#14810
Bonjour à  tous,
J'ai un soucis avec ma carte sd, je ne vois plus mes fichiers sur ma carte alors que mon dossier m'idique 1,25go de pris voici le rapport usbfix
############################## | UsbFix V 7.149 | [Research]
User: Administrator (Administrator) # COMPAQ-7D6B7CC2
Updated 03/11/2013 by El Desaparecido - Team SosVirus
Started at 11:39:35 | 06/11/2013
Website: https://www.usbfix.net/
PC: Compaq (07F4)
CPU: Mobile Intel(R) Pentium(R) 4 - M CPU 1.80GHz
RAM -> [Total : 1023 | Free : 442]
Bios: Compaq
OS: Microsoft Windows XP Professionnel (5.1.2600 32-Bit) Service Pack 3
WB: Windows Internet Explorer : 8.0.6001.18702
SC: Security Center Service [(!) Disabled]
C:\ (%systemdrive%) -> Fixed drive # 37 Gb (2 Mb free - 5%) [] # NTFS
D:\ -> CD-ROM
E:\ -> Fixed drive # 112 Gb (17 Mb free - 16%) [data] # NTFS
F:\ -> CD-ROM
G:\ -> Removable drive # 4 Gb (3 Mb free - 67%) [SD] # FAT32
################## | Active Processes |
C:\windows\System32\smss.exe (ID: 604 |ParentID: 4)
C:\windows\system32\winlogon.exe (ID: 704 |ParentID: 604)
C:\windows\system32\services.exe (ID: 748 |ParentID: 704)
C:\windows\system32\lsass.exe (ID: 760 |ParentID: 704)
C:\windows\system32\Ati2evxx.exe (ID: 948 |ParentID: 748)
C:\windows\system32\svchost.exe (ID: 960 |ParentID: 748)
C:\windows\system32\svchost.exe (ID: 1152 |ParentID: 748)
C:\windows\system32\spoolsv.exe (ID: 1460 |ParentID: 748)
C:\Program Files\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe (ID: 1692 |ParentID: 748)
C:\Program Files\Bonjour\mDNSResponder.exe (ID: 1816 |ParentID: 748)
C:\Program Files\ESET\ESET NOD32 Antivirus\ekrn.exe (ID: 220 |ParentID: 748)
C:\Program Files\Common Files\Rockwell\EventServer.exe (ID: 236 |ParentID: 748)
C:\Program Files\Rockwell Software\FactoryTalk Activation\lmgrd.exe (ID: 248 |ParentID: 748)
C:\Program Files\Rockwell Software\FactoryTalk Activation\Tools\FTActivationBoost.exe (ID: 296 |ParentID: 748)
C:\Program Files\Rockwell Software\FactoryTalk Activation\flexsvr.exe (ID: 620 |ParentID: 248)
C:\Program Files\Java\jre6\bin\jqs.exe (ID: 1344 |ParentID: 748)
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE (ID: 1384 |ParentID: 748)
C:\Program Files\Microsoft SQL Server\MSSQL$VLMSDE2KSP3\Binn\sqlservr.exe (ID: 1660 |ParentID: 748)
C:\windows\system32\NA_Service.exe (ID: 1744 |ParentID: 748)
C:\windows\system32\NA_XWAY.exe (ID: 588 |ParentID: 1744)
C:\windows\system32\NA_XWAY.exe (ID: 1780 |ParentID: 1744)
C:\Program Files\Common Files\Rockwell\NmspHost.exe (ID: 1788 |ParentID: 748)
C:\Program Files\Common Files\Rockwell\RdcyHost.exe (ID: 1948 |ParentID: 748)
C:\Program Files\Common Files\Rockwell\RNADiagnosticsSrv.exe (ID: 1968 |ParentID: 748)
C:\windows\system32\Ati2evxx.exe (ID: 1096 |ParentID: 704)
C:\windows\system32\ctfmon.exe (ID: 1540 |ParentID: 1096)
C:\windows\Explorer.EXE (ID: 1312 |ParentID: 1132)
C:\Program Files\Rockwell Software\RSView Enterprise\HMIDIAGNOSTICSLSTADAPT.exe (ID: 2088 |ParentID: 748)
C:\Program Files\Common Files\Rockwell\RsvcHost.exe (ID: 2132 |ParentID: 748)
C:\WINDOWS\system32\sim9sync.exe (ID: 2152 |ParentID: 748)
C:\windows\system32\svchost.exe (ID: 2172 |ParentID: 748)
C:\Program Files\TeamViewer\Version7\TeamViewer_Service.exe (ID: 2196 |ParentID: 748)
C:\windows\system32\UsbConnect.exe (ID: 2396 |ParentID: 748)
C:\windows\system32\wuauclt.exe (ID: 2880 |ParentID: 1152)
C:\windows\system32\usbconsole.exe (ID: 2952 |ParentID: 2396)
C:\Program Files\Common Files\Rockwell\EventClientMultiplexer.exe (ID: 3216 |ParentID: 748)
C:\Program Files\Common Files\Rockwell\RnaDirServer.exe (ID: 3236 |ParentID: 748)
C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe (ID: 3764 |ParentID: 1312)
C:\Program Files\Common Files\Siemens\S7ubtoox\s7ubtstx.exe (ID: 3892 |ParentID: 1312)
C:\Program Files\Compaq\EAB\EABSERVR.EXE (ID: 4088 |ParentID: 1312)
C:\Program Files\Compaq\Hotkey Software\hkss.exe (ID: 320 |ParentID: 1312)
C:\Program Files\Rockwell Automation\Rockwell Automation USB CIP Driver Package\UsbCipHelper\UsbCipHelper.exe (ID: 316 |ParentID: 1312)
C:\UsbFix\Go.exe (ID: 360 |ParentID: 3332)
C:\Program Files\ESET\ESET NOD32 Antivirus\egui.exe (ID: 372 |ParentID: 1312)
C:\Program Files\Common Files\Java\Java Update\jusched.exe (ID: 436 |ParentID: 1312)
C:\Program Files\Common Files\Siemens\Sqlany\dbsrv7.exe (ID: 544 |ParentID: 4056)
C:\Program Files\iTunes\iTunesHelper.exe (ID: 784 |ParentID: 1312)
C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe (ID: 920 |ParentID: 1312)
C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe (ID: 2148 |ParentID: 1312)
C:\Program Files\Common Files\Rockwell\RNADirMultiplexor.exe (ID: 2812 |ParentID: 748)
C:\Program Files\iPod\bin\iPodService.exe (ID: 212 |ParentID: 748)
C:\windows\System32\svchost.exe (ID: 3600 |ParentID: 748)
C:\Program Files\Google\Common\Google Updater\GoogleUpdaterService.exe (ID: 2300 |ParentID: 748)
04 - HKLM\SOFTWARE | Run : [ATIPTA] - C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe
04 - HKLM\SOFTWARE | Run : [S7UB Start] - "C:\Program Files\Common Files\Siemens\S7ubtoox\s7ubtstx.exe" -StartDB
04 - HKLM\SOFTWARE | Run : [eabconfg.cpl] - C:\Program Files\Compaq\EAB\EABSERVR.EXE /Start
04 - HKLM\SOFTWARE | Run : [hkss] - C:\Program Files\Compaq\Hotkey Software\hkss.exe
04 - HKLM\SOFTWARE | Run : [UsbCipHelper] - C:\Program Files\Rockwell Automation\Rockwell Automation USB CIP Driver Package\UsbCipHelper\UsbCipHelper.exe
04 - HKLM\SOFTWARE | Run : [egui] - "C:\Program Files\ESET\ESET NOD32 Antivirus\egui.exe" /hide /waitservice
04 - HKLM\SOFTWARE | Run : [SunJavaUpdateSched] - "C:\Program Files\Common Files\Java\Java Update\jusched.exe"
04 - HKLM\SOFTWARE | Run : [KernelFaultCheck] - %systemroot%\system32\dumprep 0 -k
04 - HKLM\SOFTWARE | Run : [APSDaemon] - "C:\Program Files\Common Files\Apple\Apple Application Support\APSDaemon.exe"
04 - HKLM\SOFTWARE | Run : [iTunesHelper] - "C:\Program Files\iTunes\iTunesHelper.exe"
04 - HKLM\SOFTWARE | Run : [Adobe ARM] - "C:\Program Files\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
04 - HKU\S-1-5-21-583907252-1606980848-1957994488-500\SOFTWARE | Run : [ctfmon.exe] - C:\windows\system32\ctfmon.exe
04 - HKU\S-1-5-21-583907252-1606980848-1957994488-500\SOFTWARE | Run : [swg] - "C:\Program Files\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
04 - HKU\S-1-5-18\SOFTWARE | Run : [CTFMON.EXE] - C:\WINDOWS\system32\ctfmon.exe
################## | Generic Research |
Found ! C:\windows\system32\X37012go
Found ! D:\setup.exe
Found ! D:\AUTORUN.INF
################## | Registry |
G:\Autorun.inf -> Vaccine created by UsbFix (El Desaparecido)
et voici le rapport de supression
############################## | UsbFix V 7.149 | [Deletion]
Started at 11:03:56 | 06/11/2013
PC: Compaq (07F4)
RAM -> [Total : 1023 | Free : 716]
Bios: Compaq
Boot: Fail-safe with network boot
D:\ -> CD-ROM
################## | Stopped processes |
Stopped! C:\windows\Explorer.EXE (ID: 1936 |ParentID: 1888)
Stopped! C:\windows\system32\ctfmon.exe (ID: 1952 |ParentID: 1936)
04 - HKLM\SOFTWARE | RunOnce : [Malwarebytes Anti-Malware] - C:\Program Files\Malwarebytes' Anti-Malware\mbamgui.exe /install /silent
Deleted ! C:\windows\system32\X37012go
Not deleted ! D:\setup.exe
Not deleted ! D:\AUTORUN.INF
(!) Temporary files deleted.
