par did80
#227387
Salut GwenHaDu
ou
cliquer sur scanner
cliques sur rapport
ou
  • Frst.txt
    Addition.txt
    Shortcut.txt
Mettre les 3 rapports
par did80
#227389
Lance Farbar
start::
CloseProcesses:
CreateRestorePoint:
HKU\S-1-5-21-4186444725-73973749-4098362729-1001\...\Run: [Chromium] => c:\users\user\appdata\local\chromium\application\chrome.exe [1053184 2016-03-09] (The Chromium Authors)
SearchScopes: HKU\S-1-5-21-4186444725-73973749-4098362729-1001 -> DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
ContextMenuHandlers5: [igfxcui] -> {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => -> Pas de fichier
DeleteKey: HKLM\Software\Classes\*\ShellEx\ContextMenuHandlers\WinRAR32
DeleteKey: HKLM\Software\Classes\CLSID\{B41DB860-8EE4-11D2-9906-E49FADC173CA}
DeleteKey: HKLM\Software\Classes\Folder\ShellEx\ContextMenuHandlers\WinRAR32
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\000
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\001
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\002
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\003
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\004
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\005
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\006
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\007
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\008
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\009
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\010
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\011
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\012
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\013
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\014
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\015
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\016
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\017
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\018
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\019
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\020
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\021
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\022
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\023
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\024
C:\Users\User\AppData\Local\Google\Chrome\User Data\Default\File System\025
EmptyTemp:
cmd: dism.exe /online /cleanup-image /restorehealth
cmd: sfc /scannow
end::
par did80
#227391
on commence seulement
ceci maintenant
Télécharge ZHPCleaner de Nicolas Coolman sur ton bureau
Scanner
puis cliques sur nettoyer
par did80
#227393
salut gwen
celui ci stp
Télécharger Malwarebytes
ou
Paramétrer comme ceci
« Lancer le scan »
Rapport
  1. Compte rendus
  2. Compte rendu d'analyse
  3. Afficher le compte rendu
Exporter Fichier.txt
2 déposer
par did80
#227395
ok on continue
ceci stp
mettre sur le bureau KVRT.exe
désactiver l'antivirus
parametrer
lancer le scan
Scanner
Delete : Supprimer le fichier
Clique sur le bouton Continue
pc tres lent
