#149759
Victor
Pas de souci j'ai le mot de passe ;)
On va finaliser ;)
    emptyprefetch
    firewallraz
    Shortcutfix
    emptytemp
    emptyflash
    [HKLM\Software\BearShareSRTB]  =>PUP.BearShare
    [HKLM\Software\HitmanPro]
    [HKLM\Software\SUPERAntiSpyware.com]
    O43 - CFD: 22/05/2014 - 11:52:55 - [] ----D C:\Program Files\HitmanPro
    O43 - CFD: 22/05/2014 - 11:52:47 - [] ----D C:\Documents and Settings\All Users\Application Data\HitmanPro
    O69 - SBI: SearchScopes [HKUS\S-1-5-19] {006ee092-9658-4fd6-bd8e-a21a348e59f5} - (Web Search) - https://feed.snapdo.com  =>Hijacker.SmartBar
    O69 - SBI: SearchScopes [HKUS\S-1-5-20] {006ee092-9658-4fd6-bd8e-a21a348e59f5} - (Web Search) - https://feed.snapdo.com  =>Hijacker.SmartBar
    [HKLM\Software\Classes\CLSID\{6E47D688-85EC-465A-9946-EC58220F14FC}]   =>PUP.SearchResults
    [HKLM\Software\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{6E47D688-85EC-465A-9946-EC58220F14FC}]   =>PUP.SearchResults
    sysrestore
    2. Puis Clic sur "GO"
#156320
