par Steve38 - mer. 2 juil. 2014 22:37
#156068
J'ai fait ce que tu m'as dit, mais après le dernier redémarrage aucun rapport n'est apparu.
Mais je l'ai retrouvé dans OTL :
========== OTL ==========
Registry value HKEY_USERS\S-1-5-21-4197430381-2560329346-160488451-1001\Software\Microsoft\Internet Explorer\Toolbar\WebBrowser\\{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA}\ not found.
Registry value HKEY_USERS\S-1-5-21-4197430381-2560329346-160488451-1001\Software\Microsoft\Windows\CurrentVersion\Run\\Power2GoExpress8 deleted successfully.
C:\Users\Steve\AppData\Roaming\betadeeal folder moved successfully.
C:\Users\Steve\AppData\Roaming\System Speedup folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak\ssd folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak\Advanced System Protector\Logs folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak\Advanced System Protector\Backup folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak\Advanced System Protector\2.1.1000.12580 folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak\Advanced System Protector folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak folder moved successfully.
C:\Users\Steve\AppData\Roaming\~zppnoyg.exe moved successfully.
File C:\Users\Steve\AppData\Roaming\systweak\ssd\SSDPTstub.exe not found.
C:\ProgramData\uninstall_Deeal.exe moved successfully.
C:\Windows\Tasks\System Speedup_UPDATES.job moved successfully.
C:\Windows\Tasks\System Speedup_DEFAULT.job moved successfully.
OTL by OldTimer - Version 3.2.69.0 log created on 07022014_223142
Par contre les icones de speedup et advanced sont de retour sur mon bureau et se sont rouverts... donc visiblement ça n'a pas marché ou j'ai mal fait quelque part ?!
