Supprimer aartemis.com Réparation PC
#15244
Hello :hello: ,
drivers32
%APPDATA%\*.
%APPDATA%\*.exe /s
%temp%\*.exe /s
%SYSTEMDRIVE%\*.exe
%systemroot%\*. /mp /s
services.exe
SAVEMBR:0
  • Clique sur Analyse
  • Héberge les rapports OTL.txt et Extras.txt sur Sosupload, puis copie/colle le lien fourni dans ta prochaine réponse sur le forum
#15307
Hello :hello: ,
  • Relance OTL.
    :OTL
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = https://aartemis.com/?type=hp&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Search_URL = https://www.aartemis.com/web/?type=ds&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX&q={searchTerms}
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Search Page = https://www.aartemis.com/web/?type=ds&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX&q={searchTerms}
    IE - HKLM\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = https://aartemis.com/?type=hp&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX
    IE - HKU\.DEFAULT\..\SearchScopes\{47AE1BA9-0BD1-44F4-88AE-45F8F7B605EF}: "URL" = https://www.basicserve.com/?prt=BASICSERVE111&sp=&keywords={searchTerms}
    IE - HKU\S-1-5-18\..\SearchScopes\{47AE1BA9-0BD1-44F4-88AE-45F8F7B605EF}: "URL" = https://www.basicserve.com/?prt=BASICSERVE111&sp=&keywords={searchTerms}
    IE - HKU\S-1-5-21-1863099039-1387975201-1062880193-1000\SOFTWARE\Microsoft\Internet Explorer\Main,Default_Page_URL = https://aartemis.com/?type=hp&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX
    IE - HKU\S-1-5-21-1863099039-1387975201-1062880193-1000\SOFTWARE\Microsoft\Internet Explorer\Main,Start Page = https://aartemis.com/?type=hp&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX
    IE - HKU\S-1-5-21-1863099039-1387975201-1062880193-1000\..\URLSearchHook: {AEEC3B59-CA98-4EBA-A140-57B94E283583} - No CLSID value found
    FF - prefs.js..browser.search.defaultenginename: "aartemis"
    FF - prefs.js..browser.search.selectedEngine: "aartemis"
    [2013/11/07 20:11:02 | 000,000,566 | ---- | M] () -- C:\Program Files (x86)\mozilla firefox\searchplugins\aartemis.xml
    CHR - homepage: https://aartemis.com/?type=hp&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX
    :Commands
    [emptytemp]
    [emptyflash]
    [reboot]
  • Image
    1. Choisi l'option Scanner
    2. Choisi l'option Nettoyer
par Marion
#15475
voici les deux rapports:
All processes killed
========== OTL ==========
HKLM\SOFTWARE\Microsoft\Internet Explorer\Main\\Default_Page_URL| /E : value set successfully!
HKLM\SOFTWARE\Microsoft\Internet Explorer\Main\\Default_Search_URL| /E : value set successfully!
HKLM\SOFTWARE\Microsoft\Internet Explorer\Main\\Search Page| /E : value set successfully!
HKLM\SOFTWARE\Microsoft\Internet Explorer\Main\\Start Page| /E : value set successfully!
Registry key HKEY_USERS\.DEFAULT\Software\Microsoft\Internet Explorer\SearchScopes\{47AE1BA9-0BD1-44F4-88AE-45F8F7B605EF}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{47AE1BA9-0BD1-44F4-88AE-45F8F7B605EF}\ not found.
Registry key HKEY_USERS\S-1-5-18\Software\Microsoft\Internet Explorer\SearchScopes\{47AE1BA9-0BD1-44F4-88AE-45F8F7B605EF}\ not found.
HKU\S-1-5-21-1863099039-1387975201-1062880193-1000\SOFTWARE\Microsoft\Internet Explorer\Main\\Default_Page_URL| /E : value set successfully!
HKU\S-1-5-21-1863099039-1387975201-1062880193-1000\SOFTWARE\Microsoft\Internet Explorer\Main\\Start Page| /E : value set successfully!
