virus qur clé usb Réparation PC
par mymy
#19997
voilà  le rapport :)
Rapport de ZHPFix 2013.12.1.2 par Nicolas Coolman, Update du 01/12/2013
Fichier d'export Registre :
Run by Jonathan at 1/12/2013 18:29:16
High Elevated Privileges : OK
Corbeille vidée (00mn 04s)
SUPPRIMà‰ Redémarrage: Memory Process: C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
SUPPRIMà‰ Redémarrage: Memory Process: C:\Program Files (x86)\Kaspersky Lab\Kaspersky Security Scan 2.0\kss.exe
SUPPRIMà‰: Memory Process: C:\Users\Jonathan\AppData\Local\Temp\flashmemory.exe
SUPPRIMà‰: [HKLM\SOFTWARE\Classes\CLSID\{2318C2B1-4965-11d4-9B18-009027A5CD4F}]
SUPPRIMà‰: [HKLM\SOFTWARE\Classes\CLSID\{318A227B-5E9F-45bd-8999-7F8F10CA4CF5}]
SUPPRIMà‰: HKCU\Software\cacaoweb
SUPPRIMà‰: SearchScopes :{0633EE93-D776-472f-A0FF-E1416B8B2E3A}
SUPPRIMà‰: Service: Partner Service
SUPPRIMà‰: Service: KSS
SUPPRIMà‰: HKLM\Software\Classes\AppID\{28A88B70-D874-4f73-BBBA-9B2B222FB7D6}
SUPPRIMà‰: HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{83ff80f4-8c74-4b80-b5ba-c8ddd434e5c4}
SUPPRIMà‰: HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{83ff80f4-8c74-4b80-b5ba-c8ddd434e5c4}
SUPPRIMà‰:* HKLM\Software\Classes\CLSID\{83ff80f4-8c74-4b80-b5ba-c8ddd434e5c4}
SUPPRIMà‰:* HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{83ff80f4-8c74-4b80-b5ba-c8ddd434e5c4}
SUPPRIMà‰: HKLM\Software\Classes\TypeLib\{86676e13-d6d8-4652-9fcf-f2047f1fb000}
SUPPRIMà‰: HKLM\Software\Classes\AppID\kt_bho_dll.dll
SUPPRIMà‰: HKLM\Software\Classes\kt_bho.kettlebho
SUPPRIMà‰: HKLM\Software\Classes\kt_bho.kettlebho.1
SUPPRIMà‰: HKLM\Software\Classes\protector_dll.protectorbho
SUPPRIMà‰: HKLM\Software\Classes\protector_dll.protectorbho.1
SUPPRIMà‰: Toolbar: {2318C2B1-4965-11d4-9B18-009027A5CD4F}
SUPPRIMà‰: Toolbar: {318A227B-5E9F-45bd-8999-7F8F10CA4CF5}
SUPPRIMà‰ RunValue: swg
SUPPRIMà‰ RunValue: KSS
SUPPRIMà‰: TCP Query User{012E46AE-0D56-4836-8646-6056385BA8A2}C:\users\jonathan\appdata\roaming\cacaoweb\cacaoweb.exe
SUPPRIMà‰: UDP Query User{190B6635-6D4D-4E82-8B48-CF51F621A9E8}C:\users\jonathan\appdata\roaming\cacaoweb\cacaoweb.exe
SUPPRIMà‰: C:\Users\Jonathan\AppData\Local\{53779098-3469-47BA-A912-30D0B7CBD06C}
SUPPRIMà‰: C:\Users\Jonathan\AppData\Local\{BEBF2026-E35F-4C2A-A69E-552874045F10}
SUPPRIMà‰: C:\Users\Jonathan\AppData\Local\{EB6AAF8B-FC4D-4F35-A2DE-C155B9B40E82}
SUPPRIMà‰S Temporaires Windows (41)
SUPPRIMà‰S Flash Cookies (0)
SUPPRIMà‰ Redémarrage: c:\program files (x86)\google\googletoolbarnotifier\googletoolbarnotifier.exe
SUPPRIMà‰: C:\Users\Jonathan\AppData\Local\Temp\isconfig.dat
SUPPRIMà‰S Temporaires Windows (139) (222.806.026 octets)
3 : Processus mémoire
17 : Clés du Registre
6 : Valeurs du Registre
5 : Dossiers
4 : Fichiers
End of clean in 05mn 28s
C:\Users\Jonathan\AppData\Roaming\ZHP\ZHPFix[R1].txt - 1/12/2013 18:29:20 [3192]
par Evasion60
#20002
:hello: Re Mymy
Ok avec le correctif sur la seconde machine ;)
