oui pour cs6
Désinstal Wise Disk Cleaner et Yahoo Toolbar .
Applique ce correctif =>
Ouvre le bloc-notes
Séléctionne et copie dedans le script
Script ZHPFixDouble-clique sur le raccourci du programme "ZHPFix" qui est sur ton bureau
O3 - Toolbar\WebBrowser: (no name) [64Bits] - [HKCU]{21FA44EF-376D-4D53-9B0F-8A89D3229068} Clé orpheline
O3 - Toolbar\WebBrowser: (no name) [64Bits] - [HKCU]{759D9886-0C6F-4498-BAB6-4A5F47C6C72F} Clé orpheline
O3 - Toolbar\WebBrowser: (no name) [64Bits] - [HKCU]{2318C2B1-4965-11D4-9B18-009027A5CD4F} Clé orpheline
O4 - GS\TaskBar [Patrick]: Lightroom 5.2 RC 64-bit.lnk . (...) -- C:\Program Files (x86)\Adobe\Adobe Photoshop Lightroom 5.2 RC\lightroom.exe (.not file.)
[MD5.00000000000000000000000000000000] [APT] [{16A9266D-BE32-46A2-8A65-88A85F508E13}] (...) -- H:\AUTORUN.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{3AC0A510-71DA-4DD3-8F1E-196874ABEDE9}] (...) -- D:\applic compress‚es\photos\irfanview\irfanview_plugins_425_setup.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{66BA574B-1E11-49b8-909C-8CC9E0E8E015}] (...) -- C:\Users\Patrick\AppData\Local\Temp\Sxk.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{7D652DDF-EED9-43FA-8314-95A3ABB8D554}] (...) -- C:\Users\Patrick\Desktop\JMB36X_WinDrv_R1.17.63_WHQL_eSATA\R1.17.63.01_eSATA\setup.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{7F166341-B5FD-4643-958E-C0ECAC88B6E3}] (...) -- C:\Users\Patrick\Desktop\InstallSeagateManager.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{B62195BC-BAF2-44F0-BF7B-3750E7A33AE4}] (...) -- F:\applic compress‚es\trial_xtreme_photostory_cd_dvd_8_deluxe_us.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{D59E4E52-CB2B-4725-97E0-ABF49C699F00}] (...) -- C:\Users\Patrick\Downloads\PC_inspector_File_Recovery_4.0_1901.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{DF249AE0-84B4-4502-9916-71BE6BC137CD}] (...) -- C:\Program Files (x86)\MyPDFConverter\setup\Converter.exe (.not file.) [0]
[MD5.00000000000000000000000000000000] [APT] [{E817F246-FC30-4CD7-9A06-70AB3F5C74F4}] (...) -- C:\Users\Patrick\Downloads\Spyder2_2.3.5_Setup.exe (.not file.) [0]
O43 - CFD: 11/12/2011 - 09:14:01 - [0] ----D C:\Users\Patrick\AppData\Local\MediaGet2 =>PUP.MediaGet
O44 - LFC:[MD5.AD77772F727F2EB7D4F01BF3782EA17C] - 23/09/2013 - 05:49:46 ---A- . (...) -- C:\UsbFix [Scan 4] PATRICK-PC.txt [10210]
O44 - LFC:[MD5.DB42B8E702B92F4BEE695ECB662D3F24] - 22/09/2013 - 05:27:42 ---A- . (...) -- C:\UsbFix [Scan 2] PATRICK-PC.txt [9817]
O44 - LFC:[MD5.24C5B4C3484953C314175E3566B7A32E] - 21/09/2013 - 06:59:38 ---A- . (...) -- C:\UsbFix [Scan 1] PATRICK-PC.txt [9559]
O69 - SBI: SearchScopes [HKCU] {858C7DEC-35B1-4033-9BA2-DB2C12908639} - (Yahoo) - https://fr.search.yahoo.com =>Toolbar.Yahoo
[MD5.83263C433C2917675BAFD5E0BC37C8FC] [SPRF][21/09/2013] (...) -- C:\Users\Patrick\AppData\Local\Temp\chart_data.dat [21262]
[MD5.3BF79E6868B44D3ADB2796BA99521891] [SPRF][07/09/2013] (...) -- C:\Users\Patrick\AppData\Local\Temp\Quarantine.exe [344583]
[HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\29799DE249E7DBC459FC6C8F07EB8375] =>Toolbar.Tarma
[HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\0238BBE24EA3A70408B81E4BB89C15E5] =>Toolbar.Tarma
C:\Users\Patrick\AppData\Local\MediaGet2 =>PUP.MediaGet^
EmptyCLSID
Emptytemp
Sysrestore
Un avertissement s'affiche
Si le script est conforme
Le rapport est aussi sauvegardé sur le Bureau Windows et dans le dossier : C\ZHP\ZHPFix.txt