Registry value HKEY_USERS\S-1-5-21-1863099039-1387975201-1062880193-1000\Software\Microsoft\Internet Explorer\URLSearchHooks\\{AEEC3B59-CA98-4EBA-A140-57B94E283583} deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{AEEC3B59-CA98-4EBA-A140-57B94E283583}\ not found.
C:\Program Files (x86)\Mozilla Firefox\searchplugins\aartemis.xml moved successfully.
Use Chrome's Settings page to change the HomePage.
File ptytemp] not found.
File ptyflash] not found.
File boot] not found.
OTL by OldTimer - Version 3.2.69.0 log created on 11092013_151712
# AdwCleaner v3.011 - Rapport créé le 09/11/2013 à  15:40:48
# Mis à  jour le 03/11/2013 par Xplode
# Nom d'utilisateur : Marion - MARION-PC
# Exécuté depuis : C:\Users\Marion\Downloads\adwcleaner(1).exe
# Option : Nettoyer
***** [ Services ] *****
Dossier Supprimé : C:\Users\Marion\AppData\Local\Google\Chrome\User Data\Default\Extensions\cekcjpgehmohobmdiikfnopibipmgnml
Dossier Supprimé : C:\Users\Marion\AppData\Local\Google\Chrome\User Data\Default\Extensions\gbmdkmlcnbapgegninelmjbfibaghdmk
Dossier Supprimé : C:\Users\Marion\AppData\Local\Google\Chrome\User Data\Default\Extensions\gflandjopdloblmlcoiidmncpinmmacn
***** [ Raccourcis ] *****
***** [ Registre ] *****
***** [ Navigateurs ] *****
-\\ Internet Explorer v9.0.8112.16476
-\\ Mozilla Firefox v25.0 (fr)
[ Fichier : C:\Users\Marion\AppData\Roaming\Mozilla\Firefox\Profiles\ai6fd1nk.default-1363801725819\prefs.js ]
-\\ Google Chrome v
[ Fichier : C:\Users\Marion\AppData\Local\Google\Chrome\User Data\Default\preferences ]
AdwCleaner[R0].txt - [16960 octets] - [02/11/2013 19:28:51]
AdwCleaner[R1].txt - [39582 octets] - [08/11/2013 19:54:15]
AdwCleaner[R2].txt - [1504 octets] - [08/11/2013 20:37:03]
AdwCleaner[R3].txt - [1564 octets] - [09/11/2013 15:32:37]
AdwCleaner[S0].txt - [36942 octets] - [08/11/2013 20:07:00]
AdwCleaner[S1].txt - [1488 octets] - [09/11/2013 15:40:48]
########## EOF - C:\AdwCleaner\AdwCleaner[S1].txt - [1548 octets] ##########
#15479
  • Coches toutes les cases.
  • Copie et colle le rapport qui va s'ouvrir sur le forum.
par Marion
#15502
Voici les rapports:
https://www.malwarebytes.org
Version de la base de données: v2013.11.09.05
Marion :: MARION-PC [administrateur]
09/11/2013 16:44:25
mbam-log-2013-11-09 (16-44-25).txt
Type d'examen: Examen rapide
Elément(s) analysé(s): 214564
Temps écoulé: 33 minute(s), 53 seconde(s)
Clé(s) du Registre détectée(s): 8
HKCR\CLSID\{EB93AADE-9884-47F0-AA9D-0920E1D1203F} (PUP.Optional.SpeedAnalysis2.A) -> Mis en quarantaine et supprimé avec succès.
HKCR\TypeLib\{BB30FEA7-5866-406A-B47D-FB69E1AF8FD7} (PUP.Optional.SpeedAnalysis2.A) -> Mis en quarantaine et supprimé avec succès.
HKCR\Speed Analysis 2.BackgroundHostObject.1 (PUP.Optional.SpeedAnalysis2.A) -> Mis en quarantaine et supprimé avec succès.