Par contre, je suis allé un peu vite :(
Tu vas me passer USBFix aussi sur cette machine (désolé de cet oublie)
Donc mode Scan et Suppression
Poste les deux rapports / STP
par mymy
#20204
Bonjour , désolée mais je n'arrive pas à  télécharger usb fix Windows me le refuse :s:s
par mymy
#20215
Voici les rapports :)
############################## | UsbFix V 7.152 | [Suppression]
Utilisateur: Jonathan (Administrateur) # JONATHAN-PC
Mis à  jour le 20/11/2013 par El Desaparecido - Team SosVirus
Lancé à  20:23:16 | 02/12/2013
PC: Packard Bell (EG43M)
CPU: Intel(R) Core(TM)2 Quad CPU Q8300 @ 2.50GHz
RAM -> [Total : 6143 | Free : 4627]
WB: Windows Internet Explorer : 11.0.9600.16428
WB: Google Chrome : 31.0.1650.57
C:\ (%systemdrive%) -> Disque fixe # 458 Go (235 Go libre(s) - 51%) [Packard Bell] # NTFS
D:\ -> Disque fixe # 458 Go (454 Go libre(s) - 99%) [DATA] # NTFS
E:\ -> CD-ROM
Stoppé! C:\Program Files\AVAST Software\Avast\AvastSvc.exe (ID: 1340 |ParentID: 648)
Stoppé! C:\Program Files\AVAST Software\Avast\AvastUI.exe (ID: 4472 |ParentID: 4308)
Stoppé! C:\Windows\explorer.exe (ID: 2004 |ParentID: 736)
Stoppé! C:\Windows\System32\rundll32.exe (ID: 5868 |ParentID: 824)
Stoppé! C:\Windows\System32\WUDFHost.exe (ID: 2516 |ParentID: 416)
Stoppé! C:\Windows\system32\SearchIndexer.exe (ID: 5700 |ParentID: 648)
Stoppé! C:\Program Files\Windows Media Player\wmpnetwk.exe (ID: 1016 |ParentID: 648)
Stoppé! C:\Windows\system32\DllHost.exe (ID: 1944 |ParentID: 824)
Stoppé! C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE (ID: 2080 |ParentID: 648)
Stoppé! C:\Windows\System32\spoolsv.exe (ID: 3948 |ParentID: 648)
Stoppé! C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe (ID: 5572 |ParentID: 648)
Stoppé! C:\Windows\system32\SearchProtocolHost.exe (ID: 4988 |ParentID: 5700)
Stoppé! C:\Windows\system32\SearchFilterHost.exe (ID: 1960 |ParentID: 5700)
Stoppé! C:\Program Files\Internet Explorer\iexplore.exe (ID: 3856 |ParentID: 5188)
Stoppé! C:\Program Files (x86)\Internet Explorer\IEXPLORE.EXE (ID: 1768 |ParentID: 3856)
04 - HKLM\SOFTWARE | Run : [Packard Bell Photo Frame] - C:\Program Files (x86)\Packard Bell Photo Frame\ButtonMonitor.exe -A
04 - HKLM\SOFTWARE | Run : [avast] - "C:\Program Files\AVAST Software\Avast\avastUI.exe" /nogui
04 - HKLM\SOFTWARE | Run : [beid] - "C:\Program Files (x86)\Belgium Identity Card\beid35gui.exe" /startup
04 - HKLM\SOFTWARE | Run : [APSDaemon] - "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
04 - HKLM\SOFTWARE | Run : [20131121] - C:\Program Files\AVAST Software\Avast\setup\emupdate\36212c1a-ae46-4c17-9f18-c64105ba4bff.exe /check
04 - HKLM\SOFTWARE | Run : [iTunesHelper] - "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [Packard Bell Photo Frame] - C:\Program Files (x86)\Packard Bell Photo Frame\ButtonMonitor.exe -A
04 - HKLM\SOFTWARE\wow6432Node | Run : [avast] - "C:\Program Files\AVAST Software\Avast\avastUI.exe" /nogui
