved successfully.
C:\Windows\Temp\{3A3800BD-0043-4F81-97C3-235FD0A65BC9} folder moved successfully.
C:\Windows\Temp\{4394E3A8-EA48-45E4-BBA3-227410301FBC} folder moved successfully.
C:\Windows\Temp\{65D3AE49-7D3F-4AF4-B693-56723245FE8E} folder moved successfully.
C:\Windows\Temp\{76B4F6A6-BF26-43AB-8D12-2024266AFA07} folder moved successfully.
C:\Windows\Temp\{FA8E906C-502E-4B78-9971-DC7267543460} folder moved successfully.
File\Folder C:\Program Files\Show-Password not found.
File move failed. C:\Windows\System32\drivers\etc\Hosts scheduled to be moved on reboot.
Error: Unble to create default HOSTS file!
[EMPTYTEMP]
User: All Users
User: Default
->Temporary Internet Files folder emptied: 33170 bytes
->Flash cache emptied: 57616 bytes
User: Default User
User: Public
User: Rémi
->Temp folder emptied: 36036305 bytes
->Temporary Internet Files folder emptied: 79009585 bytes
->Java cache emptied: 3295430424 bytes
->FireFox cache emptied: 83070173 bytes
->Opera cache emptied: 11038483 bytes
->Flash cache emptied: 67586 bytes
Windows Temp folder emptied: 0 bytes
RecycleBin emptied: 558900725 bytes
Total Files Cleaned = 3Â 875,00 mb
OTL by OldTimer - Version 3.2.69.0 log created on 12222013_134456
#23360
t'avais arrêté l'antivirus ?
#23378
ok arrête l'antivirus et refais une correction juste avec ca :
:commands
[ResetHosts]
[emtytemp]
par Marie Poppins
#23381
Ok, voilà le rapport :
C:\Windows\System32\drivers\etc\Hosts moved successfully.
HOSTS file reset successfully
[EMPTYTEMP]
User: All Users
User: Default
User: Default User
User: Public
User: Rémi
->Temp folder emptied: 700 bytes
->Temporary Internet Files folder emptied: 33300 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 382362938 bytes
->Opera cache emptied: 0 bytes
->Flash cache emptied: 747 bytes
Windows Temp folder emptied: 608 bytes
RecycleBin emptied: 3082543754 bytes
Total Files Cleaned = 3Â 304,00 mb
OTL by OldTimer - Version 3.2.69.0 log created on 12222013_165318
à‡a y est je suis guéri ? :cool:
#23383
ma-gni-fi-co !! ^^
tu ressents encore des soucis de ton coté ?
par Marie Poppins
#23386
Yep, plus de pubs, plus de page d‚accueil bizarre, la bande passante a l'air nickel..
Merci infiniment pour ton aide, et encore bravo pour votre site !
:bravo1:
#23387
c'est pas fini , après la guerre faut nettoyer tout le sang , ca fait pas propre ^^
  • Clique sur GO
  • Télécharge sur ton Bureau.
    • Réactiver l'UAC
No Internet Explorer :
Internet Explorer :
par Marie Poppins
#23392
Le rapport SFTGC :
Le rapport Delfix :
# DelFix v10.6 - Rapport créé le 22/12/2013 à 17:59:52
# Nom d'utilisateur : Rémi - Rà‰MI-PC
# Système d'exploitation : Windows 7 Professional (32 bits)
~ Activation de l'UAC ... OK
Supprimé : C:\USBFix
Supprimé : C:\_OTL
Supprimé : C:\AdwCleaner
Supprimé : C:\Program Files\SEAF
Supprimé : C:\SeafLog.txt
Supprimé : C:\UsbFix [Clean 2] Rà‰MI-PC.txt
Supprimé : C:\UsbFix [Scan 1] Rà‰MI-PC.txt
Supprimé : C:\Users\Rémi\Desktop\adwcleaner.exe
Supprimé : C:\Users\Rémi\Desktop\Extras.Txt
Supprimé : C:\Users\Rémi\Desktop\OTL.Txt
Supprimé : C:\Users\Rémi\Desktop\OTL.exe
Supprimé : C:\Users\Rémi\Desktop\SFTGC.exe
Supprimé : C:\Users\Rémi\Desktop\SFTGC.txt
Supprimé : C:\Users\Rémi\Downloads\seaf.exe
Supprimée : HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SEAF
Supprimé : RP #390 [Windows Update | 12/12/2013 02:00:31]
Supprimé : RP #391 [Point de contrôle planifié | 12/21/2013 17:25:16]
Supprimé : RP #392 [OTL Restore Point - 21/12/2013 22:35:47 | 12/21/2013 21:35:51]
Supprimé : RP #393 [Removed Java(TM) 6 Update 35 | 12/22/2013 12:35:40]
Supprimé : RP #394 [Removed Java(TM) 7 Update 5 | 12/22/2013 12:38:14]
########## - EOF - ##########
#23393
magnifique :)