Deleted ! HKU\S-1-5-21-583907252-1606980848-1957994488-500\Software\.\.\.\.\Mountpoints2\D
[06/11/2013 - 09:14:29 | D ] C:\AdwCleaner
[22/07/2013 - 06:03:25 | D ] C:\Documents and Settings
[16/06/2009 - 08:19:51 | N | 172] C:\EVRSI.SYS
[20/12/2007 - 19:33:37 | D ] C:\i386
[04/01/1980 - 09:55:40 | N | 0] C:\IO.SYS
[21/12/2007 - 09:07:31 | D ] C:\Micrelec
[04/01/1980 - 09:55:40 | N | 0] C:\MSDOS.SYS
[20/12/2007 - 17:30:05 | RHD ] C:\MSOCache
[28/02/2006 - 13:00:00 | N | 47564] C:\NTDETECT.COM
[10/09/2008 - 06:30:29 | N | 250048] C:\ntldr
[06/11/2013 - 10:57:42 | ASH | 2147483648] C:\pagefile.sys
[07/10/2009 - 06:17:07 | D ] C:\Panasonic MEW Documents
[09/10/2013 - 12:45:12 | N | 1476] C:\pb_Label.csv
[21/12/2007 - 06:07:03 | D ] C:\PL7
[18/09/2013 - 11:21:31 | D ] C:\PL7TEMP
[24/07/2013 - 11:42:33 | D ] C:\PL7USER
[06/11/2013 - 10:03:24 | D ] C:\Program Files
[04/10/2011 - 07:43:07 | N | 4542] C:\Project.Cfg
[14/10/2010 - 06:32:01 | D ] C:\Qoobox
[15/04/2011 - 07:01:11 | N | 145] C:\Raccourci vers Lecteur CD.lnk
[20/12/2007 - 18:14:46 | N | 20725] C:\RASETUP.LOG
[20/12/2007 - 17:39:18 | N | 489] C:\RASETUP1.LOG
[07/10/2010 - 12:50:11 | D ] C:\RATrendData
[21/07/2011 - 13:55:08 | N | 1282] C:\RECUP.DOC
[06/11/2013 - 11:04:39 | SHD ] C:\RECYCLER
[21/04/2010 - 11:19:43 | D ] C:\RSLogix 5000
[20/12/2007 - 18:11:16 | D ] C:\S5_INFO
[26/05/2010 - 11:07:03 | D ] C:\Schneider Application
[24/10/2008 - 13:39:03 | D ] C:\SIS
[12/04/2010 - 13:19:52 | D ] C:\Solidworks Data
[06/04/2012 - 09:49:07 | D ] C:\SolidWorks Data (2)
[17/05/2013 - 07:13:13 | D ] C:\SolidWorks Data (3)
[30/06/2011 - 09:37:48 | D ] C:\STEP5
[20/12/2007 - 19:33:04 | D ] C:\swsetup
[21/02/2013 - 13:05:13 | SHD ] C:\System Volume Information
[30/05/2013 - 10:22:18 | D ] C:\temp
[29/06/2011 - 13:52:41 | D ] C:\tmp
[12/03/2012 - 15:34:18 | N | 899] C:\trace.log
[21/05/2008 - 11:49:21 | D ] C:\twidosoft
[08/09/2011 - 06:18:25 | D ] C:\twidosuite
[01/10/2013 - 07:45:31 | D ] C:\UnityProTemp
[06/11/2013 - 11:04:39 | D ] C:\UsbFix
[06/11/2013 - 11:04:42 | A | 5375] C:\UsbFix [Clean 1] COMPAQ-7D6B7CC2.txt
[06/11/2013 - 09:05:10 | N | 20773] C:\UsbFix [Clean 2] COMPAQ-7D6B7CC2.txt
[06/11/2013 - 09:47:55 | N | 20788] C:\UsbFix [Clean 3] COMPAQ-7D6B7CC2.txt
[05/11/2013 - 14:43:46 | N | 7593] C:\UsbFix [Listing 1 ] COMPAQ-7D6B7CC2.txt
[06/11/2013 - 11:01:42 | N | 3889] C:\UsbFix [Scan 1] COMPAQ-7D6B7CC2.txt
[05/11/2013 - 14:21:30 | N | 8313] C:\UsbFix [Scan 2] COMPAQ-7D6B7CC2.txt
[05/11/2013 - 14:45:20 | N | 4582] C:\UsbFix [Scan 3] COMPAQ-7D6B7CC2.txt
[05/11/2013 - 15:21:01 | N | 4839] C:\UsbFix [Scan 4] COMPAQ-7D6B7CC2.txt
[06/11/2013 - 08:22:28 | N | 7150] C:\UsbFix [Scan 5] COMPAQ-7D6B7CC2.txt
[06/11/2013 - 09:52:50 | N | 4100] C:\vscnpa64.log
[06/11/2013 - 10:57:45 | D ] C:\WINDOWS
[01/10/2013 - 06:22:01 | N | 619592] C:\xerror.log
[14/04/2008 - 13:00:00 | R | 112] D:\AUTORUN.INF
[14/04/2008 - 13:00:00 | R | 4952] D:\BOOTFONT.BIN
[14/04/2008 - 13:00:00 | RD ] D:\DOCS
[14/04/2008 - 13:00:00 | RD ] D:\DOTNETFX
[14/04/2008 - 13:00:00 | RD ] D:\I386
[14/04/2008 - 13:00:00 | R | 41060] D:\LISEZMOI.HTM
[14/04/2008 - 13:00:00 | R | 2584576] D:\SETUP.EXE
[14/04/2008 - 13:00:00 | R | 105053] D:\SETUPXP.HTM
[14/04/2008 - 13:00:00 | RD ] D:\SUPPORT
[14/04/2008 - 13:00:00 | RD ] D:\VALUEADD
[14/04/2008 - 13:00:00 | R | 10] D:\WIN51
[14/04/2008 - 13:00:00 | R | 10] D:\WIN51IP
[14/04/2008 - 13:00:00 | R | 10] D:\WIN51IP.SP3
[19/04/2010 - 16:30:56 | D ] E:\2010-04-19-10-img
[14/02/2011 - 08:07:22 | D ] E:\61d38c45555232d1fdca
[19/04/2010 - 15:32:14 | D ] E:\AX NF ZZ
[23/08/2010 - 14:49:21 | D ] E:\b4d054701eaa405f7c873f574b
[03/11/2008 - 11:03:30 | N | 231424] E:\BDD1.MDB
[19/02/2013 - 13:02:51 | N | 30720] E:\cvJonathan_PATOIr.doc
[16/09/2013 - 07:37:07 | D ] E:\d0d9f0ce41f24935a5
[16/04/2012 - 07:10:52 | D ] E:\DAQSTANDARD R7.12
[19/04/2010 - 15:35:07 | D ] E:\Documents and Settings
[18/07/2013 - 12:30:16 | D ] E:\DRIVER
[07/04/2011 - 10:49:02 | D ] E:\EMILEMAURIN
[10/05/2013 - 08:30:31 | N | 29679000] E:\foxit-reader_6-0-2-0413_fr_13808.exe
[06/05/2013 - 11:05:52 | N | 913428480] E:\FR_OFFICE_ENTR07_SP1.iso
[29/03/2011 - 12:07:51 | D ] E:\MAIL
[29/03/2011 - 11:59:59 | D ] E:\mail 29032011
[31/10/2013 - 12:22:52 | D ] E:\My Documents
[10/05/2013 - 08:44:02 | D ] E:\NewFileTime
[10/05/2013 - 08:43:43 | N | 37305] E:\NewFileTime.zip
[18/07/2013 - 12:31:55 | D ] E:\Nouveau dossier
[03/09/2013 - 05:58:37 | D ] E:\Nouveau dossier (2)
[18/07/2013 - 12:36:07 | D ] E:\Nouveau dossier (4)
[29/04/2013 - 12:42:19 | D ] E:\Nouveau dossier (5)
[06/11/2013 - 10:57:43 | ASH | 1609605120] E:\pagefile.sys
[19/03/2013 - 13:45:06 | N | 23552] E:\Patoir JonathanHergnies mate.doc
[25/02/2013 - 14:58:34 | N | 25088] E:\Patoir JonathanHergnies.doc
[10/05/2013 - 08:54:01 | N | 17502040] E:\pdfcreator_1.7.0_fr_11085.exe
[29/08/2013 - 07:35:30 | D ] E:\PL707
[19/04/2010 - 15:35:08 | D ] E:\PL7TEMP
[17/05/2013 - 06:50:49 | D ] E:\Program Files
[24/09/2013 - 08:37:28 | D ] E:\programme automate
[03/03/2010 - 09:58:54 | N | 6971] E:\RASETUP.LOG
[03/03/2010 - 07:09:13 | N | 485] E:\RASETUP1.LOG
[03/03/2010 - 09:55:28 | N | 24203] E:\RASETUP2.LOG
[06/11/2013 - 11:04:39 | SHD ] E:\RECYCLER
[19/04/2010 - 15:42:25 | D ] E:\S5_INFO
[26/09/2011 - 14:04:09 | N | 3080822] E:\SP-1002_EN.pdf
[19/04/2010 - 15:42:26 | D ] E:\STEP5
[19/04/2010 - 15:42:34 | D ] E:\swsetup
[11/06/2013 - 12:20:15 | SHD ] E:\System Volume Information
[22/07/2013 - 12:25:07 | D ] E:\UnityPro_XL_60
[29/08/2011 - 15:00:07 | N | 100000000] E:\Vijeo_Designer_v51.part01.rar
[07/09/2011 - 13:25:54 | N | 100000000] E:\Vijeo_Designer_v51.part02.rar
[08/09/2011 - 06:30:39 | N | 100000000] E:\Vijeo_Designer_v51.part03.rar
[08/09/2011 - 07:01:20 | N | 100000000] E:\Vijeo_Designer_v51.part04.rar
[08/09/2011 - 06:49:46 | N | 100000000] E:\Vijeo_Designer_v51.part05.rar
[08/09/2011 - 06:35:39 | N | 100000000] E:\Vijeo_Designer_v51.part06.rar
[08/09/2011 - 06:31:55 | N | 100000000] E:\Vijeo_Designer_v51.part07.rar
[08/09/2011 - 06:51:37 | N | 100000000] E:\Vijeo_Designer_v51.part08.rar