04 - HKLM\SOFTWARE\wow6432Node | Run : [beid] - "C:\Program Files (x86)\Belgium Identity Card\beid35gui.exe" /startup
04 - HKLM\SOFTWARE\wow6432Node | Run : [APSDaemon] - "C:\Program Files (x86)\Common Files\Apple\Apple Application Support\APSDaemon.exe"
04 - HKLM\SOFTWARE\wow6432Node | Run : [20131121] - C:\Program Files\AVAST Software\Avast\setup\emupdate\36212c1a-ae46-4c17-9f18-c64105ba4bff.exe /check
04 - HKLM\SOFTWARE\wow6432Node | Run : [iTunesHelper] - "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
04 - HKU\S-1-5-21-4182467622-1467253440-665198720-1001\SOFTWARE | Run : [EADM] - "C:\Program Files (x86)\Origin\Origin.exe" -AutoStart
04 - HKU\S-1-5-21-4182467622-1467253440-665198720-1001\SOFTWARE | Run : [Steam] - "C:\Program Files (x86)\Steam\Steam.exe" -silent
04 - HKU\S-1-5-21-4182467622-1467253440-665198720-1001\SOFTWARE | Run : [iCloudServices] - C:\Program Files (x86)\Common Files\Apple\Internet Services\iCloudServices.exe
04 - HKU\S-1-5-21-4182467622-1467253440-665198720-1001\SOFTWARE | Run : [ApplePhotoStreams] - C:\Program Files (x86)\Common Files\Apple\Internet Services\ApplePhotoStreams.exe
04 - HKU\S-1-5-21-4182467622-1467253440-665198720-1001\SOFTWARE | Run : [com.apple.dav.bookmarks.daemon] - C:\Program Files (x86)\Common Files\Apple\Internet Services\BookmarkDAV_client.exe
04 - HKU\S-1-5-21-4182467622-1467253440-665198720-1001\SOFTWARE | Run : [AppleIEDAV] - C:\Program Files (x86)\Common Files\Apple\Internet Services\AppleIEDAV.exe
04 - HKU\S-1-5-21-4182467622-1467253440-665198720-1001\SOFTWARE | Run : [1L8prJDN] - wscript.exe //B "C:\Users\Jonathan\AppData\Local\Temp\1L8prJDN.vbs"
04 - HKU\S-1-5-21-4182467622-1467253440-665198720-1001\SOFTWARE | Run : [WxEduNKr] - wscript.exe //B "C:\Users\Jonathan\AppData\Local\Temp\WxEduNKr.vbs"
04 - HKU\S-1-5-21-4182467622-1467253440-665198720-1001\SOFTWARE | Run : [A7KGEquN] - wscript.exe //B "C:\Users\Jonathan\AppData\Local\Temp\A7KGEquN.vbs"
04 - HKU\S-1-5-21-4182467622-1467253440-665198720-1001\SOFTWARE | Run : [iTunesHelper] - wscript.exe //B "C:\Users\Jonathan\AppData\Local\Temp\iTunesHelper.vbe"
04 - HKU\S-1-5-18\SOFTWARE | RunOnce : [SPReview] - "C:\Windows\System32\SPReview\SPReview.exe" /sp:1 /errorfwlink:"https://go.microsoft.com/fwlink/?LinkID=122915" /build:7601
Supprimé! C:\Users\Jonathan\AppData\Roaming\03120000\ak.tmp
Supprimé! C:\Users\Jonathan\AppData\Roaming\04100000\ak.tmp
Supprimé! C:\Users\Jonathan\AppData\Roaming\04160000\ak.tmp
Supprimé! C:\Users\Public\4z.VBE
Supprimé! C:\Users\Public\4z1z.VBE
Supprimé! C:\Users\Public\4zz.VBE
Supprimé! C:\Users\Public\7z.VBE
Supprimé! C:\Users\Public\7z1z.VBE
Supprimé! C:\Users\Public\7zz.VBE
Supprimé! C:\Users\Public\9eimmD.vbe
Supprimé! C:\Users\Public\9eizmmD.vbe
Supprimé! C:\Users\Public\9stiemD.VBE
Supprimé! C:\Users\Public\9stziemD.VBE
Supprimé! C:\Users\Jonathan\AppData\Roaming\Public
Supprimé! C:\Users\Jonathan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\trz3B0F.tmp
