voilà :
############################## | UsbFix V 7.150 | [Suppression]
Utilisateur: Vincent (Administrateur) # VINCENT-VAIO
Mis à jour le 08/11/2013 par El Desaparecido - Team SosVirus
Lancé à 18:59:43 | 09/11/2013
Site Web :
https://www.usbfix.net
Forum :
https://www.sosvirus.net/
Upload Malware :
https://www.sosvirus.net/upload_malware.php
Contact :
https://www.usbfix.net/contact/
PC: Sony Corporation (VAIO)
CPU: Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz
RAM -> [Total : 4077 | Free : 2497]
C:\ (%systemdrive%) -> Disque fixe # 453 Go (355 Go libre(s) - 78%) [] # NTFS
D:\ -> CD-ROM
E:\ -> Disque amovible # 7 Go (7 Go libre(s) - 88%) [PHILIPS UFD] # FAT32
Stoppé! C:\Program Files\AVAST Software\Avast\AvastSvc.exe (ID: 1380 |ParentID: 712)
Stoppé! C:\Program Files\AVAST Software\Avast\AvastUI.exe (ID: 6396 |ParentID: 5544)
Stoppé! C:\Windows\explorer.exe (ID: 2204 |ParentID: 968)
Stoppé! C:\Windows\System32\rundll32.exe (ID: 5904 |ParentID: 836)
Stoppé! C:\Program Files (x86)\Sony\VAIO Event Service\VESMgr.exe (ID: 4292 |ParentID: 712)
Stoppé! C:\Windows\SysWOW64\DllHost.exe (ID: 3828 |ParentID: 836)
Stoppé! C:\Program Files (x86)\Sony\VAIO Event Service\VESMgrSub.exe (ID: 5892 |ParentID: 4292)
Stoppé! C:\Windows\system32\SearchIndexer.exe (ID: 3292 |ParentID: 712)
Stoppé! C:\Program Files\Windows Media Player\wmpnetwk.exe (ID: 5732 |ParentID: 712)
Stoppé! C:\Program Files\WIDCOMM\Bluetooth Software\btwdins.exe (ID: 5036 |ParentID: 712)
Stoppé! C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe (ID: 1112 |ParentID: 712)
Stoppé! C:\Windows\System32\spoolsv.exe (ID: 7416 |ParentID: 712)
Stoppé! C:\Windows\System32\WUDFHost.exe (ID: 6580 |ParentID: 660)
Stoppé! C:\Windows\system32\DllHost.exe (ID: 5256 |ParentID: 836)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (ID: 3760 |ParentID: 2204)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (ID: 4228 |ParentID: 3760)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (ID: 7444 |ParentID: 3760)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (ID: 5956 |ParentID: 3760)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (ID: 3388 |ParentID: 3760)
Stoppé! C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (ID: 6956 |ParentID: 3760)
Stoppé! C:\Windows\system32\taskeng.exe (ID: 4436 |ParentID: 1072)
04 - HKLM\SOFTWARE | Run : [PMBVolumeWatcher] - C:\Program Files (x86)\Sony\PMB\PMBVolumeWatcher.exe
04 - HKLM\SOFTWARE | Run : [HP Software Update] - C:\Program Files (x86)\HP\HP Software Update\HPWuSchd2.exe
04 - HKLM\SOFTWARE | Run : [QuickTime Task] - "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
04 - HKLM\SOFTWARE | Run : [APSDaemon] - "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
04 - HKLM\SOFTWARE | Run : [iTunesHelper] - "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
04 - HKLM\SOFTWARE | Run : [Adobe Acrobat Speed Launcher] - "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat_sl.exe"
04 - HKLM\SOFTWARE | Run : [Acrobat Assistant 8.0] - "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrotray.exe"
04 - HKLM\SOFTWARE | Run : [AvastUI.exe] - "C:\Program Files\AVAST Software\Avast\AvastUI.exe" /nogui
04 - HKLM\SOFTWARE\wow6432Node | Run : [PMBVolumeWatcher] - C:\Program Files (x86)\Sony\PMB\PMBVolumeWatcher.exe
04 - HKLM\SOFTWARE\wow6432Node | Run : [HP Software Update] - C:\Program Files (x86)\HP\HP Software Update\HPWuSchd2.exe
04 - HKLM\SOFTWARE\wow6432Node | Run : [QuickTime Task] - "C:\Program Files (x86)\QuickTime\QTTask.exe" -atboottime
