#155825
Merci beaucoup je vous laisse continuer :) bonne désinfection ^^:)
par V-X
#155827
  • Colle les lignes copier au ci dessus dans la partie inférieure d'OTL "Personnalisation"
    :OTL
    IE:[b]64bit:[/b] - HKLM\..\SearchScopes,DefaultScope = {0633EE93-D776-472f-A0FF-E1416B8B2E3A}
    FF:[b]64bit:[/b] - HKLM\Software\MozillaPlugins\@adobe.com/FlashPlayer: C:\windows\system32\Macromed\Flash\NPSWF64_13_0_0_214.dll File not found
    FF - HKEY_LOCAL_MACHINE\software\mozilla\Thunderbird\Extensions\\msktbird@mcafee.com: C:\Program Files\McAfee\MSK
    O2:[b]64bit:[/b] - BHO: (avast! Online Security) - {318A227B-5E9F-45bd-8999-7F8F10CA4CF5} - C:\Program Files\AVAST Software\Avast\aswWebRepIE64.dll File not found
    O3:[b]64bit:[/b] - HKLM\..\Toolbar: (avast! Online Security) - {318A227B-5E9F-45bd-8999-7F8F10CA4CF5} - C:\Program Files\AVAST Software\Avast\aswWebRepIE64.dll File not found
    O3:[b]64bit:[/b] - HKLM\..\Toolbar: (no name) - Locked - No CLSID value found.
    O4:[b]64bit:[/b] - HKLM..\Run: []  File not found
    O4:[b]64bit:[/b] - HKLM..\Run: [Toshiba TEMPRO] C:\Program Files (x86)\Toshiba TEMPRO\TemproTray.exe File not found
    O4 - HKLM..\Run: [TPUReg(x86)] "C:\Program Files\TOSHIBA\Password Utility\TosPU.exe" /Retimes File not found
    O18:[b]64bit:[/b] - Protocol\Handler\ipp - No CLSID value found
    O18:[b]64bit:[/b] - Protocol\Handler\ipp\0x00000001 - No CLSID value found
    O18:[b]64bit:[/b] - Protocol\Handler\msdaipp - No CLSID value found
    O18:[b]64bit:[/b] - Protocol\Handler\msdaipp\0x00000001 - No CLSID value found
    O18:[b]64bit:[/b] - Protocol\Handler\msdaipp\oledb - No CLSID value found
    O18:[b]64bit:[/b] - Protocol\Handler\ms-help - No CLSID value found
    O21:[b]64bit:[/b] - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - No CLSID value found.
    O21 - SSODL: WebCheck - {E6FB5E20-DE35-11CF-9C87-00AA005127ED} - No CLSID value found.
    O30 - LSA: Security Packages - (livessp) -  File not found
    [2014/06/29 22:17:06 | 000,800,978 | ---- | M] () -- C:\windows\SysNative\perfh00C.dat
    [2014/06/29 22:17:06 | 000,776,694 | ---- | M] () -- C:\windows\SysNative\prfh0816.dat
    [2014/06/29 22:17:06 | 000,710,244 | ---- | M] () -- C:\windows\SysNative\perfh009.dat
    [2014/06/29 22:17:06 | 000,702,446 | ---- | M] () -- C:\windows\SysNative\perfh01F.dat
    [2014/06/29 22:17:06 | 000,159,974 | ---- | M] () -- C:\windows\SysNative\prfc0816.dat
    [2014/06/29 22:17:06 | 000,155,650 | ---- | M] () -- C:\windows\SysNative\perfc00C.dat
    [2014/06/29 22:17:06 | 000,146,580 | ---- | M] () -- C:\windows\SysNative\perfc01F.dat
    [2014/06/29 22:17:06 | 000,132,614 | ---- | M] () -- C:\windows\SysNative\perfc009.dat
    :Commands
    [Emptytemp]
  • Clique sur Correction
  • Une fois le scan terminé 1 rapport va s'ouvrir ¤¤¤¤¤¤¤¤¤¤¤.log.
  • Copie et colle le contenu du rapport sur le forum.
par maladryk
#155828
Bon rien ne marche,
J'ai lancé OTL, coller le script et appuyer sur correction. L'ordi a dit qu'il devait redémarrer, chose faite, mais au démarrage de windows, le mot de passe ne fonctionne plus !
Donc pas moyen de lancer windows.
J'ai fait un chngement de mot de passe depuis un autre ordi sur account.live.com/password/reset comme suggéré par windows, mais ça ne marche toujorus pas...?
Une explication ? Car je ne peux plus du tout accéder à l'ordi.
par V-X
#155829
Tu as quoi comme message ou autres, car au redémarrage tu avais un MDP ou pas ?
as tu accès au mode sans échec, tapotte sur la touche F8 ou F12 au redémarrage du PC ?
par maladryk
#155830
Pas de message spécifique, j'ai normalement un mot de passe mais lorsque je le rentre il me répond que ce n'est pas le bon...
Je viens de le redémarrer mais je n'arrive pas à lancer le mode sans échec...
Je vais malheureusement devoir m'absenter quelques heures, mais je vous lirai à mon retour. Toutes mes excuses et encore merci pour votre patience.
Kévin
par V-X
#155831
Téléchargez
Exécute l'installeur :
Attention sur Vista/Seven, si l'UAC est activé, lancer OTLPEUSB par un clic droit / executer en tant qu'administarteur.
Acceptez l'extraction en faisant OK.
OTLPE va lister les lecteurs, sélectionnez votre clef USB.
Selectionnez la version de Windows sur laquelle vous copiez la clef USB : Windows XP ou Vista/Seven
Cochez l'option OTLPE_NETWORK.iso
Cliquez sur Lancer
La copie s'effectue, un message vous indique lorsque la copie est terminée.
Le PC redémarré avec la clé USB ayant OTLPE dessus (Voir le BIOS pour changer l'ordre du Boot et sélectionner clé USB => USB/CD-Rom en premier)
Double clic sur OTL
Copie/colle tout le texte qui est dans le cadre code en dessous de Custom Scan/Fixes
:OTL
Clique sur le bouton Run Fix
Une fois terminé, le rapport de suppression est sauvegardé sur ton disque dur C:\_OTL\ sous la forme date_heure.txt.
Poste le contenu du rapport généré dans ta prochaine réponse
Retire la clé USB et tente un redémarrage en mode normal
par maladryk
#155842
Désolé pour cette absence.
Juste une petite question... comment accéder au BIOS sous windows 8 lorsqu'on ne peut pas accéder à windows...? Car j'ai trouvé des manip pour accéder au BIOS mais toutes nécessitent d'aller dans le panneau de configuration... (rien ne se passe lorsque je presse F12).