[08/09/2011 - 06:39:39 | N | 100000000] E:\Vijeo_Designer_v51.part09.rar
[19/04/2010 - 15:47:55 | D ] E:\WINDOWS
[14/01/2013 - 10:04:22 | D ] E:\windows_xp_pro_par_Seh_pour_WM
[20/03/2013 - 07:54:07 | N | 659290112] E:\XP-French.iso
[26/03/2011 - 00:41:48 | D ] G:\DCIM
[26/03/2011 - 00:41:48 | D ] G:\MISC
[26/03/2011 - 00:41:48 | N | 512] G:\NIKON001.DSC
[26/03/2011 - 00:42:06 | D ] G:\NCFL
[10/11/2013 - 10:49:40 | RASHD ] G:\Autorun.inf
après cette suppression j'ai toujours mon dossier vide
merci pour votre aide
cordialement
#14832
Voici le rapport de scanme.bat
[26/03/2011 00:41|d--------|0] G:\DCIM
[26/03/2011 00:41|d--------|0] G:\MISC
[26/03/2011 00:42|d--------|0] G:\NCFL
[06/11/2013 11:42|drahs----|0] G:\Autorun.inf
[26/03/2011 00:42|d--hs----|0] G:\DCIM\100NIKON
[07/05/2011 12:34|d--hs----|0] G:\DCIM\101NIKON
[25/12/2011 16:42|d--hs----|0] G:\DCIM\102NIKON
[11/08/2012 16:26|d--hs----|0] G:\DCIM\103NIKON
[13/07/2013 15:08|d--hs----|0] G:\DCIM\104NIKON
[11/08/2013 17:59|d--hs----|0] G:\DCIM\105NIKON
[26/03/2011 00:41|---------|512] G:\NIKON001.DSC
[13/07/2013 12:16|--a------|2558368] G:\DCIM\103NIKON\DSCN0953.JPG
[13/07/2013 12:16|--a------|2404838] G:\DCIM\103NIKON\DSCN0954.JPG
[13/07/2013 12:16|--a------|2493661] G:\DCIM\103NIKON\DSCN0955.JPG
[13/07/2013 12:17|--a------|2501286] G:\DCIM\103NIKON\DSCN0956.JPG
[13/07/2013 12:17|--a------|2556034] G:\DCIM\103NIKON\DSCN0957.JPG
[13/07/2013 12:17|--a------|2411658] G:\DCIM\103NIKON\DSCN0958.JPG
[13/07/2013 12:28|--a------|2447548] G:\DCIM\103NIKON\DSCN0959.JPG
[13/07/2013 14:10|--a------|2431248] G:\DCIM\103NIKON\DSCN0960.JPG
[13/07/2013 14:10|--a------|2566141] G:\DCIM\103NIKON\DSCN0961.JPG
[13/07/2013 14:11|--a------|2568197] G:\DCIM\103NIKON\DSCN0962.JPG
[13/07/2013 14:11|--a------|2562659] G:\DCIM\103NIKON\DSCN0963.JPG
[13/07/2013 14:12|--a------|2479969] G:\DCIM\103NIKON\DSCN0964.JPG
[13/07/2013 14:12|--a------|2542929] G:\DCIM\103NIKON\DSCN0965.JPG
[13/07/2013 14:15|--a------|2709235] G:\DCIM\103NIKON\DSCN0966.JPG
[13/07/2013 14:16|--a------|2743191] G:\DCIM\103NIKON\DSCN0967.JPG
[13/07/2013 14:16|--a------|2701127] G:\DCIM\103NIKON\DSCN0968.JPG
[13/07/2013 14:16|--a------|2658188] G:\DCIM\103NIKON\DSCN0969.JPG
[13/07/2013 14:17|--a------|2640608] G:\DCIM\103NIKON\DSCN0970.JPG
[13/07/2013 14:24|--a------|2463653] G:\DCIM\103NIKON\DSCN0971.JPG
[29/09/2012 15:41|--a------|2532912] G:\DCIM\103NIKON\DSCN0751.JPG
[29/09/2012 15:41|--a------|2418778] G:\DCIM\103NIKON\DSCN0752.JPG
[29/09/2012 15:42|--a------|2518687] G:\DCIM\103NIKON\DSCN0753.JPG
[29/09/2012 15:42|--a------|2532073] G:\DCIM\103NIKON\DSCN0754.JPG
[29/09/2012 15:42|--a------|2518619] G:\DCIM\103NIKON\DSCN0755.JPG
[29/09/2012 15:42|--a------|2432159] G:\DCIM\103NIKON\DSCN0756.JPG
[29/09/2012 15:43|--a------|2457184] G:\DCIM\103NIKON\DSCN0758.JPG
[29/09/2012 15:49|--a------|2669629] G:\DCIM\103NIKON\DSCN0759.JPG
[29/09/2012 15:49|--a------|2629401] G:\DCIM\103NIKON\DSCN0760.JPG
[29/09/2012 15:49|--a------|2425599] G:\DCIM\103NIKON\DSCN0761.JPG
[29/09/2012 15:49|--a------|2416312] G:\DCIM\103NIKON\DSCN0762.JPG
[29/09/2012 15:50|--a------|2770761] G:\DCIM\103NIKON\DSCN0763.JPG
[29/09/2012 15:50|--a------|2730293] G:\DCIM\103NIKON\DSCN0764.JPG
[29/09/2012 15:50|--a------|2712386] G:\DCIM\103NIKON\DSCN0765.JPG
[29/09/2012 16:00|--a------|2680770] G:\DCIM\103NIKON\DSCN0766.JPG
[29/09/2012 16:00|--a------|2695688] G:\DCIM\103NIKON\DSCN0767.JPG
[29/09/2012 16:01|--a------|2692241] G:\DCIM\103NIKON\DSCN0768.JPG
[29/09/2012 16:01|--a------|2732012] G:\DCIM\103NIKON\DSCN0769.JPG
[29/09/2012 16:01|--a------|2719727] G:\DCIM\103NIKON\DSCN0770.JPG
[29/09/2012 16:02|--a------|2475222] G:\DCIM\103NIKON\DSCN0771.JPG
[29/09/2012 16:02|--a------|2596719] G:\DCIM\103NIKON\DSCN0772.JPG
[29/09/2012 16:02|--a------|2581628] G:\DCIM\103NIKON\DSCN0773.JPG
[29/09/2012 16:02|--a------|2576917] G:\DCIM\103NIKON\DSCN0774.JPG
[29/09/2012 16:03|--a------|2688264] G:\DCIM\103NIKON\DSCN0775.JPG
[29/09/2012 16:03|--a------|2596756] G:\DCIM\103NIKON\DSCN0776.JPG
[29/09/2012 16:04|--a------|2699787] G:\DCIM\103NIKON\DSCN0777.JPG
[29/09/2012 16:04|--a------|2641858] G:\DCIM\103NIKON\DSCN0778.JPG
[29/09/2012 16:04|--a------|2619073] G:\DCIM\103NIKON\DSCN0779.JPG
[29/09/2012 16:04|--a------|2430706] G:\DCIM\103NIKON\DSCN0780.JPG
[29/09/2012 16:04|--a------|2530343] G:\DCIM\103NIKON\DSCN0781.JPG
[29/09/2012 16:04|--a------|2501590] G:\DCIM\103NIKON\DSCN0782.JPG
[29/09/2012 16:05|--a------|2733378] G:\DCIM\103NIKON\DSCN0783.JPG
[29/09/2012 16:05|--a------|2670751] G:\DCIM\103NIKON\DSCN0784.JPG
[29/09/2012 16:08|--a------|2643125] G:\DCIM\103NIKON\DSCN0785.JPG
[29/09/2012 16:08|--a------|2694286] G:\DCIM\103NIKON\DSCN0786.JPG
[29/09/2012 16:08|--a------|2694650] G:\DCIM\103NIKON\DSCN0787.JPG
[29/09/2012 16:09|--a------|2720881] G:\DCIM\103NIKON\DSCN0788.JPG
[29/09/2012 16:09|--a------|2693940] G:\DCIM\103NIKON\DSCN0789.JPG
[29/09/2012 16:09|--a------|2672965] G:\DCIM\103NIKON\DSCN0790.JPG
[29/09/2012 16:09|--a------|2612614] G:\DCIM\103NIKON\DSCN0791.JPG
[13/07/2013 14:24|--a------|2688006] G:\DCIM\103NIKON\DSCN0972.JPG
[13/07/2013 14:24|--a------|2741872] G:\DCIM\103NIKON\DSCN0973.JPG
[13/07/2013 14:24|--a------|2694641] G:\DCIM\103NIKON\DSCN0974.JPG
[13/07/2013 14:25|--a------|2699091] G:\DCIM\103NIKON\DSCN0975.JPG
[13/07/2013 14:25|--a------|2603995] G:\DCIM\103NIKON\DSCN0976.JPG
[13/07/2013 14:30|--a------|2550401] G:\DCIM\103NIKON\DSCN0977.JPG
[13/07/2013 14:31|--a------|2414528] G:\DCIM\103NIKON\DSCN0978.JPG
[13/07/2013 14:31|--a------|2712825] G:\DCIM\103NIKON\DSCN0979.JPG
[13/07/2013 14:33|--a------|2431842] G:\DCIM\103NIKON\DSCN0980.JPG
[13/07/2013 14:43|--a------|2673684] G:\DCIM\103NIKON\DSCN0981.JPG
[29/09/2012 16:09|--a------|2528767] G:\DCIM\103NIKON\DSCN0792.JPG
[29/09/2012 16:09|--a------|2661412] G:\DCIM\103NIKON\DSCN0793.JPG
[29/09/2012 16:10|--a------|2691409] G:\DCIM\103NIKON\DSCN0794.JPG
[29/09/2012 16:10|--a------|2655718] G:\DCIM\103NIKON\DSCN0795.JPG
[29/09/2012 16:11|--a------|2461687] G:\DCIM\103NIKON\DSCN0796.JPG
[29/09/2012 16:11|--a------|2525917] G:\DCIM\103NIKON\DSCN0797.JPG
