Re
Correction :
Nous avons besoin de corriger certains éléments que FRST a trouvés
Ouvrez le Bloc-notes. Copiez le contenu de la zone Code ci-dessous.
Pour ce faire, sélectionnez le contenu de la zone, faites un clic droit et choisissez Copier
Dans le Bloc-notes, faites un clic droit et choisissez Coller
Enregistrez le fichier sous le nom
fixlist.txt sur le bureau // Ou sur la clé USB
Start
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = https://www.aartemis.com/web/?type=ds&ts ... 9780797&q={searchTerms}
HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = https://aartemis.com/?type=hp&ts=1383942 ... 8079780797
HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = https://aartemis.com/?type=hp&ts=1383942 ... 8079780797
HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = https://www.aartemis.com/web/?type=ds&ts ... 9780797&q={searchTerms}
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL = https://www.aartemis.com/web/?type=ds&ts ... 9780797&q={searchTerms}
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL = https://aartemis.com/?type=hp&ts=1383942 ... 8079780797
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = https://aartemis.com/?type=hp&ts=1383942 ... 8079780797
HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page = https://www.aartemis.com/web/?type=ds&ts ... 9780797&q={searchTerms}
StartMenuInternet: IEXPLORE.EXE - C:\Program Files (x86)\Internet Explorer\iexplore.exe https://aartemis.com/?type=sc&ts=1383942 ... 8079780797 => Microsoft%Internet Explorer
SearchScopes: HKLM - DefaultScope {33BB0A4E-99AF-4226-BDF6-49120163DE86} URL = => Infection PUP (PUP.V9Software)
BHO-x32: avast! WebRep - {8E5E2654-AD2D-48bf-AC2D-D17F00898D06} - C:\Program Files\AVAST Software\Avast\aswWebRepIE.dll (AVAST Software) => Toolbar.Avast
Toolbar: HKLM-x32 - avast! WebRep - {8E5E2654-AD2D-48bf-AC2D-D17F00898D06} - C:\Program Files\AVAST Software\Avast\aswWebRepIE.dll (AVAST Software) => Toolbar.Avast
FF NewTab: hxxp://aartemis.com/newtab/?type=nt&ts=1383942612&from=tugs&uid=WDCXWD10EZEX-60ZF5A0_WD-WMC1S368079780797
FF Homepage: hxxp://aartemis.com/?type=hp&ts=1383942612&from=tugs&uid=WDCXWD10EZEX-60ZF5A0_WD-WMC1S368079780797
FF SearchPlugin: C:\Users\Hugo\AppData\Roaming\Mozilla\Firefox\Profiles\r6u3591m.default\searchplugins\utorrentbarfr-customized-web-search.xml => P2P.µTorrent*
FF SearchPlugin: C:\Program Files (x86)\mozilla firefox\browser\searchplugins\aartemis.xml
2013-11-08 21:11 - 2013-11-08 21:11 - 00400744 _____ (Softonic ) C:\Users\Hugo\Downloads\SoftonicDownloader_pour_mini-ninjas.exe => Toolbar.Conduit*
2013-10-17 16:03 - 2013-05-08 19:18 - 00000000 ____D C:\Users\Hugo\AppData\Roaming\uTorrent => P2P.µTorrent*
End
NOTE: Ces lignes ont été écrites spécialement pour cet utilisateur, pour être utilisées exclusivement sur ce PC. Exécuter ces instructions sur une autre machine pourrait endommager le système d'exploitation
Sur Vista ou Windows 7: Ouvrez le menu des Options de récupération système
Sur Windows XP: Démarrez avec le CD BartPE
Lancez
FRST, cliquez une seule fois sur le bouton
Fix et attendez
L'outil va créer un rapport de correction (Fixlog.txt)
sur le bureau // ou la clé USB
Copiez/collez ce rapport dans votre réponse après avoir redémarré le pc normalement
de AdwCleaner(d'Xplode)
Télécharge et enregistre AdwCleaner =>
https://general-changelog-team.fr/fr/dow ... adwcleaner sur ton bureau
Clique sur AdwCleaner pour le lancer
Clique sur "
Scanner"
Une fois le Scan terminé, clique sur "
Rapport"
Copie/Colle le rapport dans ta réponse, sur le forum
Relance AdwCleaner
Clique sur "
Nettoyer"
A l'issue, le rapport de nettoyage va s'afficher, poste le par copier/coller dans ta réponse, sur le forum
Vous pouvez fermer le programme
Note : Le rapport est également sauvegardé sous C:\AdwCleaner\AdwCleaner[0].txt
3/
Téléchargez et enregistrez ZHPDiag =>
https://telechargement.zebulon.fr/telech ... pdiag.html sur votre ordinateur.
Laissez vous guider lors de l'installation en laissant les réglages par défaut, n'oubliez pas de cocher la case "
raccourci bureau".
Suite à ces actions, deux raccourcis bureau sont présents. (ZHPFix, ZHPDiag)
Pour exécuter une analyse compléte, cliquez sur l'icône bureau "
ZHPDiag" représentant un "
parchemin".
Dans l'interface du logiciel, cliquez sur le bouton "
Configurer" pour accéder aux réglages.
Cliquez ensuite sur bouton "
Loupe + " en bas à gauche, pour lancer un
Diagnostic Full options
Le rapport
ZHPDiag.txt sera aussi sur votre bureau.
En cas de nécessité, il est sauvegardé dans
C:\user\nomxx\AppData\Roaming\ZHP\ZHPDiag.txt
Vérifier dans le bloc notes (Notepad) > Format , que "Retour automatique à la ligne" soit décoché.
Appuyer simultanément sur les touches CTRL et A pour tout sélectionner (surligné en bleu en général) et relàcher les touches.
Appuyer simultanément sur les touches CTRL et C pour copier le contenu du rapport dans le presse-papier de Windows et relàcher les touches.
Rendez vous sur le site Cjoint =>
https://WWW.Cjoint.com
Cliquez sur "Parcourir" pour recueillir le rapport qui est sur votre ordinateur.
Cochez "21 jours" pour la durée d'hébergement.
Cliquez sur "Créer le lien Cjoint"
Dans la fenêtre suivante, vous "copiez" votre lien Cjoint.
Vous "collez" ce lien dans votre réponse sur le forum qui vous aide.
Reviens dans ta réponse avec les
trois rapports demandés
