- mar. 12 nov. 2013 18:52
#16371
All processes killed
========== PROCESSES ==========
No active process named explorer.exe was found!
No active process named iexplore.exe was found!
No active process named firefox.exe was found!
No active process named msnmsgr.exe was found!
No active process named Teatimer.exe was found!
========== OTL ==========
Service NTIOLib_1_0_C stopped successfully!
Service NTIOLib_1_0_C deleted successfully!
File E:\NTIOLib.sys not found.
Service MSICDSetup stopped successfully!
Service MSICDSetup deleted successfully!
File E:\CDriver.sys not found.
Service gdrv stopped successfully!
Service gdrv deleted successfully!
File C:\Windows\gdrv.sys not found.
Registry key HKEY_USERS\S-1-5-21-1893159794-2332358693-2995581271-1005\Software\Microsoft\Internet Explorer\SearchScopes\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}\ deleted successfully.
Registry key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{0633EE93-D776-472f-A0FF-E1416B8B2E3A}\ not found.
Prefs.js: firefox%40batbrowse.com:1.0.0 removed from extensions.enabledAddons
D:\NePasEffacer\Jerome\AppData\Roaming\AffiliatedUpdate\UpdateProc folder moved successfully.
D:\NePasEffacer\Jerome\AppData\Roaming\AffiliatedUpdate folder moved successfully.
C:\Windows\System32\Tasks\AffiliatedUpdate moved successfully.
C:\Windows\System32\Tasks\CCleanerSkipUAC moved successfully.
Registry key HKEY_LOCAL_MACHINE\Software\BrowserChoice\ deleted successfully.
[EMPTYTEMP]
User: All Users
User: Jerome
->Temp folder emptied: 14451561 bytes
->Temporary Internet Files folder emptied: 565835 bytes
->Java cache emptied: 0 bytes
->FireFox cache emptied: 48191058 bytes
->Flash cache emptied: 1926 bytes
User: Proprietaire
Windows Temp folder emptied: 0 bytes
RecycleBin emptied: 29102856 bytes
Total Files Cleaned = 88,00 mb
OTL by OldTimer - Version 3.2.69.0 log created on 11122013_184859
D:\NePasEffacer\Jerome\AppData\Local\Microsoft\Windows\Temporary Internet Files\counters.dat moved successfully.
[EMPTYTEMP]
User: All Users
User: Jerome
User: Proprietaire
