par benjamine21
#153793
le fichier log (j'espère que ça ira pr le copier/coller) :
¤<?xml version="1.0" encoding="UTF-16"?>
-<mbam-log>
-<header>
<date>2014/06/09 16:30:48 +0200</date>
<logfile>mbam-log-2014-06-09 (16-30-05).xml</logfile>
<isadmin>yes</isadmin>
</header>
-<engine>
<version>2.00.2.1012</version>
<malware-database>v2014.06.09.04</malware-database>
<rootkit-database>v2014.06.02.01</rootkit-database>
<license>free</license>
<file-protection>disabled</file-protection>
<web-protection>disabled</web-protection>
<self-protection>disabled</self-protection>
</engine>
-<system>
<osversion>Windows 7 Service Pack 1</osversion>
<arch>x86</arch>
<username>Mylène</username>
<filesys>NTFS</filesys>
</system>
-<summary>
<type>threat</type>
<result>completed</result>
<objects>271169</objects>
<time>1757</time>
<processes>0</processes>
<modules>0</modules>
<keys>0</keys>
<values>0</values>
<datas>0</datas>
<folders>0</folders>
<files>0</files>
<sectors>0</sectors>
</summary>
-<options>
<memory>enabled</memory>
<startup>enabled</startup>
<filesystem>enabled</filesystem>
<archives>enabled</archives>
<rootkits>disabled</rootkits>
<deeprootkit>disabled</deeprootkit>
<heuristics>enabled</heuristics>
<pup>enabled</pup>
<pum>enabled</pum>
</options>
<items> </items>
</mbam-log>
#153798
    HKCU\Software
        HKLM\Software
        %Homedrive%\*
        %Homedrive%\*.
        %Userprofile%\*
        %Userprofile%\*.
        %Allusersprofile%\*
        %Allusersprofile%\*.
        %LocalAppData%\*
        %LocalAppData%\*.
        %programFiles%\*
        %programfiles%\Google\Desktop\*. /s
        %programFiles%\*.
        %Systemroot%\Installer\*.
        %Systemroot%\Temp\*.exe /s
        %systemroot%\system32\*.in*
        %systemroot%\Tasks\*
        %systemroot%\Tasks\*.
        %systemroot%\system32\Tasks\*
        %systemroot%\system32\*.sys
        dir %Homedrive%\* /S /A:L /C
        volsnap.sys
        atapi.sys
        ndis.sys
        cdrom.sys
        i8042prt.sys
        iastor.sys
        tdx.sys
        netbt.sys
        afd.sys
  • Clique sur Analyse
#153824
cite les soucis restants stp
par benjamine21
#154006
L'affichage des pages Web est très lent (le chenillard tourne longtemps avant que la page demandée ne s'affiche).
D'avance merci
#154041
desinstalle adobe reader 9
colle ce texte en bas d'OTL puis clique sur correction et poste le nouveau rapport
:OTL
O2 - BHO: (Java Plug-In 2 SSV Helper) - {DBC80044-A445-435b-BC74-9C25C1C588A9} - C:\Program Files\Java\jre6\bin\jp2ssv.dll File not found
O3 - HKU\S-1-5-21-1789789911-2046478862-1788013786-1000\..\Toolbar\WebBrowser: (no name) - {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} - No CLSID value found.
O16 - DPF: {CF84DAC5-A4F5-419E-A0BA-C01FFD71112F} https://content.systemrequirementslab.com.s3.amazonaws.com/global/bin/srldetect_intel_4.5.5.0.cab (Reg Error: Key error.)
[2014/04/06 13:59:47 | 000,000,000 | ---D | M] -- C:\ProgramData\a7ffff2060f5865c
[2012/07/15 14:46:56 | 000,003,540 | ---- | M] () -- C:\windows\system32\Tasks\CreateChoiceProcessTask
@Alternate Data Stream - 121 bytes -> C:\ProgramData\Temp:373E1720
:reg
[-HKEY_LOCAL_MACHINE\Software\BrowserChoice]
:files
C:\Windows\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files\Content.IE5\*
:commands
[emptytemp]
#154662
peux-tu m'envoyer ce dossier zippé via un lien stp ?
c:\_otl\moved files\C\ProgramData\a7ffff2060f5865c
#154705
merci ,
ok , bonsoir
on a de l'amelioration ?
