#213381
:hello:
    O3 - Toolbar\WebBrowser: (no name) - [HKCU]{F2CF5485-4E02-4F68-819C-B92DE9277049} Clé orpheline
    O3 - Toolbar\WebBrowser: (no name) - [HKCU]{1DAC0C53-7D23-4AB3-856A-B04D98CD982A} Clé orpheline
    O4 - GS\Desktop [catherinejubin]: FastPlayer.lnk . (...) -- C:\Program Files\FastPlayer\FastPlayer.exe (.not file.) =>PUP.FastPlayer
    O4 - GS\Desktop [catherinejubin]: PepperZip.lnk . (...) -- C:\Program Files\PepperZip\PepperZip.exe (.not file.) =>PUP.PepperZip
    [MD5.00000000000000000000000000000000] [APT] [EZDGG] (...) -- C:\Users\catherinejubin\AppData\Roaming\EZDGG.exe (.not file.) [0]
    [MD5.00000000000000000000000000000000] [APT] [{1C3AAED1-0D74-4715-AECF-3AF8C65145C4}] (...) -- F:\.NET Framework 3.5 SP1\dotnetfx35_vista_x86.exe (.not file.) [0]
    O39 - APT: EZDGG - (...) -- C:\Windows\Tasks\EZDGG.job [1372]
    O39 - APT: EZDGG - (...) -- C:\Windows\System32\Tasks\EZDGG [1372]
    O41 - Driver: (kbrtdcrv) . (. - .) - C:\Windows\system32\drivers\kbrtdcrv.sys (.not file.)
    O41 - Driver: (rjawmzva) . (. - .) - C:\Windows\system32\drivers\rjawmzva.sys (.not file.)
    O41 - Driver: (xwjzmdxl) . (. - .) - C:\Windows\system32\drivers\xwjzmdxl.sys (.not file.)
    [HKCU\Software\EZDGG]
    [HKLM\Software\54c]
    O43 - CFD: 11/02/2014 - 10:38:50 - [] ----D C:\Users\catherinejubin\AppData\Roaming\main
    [HKCU\Software\Microsoft\Internet Explorer\SearchScopes\{9BB47C17-9C68-4BB3-B188-DD9AF0FD2406}] =>Adware.Bandoo
    [HKLM\Software\Classes\Interface\{8DEC3C75-9A5D-446C-B7B5-E4AB4FDD6309}] =>Adware.Bandoo
    [HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{11111111-1111-1111-1111-110211701196}] =>PUP.CrossRider
    firewallraz
    emptyclsid
    emptyprefetch
    EmptyCLSID
    Emptytemp
  • Copie le contenu du rapport ZHPFixReport sur Paste And Furious, puis copie/colle le lien généré dans ta prochaine réponse.
    -> Tuto Paste And Furious : http://www.sosvirus.net/tutoriel-paste- ... 04985.html" onclick="window.open(this.href);return false;
#213549
:hello:
  • Coche la case Addition.txt
  • Clique sur Scan
#213615
:hello:
  • Clic sur OK
    start
    Task: {05168F8E-6B7E-4D25-B0CD-01B20F568340} - \WSE_Vosteran No Task File <==== ATTENTION
    Task: {358AA937-11E2-422F-AFE2-6C832CF0D670} - \4ab7c0d4-7db8-4363-8bd4-09a5b8e1c01b-2 No Task File <==== ATTENTION
    Task: {5F87F3B5-A1A1-4F96-91A1-6C044C903DDD} - \Updater27096.exe No Task File <==== ATTENTION
    Task: {AD5F6AB5-E6D4-4C92-8237-2ECAAE8A9E51} - System32\Tasks\Microsoft\Windows\Maintenance\SMupdate2 => Rundll32.exe C:\PROGRA~1\COMMON~1\System\SysMenu.dll ,Command701 update2 <==== ATTENTION
    Task: {C5A71372-87AA-4E76-934C-41365B1A2671} - \4fc7b440-ae51-4fef-9379-e097ec8020a6-10_user No Task File <==== ATTENTION
    Task: {D5E7A2CE-A602-4983-8A03-402B3839CF27} - \4fc7b440-ae51-4fef-9379-e097ec8020a6-2 No Task File <==== ATTENTION
    Task: {FBBA8E79-B2B7-4C2D-9309-E9397927253A} - System32\Tasks\Microsoft\Windows\Multimedia\SMupdate3 => Rundll32.exe C:\PROGRA~1\COMMON~1\System\SysMenu.dll ,Command701 update3 <==== ATTENTION
    Task: C:\Windows\Tasks\GoogleUpdateTaskMachineCore.job => C:\Program Files\Google\Update\GoogleUpdate.exe
    Task: C:\Windows\Tasks\GoogleUpdateTaskMachineUA.job => C:\Program Files\Google\Update\GoogleUpdate.exe
    ProxyEnable: [.DEFAULT] => Internet Explorer proxy is enabled.
    ProxyServer: [.DEFAULT] => http=127.0.0.1:49179;https=127.0.0.1:49179
    Toolbar: HKLM - No Name - !{0E8A89AD-95D7-40EB-8D9D-083EF7066A01} -  No File
    Toolbar: HKLM - No Name - !{11111111-1111-1111-1111-110211701196} -  No File
    Toolbar: HKLM - No Name - !{82E1477C-B154-48D3-9891-33D83C26BCD3} -  No File
    Toolbar: HKLM - No Name - !{C1AF5FA5-852C-4C90-812E-A7F75E011D87} -  No File
    Toolbar: HKLM - No Name - !{F9639E4A-801B-4843-AEE3-03D9DA199E77} -  No File
    Toolbar: HKLM - No Name - {1DAC0C53-7D23-4AB3-856A-B04D98CD982A} -  No File
    CHR HKLM\...\Chrome\Extension: [fabcmochhfpldjekobfaaggijgohadih] - No Path
    BHO: No Name -> {1DAC0C53-7D23-4AB3-856A-B04D98CD982A} ->  No File
    2015-01-25 00:37 - 2014-09-01 09:18 - 00000365 _____ () C:\Users\catherinejubin\AppData\Roaming\EZDGG
    end
  • Clic sur Fix
par nioute35
#213675
ca a marché, plus de fenetre au demarrage.
par contre je trouve qu'il est long au demmarage, mais x"est peut etre normal?