04 - HKLM\SOFTWARE\wow6432Node | Run : [APSDaemon] - "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [iTunesHelper] - "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [] -
04 - HKLM\SOFTWARE\wow6432Node | Run : [Adobe Acrobat Speed Launcher] - "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat_sl.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [Acrobat Assistant 8.0] - "C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrotray.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [AvastUI.exe] - "C:\Program Files\AVAST Software\Avast\AvastUI.exe" /nogui
04 - HKLM\SOFTWARE | RunOnce : [aswAhAScr.dll] - "C:\Program Files\AVAST Software\Avast\aswRegSvr.exe" "C:\Program Files\AVAST Software\Avast\AhAScr.dll"
04 - HKLM\SOFTWARE | RunOnce : [aswasOutExt.dll] - "C:\Program Files\AVAST Software\Avast\aswRegSvr.exe" "C:\Program Files\AVAST Software\Avast\asOutExt.dll"
04 - HKLM\SOFTWARE | RunOnce : [aswasOutExt64.dll] - "C:\Program Files\AVAST Software\Avast\aswRegSvr64.exe" "C:\Program Files\AVAST Software\Avast\asOutExt64.dll"
04 - HKLM\SOFTWARE\wow6432Node | RunOnce : [aswAhAScr.dll] - "C:\Program Files\AVAST Software\Avast\aswRegSvr.exe" "C:\Program Files\AVAST Software\Avast\AhAScr.dll"
04 - HKLM\SOFTWARE\wow6432Node | RunOnce : [aswasOutExt.dll] - "C:\Program Files\AVAST Software\Avast\aswRegSvr.exe" "C:\Program Files\AVAST Software\Avast\asOutExt.dll"
04 - HKLM\SOFTWARE\wow6432Node | RunOnce : [aswasOutExt64.dll] - "C:\Program Files\AVAST Software\Avast\aswRegSvr64.exe" "C:\Program Files\AVAST Software\Avast\asOutExt64.dll"
04 - HKU\S-1-5-21-3321599819-4190863736-1341510468-1000\SOFTWARE | Run : [iTunesHelper] - wscript.exe //B "C:\Users\Vincent\AppData\Local\Temp\iTunesHelper.vbe"
04 - HKU\S-1-5-18\SOFTWARE | RunOnce : [SPReview] - "C:\Windows\System32\SPReview\SPReview.exe" /sp:1 /errorfwlink:"
https://go.microsoft.com/fwlink/?LinkID=122915" /build:7601
Supprimé! C:\Users\Vincent\AppData\Local\Temp\iTunesHelper.vbe
Supprimé! C:\Users\Vincent\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\iTunesHelper.vbe
Supprimé! E:\iTunesHelper.vbe
Supprimé! E:\CarryItEasy.exe
Supprimé! E:\license.lnk
Supprimé! E:\msvcr71.lnk
Supprimé! E:\cv.lnk
Supprimé! E:\imprimer.lnk
Supprimé! E:\musique.lnk
Supprimé! E:\CarryItEasy.lnk
Supprimé! E:\User Manual vintage edition .lnk
Supprimé! E:\imprimer .lnk
Supprimé! E:\WMPInfo.lnk
Supprimé! E:\Attestation d'affiliation.lnk
Supprimé! E:\EditionReinscriptionRecapitulatif.lnk
Supprimé! E:\Déclaration du choix de médecin traitant.lnk
Supprimé! E:\SUPEXAM ANATOMIE TC et PB .lnk
Supprimé! E:\musique .lnk
Supprimé! E:\CarryItEasySettings .lnk
Supprimé! E:\http--svtjalenques.lnk
Supprimé! E:\Personal Data .lnk
Supprimé! E:\Musiques demandées .lnk
Supprimé! E:\.lnk
Supprimé! E:\Synthèse tpe vincent.lnk
Supprimé! E:\Music .lnk
Supprimé! E:\Tete et Cou .lnk
Supprimé! E:\Petit bassin 2 avec légendes .lnk
Supprimé! E:\chlo .lnk
Supprimé! E:\Petit bassin 1 avec légendes .lnk
Supprimé! E:\INSCRIPTION .lnk
Supprimé! E:\a trier .lnk
Supprimé! E:\Nouveau dossier .lnk
Supprimé! E:\Thumbs.lnk
Supprimé! E:\Thumbs .lnk
Supprimé! E:\CarryItEasySettings.lnk
Supprimé! E:\Personal Data.lnk
Supprimé! E:\Musiques demandées.lnk
Supprimé! E:\Music.lnk
Supprimé! E:\Tete et Cou.lnk
Supprimé! E:\Petit bassin 2 avec légendes.lnk
Supprimé! E:\chlo.lnk
Supprimé! E:\Petit bassin 1 avec légendes.lnk
Supprimé! E:\.Trashes.lnk
Supprimé! E:\INSCRIPTION.lnk
Supprimé! E:\.Spotlight-V100.lnk
Supprimé! E:\.TemporaryItems.lnk
Supprimé! E:\a trier.lnk
Supprimé! E:\Nouveau dossier.lnk
Supprimé! E:\.fseventsd.lnk
Supprimé! E:\Cytoge´ne´tique -IMPRESSION.lnk
