#15477
Hello :hello: ,
  • Clic sur OK
    start
    HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = https://aartemis.com/?type=hp&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551
    HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = https://www.aartemis.com/web/?type=ds&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551&q={searchTerms}
    HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = https://aartemis.com/?type=hp&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551
    HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = https://aartemis.com/?type=hp&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551
    HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = https://www.aartemis.com/web/?type=ds&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551&q={searchTerms}
    HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Search_URL = https://www.aartemis.com/web/?type=ds&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551&q={searchTerms}
    HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Default_Page_URL = https://aartemis.com/?type=hp&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551
    HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Start Page = https://aartemis.com/?type=hp&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551
    HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Main,Search Page = https://www.aartemis.com/web/?type=ds&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551&q={searchTerms}
    StartMenuInternet: IEXPLORE.EXE - C:\Program Files (x86)\Internet Explorer\iexplore.exe https://aartemis.com/?type=sc&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551
    CHR StartMenuInternet: Google Chrome - C:\Program Files (x86)\Google\Chrome\Application\chrome.exe https://aartemis.com/?type=sc&ts=1383947470&from=tugs&uid=WDCXWD5000BEVT-22A0RT0_WD-WXH1A603455134551
    C:\Users\LeGuillouzic\AppData\Roaming\Vydoa
    C:\Users\LeGuillouzic\AppData\Roaming\Onholu
    C:\Users\LeGuillouzic\AppData\Roaming\Ifga
    C:\ProgramData\iej7oc.reg
    C:\ProgramData\ocr7v.reg
    C:\Users\LeGuillouzic\AppData\Local\Temp\ApnStub.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\BackupSetup.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\COMAP.EXE
    C:\Users\LeGuillouzic\AppData\Local\Temp\coupish-babylon.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\ICReinstall_SkypeSetup.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\IE9-Windows7-x64.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\iesetup-win7-x64.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\IminentSetup.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\installhelper.dll
    C:\Users\LeGuillouzic\AppData\Local\Temp\Install_BubbleDock.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\jre-6u37-windows-i586-iftw.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\jre-7u45-windows-i586-iftw.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\Messenger-full-installer.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\mgsqlite3.dll
    C:\Users\LeGuillouzic\AppData\Local\Temp\Player_Setup.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\Quarantine.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\Runner.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\Shortcut_bundlesweetimsetup.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\Shortcut_setup.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\SIMEEIInstaller.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\SkypeSetup.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\SQLite.dll
    C:\Users\LeGuillouzic\AppData\Local\Temp\SRAssetsHelper.dll
    C:\Users\LeGuillouzic\AppData\Local\Temp\Toolbar_Phpnuke.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\uninst1.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\vcredist_x64.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\vcredist_x86.exe
    C:\Users\LeGuillouzic\AppData\Local\Temp\{23789DF2-039B-427C-BE4D-B9DE82B72890}-chrome_installer.exe
    end
  • Clic sur Fix
    1. Choisi l'option Scanner
    2. Choisi l'option Nettoyer
  • Coches toutes les cases.
  • Copie et colle le rapport qui va s'ouvrir sur le forum.