[29/09/2012 16:11|--a------|2578962] G:\DCIM\103NIKON\DSCN0798.JPG
[29/09/2012 16:11|--a------|2415478] G:\DCIM\103NIKON\DSCN0799.JPG
[29/09/2012 16:11|--a------|2495161] G:\DCIM\103NIKON\DSCN0800.JPG
[29/09/2012 16:12|--a------|2557008] G:\DCIM\103NIKON\DSCN0801.JPG
[29/09/2012 16:12|--a------|2463535] G:\DCIM\103NIKON\DSCN0802.JPG
[29/09/2012 16:12|--a------|2397979] G:\DCIM\103NIKON\DSCN0803.JPG
[29/09/2012 16:12|--a------|2534195] G:\DCIM\103NIKON\DSCN0804.JPG
[29/09/2012 16:12|--a------|2492426] G:\DCIM\103NIKON\DSCN0805.JPG
[29/09/2012 16:12|--a------|2509333] G:\DCIM\103NIKON\DSCN0806.JPG
[29/09/2012 16:13|--a------|2478956] G:\DCIM\103NIKON\DSCN0807.JPG
[29/09/2012 16:13|--a------|2506018] G:\DCIM\103NIKON\DSCN0808.JPG
[29/09/2012 16:13|--a------|2355842] G:\DCIM\103NIKON\DSCN0809.JPG
[29/09/2012 16:16|--a------|2501188] G:\DCIM\103NIKON\DSCN0810.JPG
[29/09/2012 16:16|--a------|2513913] G:\DCIM\103NIKON\DSCN0811.JPG
[29/09/2012 16:16|--a------|2519047] G:\DCIM\103NIKON\DSCN0812.JPG
[29/09/2012 16:20|--a------|2499025] G:\DCIM\103NIKON\DSCN0813.JPG
[29/09/2012 16:20|--a------|2454198] G:\DCIM\103NIKON\DSCN0814.JPG
[29/09/2012 16:23|--a------|2711186] G:\DCIM\103NIKON\DSCN0815.JPG
[29/09/2012 16:23|--a------|2680524] G:\DCIM\103NIKON\DSCN0816.JPG
[29/09/2012 16:23|--a------|2677042] G:\DCIM\103NIKON\DSCN0817.JPG
[29/09/2012 17:31|--a------|2691701] G:\DCIM\103NIKON\DSCN0818.JPG
[29/09/2012 17:31|--a------|2645958] G:\DCIM\103NIKON\DSCN0819.JPG
[13/07/2013 14:44|--a------|2651796] G:\DCIM\103NIKON\DSCN0982.JPG
[29/09/2012 17:32|--a------|2511176] G:\DCIM\103NIKON\DSCN0821.JPG
[29/09/2012 17:34|--a------|2406497] G:\DCIM\103NIKON\DSCN0822.JPG
[29/09/2012 17:34|--a------|2475759] G:\DCIM\103NIKON\DSCN0823.JPG
[29/09/2012 17:34|--a------|2662290] G:\DCIM\103NIKON\DSCN0824.JPG
[29/09/2012 17:34|--a------|2719263] G:\DCIM\103NIKON\DSCN0825.JPG
[29/09/2012 18:05|--a------|2665841] G:\DCIM\103NIKON\DSCN0826.JPG
[29/09/2012 18:05|--a------|2593539] G:\DCIM\103NIKON\DSCN0827.JPG
[29/09/2012 18:05|--a------|2512259] G:\DCIM\103NIKON\DSCN0828.JPG
[29/09/2012 18:05|--a------|2676433] G:\DCIM\103NIKON\DSCN0829.JPG
[29/09/2012 18:06|--a------|2622229] G:\DCIM\103NIKON\DSCN0830.JPG
[29/09/2012 18:07|--a------|2640600] G:\DCIM\103NIKON\DSCN0831.JPG
[29/09/2012 18:07|--a------|2692607] G:\DCIM\103NIKON\DSCN0832.JPG
[29/09/2012 18:07|--a------|2712962] G:\DCIM\103NIKON\DSCN0833.JPG
[29/09/2012 18:07|--a------|2757441] G:\DCIM\103NIKON\DSCN0834.JPG
[29/09/2012 18:08|--a------|2547316] G:\DCIM\103NIKON\DSCN0835.JPG
[29/09/2012 18:08|--a------|2730550] G:\DCIM\103NIKON\DSCN0836.JPG
[29/09/2012 18:08|--a------|2624538] G:\DCIM\103NIKON\DSCN0837.JPG
[29/09/2012 18:09|--a------|2655780] G:\DCIM\103NIKON\DSCN0838.JPG
[29/09/2012 18:09|--a------|2678112] G:\DCIM\103NIKON\DSCN0839.JPG
[29/09/2012 18:10|--a------|2609225] G:\DCIM\103NIKON\DSCN0840.JPG
[29/09/2012 18:10|--a------|2637443] G:\DCIM\103NIKON\DSCN0841.JPG
[29/09/2012 18:10|--a------|2714132] G:\DCIM\103NIKON\DSCN0842.JPG
[29/09/2012 18:10|--a------|2686396] G:\DCIM\103NIKON\DSCN0843.JPG
[29/09/2012 18:10|--a------|2666010] G:\DCIM\103NIKON\DSCN0844.JPG
[29/09/2012 18:11|--a------|2720396] G:\DCIM\103NIKON\DSCN0845.JPG
[29/09/2012 18:11|--a------|2691465] G:\DCIM\103NIKON\DSCN0846.JPG
[29/09/2012 18:12|--a------|2712193] G:\DCIM\103NIKON\DSCN0847.JPG
[29/09/2012 18:14|--a------|2767052] G:\DCIM\103NIKON\DSCN0848.JPG
[29/09/2012 18:14|--a------|2727957] G:\DCIM\103NIKON\DSCN0849.JPG
[29/09/2012 18:16|--a------|2658520] G:\DCIM\103NIKON\DSCN0850.JPG
[29/09/2012 18:16|--a------|2739363] G:\DCIM\103NIKON\DSCN0851.JPG
[29/09/2012 18:17|--a------|2713223] G:\DCIM\103NIKON\DSCN0852.JPG
[29/09/2012 18:18|--a------|2770231] G:\DCIM\103NIKON\DSCN0853.JPG
[29/09/2012 18:18|--a------|2635643] G:\DCIM\103NIKON\DSCN0854.JPG
[29/09/2012 18:21|--a------|2492349] G:\DCIM\103NIKON\DSCN0855.JPG
[29/09/2012 18:21|--a------|2505862] G:\DCIM\103NIKON\DSCN0856.JPG
[29/09/2012 18:29|--a------|2539117] G:\DCIM\103NIKON\DSCN0857.JPG
[29/09/2012 18:30|--a------|2545373] G:\DCIM\103NIKON\DSCN0858.JPG
[29/09/2012 19:38|--a------|2706219] G:\DCIM\103NIKON\DSCN0859.JPG
[29/09/2012 19:39|--a------|2445837] G:\DCIM\103NIKON\DSCN0860.JPG
[29/09/2012 19:39|--a------|2499271] G:\DCIM\103NIKON\DSCN0861.JPG
[29/09/2012 19:39|--a------|2506906] G:\DCIM\103NIKON\DSCN0862.JPG
[29/09/2012 19:40|--a------|2471471] G:\DCIM\103NIKON\DSCN0863.JPG
[29/09/2012 19:40|--a------|2596088] G:\DCIM\103NIKON\DSCN0864.JPG
[29/09/2012 19:41|--a------|2531603] G:\DCIM\103NIKON\DSCN0865.JPG
[29/09/2012 19:41|--a------|2595830] G:\DCIM\103NIKON\DSCN0866.JPG
[29/09/2012 19:41|--a------|2684887] G:\DCIM\103NIKON\DSCN0867.JPG
[29/09/2012 19:41|--a------|2524499] G:\DCIM\103NIKON\DSCN0868.JPG
[29/09/2012 19:43|--a------|2429560] G:\DCIM\103NIKON\DSCN0869.JPG
[29/09/2012 23:22|--a------|2318882] G:\DCIM\103NIKON\DSCN0870.JPG
[29/09/2012 23:22|--a------|2084271] G:\DCIM\103NIKON\DSCN0871.JPG
[29/09/2012 23:22|--a------|2518845] G:\DCIM\103NIKON\DSCN0872.JPG
[29/09/2012 23:22|--a------|2525290] G:\DCIM\103NIKON\DSCN0873.JPG
[29/09/2012 23:22|--a------|2512123] G:\DCIM\103NIKON\DSCN0874.JPG
[29/09/2012 23:23|--a------|2566921] G:\DCIM\103NIKON\DSCN0875.JPG
[13/07/2013 14:44|--a------|2631973] G:\DCIM\103NIKON\DSCN0983.JPG
[13/07/2013 14:45|--a------|2698291] G:\DCIM\103NIKON\DSCN0984.JPG
[29/09/2012 23:23|--a------|2587365] G:\DCIM\103NIKON\DSCN0878.JPG
[29/09/2012 23:24|--a------|2690898] G:\DCIM\103NIKON\DSCN0879.JPG
[29/09/2012 23:43|--a------|2329511] G:\DCIM\103NIKON\DSCN0880.JPG
[29/09/2012 23:43|--a------|2310354] G:\DCIM\103NIKON\DSCN0881.JPG
[29/09/2012 23:43|--a------|2446626] G:\DCIM\103NIKON\DSCN0882.JPG
[29/09/2012 23:43|--a------|2362610] G:\DCIM\103NIKON\DSCN0883.JPG
[29/09/2012 23:43|--a------|2319755] G:\DCIM\103NIKON\DSCN0884.JPG
[29/09/2012 23:43|--a------|2395749] G:\DCIM\103NIKON\DSCN0885.JPG
[29/09/2012 23:43|--a------|2310375] G:\DCIM\103NIKON\DSCN0886.JPG
[29/09/2012 23:43|--a------|2257600] G:\DCIM\103NIKON\DSCN0887.JPG
[29/09/2012 23:43|--a------|2265072] G:\DCIM\103NIKON\DSCN0888.JPG
