#27344
juste un dernier truc :
passe ce script et donne moi le rapport stp !
merci
    O3 - Toolbar: Bing Bar - [HKLM]{8dcb7100-df86-4384-8842-8fa844297b3f} . (.Microsoft Corporation. - Extensions du client Bing.) -- C:\Program Files\Microsoft\BingBar\BingExt.dll =>Toolbar.Bing
    O58 - SDL:[MD5.C44E3C2BAB6837DB337DDEE7544736DB] - 09/01/2014 - 17:29:54 ---A- . (.Hauppauge Computer Works, Inc. - Hauppauge WinTV 885 Consumer IR Driver for eHome.) -- C:\Windows\System32\Drivers\hcw85cir.sys.bak   [26624]
    O90 - PUC: "5509804B864D4A546AABA531D87D51CF" . (.Bing Bar.) -- C:\Windows\Installer\{B4089055-D468-45A4-A6BA-5A138DD715FC}\icon_installer_ico =>Toolbar.Bing
    [HKLM\Software\Microsoft\Internet Explorer\Toolbar]:{8dcb7100-df86-4384-8842-8fa844297b3f}   =>Toolbar.Bing^
    EmptyCLSID
    Emptytemp
    exemple :
