Bonsoir
---\\ Logiciels de protection du systàƒÂ¨me
Kaspersky Anti-Virus 2012 v12.0.0.374 => Kaspersky Lab*
Malwarebytes Anti-Malware version 1.75.0.1300 => Malwarebytes Corporation*
Windows Defender W7 => Microsoft //
à désactiver (Kaspersky n'aime pas/conflits)
Adobe Flash Player 11 Plugin => Adobe Systems
Adobe Reader XI => Adobe Systems
Java 7 Update 25 => Oracle //
en 7u45 ,
sur le site officiel d'Oracle
Applique ce correctif =>
Ouvre le bloc-notes
Séléctionne et copie dedans le script
O3 - Toolbar: Google Toolbar - [HKLM]{2318C2B1-4965-11d4-9B18-009027A5CD4F} . (.Google Inc. - Google Toolbar.) -- C:\Program Files\Google\Google Toolbar\GoogleToolbar_32.dll
O4 - GS\Desktop [Aurifeille]: Search.lnk . (...) -- C:\ProgramData\DSearchLink\DSearchLink.exe (.not file.) => Toolbar.DeltaSearch
O16 - DPF: {1E54D648-B804-468d-BC78-4AFFED8E262F} (System Requirements Lab) - https://www.nvidia.com/content/DriverDow ... ab_nvd.cab => System Requirements Lab
O44 - LFC:[MD5.32FF93F17CA609D0C34D1E188BEF7351] - 15/11/2013 - 18:48:57 R--A- . (...) -- C:\Pre_Scan_15_11_2013_18_48_57.txt [16693] => gen-hackman Pre_Scan
C:\Users\Aurifeille\Desktop\ADOBE SOFTS INSTALL\Adobe Photoshop Elements\Keymaker-CORE\keygen.exe
[HKLM\Software\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{21111111-1111-1111-1111-110211181110}] => Infection PUP (PUP.CrossRider)
[HKLM\Software\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{11111111-1111-1111-1111-110211181110}] => Infection PUP (PUP.CrossRider)
[HKLM\Software\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{11111111-1111-1111-1111-110211181110}] => Infection PUP (PUP.CrossRider)
[HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{11111111-1111-1111-1111-110211181110}] => Infection PUP (PUP.CrossRider)
[HKLM\Software\Microsoft\Internet Explorer\Toolbar]:{2318C2B1-4965-11d4-9B18-009027A5CD4F} => Toolbar.Google
EmptyCLSID
Emptytemp
Double-clique sur le raccourci du programme "
ZHPFix" qui est sur ton bureau
Dans l'interface du logiciel qui s'est ouvert, clique sur "
Importer" pour coller le Script ZHPFix
Un avertissement s'affiche
Si le script est conforme
Clique sur le bouton
GO » pour lancer le nettoyage
Confirme ce nettoyage en cliquant sur "
OUI" dans les deux fenêtres suivantes
A l'issue un rapport
ZHPFix.txt s'affiche dans la zone de rapport de l'interface et dans le bloc note Windows
Le rapport est aussi sauvegardé sur le Bureau Windows et dans le dossier :
C\User\nomxxx\AppData\Roaming\ZHP\ZHPFix.txt
Reviens avec son rapport / STP