HKCR\Speed Analysis 2.BackgroundHostObject (PUP.Optional.SpeedAnalysis2.A) -> Mis en quarantaine et supprimé avec succès.
HKCR\CLSID\{3bc93e76-92f8-5fda-b676-5afee3735bf1} (PUP.Optional.OfferMosquito.A) -> Mis en quarantaine et supprimé avec succès.
HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Ext\Stats\{3BC93E76-92F8-5FDA-B676-5AFEE3735BF1} (PUP.Optional.OfferMosquito.A) -> Mis en quarantaine et supprimé avec succès.
HKCR\TypeLib\{B83C16AE-3C3D-5362-85D6-D19F9FB51262} (PUP.Optional.OfferMosquito.A) -> Mis en quarantaine et supprimé avec succès.
HKCR\Interface\{2C0830EC-8559-5E15-9DC7-5BB830020064} (PUP.Optional.OfferMosquito.A) -> Mis en quarantaine et supprimé avec succès.
Dossier(s) détecté(s): 8
C:\Program Files (x86)\Winsudate (Adware.Gibmedia) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\AppData\Local\Temp\mt_ffx\Delta (PUP.Optional.Delta.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\AppData\Local\Temp\mt_ffx\Delta\delta (PUP.Optional.Delta.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\AppData\Local\Temp\mt_ffx\Delta\delta\1.8.22.0 (PUP.Optional.Delta.A) -> Mis en quarantaine et supprimé avec succès.
C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{740B3FD5-4483-469D-BE7F-8555B153BD04} (PUP.Optional.Zwangi.A) -> Mis en quarantaine et supprimé avec succès.
C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{740B3FD5-4483-469D-BE7F-8555B153BD04}\chrome (PUP.Optional.Zwangi.A) -> Mis en quarantaine et supprimé avec succès.
C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{740B3FD5-4483-469D-BE7F-8555B153BD04}\defaults (PUP.Optional.Zwangi.A) -> Mis en quarantaine et supprimé avec succès.
C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{740B3FD5-4483-469D-BE7F-8555B153BD04}\defaults\preferences (PUP.Optional.Zwangi.A) -> Mis en quarantaine et supprimé avec succès.
Fichier(s) détecté(s): 24
C:\Users\Marion\Downloads\7ZipSetup-da3iMM9.exe (PUP.Optional.Somoto) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Downloads\CodecPerformerSetup.exe (Adware.InstallBrain) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Downloads\iLividSetup-r394-n-bf.exe (PUP.Optional.Vid) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Downloads\iLividSetupV1.exe (PUP.Optional.Bandoo) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Downloads\izarc_izarc_4.1.7_francais_11017.exe (PUP.Optional.Somoto) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Downloads\rcpsetup_matomy_my2271.exe (PUP.Optional.RegCleanerPro) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Downloads\rcpsetup_r.exe (PUP.Optional.RegCleanerPro) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Downloads\SoftonicDownloader_pour_inkscape.exe (PUP.Optional.Softonic.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Downloads\Webplayer.exe (PUP.Optional.KreaP) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\AppData\Local\ext_offermosquito\npOfferMosquitoIEHelper.dll (PUP.Optional.OfferMosquito.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Local Settings\Temporary Internet Files\Content.IE5\BKI6CVP2\basicserve_bscsrvlink3[1].exe (Adware.OneStep) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Local Settings\Temporary Internet Files\Content.IE5\BKI6CVP2\sdpupdater[1].exe (PUP.Optional.FilesFrog.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Local Settings\Temporary Internet Files\Content.IE5\BKI6CVP2\SPIdentifierImpl[1].exe (PUP.Optional.SearchProtect.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Local Settings\Temporary Internet Files\Content.IE5\G6BM4KRU\component_libcef_1.1364.1123[1].exe (PUP.Optional.Desk365.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Local Settings\Temporary Internet Files\Content.IE5\G6BM4KRU\pack[1].7z (PUP.Optional.PerformerSoft.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Local Settings\Temporary Internet Files\Content.IE5\G6BM4KRU\WebCakesetup[1].exe (PUP.Optional.Yontoo) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Local Settings\Temporary Internet Files\Content.IE5\S1RT4DU3\59347.Bubble_Dock.BBD023.no[1].exe (PUP.Optional.BubbleDock.A) -> Mis en quarantaine et supprimé avec succès.
