#2136
bien relance l'outil , clique sur diag , heberge le rapport pre_diag et donne le lien
#2152
hello
Télécharge et enregistre <gras>[https://general-changelog-team.fr/fr/dow ... adwcleaner ADWCleaner]</gras> sur ton bureau :
Lance le,(Pour vista/7/8 => clic droit "executer en tant qu'administrateur")
clique sur suppression et poste C:\Adwcleaner[Sx].txt
#2179
selectionne ce teste puis CTRL + C :
Kill::
Key::
[HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{11AF66E1-6BDE-4AA0-A061-65188608936B}]
[HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{973F1DA1-9BE8-49C1-A68D-EAA0D9847898}]
[HKLM\SOFTWARE\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{ABC32CC5-ED91-449b-8472-7A7376361232}]
[HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{938958E8-355C-49FF-92B0-53C1B87ACEA9}]
[HKU\S-1-5-21-1659004503-789336058-725345543-1004\SOFTWARE\Microsoft\Active Setup\Installed Components\{08B0E5JF-4FCB-11CF-AAA5-00401C6XX500}]
[HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{8AD9C840-044E-11D1-B3E9-00805F499D93}]
[HKCR\CLSID\{8AD9C840-044E-11D1-B3E9-00805F499D93}]
[HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-0016-0000-0043-ABCDEFFEDCBA}]
[HKCR\CLSID\{CAFEEFAC-0016-0000-0043-ABCDEFFEDCBA}]
[HKLM\SOFTWARE\Microsoft\Code Store Database\Distribution Units\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}]
[HKCR\CLSID\{CAFEEFAC-FFFF-FFFF-FFFF-ABCDEFFEDCBA}]
[HKU\S-1-5-21-1659004503-789336058-725345543-1004\Software\BI]
[HKLM\System\CurrentControlSet\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]|[1700:TCP]
[HKLM\System\CurrentControlSet\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]|[1641:TCP]
[HKLM\System\CurrentControlSet\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]|[48113:TCP]
[HKLM\System\CurrentControlSet\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]|[48113:UDP]
[HKLM\System\CurrentControlSet\services\sharedaccess\parameters\firewallpolicy\domainprofile\GloballyOpenPorts\List]|[1900:UDP]
[HKLM\System\CurrentControlSet\services\sharedaccess\parameters\firewallpolicy\domainprofile\GloballyOpenPorts\List]|[2869:TCP]
[HKLM\System\CurrentControlSet\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]|[1900:UDP]
[HKLM\System\CurrentControlSet\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]|[2869:TCP]
[HKLM\System\CurrentControlSet\services\sharedaccess\parameters\firewallpolicy\standardprofile\GloballyOpenPorts\List]|[3389:TCP]
[HKCR\CLSID\{43969E3F-3E7C-4911-A8F1-79C6CA6AC731}]
[HKCR\CLSID\{4EC06F7F-2290-4D9E-8D24-54CE42766B04}]
[HKCR\CLSID\{938958E8-355C-49FF-92B0-53C1B87ACEA9}]
[HKCR\CLSID\{AFFE513B-69AD-4C97-A74F-95AB17C9D42C}]
[HKCR\Installer\Products\4EA42A62D9304AC4784BF238120634FF]
[HKCR\Installer\Products\4EA42A62D9304AC4784BF238120770FF]
List::
C:\WINDOWS\system32\AI_RecycleBin
command::
Reg ADD "HKLM\SYSTEM\CurrentControlSet\Services\sharedaccess\Parameters\FirewallPolicy\standardprofile\authorizedapplications\list" /v "C:\WINDOWS\system32\sessmgr.exe" /t REG_SZ /d "C:\WINDOWS\system32\sessmgr.exe:*:Enabled:@xpsp2res.dll,-22019"
File|Fold::
C:\Program Files\Mozilla Firefox\extensions\{CAFEEFAC-0016-0000-0043-ABCDEFFEDCBA}
C:\2e2c47746bcb31ce9d6ded12f30770
C:\89c46e1fa485350f70e8
C:\fac856887c32ab7fe3ff47
C:\Documents and Settings\Nec\Local Settings\Application Data\LzFEq5Qd4z9MOOO
C:\WINDOWS\system32\750820A2
Driver::
01741892
13488057
1881485DRV
33667871
37446140
37746337
43421192
43428528
519C55FDA903FA94
53853599
79300770
84691075
91729053
93349344
E1F81476
IBUPDATERSERVICE
PE3APJ8B
PF2APJ8B
SBKUPNT
Clean::
MBR::
Reboot::
Relance Pre_scan puis choisis l'option "Script"
une page va s'ouvrir
logiquement le texte que tu as sélectionné s'y trouve déjà  , donc tu fermes et le programme va travailler.
sinon colle-le (clic droit/coller ou ctrl+V) dans la page vierge.
puis onglet fichier => enregistrer (pas enregistrer sous...) , puis ferme le texte
des fenetres noires risquent de clignoter , c'est normal , c'est le programme qui travaille
poste Pre_Script.txt qui apparaitra sur le bureau en fin de travail
par hercules28
#2185
la maj kb955759 et revenu et toujours le meme probleme elle s'installe mais se fixe pas lol qué bordel!!!
#2186
Désinstalle la mise à  jour dans ajout et suppression s'il est présent, si non va voir dans: C\windows, repère le fichier $NtUninstall KB955759 , à  l'intérieur, clique sur spuninst pour le désinstaller, ensuite vide le dossier download, installe-le manuellement et vois que ca donne.
par hercules28
#2189
ca y est elle apparait dans ajout suppression programme mais c'est marqué cette mise a jour ne peut etre supprimée
  • 2
  • 3
  • 4
  • 5
  • 7