[29/09/2012 23:44|--a------|2453878] G:\DCIM\103NIKON\DSCN0889.JPG
[29/09/2012 23:44|--a------|2480480] G:\DCIM\103NIKON\DSCN0890.JPG
[29/09/2012 23:44|--a------|2513760] G:\DCIM\103NIKON\DSCN0891.JPG
[29/09/2012 23:45|--a------|2585874] G:\DCIM\103NIKON\DSCN0892.JPG
[29/09/2012 23:45|--a------|2472232] G:\DCIM\103NIKON\DSCN0893.JPG
[29/09/2012 23:45|--a------|2548473] G:\DCIM\103NIKON\DSCN0894.JPG
[29/09/2012 23:45|--a------|2446163] G:\DCIM\103NIKON\DSCN0895.JPG
[30/09/2012 00:21|--a------|2491559] G:\DCIM\103NIKON\DSCN0896.JPG
[13/07/2013 14:45|--a------|2729348] G:\DCIM\103NIKON\DSCN0985.JPG
[13/07/2013 14:45|--a------|2673700] G:\DCIM\103NIKON\DSCN0986.JPG
[13/07/2013 14:46|--a------|2667430] G:\DCIM\103NIKON\DSCN0987.JPG
[13/07/2013 14:46|--a------|2651985] G:\DCIM\103NIKON\DSCN0988.JPG
[13/07/2013 14:46|--a------|2678580] G:\DCIM\103NIKON\DSCN0989.JPG
[13/07/2013 14:46|--a------|2651857] G:\DCIM\103NIKON\DSCN0990.JPG
[13/07/2013 14:50|--a------|2398995] G:\DCIM\103NIKON\DSCN0991.JPG
[13/07/2013 14:50|--a------|2476204] G:\DCIM\103NIKON\DSCN0992.JPG
[13/07/2013 14:50|--a------|2549490] G:\DCIM\103NIKON\DSCN0993.JPG
[13/07/2013 14:51|--a------|2445532] G:\DCIM\103NIKON\DSCN0994.JPG
[13/07/2013 14:51|--a------|2453335] G:\DCIM\103NIKON\DSCN0995.JPG
[13/07/2013 14:51|--a------|2414521] G:\DCIM\103NIKON\DSCN0996.JPG
[13/07/2013 14:52|--a------|2420836] G:\DCIM\103NIKON\DSCN0997.JPG
[13/07/2013 14:52|--a------|2374309] G:\DCIM\103NIKON\DSCN0998.JPG
[12/07/2013 17:10|--a------|2544687] G:\DCIM\103NIKON\DSCN0951.JPG
[12/07/2013 17:10|--a------|2571209] G:\DCIM\103NIKON\DSCN0952.JPG
[13/07/2013 14:54|--a------|2449042] G:\DCIM\103NIKON\DSCN0999.JPG
[13/07/2013 14:54|--a------|2416858] G:\DCIM\103NIKON\DSCN1000.JPG
[13/07/2013 14:55|--a------|2415519] G:\DCIM\103NIKON\DSCN1001.JPG
[13/07/2013 14:56|--a------|2446893] G:\DCIM\103NIKON\DSCN1002.JPG
[13/07/2013 14:57|--a------|2407402] G:\DCIM\103NIKON\DSCN1003.JPG
[13/07/2013 15:06|--a------|2423977] G:\DCIM\103NIKON\DSCN1004.JPG
[13/07/2013 15:06|--a------|2427753] G:\DCIM\103NIKON\DSCN1005.JPG
[13/07/2013 15:07|--a------|2405018] G:\DCIM\103NIKON\DSCN1006.JPG
[13/07/2013 15:07|--a------|2423571] G:\DCIM\103NIKON\DSCN1007.JPG
[22/08/2013 09:59|--a------|2483591] G:\DCIM\103NIKON\DSCN0757.JPG
[13/07/2013 15:08|--a------|2440617] G:\DCIM\104NIKON\DSCN1008.JPG
[13/07/2013 15:08|--a------|2408023] G:\DCIM\104NIKON\DSCN1009.JPG
[13/07/2013 15:08|--a------|2446170] G:\DCIM\104NIKON\DSCN1010.JPG
[13/07/2013 15:40|--a------|2518534] G:\DCIM\104NIKON\DSCN1011.JPG
[13/07/2013 16:27|--a------|2469069] G:\DCIM\104NIKON\DSCN1012.JPG
[13/07/2013 16:27|--a------|2475246] G:\DCIM\104NIKON\DSCN1013.JPG
[13/07/2013 16:27|--a------|2497132] G:\DCIM\104NIKON\DSCN1014.JPG
[13/07/2013 16:35|--a------|2488860] G:\DCIM\104NIKON\DSCN1015.JPG
[13/07/2013 16:35|--a------|2534707] G:\DCIM\104NIKON\DSCN1016.JPG
[13/07/2013 18:13|--a------|2534845] G:\DCIM\104NIKON\DSCN1017.JPG
[13/07/2013 18:14|--a------|2532542] G:\DCIM\104NIKON\DSCN1018.JPG
[13/07/2013 19:10|--a------|2535552] G:\DCIM\104NIKON\DSCN1019.JPG
[13/07/2013 19:11|--a------|2436185] G:\DCIM\104NIKON\DSCN1020.JPG
[13/07/2013 19:11|--a------|2414901] G:\DCIM\104NIKON\DSCN1021.JPG
[13/07/2013 19:11|--a------|2428365] G:\DCIM\104NIKON\DSCN1022.JPG
[13/07/2013 19:12|--a------|2427133] G:\DCIM\104NIKON\DSCN1023.JPG
[13/07/2013 19:12|--a------|2414785] G:\DCIM\104NIKON\DSCN1024.JPG
[13/07/2013 19:13|--a------|2447084] G:\DCIM\104NIKON\DSCN1025.JPG
[13/07/2013 19:13|--a------|2454542] G:\DCIM\104NIKON\DSCN1026.JPG
[13/07/2013 19:14|--a------|2443817] G:\DCIM\104NIKON\DSCN1027.JPG
[13/07/2013 19:14|--a------|2463837] G:\DCIM\104NIKON\DSCN1028.JPG
[13/07/2013 19:15|--a------|2447889] G:\DCIM\104NIKON\DSCN1029.JPG
[13/07/2013 19:15|--a------|2444964] G:\DCIM\104NIKON\DSCN1030.JPG
[13/07/2013 19:16|--a------|2470147] G:\DCIM\104NIKON\DSCN1031.JPG
[13/07/2013 19:16|--a------|2435966] G:\DCIM\104NIKON\DSCN1032.JPG
[13/07/2013 19:16|--a------|2475474] G:\DCIM\104NIKON\DSCN1033.JPG
[13/07/2013 19:16|--a------|2489562] G:\DCIM\104NIKON\DSCN1034.JPG
[13/07/2013 19:16|--a------|2450316] G:\DCIM\104NIKON\DSCN1035.JPG
[13/07/2013 19:17|--a------|2758758] G:\DCIM\104NIKON\DSCN1036.JPG
[13/07/2013 19:17|--a------|2782574] G:\DCIM\104NIKON\DSCN1037.JPG
[13/07/2013 19:20|--a------|2469973] G:\DCIM\104NIKON\DSCN1038.JPG
[13/07/2013 19:20|--a------|2456256] G:\DCIM\104NIKON\DSCN1039.JPG
[13/07/2013 19:21|--a------|2484153] G:\DCIM\104NIKON\DSCN1040.JPG
[13/07/2013 19:21|--a------|2474168] G:\DCIM\104NIKON\DSCN1041.JPG
[13/07/2013 19:22|--a------|2610880] G:\DCIM\104NIKON\DSCN1042.JPG
[13/07/2013 19:22|--a------|2624037] G:\DCIM\104NIKON\DSCN1043.JPG
[13/07/2013 19:23|--a------|2711400] G:\DCIM\104NIKON\DSCN1044.JPG
[13/07/2013 19:24|--a------|2661308] G:\DCIM\104NIKON\DSCN1045.JPG
[13/07/2013 19:24|--a------|2669381] G:\DCIM\104NIKON\DSCN1046.JPG
[13/07/2013 19:24|--a------|2670151] G:\DCIM\104NIKON\DSCN1047.JPG
[13/07/2013 19:25|--a------|2664136] G:\DCIM\104NIKON\DSCN1048.JPG
[13/07/2013 19:25|--a------|2677916] G:\DCIM\104NIKON\DSCN1049.JPG
[13/07/2013 19:25|--a------|2675412] G:\DCIM\104NIKON\DSCN1050.JPG
[13/07/2013 19:26|--a------|2634702] G:\DCIM\104NIKON\DSCN1051.JPG
[13/07/2013 19:27|--a------|2725269] G:\DCIM\104NIKON\DSCN1052.JPG
[13/07/2013 19:27|--a------|2677168] G:\DCIM\104NIKON\DSCN1053.JPG
[13/07/2013 19:28|--a------|2698409] G:\DCIM\104NIKON\DSCN1054.JPG
[13/07/2013 19:28|--a------|2645697] G:\DCIM\104NIKON\DSCN1055.JPG
[13/07/2013 19:28|--a------|2647013] G:\DCIM\104NIKON\DSCN1056.JPG
[13/07/2013 19:29|--a------|2705380] G:\DCIM\104NIKON\DSCN1057.JPG
[13/07/2013 19:29|--a------|2745218] G:\DCIM\104NIKON\DSCN1058.JPG
[13/07/2013 19:29|--a------|2734135] G:\DCIM\104NIKON\DSCN1059.JPG
[13/07/2013 19:31|--a------|2654107] G:\DCIM\104NIKON\DSCN1060.JPG
[13/07/2013 19:31|--a------|2659977] G:\DCIM\104NIKON\DSCN1061.JPG
[13/07/2013 19:32|--a------|2699407] G:\DCIM\104NIKON\DSCN1062.JPG
[13/07/2013 19:32|--a------|2750433] G:\DCIM\104NIKON\DSCN1063.JPG
[13/07/2013 19:32|--a------|2684585] G:\DCIM\104NIKON\DSCN1064.JPG