Supprimé! E:\FOUND.000.lnk
Supprimé! E:\Thumbs .db
Supprimé! E:\Thumbs.com
Supprimé! E:\RavMonLog
Supprimé! E:\msvcr71.dll
Md5 : 2BCBCF86077A7E0F77BDB82F331F2957 -> C:\Users\Vincent\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\iTunesHelper.vbe
Md5 : 2BCBCF86077A7E0F77BDB82F331F2957 -> C:\Users\Vincent\AppData\Local\Temp\iTunesHelper.vbe
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\imprimer .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\SUPEXAM ANATOMIE TC et PB .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\musique .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\CarryItEasySettings .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Personal Data .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Musiques demandées .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Music .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Tete et Cou .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Petit bassin 2 avec légendes .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\chlo .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Petit bassin 1 avec légendes .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\INSCRIPTION .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\a trier .scr
Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Nouveau dossier .scr
Md5 : 2BCBCF86077A7E0F77BDB82F331F2957 -> E:\iTunesHelper.vbe
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\imprimer .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\SUPEXAM ANATOMIE TC et PB .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\musique .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\CarryItEasySettings .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Personal Data .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Musiques demandées .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Music .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Tete et Cou .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Petit bassin 2 avec légendes .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\chlo .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Petit bassin 1 avec légendes .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\INSCRIPTION .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\a trier .scr
Supprimé! Md5 : CC48D72D2E0D98755CD68D221D0FB756 -> E:\Nouveau dossier .scr
Supprimé! HKU\S-1-5-21-3321599819-4190863736-1341510468-1000\Software\Microsoft\Windows\CurrentVersion\Run|iTunesHelper
Supprimé! HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Run|iTunesHelper
[29/07/2013 - 19:58:16 | SHD ] C:\$Recycle.Bin
[09/11/2013 - 12:18:37 | HD ] C:\Config.Msi
[14/08/2010 - 09:14:06 | D ] C:\Documentation
[11/04/2008 - 09:07:18 | N | 3820] C:\eula.1028.txt
[11/04/2008 - 09:07:18 | N | 15428] C:\eula.1031.txt
[11/04/2008 - 09:07:18 | N | 10058] C:\eula.1033.txt
[11/04/2008 - 09:07:18 | N | 12246] C:\eula.1036.txt
[11/04/2008 - 09:07:18 | N | 13912] C:\eula.1040.txt
[11/04/2008 - 09:07:18 | N | 5868] C:\eula.1041.txt
[11/04/2008 - 09:07:18 | N | 5970] C:\eula.1042.txt
[11/04/2008 - 09:07:18 | N | 10134] C:\eula.1049.txt
[11/04/2008 - 09:07:18 | N | 3814] C:\eula.2052.txt
[11/04/2008 - 09:07:18 | N | 12936] C:\eula.3082.txt
[11/04/2008 - 09:07:18 | N | 1110] C:\globdata.ini
[09/11/2013 - 15:42:19 | ASH | 3206225920] C:\hiberfil.sys
[11/04/2008 - 07:03:48 | N | 562688] C:\install.exe
[11/04/2008 - 09:07:18 | N | 843] C:\install.ini
[11/04/2008 - 07:03:48 | N | 76304] C:\install.res.1028.dll
[11/04/2008 - 07:03:48 | N | 96272] C:\install.res.1031.dll
