Re Teddy
/!\ Bonne nouvelle, pas d'infection, juste de l'inutile
* Dans la fenêtre qui s'ouvre, valide par "
OK "
Code : Tout sélectionnerO2 - BHO: avast! Online Security [64Bits] - {8E5E2654-AD2D-48bf-AC2D-D17F00898D06} . (.AVAST Software - IE Webrep plugin.) -- C:\Program Files\AVAST Software\Avast\aswWebRepIE.dll =>Toolbar.Avast
O2 - BHO: Bing Bar Helper [64Bits] - {d2ce3e00-f94a-4740-988e-03dc2f38c34f} . (...) -- "C:\Program Files (x86)\Microsoft\BingBar\BingExt.dll" (.not file.) =>Toolbar.Bing
O42 - Logiciel: Bing Bar - (.Microsoft Corporation.) [HKLM][64Bits] -- {C28D96C0-6A90-459E-A077-A6706F4EC0FC} =>Toolbar.Bing
O53 - SMSR:HKLM\...\startupreg\SymSilent [Key] . (...) -- C:\Program Files (x86)\SymSilent\SymSilent.exe (.not file.) => Fichier absent
[HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{8E5E2654-AD2D-48BF-AC2D-D17F00898D06}] =>Toolbar.Avast^
[HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{D2CE3E00-F94A-4740-988E-03DC2F38C34F}] =>Toolbar.Bing^
[HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\{C28D96C0-6A90-459E-A077-A6706F4EC0FC}] =>Toolbar.Bing^
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{318A227B-5E9F-45BD-8999-7F8F10CA4CF5}] =>Toolbar.Avast
[HKLM\Software\Classes\CLSID\{318A227B-5E9F-45BD-8999-7F8F10CA4CF5}] =>Toolbar.Avast
[HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{318A227B-5E9F-45BD-8999-7F8F10CA4CF5}] =>Toolbar.Avast
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{8E5E2654-AD2D-48bf-AC2D-D17F00898D06}] =>Toolbar.Avast
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{8E5E2654-AD2D-48bf-AC2D-D17F00898D06}] =>Toolbar.Avast
[HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{8E5E2654-AD2D-48bf-AC2D-D17F00898D06}] =>Toolbar.Avast
C:\Program Files\AVAST Software\Avast\aswWebRepIE.dll =>Toolbar.Avast^
C:\Windows\Installer\{C28D96C0-6A90-459E-A077-A6706F4EC0FC}\icon_installer_ico =>Toolbar.Bing^
EmptyCLSID
Emptytemp
Sysrestore
Clique sur le bouton
Presse-papier encadré en rouge sur l'image.
GO en bas à gauche.
Puis ZHPFix se relance, il faudra à nouveau cliquer sur le bouton "Presse-papier" pour coller les lignes, puis sur le bouton "GO"
Une fois le résultat affiché, clique sur la croix rouge pour refermer l'outil (en haut à doite).
Le rapport se trouve aussi à cet emplacement => C:\ZHP\ZHPFix.txt
Reviens dans ta réponse avec le rapport de ZHPFix
