#154146
ok reinstalle avast
#154155
et le journal il dit quoi ? tu as pris l installeur o๠?
par bobop
#154164
j'ai pris l'installer sur le site officiel qui rediriger vers 01 net voilà  j'ai fais une image car j'arrivais pas à  copier le texte du journal => 13.06.2014 16:51:31 general: Started: 13.06.2014, 16:51:31
13.06.2014 16:51:31 general: Running setup_ais-557 (1367)
13.06.2014 16:51:31 system: Operating system: WindowsXP ver 5.1, build 2600, sp 3.0 [Service Pack 3]
13.06.2014 16:51:31 system: Memory: 37% load. Phys:2097151/2097151K free, Page:4094956/4194303K free, Virt:2066584/2097024K free
13.06.2014 16:51:31 system: Computer WinName: Rà‰GINE
13.06.2014 16:51:31 system: Windows Net User: Rà‰GINE\Propriétaire
13.06.2014 16:51:31 general: Cmdline: Software\Avast\RegSvr32.exe /s /u "C:\Program Files\AVAST Software\Avast\aswWrcIEBroker32.dll"
13.06.2014 16:51:31 general: Old version: ffffffff (-1)
13.06.2014 16:51:31 registry: Error deleting registry: Software\AVAST Software\Avast\UpdateReady (0x00000005)
13.06.2014 16:51:31 system: Using temp: C:\DOCUME~1\PROPRI~1\LOCALS~1\Temp\_asw_aisI.tm~a02572 (269974M free)
13.06.2014 16:51:31 general: Install check: SetupVersion does NOT exist
13.06.2014 16:51:31 general: SGW32AIS::CheckIfInstalled set m_bAlreadyInstalled to 0
13.06.2014 16:51:31 general: DldSrc set to inet
13.06.2014 16:51:31 internet: SYNCER: Agent=Syncer/5.00 (ais-1367;p)
13.06.2014 16:51:31 system: Computer DnsName: régine
13.06.2014 16:51:31 system: Computer Ip Addr: 192.168.1.81
13.06.2014 16:51:31 general: Ignoring cmdline switch: /s
13.06.2014 16:51:31 general: Ignoring cmdline switch: /u
13.06.2014 16:51:31 registry: Get registry: Software\Microsoft\Internet Explorer\Version=8.0.6001.18702
13.06.2014 16:51:31 general: Operation set to INST_OP_INSTALL
13.06.2014 16:51:31 general: GUID: 238a7fa3-d8fc-4888-b057-e7d3efa9a5f9
13.06.2014 16:51:31 general: Default server pseudo definition loaded as ''.
13.06.2014 16:51:31 general: SelectCurrent: unable to find any suitable server in 'main'
13.06.2014 16:51:31 package: bad bad bad
13.06.2014 16:51:31 package: Transferred: files 0, bytes 0, time 0 ms
13.06.2014 16:51:31 package: Retries: total 0, files 0, servers 0
13.06.2014 16:51:31 general: Customer 0
13.06.2014 16:51:31 general: ashBase!_basGetCurrentProductLicenseInfo@28 returned 110
13.06.2014 16:51:31 general: pfnBasGetCurrentLicenseFeatureInfo -1 return value: 0x0000006E
13.06.2014 16:51:31 file: NeedReboot=false
13.06.2014 16:51:31 general: Return code: 0x2000000C [Can't select any server for downloading (from 1).]
13.06.2014 16:51:31 general: Stopped: 13.06.2014, 16:51:31
13.06.2014 16:51:31 registry: Cannot create reg. key:Software\AVAST Software\Avast
#154178
tu l'as executé avec le clic droit "executer en tant qu'administrateur" ?
par bobop
#154216
En l'executant en tant qu'administrateur, il m'affiche => "The installer cannot open the SFX archive...C/documents and settings.....code 0x3ee ".
#154271
je trouve quand même ca bizarre.....
  • Télécharge Dr.Web CureIt sur ton bureau.
    Canned Speech Dr.Web CureIt
  • Lance Dr.Web CureIt, exécuter en tant qu'administrateur sous Windows : 7/8 et Vista
    NOTE : Un message va apparaître pour t'informer que le logiciel passe en mode protection renforcer, c'est normal ! ~> Clique sur OK
  • Coche "J'accepte de participer au programme d'amélioration du logiciel ..."
  • Clique sur Continuer
  • Clique sur Lancer l'analyse
  • Une fois le scan terminé ferme la fenêtre.
    Note : Le rapport se trouve dans C:\Users\""Nom de la session""\Doctor Web
  • Héberge le rapport cureit.log sur Sosupload, puis copie/colle le lien fourni dans ta prochaine réponse sur le forum
  • Aide: comment héberger un fichier sur Sosupload
  • 3
  • 4
  • 5
  • 6
  • 7