[11/04/2008 - 07:03:48 | N | 91152] C:\install.res.1033.dll
[11/04/2008 - 07:03:48 | N | 97296] C:\install.res.1036.dll
[11/04/2008 - 07:03:48 | N | 95248] C:\install.res.1040.dll
[11/04/2008 - 07:03:48 | N | 81424] C:\install.res.1041.dll
[11/04/2008 - 07:03:48 | N | 79888] C:\install.res.1042.dll
[11/04/2008 - 09:09:24 | N | 93200] C:\install.res.1049.dll
[11/04/2008 - 07:03:48 | N | 75792] C:\install.res.2052.dll
[11/04/2008 - 07:03:48 | N | 96272] C:\install.res.3082.dll
[29/07/2010 - 18:57:53 | D ] C:\Intel
[13/03/2011 - 09:17:01 | RHD ] C:\MSOCache
[09/11/2013 - 15:42:21 | ASH | 4274970624] C:\pagefile.sys
[15/05/2013 - 12:59:30 | D ] C:\Program Files
[27/10/2013 - 08:58:49 | D ] C:\Program Files (x86)
[27/10/2013 - 11:22:53 | HD ] C:\ProgramData
[14/08/2010 - 09:05:52 | N | 2253] C:\RHDSetup.log
[09/11/2013 - 18:33:08 | SHD ] C:\System Volume Information
[06/04/2012 - 10:23:48 | D ] C:\Temp
[18/10/2013 - 08:07:41 | N | 360197] C:\test.xml
[14/05/2013 - 12:15:28 | N | 0] C:\testDefBrow.html
[26/03/2012 - 11:49:40 | D ] C:\Update
[09/11/2013 - 19:09:33 | D ] C:\UsbFix
[09/11/2013 - 18:39:50 | N | 12071] C:\UsbFix [Clean 2] VINCENT-VAIO.txt
[09/11/2013 - 19:09:44 | A | 15860] C:\UsbFix [Clean 3] VINCENT-VAIO.txt
[25/08/2013 - 08:10:05 | RD ] C:\Users
[15/03/2011 - 16:28:45 | D ] C:\VAIO Entertainment
[14/08/2010 - 09:48:54 | D ] C:\VAIO Sample Contents
[11/04/2008 - 09:07:18 | N | 5686] C:\vcredist.bmp
[14/08/2010 - 09:25:21 | N | 413162] C:\vcredist_x86.log
[11/04/2008 - 09:09:38 | N | 3797292] C:\VC_RED.cab
[11/04/2008 - 09:11:40 | N | 233472] C:\VC_RED.MSI
[09/11/2013 - 18:38:43 | D ] C:\Windows
[14/08/2010 - 09:14:07 | D ] C:\_FS_SWRINFO
[02/01/2004 - 00:00:00 | N | 10460546] E:\User Manual vintage edition .pdf
[19/12/2011 - 18:13:56 | N | 89] E:\license.dat
[30/09/2013 - 14:09:08 | D ] E:\imprimer
[23/02/2012 - 16:32:36 | D ] E:\SUPEXAM ANATOMIE TC et PB
[16/01/2010 - 11:20:40 | D ] E:\musique
[19/12/2011 - 18:14:02 | D ] E:\CarryItEasySettings
[19/12/2011 - 18:14:04 | D ] E:\Personal Data
[07/11/2010 - 13:22:24 | D ] E:\Musiques demandées
[26/01/2011 - 17:17:20 | D ] E:\Music
[20/04/2012 - 12:13:02 | D ] E:\Tete et Cou
[18/12/2009 - 16:51:44 | N | 296] E:\WMPInfo.xml
[06/04/2012 - 12:11:46 | D ] E:\Petit bassin 2 avec légendes
[12/07/2012 - 12:41:02 | N | 51141] E:\Attestation d'affiliation.pdf
[11/07/2012 - 09:27:40 | N | 3801] E:\EditionReinscriptionRecapitulatif.do
[12/07/2012 - 12:41:28 | N | 42960] E:\Déclaration du choix de médecin traitant.pdf
[08/05/2009 - 21:52:24 | N | 149] E:\http--svtjalenques.hautetfort.com-media-02-02-972932408.pdf.url
[31/05/2013 - 09:51:26 | SH | 4096] E:\._.Trashes
[08/07/2013 - 10:01:24 | D ] E:\chlo
[01/02/2004 - 07:14:12 | D ] E:\Petit bassin 1 avec légendes
[31/05/2013 - 09:51:26 | SHD ] E:\.Trashes
[26/08/2013 - 19:37:50 | D ] E:\INSCRIPTION
[31/05/2013 - 09:51:28 | SHD ] E:\.Spotlight-V100
[31/05/2013 - 09:56:38 | SHD ] E:\.TemporaryItems
[31/05/2013 - 09:56:38 | SH | 4096] E:\._.TemporaryItems
[31/05/2013 - 10:35:28 | N | 4096] E:\._cv.docx
[30/09/2013 - 14:07:40 | D ] E:\a trier
[31/05/2013 - 10:35:26 | N | 14625] E:\cv.docx
[17/01/2010 - 22:23:46 | N | 30208] E:\Synthèse tpe vincent.doc
[02/10/2013 - 14:05:04 | D ] E:\Nouveau dossier
[05/10/2013 - 14:18:48 | D ] E:\.fseventsd
[09/11/2013 - 18:39:46 | N | 0] E:\SUPEXAM ANATOMIE TC et PB.lnk
[09/11/2013 - 17:56:42 | D ] E:\FOUND.000
[08/11/2013 - 16:43:56 | N | 3385037] E:\Cytoge´ne´tique -IMPRESSION.pdf
################## | E.O.F |
https://www.usbfix.net -
https://www.sosvirus.net |