[13/07/2013 19:32|--a------|2735809] G:\DCIM\104NIKON\DSCN1065.JPG
[13/07/2013 19:38|--a------|2711970] G:\DCIM\104NIKON\DSCN1066.JPG
[13/07/2013 19:38|--a------|2706686] G:\DCIM\104NIKON\DSCN1067.JPG
[13/07/2013 19:38|--a------|2671082] G:\DCIM\104NIKON\DSCN1068.JPG
[13/07/2013 20:51|--a------|2471763] G:\DCIM\104NIKON\DSCN1069.JPG
[13/07/2013 21:00|--a------|2502864] G:\DCIM\104NIKON\DSCN1070.JPG
[13/07/2013 21:00|--a------|2544150] G:\DCIM\104NIKON\DSCN1071.JPG
[13/07/2013 21:00|--a------|2556820] G:\DCIM\104NIKON\DSCN1072.JPG
[13/07/2013 21:00|--a------|2493275] G:\DCIM\104NIKON\DSCN1073.JPG
[13/07/2013 21:00|--a------|2444446] G:\DCIM\104NIKON\DSCN1074.JPG
[13/07/2013 21:00|--a------|2495883] G:\DCIM\104NIKON\DSCN1075.JPG
[14/07/2013 00:06|--a------|2702406] G:\DCIM\104NIKON\DSCN1076.JPG
[14/07/2013 00:06|--a------|2669000] G:\DCIM\104NIKON\DSCN1077.JPG
[14/07/2013 00:06|--a------|2681790] G:\DCIM\104NIKON\DSCN1078.JPG
[14/07/2013 00:06|--a------|2602032] G:\DCIM\104NIKON\DSCN1079.JPG
[14/07/2013 00:06|--a------|2638747] G:\DCIM\104NIKON\DSCN1080.JPG
[20/07/2013 14:49|--a------|2492554] G:\DCIM\104NIKON\DSCN1081.JPG
[20/07/2013 14:49|--a------|2489043] G:\DCIM\104NIKON\DSCN1082.JPG
[20/07/2013 14:49|--a------|2699185] G:\DCIM\104NIKON\DSCN1083.JPG
[20/07/2013 14:49|--a------|2717876] G:\DCIM\104NIKON\DSCN1084.JPG
[20/07/2013 14:52|--a------|2548371] G:\DCIM\104NIKON\DSCN1085.JPG
[20/07/2013 14:52|--a------|2564172] G:\DCIM\104NIKON\DSCN1086.JPG
[20/07/2013 14:56|--a------|2530500] G:\DCIM\104NIKON\DSCN1087.JPG
[20/07/2013 14:56|--a------|2469129] G:\DCIM\104NIKON\DSCN1088.JPG
[20/07/2013 15:00|--a------|2442437] G:\DCIM\104NIKON\DSCN1089.JPG
[20/07/2013 15:01|--a------|2604091] G:\DCIM\104NIKON\DSCN1090.JPG
[20/07/2013 15:33|--a------|2765963] G:\DCIM\104NIKON\DSCN1091.JPG
[20/07/2013 15:33|--a------|2617251] G:\DCIM\104NIKON\DSCN1092.JPG
[20/07/2013 15:33|--a------|2774048] G:\DCIM\104NIKON\DSCN1093.JPG
[20/07/2013 17:48|--a------|2653842] G:\DCIM\104NIKON\DSCN1094.JPG
[20/07/2013 17:48|--a------|2622389] G:\DCIM\104NIKON\DSCN1095.JPG
[20/07/2013 17:49|--a------|2619701] G:\DCIM\104NIKON\DSCN1096.JPG
[20/07/2013 17:49|--a------|2746227] G:\DCIM\104NIKON\DSCN1097.JPG
[20/07/2013 17:49|--a------|2590813] G:\DCIM\104NIKON\DSCN1098.JPG
[20/07/2013 18:02|--a------|2431178] G:\DCIM\104NIKON\DSCN1099.JPG
[20/07/2013 18:02|--a------|2471878] G:\DCIM\104NIKON\DSCN1100.JPG
[20/07/2013 18:03|--a------|2770043] G:\DCIM\104NIKON\DSCN1101.JPG
[20/07/2013 18:03|--a------|2707398] G:\DCIM\104NIKON\DSCN1102.JPG
[20/07/2013 18:04|--a------|2614723] G:\DCIM\104NIKON\DSCN1103.JPG
[04/08/2013 12:15|--a------|2312666] G:\DCIM\104NIKON\DSCN1104.JPG
[04/08/2013 12:15|--a------|2328351] G:\DCIM\104NIKON\DSCN1105.JPG
[04/08/2013 12:17|--a------|2350886] G:\DCIM\104NIKON\DSCN1106.JPG
[04/08/2013 12:24|--a------|2727254] G:\DCIM\104NIKON\DSCN1107.JPG
[04/08/2013 12:24|--a------|2560727] G:\DCIM\104NIKON\DSCN1108.JPG
[04/08/2013 12:24|--a------|2580555] G:\DCIM\104NIKON\DSCN1109.JPG
[04/08/2013 12:24|--a------|2547510] G:\DCIM\104NIKON\DSCN1110.JPG
[04/08/2013 12:24|--a------|2480038] G:\DCIM\104NIKON\DSCN1111.JPG
[10/08/2013 12:44|--a------|2717788] G:\DCIM\104NIKON\DSCN1112.JPG
[10/08/2013 12:45|--a------|2767534] G:\DCIM\104NIKON\DSCN1113.JPG
[10/08/2013 12:45|--a------|2705313] G:\DCIM\104NIKON\DSCN1114.JPG
[10/08/2013 13:14|--a------|2701574] G:\DCIM\104NIKON\DSCN1115.JPG
[10/08/2013 13:14|--a------|2678583] G:\DCIM\104NIKON\DSCN1116.JPG
[10/08/2013 13:14|--a------|2686472] G:\DCIM\104NIKON\DSCN1117.JPG
[10/08/2013 13:14|--a------|2660846] G:\DCIM\104NIKON\DSCN1118.JPG
[10/08/2013 13:17|--a------|2634476] G:\DCIM\104NIKON\DSCN1119.JPG
[10/08/2013 13:17|--a------|2701311] G:\DCIM\104NIKON\DSCN1120.JPG
[10/08/2013 13:17|--a------|2726505] G:\DCIM\104NIKON\DSCN1121.JPG
[10/08/2013 13:17|--a------|2691650] G:\DCIM\104NIKON\DSCN1122.JPG
[10/08/2013 13:19|--a------|2566406] G:\DCIM\104NIKON\DSCN1123.JPG
[10/08/2013 13:19|--a------|2551394] G:\DCIM\104NIKON\DSCN1124.JPG
[10/08/2013 13:19|--a------|2502489] G:\DCIM\104NIKON\DSCN1125.JPG
[10/08/2013 13:19|--a------|2586469] G:\DCIM\104NIKON\DSCN1126.JPG
[10/08/2013 13:20|--a------|2540343] G:\DCIM\104NIKON\DSCN1127.JPG
[10/08/2013 13:36|--a------|2400654] G:\DCIM\104NIKON\DSCN1128.JPG
[10/08/2013 13:36|--a------|2710696] G:\DCIM\104NIKON\DSCN1129.JPG
[10/08/2013 13:36|--a------|2469265] G:\DCIM\104NIKON\DSCN1130.JPG
[10/08/2013 13:37|--a------|2655774] G:\DCIM\104NIKON\DSCN1131.JPG
[10/08/2013 13:37|--a------|2623714] G:\DCIM\104NIKON\DSCN1132.JPG
[10/08/2013 14:29|--a------|2480582] G:\DCIM\104NIKON\DSCN1133.JPG
[10/08/2013 14:29|--a------|2552163] G:\DCIM\104NIKON\DSCN1134.JPG
[10/08/2013 14:29|--a------|2443016] G:\DCIM\104NIKON\DSCN1135.JPG
[10/08/2013 14:30|--a------|2465251] G:\DCIM\104NIKON\DSCN1136.JPG
[10/08/2013 14:30|--a------|2536039] G:\DCIM\104NIKON\DSCN1137.JPG
[10/08/2013 14:30|--a------|2476838] G:\DCIM\104NIKON\DSCN1138.JPG
[10/08/2013 14:30|--a------|2411357] G:\DCIM\104NIKON\DSCN1139.JPG
[10/08/2013 14:30|--a------|2522323] G:\DCIM\104NIKON\DSCN1140.JPG
[10/08/2013 14:30|--a------|2521189] G:\DCIM\104NIKON\DSCN1141.JPG
[10/08/2013 14:31|--a------|2516010] G:\DCIM\104NIKON\DSCN1142.JPG
[10/08/2013 14:31|--a------|2511243] G:\DCIM\104NIKON\DSCN1143.JPG
[10/08/2013 14:31|--a------|2527676] G:\DCIM\104NIKON\DSCN1144.JPG
[10/08/2013 14:31|--a------|2513929] G:\DCIM\104NIKON\DSCN1145.JPG
[10/08/2013 14:32|--a------|2526479] G:\DCIM\104NIKON\DSCN1146.JPG
[10/08/2013 14:32|--a------|2536052] G:\DCIM\104NIKON\DSCN1147.JPG
[10/08/2013 14:32|--a------|2502248] G:\DCIM\104NIKON\DSCN1148.JPG
[10/08/2013 14:32|--a------|2414286] G:\DCIM\104NIKON\DSCN1149.JPG
[10/08/2013 14:32|--a------|2452361] G:\DCIM\104NIKON\DSCN1150.JPG
[10/08/2013 14:33|--a------|2485559] G:\DCIM\104NIKON\DSCN1151.JPG
[10/08/2013 14:34|--a------|2382115] G:\DCIM\104NIKON\DSCN1152.JPG
[10/08/2013 14:34|--a------|2371098] G:\DCIM\104NIKON\DSCN1153.JPG
[10/08/2013 14:38|--a------|2739146] G:\DCIM\104NIKON\DSCN1154.JPG
