- sam. 16 nov. 2013 22:47
#17194
Rapport de ZHPFix 2013.11.14.5 par Nicolas Coolman, Update du 14/11/2013
Fichier d'export Registre :
Run by hp at 16/11/2013 22:45:10
High Elevated Privileges : OK
Corbeille vidée (00mn 02s)
SUPPRIMà‰ Redémarrage: Memory Process: C:\Program Files (x86)\AskPartnerNetwork\Toolbar\Updater\TBNotifier.exe
SUPPRIMà‰ Redémarrage: Memory Process: C:\Program Files (x86)\AskPartnerNetwork\Toolbar\apnmcp.exe
SUPPRIMà‰: Memory Process: C:\Users\hp\AppData\Local\Temp\Extract.exe
SUPPRIMà‰: Memory Process: C:\Users\hp\AppData\Local\Temp\SHSetup.exe
SUPPRIMà‰: Memory Process: C:\Users\hp\AppData\Local\Temp\uninst1.exe
SUPPRIMà‰: [HKLM\SOFTWARE\Classes\CLSID\{41564952-412D-5637-00A7-7A786E7484D7}]
SUPPRIMà‰: [HKLM\SOFTWARE\Classes\CLSID\{724D43A0-0D85-11D4-9908-00400523E39A}]
SUPPRIMà‰: HKCU\Software\AskPartnerNetwork
SUPPRIMà‰:* HKLM\Software\AskPartnerNetwork
SUPPRIMà‰: [HKLM\Software\Classes\Installer\Products\\25946514D2147365007A7A857BC06000]
SUPPRIMà‰: [HKLM\Software\Classes\Installer\Features\25946514D2147365007A7A857BC06000]
SUPPRIMà‰: Service: APNMCP
SUPPRIMà‰:* HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UpgradeCodes\1C875DDE39636004CA8CDAEC335B4160
SUPPRIMà‰: HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{21111111-1111-1111-1111-110211181110}
SUPPRIMà‰: HKLM\Software\Wow6432Node\Google\Chrome\Extensions\aaaaacalgebmfelllfiaoknifldpngjh
SUPPRIMà‰:* HKLM\Software\Classes\CLSID\{11111111-1111-1111-1111-110311961182}
SUPPRIMà‰:* HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{11111111-1111-1111-1111-110311961182}
SUPPRIMà‰: HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Ext\PreApproved\{11111111-1111-1111-1111-110211181110}
SUPPRIMà‰: HKLM\Software\Wow6432Node\Microsoft\Internet Explorer\Low Rights\ElevationPolicy\{11111111-1111-1111-1111-110211181110}
SUPPRIMà‰:* HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\38D5CDD0A851B3940A43CC50ABBA251C
SUPPRIMà‰:* HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\AAC05EAA51DC78A41A1DCE3B31038584
SUPPRIMà‰:* HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\BA71D41F6CC0B6247B05D473850A8AEA
SUPPRIMà‰:* HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\CA0054A5AB3EFFE4CB5660E44A1E7DCC
SUPPRIMà‰: Toolbar: {41564952-412D-5637-00A7-7A786E7484D7}
SUPPRIMà‰: Toolbar: {7FEBEFE3-6B19-4349-98D2-FFB09D4B49CA}
SUPPRIMà‰: Toolbar: {724D43A0-0D85-11D4-9908-00400523E39A}
SUPPRIMà‰ RunValue: ApnTBMon
SUPPRIMà‰: TCP Query User{31D4A265-01E7-458C-81D0-996B2B1F675B}C:\users\hp\appdata\roaming\cacaoweb\cacaoweb.exe
SUPPRIMà‰ Folder Chrome: C:\Users\hp\AppData\Local\Google\Chrome\User Data\Default\Extensions\aaaaacalgebmfelllfiaoknifldpngjh
SUPPRIMà‰ Folder Chrome: C:\Users\hp\AppData\Local\Google\Chrome\User Data\Default\Extensions\pbpohikckhbcljgombipcdoinkaedlfa
SUPPRIMà‰: C:\Users\hp\AppData\Local\{D3481063-D4F3-468E-A224-129B745091CA}
SUPPRIMà‰S Temporaires Windows (235)
SUPPRIMà‰S Flash Cookies (0)
SUPPRIMà‰: c:\users\hp\appdata\local\google\chrome\user data\default\preferences
SUPPRIMà‰: c:\program files (x86)\askpartnernetwork\toolbar\updater\tbnotifier.exe
SUPPRIMà‰: C:\Windows\Installer\eeb7d.msi
SUPPRIMà‰S Temporaires Windows (1922) (849 403 875 octets)
5 : Processus mémoire
18 : Clés du Registre
5 : Valeurs du Registre
3 : Dossiers
5 : Fichiers
2 : Préférences navigateur
End of clean in 00mn 17s
C:\Users\hp\AppData\Roaming\ZHP\ZHPFix[R1].txt - 16/11/2013 22:45:12 [4019]
3 : Dossiers
5 : Fichiers