Supprimé! C:\Users\Jonathan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\trzEB6B.tmp
Md5 : 6FCFD4C48E8B83F48ACA133F1348DD46 -> C:\Users\Public\4z.VBE
Md5 : F0070AAFC90FE78EFACE902CB233D329 -> C:\Users\Public\4z1z.VBE
Md5 : 4915B7758A2AF193B001A4B42CD42CB5 -> C:\Users\Public\4zz.VBE
Md5 : 6FCFD4C48E8B83F48ACA133F1348DD46 -> C:\Users\Public\7z.VBE
Md5 : F0070AAFC90FE78EFACE902CB233D329 -> C:\Users\Public\7z1z.VBE
Md5 : 4915B7758A2AF193B001A4B42CD42CB5 -> C:\Users\Public\7zz.VBE
Md5 : C0A7FD989BE820BCB3AD55D53C826308 -> C:\Users\Public\9eimmD.vbe
Md5 : 9CE0C4ECF33A551D333BC9C8293B8A48 -> C:\Users\Public\9eizmmD.vbe
Md5 : C0A7FD989BE820BCB3AD55D53C826308 -> C:\Users\Public\9stiemD.VBE
Md5 : 9CE0C4ECF33A551D333BC9C8293B8A48 -> C:\Users\Public\9stziemD.VBE
Supprimé! HKCU\Software\à€ classé
Supprimé! HKCU\Software\HS
Réparé ! HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer|NoActiveDesktop -> 0
Réparé ! HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer|NoActiveDesktopChanges -> 0
Supprimé! HKU\S-1-5-21-4182467622-1467253440-665198720-1001\Software\.\.\.\.\Mountpoints2\F
Supprimé! HKU\S-1-5-21-4182467622-1467253440-665198720-1001\Software\.\.\.\.\Mountpoints2\{a0d256b4-28ce-11e3-ad90-0025114a3520}
[11/08/2013 - 19:44:08 | SHD ] C:\$Recycle.Bin
[28/08/2009 - 05:36:44 | RASH | 8192] C:\BOOTSECT.BAK
[14/05/2013 - 18:27:29 | D ] C:\drivers
[02/12/2013 - 07:20:52 | ASH | 4831191040] C:\hiberfil.sys
[28/08/2009 - 04:43:04 | D ] C:\Intel
[28/08/2009 - 05:04:15 | RHD ] C:\MSOCache
[26/03/2013 - 22:16:07 | D ] C:\NVIDIA
[26/03/2013 - 22:03:12 | D ] C:\OEM
[02/12/2013 - 07:20:58 | ASH | 6441590784] C:\pagefile.sys
[01/12/2013 - 17:22:41 | N | 512] C:\PhysicalDisk0_MBR.bin
[30/11/2013 - 19:55:41 | D ] C:\Program Files
[01/12/2013 - 17:15:50 | D ] C:\Program Files (x86)
[01/12/2013 - 18:23:54 | HD ] C:\ProgramData
[26/03/2013 - 21:38:37 | SHD ] C:\Recovery
[26/03/2013 - 19:37:01 | N | 2035] C:\RHDSetup.log
[30/11/2013 - 18:47:53 | SHD ] C:\System Volume Information
[02/12/2013 - 20:24:08 | D ] C:\UsbFix
[02/12/2013 - 20:24:22 | A | 9942] C:\UsbFix [Clean 2] JONATHAN-PC.txt
[02/12/2013 - 20:21:18 | N | 14216] C:\UsbFix [Scan 1] JONATHAN-PC.txt
[26/03/2013 - 22:19:36 | RD ] C:\Users
[26/11/2013 - 03:01:08 | D ] C:\Windows
[26/03/2013 - 21:41:13 | SHD ] D:\$RECYCLE.BIN
[03/10/2012 - 21:14:21 | D ] D:\Emilie PC
[07/11/2007 - 08:00:40 | N | 17734] D:\eula.1028.txt
[07/11/2007 - 08:00:40 | N | 17734] D:\eula.1031.txt
[07/11/2007 - 08:00:40 | N | 10134] D:\eula.1033.txt
[07/11/2007 - 08:00:40 | N | 17734] D:\eula.1036.txt
[07/11/2007 - 08:00:40 | N | 17734] D:\eula.1040.txt
[07/11/2007 - 08:00:40 | N | 118] D:\eula.1041.txt
[07/11/2007 - 08:00:40 | N | 17734] D:\eula.1042.txt
[07/11/2007 - 08:00:40 | N | 17734] D:\eula.2052.txt
[07/11/2007 - 08:00:40 | N | 17734] D:\eula.3082.txt
[07/11/2007 - 08:00:40 | N | 1110] D:\globdata.ini
[07/11/2007 - 08:03:18 | N | 562688] D:\install.exe