[10/08/2013 14:38|--a------|2465591] G:\DCIM\104NIKON\DSCN1155.JPG
[10/08/2013 14:38|--a------|2723458] G:\DCIM\104NIKON\DSCN1156.JPG
[10/08/2013 15:59|--a------|2537695] G:\DCIM\104NIKON\DSCN1157.JPG
[10/08/2013 16:00|--a------|2661038] G:\DCIM\104NIKON\DSCN1158.JPG
[10/08/2013 16:00|--a------|2723056] G:\DCIM\104NIKON\DSCN1159.JPG
[10/08/2013 16:02|--a------|2708027] G:\DCIM\104NIKON\DSCN1160.JPG
[10/08/2013 16:02|--a------|2684871] G:\DCIM\104NIKON\DSCN1161.JPG
[10/08/2013 16:50|--a------|2496821] G:\DCIM\104NIKON\DSCN1162.JPG
[10/08/2013 16:50|--a------|2498728] G:\DCIM\104NIKON\DSCN1163.JPG
[10/08/2013 16:50|--a------|2479050] G:\DCIM\104NIKON\DSCN1164.JPG
[10/08/2013 16:50|--a------|2476646] G:\DCIM\104NIKON\DSCN1165.JPG
[10/08/2013 17:32|--a------|2692441] G:\DCIM\104NIKON\DSCN1166.JPG
[10/08/2013 17:32|--a------|2471030] G:\DCIM\104NIKON\DSCN1167.JPG
[11/08/2013 11:42|--a------|2497860] G:\DCIM\104NIKON\DSCN1168.JPG
[11/08/2013 11:42|--a------|2545514] G:\DCIM\104NIKON\DSCN1169.JPG
[11/08/2013 11:42|--a------|2535511] G:\DCIM\104NIKON\DSCN1170.JPG
[11/08/2013 11:43|--a------|2704478] G:\DCIM\104NIKON\DSCN1171.JPG
[11/08/2013 11:43|--a------|2625678] G:\DCIM\104NIKON\DSCN1172.JPG
[11/08/2013 12:10|--a------|2590263] G:\DCIM\104NIKON\DSCN1173.JPG
[11/08/2013 12:10|--a------|2545353] G:\DCIM\104NIKON\DSCN1174.JPG
[11/08/2013 12:10|--a------|2598945] G:\DCIM\104NIKON\DSCN1175.JPG
[11/08/2013 12:20|--a------|2699310] G:\DCIM\104NIKON\DSCN1176.JPG
[11/08/2013 12:20|--a------|2716543] G:\DCIM\104NIKON\DSCN1177.JPG
[11/08/2013 12:21|--a------|2578664] G:\DCIM\104NIKON\DSCN1178.JPG
[11/08/2013 12:21|--a------|2591278] G:\DCIM\104NIKON\DSCN1179.JPG
[11/08/2013 12:53|--a------|2738563] G:\DCIM\104NIKON\DSCN1180.JPG
[11/08/2013 12:53|--a------|2782768] G:\DCIM\104NIKON\DSCN1181.JPG
[11/08/2013 12:53|--a------|2675582] G:\DCIM\104NIKON\DSCN1182.JPG
[11/08/2013 12:53|--a------|2684008] G:\DCIM\104NIKON\DSCN1183.JPG
[11/08/2013 12:53|--a------|2630834] G:\DCIM\104NIKON\DSCN1184.JPG
[11/08/2013 12:56|--a------|2477242] G:\DCIM\104NIKON\DSCN1185.JPG
[11/08/2013 12:56|--a------|2412375] G:\DCIM\104NIKON\DSCN1186.JPG
[11/08/2013 12:56|--a------|2415451] G:\DCIM\104NIKON\DSCN1187.JPG
[11/08/2013 14:29|--a------|2496553] G:\DCIM\104NIKON\DSCN1188.JPG
[11/08/2013 14:29|--a------|2517350] G:\DCIM\104NIKON\DSCN1189.JPG
[11/08/2013 14:29|--a------|2406384] G:\DCIM\104NIKON\DSCN1190.JPG
[11/08/2013 14:30|--a------|2479746] G:\DCIM\104NIKON\DSCN1191.JPG
[11/08/2013 14:45|--a------|2506291] G:\DCIM\104NIKON\DSCN1192.JPG
[11/08/2013 14:45|--a------|2471310] G:\DCIM\104NIKON\DSCN1193.JPG
[11/08/2013 14:45|--a------|2448861] G:\DCIM\104NIKON\DSCN1194.JPG
[11/08/2013 14:45|--a------|2426332] G:\DCIM\104NIKON\DSCN1195.JPG
[11/08/2013 14:45|--a------|2470385] G:\DCIM\104NIKON\DSCN1196.JPG
[11/08/2013 14:45|--a------|2485248] G:\DCIM\104NIKON\DSCN1197.JPG
[11/08/2013 14:45|--a------|2486353] G:\DCIM\104NIKON\DSCN1198.JPG
[11/08/2013 14:45|--a------|2536359] G:\DCIM\104NIKON\DSCN1199.JPG
[11/08/2013 14:45|--a------|2521910] G:\DCIM\104NIKON\DSCN1200.JPG
[11/08/2013 14:46|--a------|2475995] G:\DCIM\104NIKON\DSCN1201.JPG
[11/08/2013 17:58|--a------|2537807] G:\DCIM\104NIKON\DSCN1202.JPG
[11/08/2013 17:58|--a------|2540116] G:\DCIM\104NIKON\DSCN1203.JPG
[11/08/2013 17:58|--a------|2465730] G:\DCIM\104NIKON\DSCN1204.JPG
[11/08/2013 17:58|--a------|2436826] G:\DCIM\104NIKON\DSCN1205.JPG
[11/08/2013 17:58|--a------|2563172] G:\DCIM\104NIKON\DSCN1206.JPG
[11/08/2013 17:58|--a------|2487494] G:\DCIM\104NIKON\DSCN1207.JPG
[11/08/2013 17:59|--a------|2490419] G:\DCIM\105NIKON\DSCN1208.JPG
[11/08/2013 17:59|--a------|2531686] G:\DCIM\105NIKON\DSCN1209.JPG
[11/08/2013 17:59|--a------|2453459] G:\DCIM\105NIKON\DSCN1210.JPG
[11/08/2013 17:59|--a------|2503221] G:\DCIM\105NIKON\DSCN1212.JPG
[11/08/2013 18:05|--a------|2522975] G:\DCIM\105NIKON\DSCN1214.JPG
[11/08/2013 18:06|--a------|2567404] G:\DCIM\105NIKON\DSCN1215.JPG
[11/08/2013 21:07|--a------|2737983] G:\DCIM\105NIKON\DSCN1217.JPG
[11/08/2013 21:07|--a------|2636702] G:\DCIM\105NIKON\DSCN1219.JPG
[11/08/2013 21:08|--a------|2710458] G:\DCIM\105NIKON\DSCN1222.JPG
[11/08/2013 21:08|--a------|2715432] G:\DCIM\105NIKON\DSCN1223.JPG
[11/08/2013 21:08|--a------|2721746] G:\DCIM\105NIKON\DSCN1224.JPG
[11/08/2013 21:08|--a------|2743332] G:\DCIM\105NIKON\DSCN1225.JPG
[11/08/2013 21:09|--a------|2718683] G:\DCIM\105NIKON\DSCN1226.JPG
[11/08/2013 21:10|--a------|2744104] G:\DCIM\105NIKON\DSCN1227.JPG
[11/08/2013 21:10|--a------|2690326] G:\DCIM\105NIKON\DSCN1228.JPG
[11/08/2013 21:10|--a------|2743398] G:\DCIM\105NIKON\DSCN1229.JPG
[11/08/2013 21:10|--a------|2635380] G:\DCIM\105NIKON\DSCN1230.JPG
[11/08/2013 21:10|--a------|2700736] G:\DCIM\105NIKON\DSCN1231.JPG
[11/08/2013 21:10|--a------|2693679] G:\DCIM\105NIKON\DSCN1232.JPG
[11/08/2013 21:11|--a------|2699226] G:\DCIM\105NIKON\DSCN1233.JPG
[11/08/2013 21:11|--a------|2693447] G:\DCIM\105NIKON\DSCN1234.JPG
[11/08/2013 21:11|--a------|2727445] G:\DCIM\105NIKON\DSCN1235.JPG
[11/08/2013 21:11|--a------|2731592] G:\DCIM\105NIKON\DSCN1236.JPG
[11/08/2013 21:11|--a------|2703368] G:\DCIM\105NIKON\DSCN1237.JPG
[11/08/2013 21:26|--a------|2640768] G:\DCIM\105NIKON\DSCN1238.JPG
[11/08/2013 21:27|--a------|2617533] G:\DCIM\105NIKON\DSCN1239.JPG
[11/08/2013 21:27|--a------|2748699] G:\DCIM\105NIKON\DSCN1240.JPG
[11/08/2013 21:27|--a------|2623640] G:\DCIM\105NIKON\DSCN1241.JPG
[11/08/2013 21:27|--a------|2679702] G:\DCIM\105NIKON\DSCN1242.JPG
[11/08/2013 21:27|--a------|2684346] G:\DCIM\105NIKON\DSCN1243.JPG
[11/08/2013 21:27|--a------|2657194] G:\DCIM\105NIKON\DSCN1244.JPG
[11/08/2013 21:28|--a------|2687945] G:\DCIM\105NIKON\DSCN1245.JPG
[11/08/2013 21:28|--a------|2637247] G:\DCIM\105NIKON\DSCN1246.JPG
[11/08/2013 21:28|--a------|2647799] G:\DCIM\105NIKON\DSCN1247.JPG
[11/08/2013 21:28|--a------|2722792] G:\DCIM\105NIKON\DSCN1248.JPG
[11/08/2013 21:28|--a------|2763104] G:\DCIM\105NIKON\DSCN1249.JPG
[11/08/2013 21:28|--a------|2618415] G:\DCIM\105NIKON\DSCN1250.JPG
[11/08/2013 21:29|--a------|2683534] G:\DCIM\105NIKON\DSCN1251.JPG
