- jeu. 3 juil. 2014 14:05
#156177
Et voilà le dernier rapport :
All processes killed
========== PROCESSES ==========
========== FILES ==========
C:\Program Files (x86)\Advanced System Protector\AdvancedSystemProtector.exe moved successfully.
C:\Program Files (x86)\Advanced System Protector\aspsys.dll moved successfully.
C:\Program Files (x86)\Advanced System Protector\unrar.dll moved successfully.
C:\Program Files (x86)\Advanced System Protector\System.Data.SQLite.dll moved successfully.
File\Folder C:\Program Files (x86)\Deeal\ScriptHost.dll (Deeal) not found.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Advanced System Protector folder moved successfully.
C:\ProgramData\Systweak\Advanced System Protector\updates folder moved successfully.
C:\ProgramData\Systweak\Advanced System Protector\signatures folder moved successfully.
C:\ProgramData\Systweak\Advanced System Protector\2.1.1000.12580 folder moved successfully.
C:\ProgramData\Systweak\Advanced System Protector folder moved successfully.
C:\ProgramData\Systweak folder moved successfully.
C:\Program Files (x86)\Advanced System Protector\Troubleshooter folder moved successfully.
C:\Program Files (x86)\Advanced System Protector\clamunpack folder moved successfully.
Folder move failed. C:\Program Files (x86)\Advanced System Protector scheduled to be moved on reboot.
C:\Users\Steve\AppData\Roaming\System Speedup folder moved successfully.
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\System Speedup folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak\ssd folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak\Advanced System Protector\Logs folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak\Advanced System Protector\Backup folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak\Advanced System Protector\2.1.1000.12580 folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak\Advanced System Protector folder moved successfully.
C:\Users\Steve\AppData\Roaming\systweak folder moved successfully.
C:\Program Files (x86)\System Speedup folder moved successfully.
C:\Program Files (x86)\Deeal folder moved successfully.
C:\Users\Steve\AppData\Roaming\betadeeal folder moved successfully.
C:\Windows\SysNative\roboot64.exe moved successfully.
C:\Users\Public\Desktop\System Speedup.lnk moved successfully.
C:\Users\Steve\AppData\Roaming\~sxkveon.exe moved successfully.
C:\ProgramData\uninstall_Deeal.exe moved successfully.
File\Folder C:\Users\Steve\AppData\Roaming\~sxkveon.exe not found.
File\Folder C:\Users\Public\Desktop\System Speedup.lnk not found.
C:\Users\Public\Desktop\Advanced System Protector.lnk moved successfully.
File\Folder C:\ProgramData\uninstall_Deeal.exe not found.
File\Folder C:\Users\Steve\AppData\Roaming\betadeeal not found.
File\Folder C:\Users\Steve\AppData\Roaming\systweak not found.
File\Folder C:\Users\Steve\AppData\Roaming\System Speedup not found.
File\Folder C:\Users\Steve\AppData\Roaming\systweak\ssd\SSDPTstub.exe not found.
Registry key HKEY_LOCAL_MACHINE\Software\Deeal\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\System Speedup\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\systweak\ deleted successfully.
Registry key HKEY_CURRENT_USER\Software\System Speedup\ deleted successfully.
Registry key HKEY_CURRENT_USER\Software\systweak\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\00212D92-C5D8-4ff4-AE50-B20F0F85C40A_Systweak_Ad~B9F029BF_is1\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\Deeal\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\System Speedup_is1\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\Software\System Speedup\ not found.
Registry key HKEY_LOCAL_MACHINE\Software\systweak\ not found.
[EMPTYTEMP]
User: All Users
User: Default
User: Default User
User: Public
User: Steve
->Temp folder emptied: 20782293 bytes
->Temporary Internet Files folder emptied: 11423423 bytes
->Google Chrome cache emptied: 240938719 bytes
Windows Temp folder emptied: 11177382 bytes
%systemroot%\system32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 128 bytes
%systemroot%\sysnative\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files folder emptied: 0 bytes
RecycleBin emptied: 0 bytes
Total Files Cleaned = 271,00 mb
OTL by OldTimer - Version 3.2.69.0 log created on 07032014_140057
C:\Program Files (x86)\Advanced System Protector folder moved successfully.
C:\Users\Steve\AppData\Local\Temp\CVHLauncher(20140703134346C04).log moved successfully.
C:\Users\Steve\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