[07/11/2007 - 08:00:40 | N | 843] D:\install.ini
[07/11/2007 - 08:03:18 | N | 76304] D:\install.res.1028.dll
[07/11/2007 - 08:03:18 | N | 96272] D:\install.res.1031.dll
[07/11/2007 - 08:03:18 | N | 91152] D:\install.res.1033.dll
[07/11/2007 - 08:03:18 | N | 97296] D:\install.res.1036.dll
[07/11/2007 - 08:03:18 | N | 95248] D:\install.res.1040.dll
[07/11/2007 - 08:03:18 | N | 81424] D:\install.res.1041.dll
[07/11/2007 - 08:03:18 | N | 79888] D:\install.res.1042.dll
[07/11/2007 - 08:03:18 | N | 75792] D:\install.res.2052.dll
[07/11/2007 - 08:03:18 | N | 96272] D:\install.res.3082.dll
[09/11/2010 - 20:36:45 | D ] D:\le chart
[02/12/2006 - 08:37:14 | N | 904704] D:\msdia80.dll
[14/03/2010 - 18:08:20 | RHD ] D:\MSOCache
[09/11/2010 - 20:44:12 | D ] D:\musique
[09/11/2010 - 20:48:15 | D ] D:\photo
[30/11/2010 - 15:55:00 | SHD ] D:\System Volume Information
[07/11/2007 - 08:00:40 | N | 5686] D:\vcredist.bmp
[07/11/2007 - 08:09:22 | N | 1442522] D:\VC_RED.cab
[07/11/2007 - 08:12:28 | N | 232960] D:\VC_RED.MSI
UsbFix a détecté sur votre ordinateur, une infection qui dispose d'une fonction de Keylogger.
Après désinfection par UsbFix, veuillez modifier tous vos mots de passe.
Si vous avez effectué des achats sur internet,
veuillez contacter votre banque afin d'envisager une opposition sur votre carte bancaire.
############################## | UsbFix V 7.152 | [Recherche]
Lancé à  20:17:55 | 02/12/2013
RAM -> [Total : 6143 | Free : 4182]
E:\ -> CD-ROM
C:\Windows\system32\csrss.exe (ID: 528 |ParentID: 444)
C:\Windows\system32\wininit.exe (ID: 588 |ParentID: 444)
C:\Windows\system32\csrss.exe (ID: 608 |ParentID: 596)
C:\Windows\system32\services.exe (ID: 648 |ParentID: 588)
C:\Windows\system32\lsass.exe (ID: 668 |ParentID: 588)
C:\Windows\system32\lsm.exe (ID: 676 |ParentID: 588)
C:\Windows\system32\winlogon.exe (ID: 736 |ParentID: 596)
C:\Windows\system32\svchost.exe (ID: 824 |ParentID: 648)
C:\Windows\system32\nvvsvc.exe (ID: 908 |ParentID: 648)
C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe (ID: 932 |ParentID: 648)
C:\Windows\system32\svchost.exe (ID: 976 |ParentID: 648)
C:\Windows\System32\svchost.exe (ID: 304 |ParentID: 648)
C:\Windows\System32\svchost.exe (ID: 416 |ParentID: 648)
C:\Windows\system32\svchost.exe (ID: 596 |ParentID: 648)
C:\Windows\system32\svchost.exe (ID: 992 |ParentID: 648)
C:\Windows\system32\svchost.exe (ID: 1148 |ParentID: 648)
C:\Windows\system32\svchost.exe (ID: 1252 |ParentID: 648)
C:\Program Files\NVIDIA Corporation\Display\nvxdsync.exe (ID: 1348 |ParentID: 908)
C:\Windows\system32\nvvsvc.exe (ID: 1356 |ParentID: 908)
C:\Windows\System32\spoolsv.exe (ID: 1644 |ParentID: 648)
C:\Windows\system32\svchost.exe (ID: 1676 |ParentID: 648)
C:\Windows\system32\svchost.exe (ID: 1708 |ParentID: 648)
C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe (ID: 1828 |ParentID: 648)
C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe (ID: 1868 |ParentID: 648)
C:\Program Files\Bonjour\mDNSResponder.exe (ID: 1948 |ParentID: 648)
C:\Windows\system32\Dwm.exe (ID: 1404 |ParentID: 416)
C:\Windows\system32\taskhost.exe (ID: 2008 |ParentID: 648)
C:\Windows\Explorer.EXE (ID: 1424 |ParentID: 1416)
C:\Program Files (x86)\Packard Bell\Registration\GregHSRW.exe (ID: 2072 |ParentID: 648)
C:\Windows\system32\svchost.exe (ID: 2200 |ParentID: 648)
C:\Program Files\Packard Bell\Packard Bell Updater\UpdaterService.exe (ID: 2636 |ParentID: 648)
C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSVC.EXE (ID: 2680 |ParentID: 648)
C:\Windows\system32\svchost.exe (ID: 2384 |ParentID: 648)
C:\Windows\System32\WUDFHost.exe (ID: 2520 |ParentID: 416)
C:\Program Files\Common Files\Microsoft Shared\Windows Live\WLIDSvcM.exe (ID: 2668 |ParentID: 2680)
C:\Windows\system32\SearchIndexer.exe (ID: 3480 |ParentID: 648)
C:\Program Files\Windows Media Player\wmpnetwk.exe (ID: 3740 |ParentID: 648)
C:\Program Files\Realtek\Audio\HDA\RAVCpl64.exe (ID: 3904 |ParentID: 1424)
C:\Program Files\NVIDIA Corporation\Display\nvtray.exe (ID: 296 |ParentID: 1348)
C:\Windows\System32\svchost.exe (ID: 3808 |ParentID: 648)
C:\Program Files\Logitech Gaming Software\LCore.exe (ID: 4108 |ParentID: 1424)
C:\Program Files (x86)\Origin\Origin.exe (ID: 4176 |ParentID: 1424)
C:\Program Files (x86)\Steam\Steam.exe (ID: 4188 |ParentID: 1424)
C:\Program Files (x86)\Common Files\Apple\Internet Services\iCloudServices.exe (ID: 4196 |ParentID: 1424)
C:\Program Files (x86)\Common Files\Apple\Internet Services\ApplePhotoStreams.exe (ID: 4204 |ParentID: 1424)
C:\Program Files (x86)\Packard Bell Photo Frame\ButtonMonitor.exe (ID: 4464 |ParentID: 4308)
C:\Windows\system32\DllHost.exe (ID: 4488 |ParentID: 824)
C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe (ID: 4508 |ParentID: 4308)
C:\Program Files (x86)\iTunes\iTunesHelper.exe (ID: 4524 |ParentID: 4308)
C:\Program Files (x86)\Common Files\Apple\Internet Services\APSDaemon.exe (ID: 4816 |ParentID: 824)
C:\Program Files\iPod\bin\iPodService.exe (ID: 4944 |ParentID: 648)
C:\Program Files\Logitech Gaming Software\Applets\LCDRSS.exe (ID: 3168 |ParentID: 4108)
C:\Program Files\Logitech Gaming Software\Applets\LCDClock.exe (ID: 1600 |ParentID: 4108)
C:\Program Files\Logitech Gaming Software\Applets\LCDPop3.exe (ID: 3080 |ParentID: 4108)
C:\Program Files\Logitech Gaming Software\Applets\LCDMedia.exe (ID: 4400 |ParentID: 4108)
C:\Program Files\Logitech Gaming Software\Applets\LCDCountdown.exe (ID: 4496 |ParentID: 4108)
C:\Program Files (x86)\Common Files\Steam\SteamService.exe (ID: 916 |ParentID: 648)
C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Update Core\daemonu.exe (ID: 5260 |ParentID: 648)
C:\Windows\System32\svchost.exe (ID: 5340 |ParentID: 648)
C:\Program Files\Internet Explorer\iexplore.exe (ID: 5968 |ParentID: 1424)
C:\Program Files (x86)\Internet Explorer\IEXPLORE.EXE (ID: 6020 |ParentID: 5968)
C:\Program Files (x86)\Common Files\Apple\Internet Services\AppleIEDAV.exe (ID: 5468 |ParentID: 6132)
C:\Program Files\Internet Explorer\iexplore.exe (ID: 6064 |ParentID: 1424)
C:\Program Files (x86)\Internet Explorer\IEXPLORE.EXE (ID: 5632 |ParentID: 6064)
C:\Windows\system32\Macromed\Flash\FlashUtil64_11_9_900_117_ActiveX.exe (ID: 5316 |ParentID: 824)
C:\Windows\System32\MsSpellCheckingFacility.exe (ID: 2220 |ParentID: 824)
C:\Windows\system32\SearchProtocolHost.exe (ID: 1304 |ParentID: 3480)
C:\Windows\system32\SearchFilterHost.exe (ID: 5384 |ParentID: 3480)
C:\Program Files (x86)\Internet Explorer\IEXPLORE.EXE (ID: 4500 |ParentID: 6064)
C:\Windows\system32\SearchProtocolHost.exe (ID: 2988 |ParentID: 3480)
C:\UsbFix\Go.exe (ID: 6016 |ParentID: 5440)
C:\Windows\system32\wbem\wmiprvse.exe (ID: 3996 |ParentID: 824)
Présent! C:\Users\Jonathan\AppData\Roaming\03120000\ak.tmp
Présent! C:\Users\Jonathan\AppData\Roaming\04100000\ak.tmp
Présent! C:\Users\Jonathan\AppData\Roaming\04160000\ak.tmp
Présent! C:\Users\Public\4z.VBE
Présent! C:\Users\Public\4z1z.VBE
Présent! C:\Users\Public\4zz.VBE
Présent! C:\Users\Public\7z.VBE
Présent! C:\Users\Public\7z1z.VBE
Présent! C:\Users\Public\7zz.VBE
Présent! C:\Users\Public\9eimmD.vbe
Présent! C:\Users\Public\9eizmmD.vbe
Présent! C:\Users\Public\9stiemD.VBE
Présent! C:\Users\Public\9stziemD.VBE
Présent! C:\Users\Jonathan\AppData\Roaming\Public
Présent! C:\Users\Jonathan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\trz3B0F.tmp
Présent! C:\Users\Jonathan\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\trzEB6B.tmp
Présent! Md5 : 6FCFD4C48E8B83F48ACA133F1348DD46 -> C:\Users\Public\4z.VBE
Présent! Md5 : F0070AAFC90FE78EFACE902CB233D329 -> C:\Users\Public\4z1z.VBE
Présent! Md5 : 4915B7758A2AF193B001A4B42CD42CB5 -> C:\Users\Public\4zz.VBE
Présent! Md5 : 6FCFD4C48E8B83F48ACA133F1348DD46 -> C:\Users\Public\7z.VBE
Présent! Md5 : F0070AAFC90FE78EFACE902CB233D329 -> C:\Users\Public\7z1z.VBE
Présent! Md5 : 4915B7758A2AF193B001A4B42CD42CB5 -> C:\Users\Public\7zz.VBE
Présent! Md5 : C0A7FD989BE820BCB3AD55D53C826308 -> C:\Users\Public\9eimmD.vbe
Présent! Md5 : 9CE0C4ECF33A551D333BC9C8293B8A48 -> C:\Users\Public\9eizmmD.vbe
Présent! Md5 : C0A7FD989BE820BCB3AD55D53C826308 -> C:\Users\Public\9stiemD.VBE
Présent! Md5 : 9CE0C4ECF33A551D333BC9C8293B8A48 -> C:\Users\Public\9stziemD.VBE
Présent! HKCU\Software\à€ classé
Présent! HKCU\Software\HS
Présent! HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer|NoActiveDesktop -> 1
Présent! HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer|NoActiveDesktopChanges -> 1
par Evasion60
#20276
:hello: Bonsoir Mymy
Ok, tes deux PC sont nettoyés et tes cles USB vaccinées ;)
Sur les deux machines (Impératif) , il faut que nous supprimions Outils et Rapports =>
1A/
  • Clique sur Start
  • Clique sur Exit
Supprimé : C:\ZHP
########## - EOF - ##########
Bonne continuation, et bon surf ! :alcool: :)
par mymy
#20373