C:\Users\Marion\Local Settings\Temporary Internet Files\Content.IE5\S1RT4DU3\DeltaTB[1].exe (PUP.Optional.Babylon.A) -> Mis en quarantaine et supprimé avec succès.
C:\Program Files (x86)\Winsudate\gibidl64.dll (Adware.Gibmedia) -> Mis en quarantaine et supprimé avec succès.
C:\Program Files (x86)\Winsudate\gibupt.exe (Adware.Gibmedia) -> Mis en quarantaine et supprimé avec succès.
C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{740B3FD5-4483-469D-BE7F-8555B153BD04}\chrome.manifest (PUP.Optional.Zwangi.A) -> Mis en quarantaine et supprimé avec succès.
C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{740B3FD5-4483-469D-BE7F-8555B153BD04}\install.rdf (PUP.Optional.Zwangi.A) -> Mis en quarantaine et supprimé avec succès.
C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{740B3FD5-4483-469D-BE7F-8555B153BD04}\chrome\basicserve.jar (PUP.Optional.Zwangi.A) -> Mis en quarantaine et supprimé avec succès.
C:\Program Files (x86)\Mozilla Firefox\browser\extensions\{740B3FD5-4483-469D-BE7F-8555B153BD04}\defaults\preferences\prefs.js (PUP.Optional.Zwangi.A) -> Mis en quarantaine et supprimé avec succès.
(fin)
¤¤¤¤¤¤¤¤¤¤ | Shortcut_Module 27.09.2013 - g3n-h@ckm@n
17:20:33 - 09/11/2013
Disinfected : C:\Users\All Users\Microsoft\Windows\Start Menu\Programs\Mozilla Firefox.lnk : C:\Program Files (x86)\Mozilla Firefox\firefox.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Google Chrome.lnk : C:\Users\Marion\AppData\Local\Google\Chrome\Application\chrome.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\Launch Internet Explorer Browser.lnk : C:\Program Files (x86)\Internet Explorer\iexplore.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\mail.google.com.lnk : C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\StartMenu\Internet Explorer.lnk : C:\Program Files (x86)\Internet Explorer\iexplore.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar\Mozilla Firefox.lnk : C:\Program Files (x86)\Mozilla Firefox\firefox.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Internet Explorer (64-bit).lnk : C:\Program Files\Internet Explorer\iexplore.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Internet Explorer.lnk : C:\Program Files (x86)\Internet Explorer\iexplore.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Accessories\System Tools\Internet Explorer (No Add-ons).lnk : C:\Program Files (x86)\Internet Explorer\iexplore.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Google Chrome\Google Chrome.lnk : C:\Users\Marion\AppData\Local\Google\Chrome\Application\chrome.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\Desktop\Google Chrome.lnk : C:\Users\Marion\AppData\Local\Google\Chrome\Application\chrome.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Marion\Desktop\Internet Explorer.lnk : C:\Program Files (x86)\Internet Explorer\iexplore.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
Disinfected : C:\Users\Public\Desktop\Mozilla Firefox.lnk : C:\Program Files (x86)\Mozilla Firefox\firefox.exe (hxxp://aartemis.com/?type=sc&ts=1383851400&from=tugs&uid=HitachiXHTS545025B9A300_090807PBY206QSC3DD8AX)
par Marion
#15706
J'ai donc redémarrer mon pc puis lancer internet: c'est bien ma page d'accueil habituelle que j'ai mais lorsque je souhaite ouvrir un autre onglet c'est aartemis qui s'ouvre. Pourquoi?
En tout cas, merci pour votre aide.
#15707
Bonjour Marion,
Sur quel navigateur ? Tous ?
