#135106
Hurk hurk hurk, j'ai posté trop vite, il fallait lui laisser le temps d'opérer:
All processes killed
========== FILES ==========
I:\SURVIVAL.vbe moved successfully.
I:\.lnk moved successfully.
I:\autorun.lnk moved successfully.
I:\Upload to Garmin Connect.lnk moved successfully.
I:\Garmin.lnk moved successfully.
I:\Documents.lnk moved successfully.
I:\.Trashes.lnk moved successfully.
I:\.fseventsd.lnk moved successfully.
I:\.Spotlight-V100.lnk moved successfully.
[EMPTYTEMP]
User: Admin
->Temp folder emptied: 679629924 bytes
->Temporary Internet Files folder emptied: 48168166 bytes
->Java cache emptied: 10602858 bytes
->FireFox cache emptied: 22496063 bytes
->Google Chrome cache emptied: 371512420 bytes
->Flash cache emptied: 105777 bytes
User: All Users
User: Default
User: Default User
User: Default.migrated
User: Lilou
->Temp folder emptied: 714113 bytes
->Temporary Internet Files folder emptied: 537689 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 364076480 bytes
->Google Chrome cache emptied: 353442875 bytes
->Flash cache emptied: 37062 bytes
User: Public
User: Sacha
->Temp folder emptied: 23208 bytes
->Temporary Internet Files folder emptied: 260597138 bytes
->Java cache emptied: 12102 bytes
->FireFox cache emptied: 16116078 bytes
->Google Chrome cache emptied: 353179395 bytes
->Flash cache emptied: 28001 bytes
User: UpdatusUser
Windows Temp folder emptied: 21392459 bytes
RecycleBin emptied: 2419469253 bytes
Total Files Cleaned = 4Â 694,00 mb
OTM by OldTimer - Version 3.1.21.0 log created on 04242014_190427
Files moved on Reboot...
File C:\Users\Admin\AppData\Local\Temp\etilqs_IuNKPJsfbOS0mcI not found!
File C:\Users\Admin\AppData\Local\Temp\etilqs_U7VqSeHPGnhGoX2 not found!
C:\Users\Admin\AppData\Local\Microsoft\Windows\INetCache\counters.dat moved successfully.
C:\Users\Admin\AppData\Local\Mozilla\Firefox\Profiles\35dc40bv.default\Cache\_CACHE_001_ moved successfully.
C:\Users\Admin\AppData\Local\Mozilla\Firefox\Profiles\35dc40bv.default\Cache\_CACHE_002_ moved successfully.
C:\Users\Admin\AppData\Local\Mozilla\Firefox\Profiles\35dc40bv.default\Cache\_CACHE_003_ moved successfully.
C:\Users\Admin\AppData\Local\Mozilla\Firefox\Profiles\35dc40bv.default\Cache\_CACHE_MAP_ moved successfully.
C:\Users\Admin\AppData\Local\Mozilla\Firefox\Profiles\35dc40bv.default\_CACHE_CLEAN_ moved successfully.
File move failed. C:\WINDOWS\temp\_avast_\Webshlock.txt scheduled to be moved on reboot.
#135112
Euh... par contre mon GPS est vide...
Non t'inquiètes pas ;)
On va faire un tour de magie :)
Avec le GPS connecté sans carte sd toujours :
Presse la touche Windows et R en même temps, cela va ouvrir la commande exécuter, dans cette fenêtre tape cmd et valide par OK
Une fenêtre noire va apparaître (c'est l'invite de commande -> cmd.exe)
Dans la fenêtre noire, copie colle cette ligne :
attrib -r -s -h -a "I:\*" /s /d
Valide ensuite en pressant la touche Entrée.
Vérifie le contenu de ton GPS une fois terminé.
#135124
C'est fini?
Ouep :)
On juste supprimer les outils de désinfection et leur zones de quarantaine.
Je te souhaites une bonne fin de semaine :)
#135147
Euh par contre, je suis pas d'accord avec les conditions suivantes à accepter lors du don:
donnez l'autorisation expresse à PayPal de communiquer les informations spécifiques vous concernant à des tiers, conformément au Règlement sur le respect de la vie privée.
Affirmez spécifiquement et expressément votre accord à l'emploi des méthodes de suivi de votre utilisation du site, notamment l'utilisation des cookies, et à la transmission sécurisée des données personnelles vous concernant hors de l'Union européenne (notamment aux à‰tats-Unis), conformément au Règlement sur le respect de la vie privée.
Notamment la transmission à des Tiers.
Y a t'il moyen de faire autrement?
#135413
Hello,
Ouais Paypal à changé sa politique et il va falloir que je me penche sérieusement sur le problème.
Oui :)
SosVirus est une société (auto-entreprise), tu peux donc participer à notre développement en effectuant un mandat cash ou par chèque.
Le tout à mettre à l'ordre de Mr Le Bozec Cédric, qui est : Moi même :
Adresse :
Société SosVirus
Mr Le Bozec Cédric
8, allée des écureuils
17390 Ronces les bains
France.
Je suis en train de faire la page de contact finale mais je manque de temps :( : https://www.sosvirus.net/contact/
Merci à toi par avance :):super:
