#148981
juste 2 ou 3 trucs :
Supprime tes P2P et passe ce script :
    O3 - Toolbar\WebBrowser: (no name) - [HKCU]{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} Clé orpheline    => Toolbar.Norton
    [MD5.00000000000000000000000000000000] [APT] [{D0366D45-05A3-4AB9-9220-9317AFDCBC6C}] (...) -- C:\Users\Gary\Downloads\Age Of Empire III [crack+serial] Team WBZ\autorun.exe (.not file.)   [0]    => Crack, KeyGen, Keymaker - Possible Malware
    [MD5.00000000000000000000000000000000] [APT] [{E946FF18-B6F8-456E-A99A-BB654047FD43}] (...) -- E:\setup.exe (.not file.)   [0]    => Existe aussi en malware DELF-CA.Troj
    [MD5.00000000000000000000000000000000] [APT] [{ED16EB28-2DF9-435D-AC70-57DA4E9077C7}] (...) -- C:\Users\Gary\Desktop\AoE 3\setup.exe (.not file.)   [0]    => Fichier absent
    O42 - Logiciel: Java 6 Update 24 (64-bit) - (.Oracle.) [HKLM][64Bits] -- {26A24AE4-039D-4CA4-87B4-2F86416024FF}    => Oracle
    [HKCU\Software\BitTorrent]   =>P2P.BitTorrent
    [HKCU\Software\MCAFEE]
    [HKCU\Software\Symantec]
    [HKLM\Software\Norton]    => Symantec Norton
    [HKLM\Software\Wow6432Node\McAfee.com]    => ZHPHosts White List
    [HKLM\Software\Wow6432Node\Symantec]
    [HKLM\Software\Wow6432Node\mcafeeupdater]    => McAfee Updater
    O43 - CFD: 30/11/2013 - 13:20:00 - [] ----D C:\ProgramData\McAfee
    O43 - CFD: 19/03/2014 - 09:51:54 - [] ----D C:\ProgramData\Norton    => Symantec Norton
    O43 - CFD: 3/08/2012 - 02:20:39 - [] ----D C:\ProgramData\NortonInstaller
    O43 - CFD: 21/05/2014 - 12:14:15 - [] ----D C:\Users\Gary\AppData\Roaming\uTorrent   =>P2P.µTorrent
    O43 - CFD: 24/12/2013 - 17:07:39 - [] ----D C:\Users\Gary\AppData\Local\_
    HKLM\SOFTWARE\Wow6432Node\Microsoft\Tracing\BingBar_RASAPI32   =>Toolbar.Bing
    HKLM\SOFTWARE\Wow6432Node\Microsoft\Tracing\utorrent_RASAPI32   =>P2P.µTorrent
    HKLM\SOFTWARE\Wow6432Node\Microsoft\Tracing\utorrent_RASMANCS   =>P2P.µTorrent
    [HKLM\Software\Wow6432Node\Microsoft\Tracing\BingBar_RASAPI32]   =>Toolbar.Bing
    C:\Users\Gary\AppData\Roaming\uTorrent   =>P2P.µTorrent^
    [HKCU\Software\BitTorrent]   =>P2P.BitTorrent^
    ProxyFix
    EmptyPrefetch
    SysRestore
    FirewallRAZ
    EmptyTemp
    exemple :
après tu me dis comment va ton PC !
#149158
bonjour,
si c('est cool pour toi ..... :D
passe delfix :
Delfix
1 - Télécharges DelFix sur votre bureau ICI
2 - Vous pouvez cocher la case "réactiver l'UAC s'il a été désactivé !
la case "suprimer les outils de désinfection est cochée par défaut !
3 - vous pouvez cocher la case "éffectuer une sauvegarde du registre ! (au cas ou il y est un pbl )
4 - vous pouvez cocher la case "purger la restauration système" tous les anciens points seront supprimés et un nouveau "sain" sera créer !
5 - enfin cliquez sur : exécuter
ps : Si c'est en milieu de désinfection ou si ce n'est pas indiqué, le passer comme il est programmé !
:bye: Bon week-end (il arrive :P: )