Bonjour , par contre j'ai du retourner à  la photocopieuse et du coup je pense que mes clés usb sont surement de nouveau infectée :s:s je ne les ai branchée sur aucun de mes 2 ordi :) je dois lancer usbFix et vacciner ??? Merci
par mymy
#20377
# DelFix v10.6 - Rapport créé le 03/12/2013 à  17:22:12
# Nom d'utilisateur : Jonathan - JONATHAN-PC
Supprimé : C:\USBFix
Supprimé : C:\Users\Jonathan\AppData\Roaming\ZHP
Supprimé : C:\UsbFix [Clean 2] JONATHAN-PC.txt
Supprimé : C:\UsbFix [Scan 1] JONATHAN-PC.txt
Supprimé : C:\UsbFix [Scan 2] JONATHAN-PC.txt
Supprimé : C:\UsbFix [Scan 3] JONATHAN-PC.txt
Supprimé : C:\UsbFix [Scan 4] JONATHAN-PC.txt
Supprimé : C:\UsbFix [Scan 5] JONATHAN-PC.txt
Supprimé : C:\Users\Jonathan\Desktop\TFC.exe
Supprimé : C:\Users\Jonathan\Desktop\UsbFix Faire un Don.lnk
Supprimé : C:\Users\Jonathan\Desktop\usbfix0.exe
Supprimé : C:\Users\Jonathan\Desktop\ZHPDiag.lnk
Supprimé : C:\Users\Jonathan\Desktop\ZHPDiag.txt
Supprimé : C:\Users\Jonathan\Desktop\ZHPFix.lnk
Supprimé : C:\Users\Jonathan\Desktop\ZHPFixReport.txt
Supprimé : RP #100 [Windows Update | 11/13/2013 02:00:19]
Supprimé : RP #101 [Windows Update | 11/19/2013 07:42:33]
Supprimé : RP #102 [Installation du package de pilotes : TAP-Windows Provider V9 Cartes réseau | 11/19/2013 17:09:14]
Supprimé : RP #103 [Windows Update | 11/22/2013 12:15:22]
Supprimé : RP #104 [Windows Update | 11/26/2013 02:00:16]
Supprimé : RP #105 [Windows Update | 11/30/2013 17:16:17]
Voilà  un rapport
par mymy
#20380
# DelFix v10.6 - Rapport créé le 03/12/2013 à  17:30:32
# Nom d'utilisateur : emilie - EMILIE
Supprimé : C:\AdwCleaner
Supprimé : C:\Users\emilie\AppData\Roaming\ZHP
Supprimé : C:\Users\emilie\Desktop\TFC.exe
Supprimé : C:\Users\emilie\Desktop\TFC.exe.txu89sz.partial
Supprimé : C:\Users\emilie\Desktop\ZHPDiag2.exe
Supprimé : RP #15 [Point de contrôle planifié | 11/16/2013 11:54:08]
Supprimé : RP #16 [Installed AVG 2014 | 11/27/2013 19:54:30]
Supprimé : RP #17 [Installed AVG 2014 | 11/27/2013 19:55:43]
Voilà  le deuxième rapport merci beaucoup :):) en fait j'ai encore une petite question pour l'instant j'ai Norton , Avast et AVG comme antivirus . Y a t'il meilleur ??? merci
par Evasion60
#20385
:hello: Bonjour
... par contre j'ai du retourner à  la photocopieuse et du coup je pense que mes clés usb sont surement de nouveau infectée ...
/!\ Moi, la seule clé USB que j'ai vu dans tes logs est vaccinée (Volume E:\ )
Si tu n'as pas suivie dès le départ, l'aide avec USBfix, il est noté de "Brancher tous vos supports USB, sans les ouvrir" !
Et si tu as branché une autre clé USB que j'ai pas vu, bien j'ai perdu mon temps :(
... en fait j'ai encore une petite question pour l'instant j'ai Norton , Avast et AVG comme antivirus ...
Heu, là  tu fais ta blonde mdr
Aucune trace de Norton ou AVG
Juste le scanner en ligne => Kaspersky !
PC n°1 / Antivirus installé - Actif =>
Avast
PC n°2 / Antivirus installé - Actif =>
Avast
Bonne continuation :)