[11/08/2013 21:29|--a------|2681315] G:\DCIM\105NIKON\DSCN1252.JPG
[11/08/2013 21:31|--a------|2707174] G:\DCIM\105NIKON\DSCN1253.JPG
[11/08/2013 21:31|--a------|2716488] G:\DCIM\105NIKON\DSCN1254.JPG
[11/08/2013 21:31|--a------|2664016] G:\DCIM\105NIKON\DSCN1255.JPG
[11/08/2013 21:31|--a------|2643233] G:\DCIM\105NIKON\DSCN1256.JPG
[11/08/2013 21:32|--a------|2715567] G:\DCIM\105NIKON\DSCN1257.JPG
[11/08/2013 21:32|--a------|2698819] G:\DCIM\105NIKON\DSCN1258.JPG
[11/08/2013 21:32|--a------|2729917] G:\DCIM\105NIKON\DSCN1259.JPG
[11/08/2013 21:32|--a------|2719847] G:\DCIM\105NIKON\DSCN1260.JPG
[11/08/2013 21:33|--a------|2718515] G:\DCIM\105NIKON\DSCN1261.JPG
[11/08/2013 21:34|--a------|2668900] G:\DCIM\105NIKON\DSCN1262.JPG
[11/08/2013 21:34|--a------|2420373] G:\DCIM\105NIKON\DSCN1263.JPG
[11/08/2013 21:34|--a------|2539406] G:\DCIM\105NIKON\DSCN1264.JPG
[11/08/2013 21:35|--a------|2483970] G:\DCIM\105NIKON\DSCN1265.JPG
[11/08/2013 21:36|--a------|2503089] G:\DCIM\105NIKON\DSCN1266.JPG
[11/08/2013 21:36|--a------|2531335] G:\DCIM\105NIKON\DSCN1267.JPG
[11/08/2013 21:36|--a------|2563965] G:\DCIM\105NIKON\DSCN1268.JPG
[11/08/2013 21:36|--a------|2527692] G:\DCIM\105NIKON\DSCN1269.JPG
[11/08/2013 21:37|--a------|2578934] G:\DCIM\105NIKON\DSCN1270.JPG
[11/08/2013 21:37|--a------|2508647] G:\DCIM\105NIKON\DSCN1271.JPG
[11/08/2013 22:07|--a------|2716895] G:\DCIM\105NIKON\DSCN1272.JPG
[11/08/2013 22:07|--a------|2693367] G:\DCIM\105NIKON\DSCN1273.JPG
[11/08/2013 22:07|--a------|2704907] G:\DCIM\105NIKON\DSCN1274.JPG
[11/08/2013 22:09|--a------|2500487] G:\DCIM\105NIKON\DSCN1275.JPG
[11/08/2013 22:09|--a------|2544737] G:\DCIM\105NIKON\DSCN1276.JPG
[11/08/2013 22:15|--a------|2481095] G:\DCIM\105NIKON\DSCN1277.JPG
[11/08/2013 22:15|--a------|2408783] G:\DCIM\105NIKON\DSCN1278.JPG
[11/08/2013 22:16|--a------|2520098] G:\DCIM\105NIKON\DSCN1279.JPG
[11/08/2013 22:16|--a------|2575130] G:\DCIM\105NIKON\DSCN1280.JPG
[11/08/2013 22:17|--a------|2448936] G:\DCIM\105NIKON\DSCN1281.JPG
[11/08/2013 22:17|--a------|2496956] G:\DCIM\105NIKON\DSCN1282.JPG
[11/08/2013 22:18|--a------|2450753] G:\DCIM\105NIKON\DSCN1283.JPG
[13/08/2013 21:19|--a------|2573984] G:\DCIM\105NIKON\DSCN1284.JPG
[13/08/2013 21:19|--a------|2571747] G:\DCIM\105NIKON\DSCN1285.JPG
[13/08/2013 21:19|--a------|2588028] G:\DCIM\105NIKON\DSCN1286.JPG
[13/08/2013 21:19|--a------|2522285] G:\DCIM\105NIKON\DSCN1287.JPG
[13/08/2013 21:19|--a------|2424016] G:\DCIM\105NIKON\DSCN1288.JPG
[13/08/2013 21:19|--a------|2482458] G:\DCIM\105NIKON\DSCN1289.JPG
[27/10/2013 11:12|--a------|2473357] G:\DCIM\105NIKON\DSCN1290.JPG
[27/10/2013 11:18|--a------|2395628] G:\DCIM\105NIKON\DSCN1291.JPG
[27/10/2013 11:18|--a------|2430081] G:\DCIM\105NIKON\DSCN1292.JPG
[27/10/2013 11:19|--a------|2523802] G:\DCIM\105NIKON\DSCN1293.JPG
[27/10/2013 11:19|--a------|2404885] G:\DCIM\105NIKON\DSCN1294.JPG
[27/10/2013 12:32|--a------|2540143] G:\DCIM\105NIKON\DSCN1297.JPG
[27/10/2013 12:32|--a------|2531078] G:\DCIM\105NIKON\DSCN1298.JPG
[27/10/2013 12:33|--a------|2538901] G:\DCIM\105NIKON\DSCN1299.JPG
[27/10/2013 12:35|--a------|2505800] G:\DCIM\105NIKON\DSCN1301.JPG
[27/10/2013 12:36|--a------|2522425] G:\DCIM\105NIKON\DSCN1302.JPG
[27/10/2013 13:12|--a------|2693882] G:\DCIM\105NIKON\DSCN1303.JPG
[27/10/2013 13:12|--a------|2675152] G:\DCIM\105NIKON\DSCN1304.JPG
[27/10/2013 13:12|--a------|2695335] G:\DCIM\105NIKON\DSCN1305.JPG
[27/10/2013 13:14|--a------|2588125] G:\DCIM\105NIKON\DSCN1306.JPG
[27/10/2013 13:14|--a------|2541730] G:\DCIM\105NIKON\DSCN1307.JPG
[27/10/2013 13:14|--a------|2485549] G:\DCIM\105NIKON\DSCN1308.JPG
[27/10/2013 13:24|--a------|2502619] G:\DCIM\105NIKON\DSCN1309.JPG
[27/10/2013 13:24|--a------|2514169] G:\DCIM\105NIKON\DSCN1311.JPG
[27/10/2013 13:24|--a------|2485603] G:\DCIM\105NIKON\DSCN1312.JPG
[27/10/2013 13:26|--a------|2474825] G:\DCIM\105NIKON\DSCN1313.JPG
[27/10/2013 13:26|--a------|2536752] G:\DCIM\105NIKON\DSCN1314.JPG
[27/10/2013 13:27|--a------|2716373] G:\DCIM\105NIKON\DSCN1315.JPG
[27/10/2013 13:27|--a------|2679735] G:\DCIM\105NIKON\DSCN1316.JPG
[27/10/2013 13:27|--a------|2696307] G:\DCIM\105NIKON\DSCN1317.JPG
[27/10/2013 13:28|--a------|2699990] G:\DCIM\105NIKON\DSCN1318.JPG
[27/10/2013 13:28|--a------|2735576] G:\DCIM\105NIKON\DSCN1319.JPG
[27/10/2013 13:28|--a------|2684327] G:\DCIM\105NIKON\DSCN1320.JPG
[27/10/2013 13:28|--a------|2713861] G:\DCIM\105NIKON\DSCN1321.JPG
[27/10/2013 13:28|--a------|2711616] G:\DCIM\105NIKON\DSCN1322.JPG
[27/10/2013 15:00|--a------|2635380] G:\DCIM\105NIKON\DSCN1323.JPG
[27/10/2013 22:22|--a------|2462106] G:\DCIM\105NIKON\DSCN1324.JPG
[27/10/2013 22:23|--a------|2520718] G:\DCIM\105NIKON\DSCN1325.JPG
[27/10/2013 22:24|--a------|2483128] G:\DCIM\105NIKON\DSCN1326.JPG
[27/10/2013 22:28|--a------|2505753] G:\DCIM\105NIKON\DSCN1327.JPG
[27/10/2013 22:45|--a------|2752051] G:\DCIM\105NIKON\DSCN1328.JPG
[02/11/2013 17:10|--a------|2451860] G:\DCIM\105NIKON\DSCN1295.JPG
[02/11/2013 17:10|--a------|2499886] G:\DCIM\105NIKON\DSCN1296.JPG
[02/11/2013 17:11|--a------|2483202] G:\DCIM\105NIKON\DSCN1300.JPG
[02/11/2013 17:12|--a------|2484951] G:\DCIM\105NIKON\DSCN1310.JPG
[02/11/2013 17:15|--a------|2725475] G:\DCIM\105NIKON\DSCN1329.JPG
[02/11/2013 17:16|--a------|2595544] G:\DCIM\105NIKON\DSCN1330.JPG
[02/11/2013 17:16|--a------|2405989] G:\DCIM\105NIKON\DSCN1211.JPG
[02/11/2013 17:16|--a------|2498232] G:\DCIM\105NIKON\DSCN1213.JPG
[02/11/2013 17:17|--a------|2682028] G:\DCIM\105NIKON\DSCN1216.JPG
[02/11/2013 17:18|--a------|2656416] G:\DCIM\105NIKON\DSCN1218.JPG
[02/11/2013 17:18|--a------|2616356] G:\DCIM\105NIKON\DSCN1220.JPG
[02/11/2013 17:18|--a------|2672974] G:\DCIM\105NIKON\DSCN1221.JPG
[27/10/2013 22:46|--a------|93889] G:\NCFL\SORLST.LST
[||] G:\Autorun.inf\lpt1.UsbFix
#14844
merci beaucoup, ma carte refonctionne et j'ai bien recuperé mes fichiers
Désinstalle UsbFix et supprime le fichier .bat .
Nous en avons donc terminé , tu vas pouvoir passer ton sujet en résolu.
T'apprécies SosVirus ? Fais nous connaitre dans ton entourage !
[pagefan][/pagefan]
Bonne fin de semaine :)
